Printable Version of Topic
914World.com _ FS/WTB: 914 Parts _ FS: Billet Tuna Can - NEW!
Posted by: 914werke Dec 14 2019, 07:38 PM
Here is a solution for oil starvation when driving your 914/4 in the manner it was designed!!
Highly recommended for ANY 914, street or tracked.
Simple install.
Available https://914werke.com/shop?olsPage=products%2Foil-temperature-sender & in the http://www.914world.com/bbs2/index.php?s=&showtopic=342241&view=findpost&p=2769866 section
Posted by: CHIZ 914 Dec 16 2019, 11:14 AM
Put me down for one
Thanks Rich!
Posted by: 914werke Feb 14 2020, 10:59 AM
[attachmentid=730326]Attached Image
Posted by: second wind Apr 2 2020, 09:37 PM
Hello there.....is it wrong thinking on my part that this will somehow get hit since it is lower that the stock set-up? I like the idea of more oil and curing the starvation of oil issue which I know nothing about. Please share a little more of why this is a good idea. Thank you very much.
gg
Posted by: 914werke Apr 2 2020, 10:39 PM
Its a common concern but in reality the sump once installed is no lower than the engine mount bar. If you are dragging the sump on anything, there is something else going on ~
Its purpose it to MAINTAIN oil pressure.
The 914 was designed to be capable of navigating curvy roads at high rates of speed and (with the right tires) + G-force's.
The result of which is to cause the oil in the bottom of the engine to slosh away from the pickup. By extending the PU into a small oil reservoir at the lowest point of the engine, that should never occur.
Posted by: pete-stevers Jun 25 2020, 08:09 PM
Hey Rich I need to put an order together for you!
Posted by: drem914 Jun 25 2020, 09:33 PM
Do these leak any less than the stock sump cover? Any special consideration need to be done when installing or extra gaskets required?
Posted by: 914werke Jun 25 2020, 10:33 PM
QUOTE(pete-stevers @ Jun 25 2020, 07:09 PM) *
Posted by: 914werke Jun 25 2020, 10:41 PM
QUOTE(drem914 @ Jun 25 2020, 08:33 PM) *
Typically the stock sump cover isnt an area I see a lot of leaking. confused24.gif
Unless of course your sump mount boss had been over torqued & isnt holding?
The cap nut seal is the only other area I can see leaking, it is replaced with an
tapered female bolt.
No extra gaskets or special prep is necessary unless you plan on running it with the screen. smile.gif
Posted by: drem914 Jun 26 2020, 09:47 PM
Just put in an order. I think you had sump extension instructions posted somewhere?
Posted by: 914werke Jun 27 2020, 12:25 AM
QUOTE(drem914 @ Jun 26 2020, 08:47 PM) *
You will receive a copy with the order but I also have it posted on the downloads section
on https://914werke.com/home smile.gif
Posted by: Tdskip Aug 11 2020, 01:42 PM
@http://www.914world.com/bbs2/index.php?showuser=453 - Rich, are these steel or aluminum? When you go to order it shows a "Raw" as to the finish but the pictures show metal or black finish.
Posted by: 914werke Aug 11 2020, 02:32 PM
QUOTE(Tdskip @ Aug 11 2020, 12:42 PM) *
Initially I offered both black & raw (or Alum.) finish.. but no one wanted the black so I made that a special order option.
Posted by: RolinkHaus Oct 14 2020, 05:11 AM
I will take one too, paypal ok
Posted by: 914werke Oct 14 2020, 11:17 AM
QUOTE(RolinkHaus @ Oct 14 2020, 04:11 AM) *
PM sent
Posted by: drem914 Apr 10 2021, 01:55 PM
QUOTE(914werke @ Jun 25 2020, 09:41 PM) *
@http://www.914world.com/bbs2/index.php?showuser=453 Getting ready to install but had a couple questions:
1. Is there any added benefit to running the screen with the extend sump?
2. If the screen is used can I use an RTV to connect or should it be tack welded or soldered instead?
Posted by: 914werke Apr 10 2021, 03:29 PM
Given that the screen will only stop rather large pieces of debris, the reality is at that point you recognize its catching stuff,
My belief is the screen is a hold over from the T1 design w/o a spin on filter.
So no its not necessary.
But.. if you want you use it, its not that hard.
1st - you need a third sealing ring to sandwich the screen flange between the sump mating surface & the cover.
2nd - you need to ream the hole in the thin alum. on the bottom of the screen that is only as large as the M6(?) sump stud, to a hole that will fit the female securing stud .. snugly. Go slow & work up to your fit. If you just hit it with a drill bit you may not like the results BTDT.
Last - I also used a file & opened up the slots on the base to allow a bit more flow, no real evidence that it is necessary it just made me feel better.
Posted by: drem914 Apr 11 2021, 11:56 AM
Thanks. What "sealant" should be used, as noted in your printed instructions, to connect the extender collar?
Posted by: FlacaProductions Apr 11 2021, 12:12 PM
Permatex Motoseal 1 or Honda/Yamabond - same stuff, I believe.
Remember - the oil sump plate is 9 ft/lbs which is 108 inch/lbs...not a pound more.
This may help:
http://www.914world.com/bbs2/index.php?act=Attach&type=post&id=716717
or this - long thread but this will get you in there:
http://www.914world.com/bbs2/index.php?showtopic=203236&hl=tuna&st=100
If you search "tuna" it should yield a lot of threads.
Posted by: 914werke May 17 2021, 08:44 PM
Posted by: 914werke Jan 3 2022, 04:42 PM
Posted by: 914werke Sep 26 2022, 05:52 PM
So a few folks have asked for more detailed instructions than the one page install sheet provided. biggrin.gif
Rather than create the next War & Peace I figure a few photo's cant hurt happy11.gif
Below is the actual sump removed from the case (not necessary for installation)
This way you will more clearly see the Pick-up tube, which is extended with a piece in the kit.
The issue is that that tube is a stamped part that can need a bit of love to allow the fit of the extension.
Ive found that the application of some slight filing or sanding at the bottom mil or two of that tube will allow the tight fit necessary.
Posted by: FlacaProductions May 19 2023, 11:18 AM
It's a nice piece, Rich - finally got mine on. Not a drop. Attached Image
Posted by: 914werke May 19 2023, 01:10 PM
Posted by: second wind Jun 5 2023, 09:36 PM
How much additional oil does this part provide? Thank you very much.
gg
Posted by: 914werke Jun 6 2023, 10:48 AM
QUOTE(second wind @ Jun 5 2023, 08:36 PM) *
gg
Probably 300ml +/- but Ive never actually measured.
Posted by: burton73 Jul 29 2023, 11:22 AM
QUOTE(914werke @ Jul 29 2023, 09:05 AM) *
I this backordered. We need one now or very soon
Bob B.
burton73
Posted by: 914werke Jul 30 2023, 12:25 PM
Im picking up parts from the shop this week
Posted by: 914werke Jul 31 2023, 08:41 PM
Posted by: 914werke Aug 23 2023, 07:52 PM
Posted by: 914werke Oct 1 2023, 12:41 PM
Posted by: 914werke Oct 16 2023, 11:16 AM
Posted by: 914werke Nov 4 2023, 03:38 PM
Posted by: 914werke Nov 30 2023, 12:44 PM
Posted by: 914werke Dec 13 2023, 11:14 AM
Posted by: 914werke Dec 30 2023, 06:30 PM
Posted by: 914werke Feb 22 2024, 01:53 PM
Posted by: 914werke Mar 18 2024, 09:55 AM
Posted by: sithot Mar 23 2024, 12:06 PM
300 ml
0.31700 qt.
1.2680 cup
10.14 US oz
Posted by: 914werke Mar 24 2024, 05:44 PM
first.gif very nice thanks for the confirmation sithot
Posted by: 914werke May 22 2024, 11:46 AM
Posted by: 914werke Jun 3 2024, 11:15 AM
Posted by: 914werke Jun 21 2024, 12:25 PM
Posted by: 914werke Sep 27 2024, 07:46 PM
Posted by: 914werke Oct 7 2024, 03:06 PM
Posted by: 914werke Oct 25 2024, 10:45 AM
Posted by: 914werke Nov 14 2024, 01:59 PM
Posted by: 914werke Nov 30 2024, 04:07 PM
Posted by: 914werke Dec 13 2024, 07:11 PM
Posted by: 914werke Jan 28 2025, 01:54 PM
Posted by: 914werke Feb 20 2025, 01:35 PM
