So,
What are the options for oil tanks?
New, used?
Who sells the new ones, and how much?
Rich
I don't know if Don Welch is still making tanks or not, but that's probably the best way to go on a non concours car. Not to say his tanks aren't nice, they are. I want to say he had a filler neck and filter console that went with it too. I think the total was $950 for the tank/filler neck/filter console package. You can still use the factory filter console boot and nylon tank spacers.
Velios used to make a cast aluminum tank, it's heavy and I had about a 25% leak ratio on the ones I sold. I don't think Velios is even in business anymore, even if he was I personally wouldn't buy anything from him.
The last factory tank I got was over a grand, and then you've got to get all the ancillaries. I'd say budget about $1100-$1200 to go that way.
The factory boot with clip and the nylon spacers will run around $60 IIRC.
I thought Rich Johnson had them
T.C.
Sorry, could you post a few pics of all these parts you are talking about?
Rich
don now lives in Australia, and i am not sure if he has found a machine shop to make them there.
Peterson tank in the front trunk ... $400
911 tank cut into rear trunk ... Reasonably cheap
Stock tank ... $1.1K new, $800 used
Custom made ... have no idea
Add in for lines and fittings for all .
The engine doesn't give a shit where the tank is or what it is as long as the suction of the oil pump on a six is flooded at all times (height of oil level above pump, volume of oil and diameter of supply line.
Purists & pinky lifters will frown upon you for anything but stock!!
Aase Bros. have a NOS tank on their site for $975
aasesales.com
I bought a new OEM unit from Rich Johnson. $950-ish. No pics. It looks like a brand new factory tank.
if i only got off my ass, i would like to make them, and call them Easton's tanks
they would be modified from an original, with more volume and a better filling spout
but i need to get moving on it
we need a smiley with me and a fire under my ass
been thinkin about this for a while
I saw an aluminum repro tank on the Mittelmotor web site the other day. The info was sparse but it may be worth investigating also.
Years ago I found my NOS factory tank on ebay for a sweet price. The bonus was that the guy actually lived 1/2 mile from me so I picked it up in person and met another 914 fan in the neighborhood. I doubt they are as easy to find at less than full $$$$ these days.
Patrick sells a repro. About $1k fully outfitted (filler neck, filter console, etc.).
http://www.patrickmotorsports.com/part/434/
I should have the original tank, Rich Johnson oil lines, console with new o-ring, bolts and washers setting in my parts bin not being used. If you are interested in them, I could get them out of the sorage before the snow season. Right now I am in California and will be home after Monday, Oct. 19th.
Do not have any idea on pricing or shipping costs.
Need to clean out all the Porsche items I am not using.
Steve Hurt
When I finally had the funds I purchased one of Don's tanks, like Andy pictured. The only place I could find it was at Patrick. It is a very nice piece!
I did a group buy here on the last of Don's tanks about a year ago. I'm not sure if Clint at Rebel has a tank or two left but I doubt it. Patrick Motorsports made a run of them after Don left, I haven't seen one in person but they're probably quite nice. Don isn't sure if he'll make tanks again, even though they're expensive he wasn't exactly getting rich on them. I helped him make a run of 20 or so once and there is a looooot of labor involved. They look simpler than they are.
I have a bunch of oil filter stands left over from Don's tanks, brand new anodized with an O ring and mounting hardware. PM me if you need any if you decide to make tanks or whatever. Fire sale prices!
not sure if anyone saw this
http://cgi.ebay.com.au/PORSCHE-914-6-ORIGINAL-OIL-TANK_W0QQitemZ250514961423QQcmdZViewItemQQptZAU_Car_Parts_Accessories?hash=item3a53daf40f
it isnt mine i just thought someone might be interested and it may be easy to miss as it is on the Aus Ebay.
cheers
edwin
i know of a "doesn't leak" 911 tank for $50.
good deal?
Can us hack and modify peeps cut up a 911 tank and make a 914 tank out of it? I can borrow a 914 tank for a pattern.
What someone should do, someone with the skills, is make one. Document the process, publish the templates, list materials, take pictures, and post here.
Instant classic.
Hero status.
Wasn't the originals just steel? Heck if it came down to it parker push-loc hose fittings would be fine for me.
I've seen some prices for the factory hoses.
Rich,
it should work..
but depending upon what you use for oil lines you may or may not want to use the 911 fittings..
the tank fittings are metric
if you use stock 914/6 oil lines than they will work fine
most aftermarket lines are not metric
they are often AN
and if that is the case then you have to come up with metric to AN conversion fittings...
we did this on my stock tank in order to use braided stainless oil lines.
So depending upon your choice of oil lines, you may want to make the tank out of those fittings.... Thus the reason I made an aluminum tank and used aluminum AN fittings on it.. I intend to convert another car and use AN fittings/aftermarket lines on that car
I installed a Don Welch tank in my GT clone and that thing is a piece of art. Very well made. However I did convert both fittings to AN so I could run braided hose. Not that braided hose is cheap . I used -16AN from the tank to the engine cooler and -12AN from the engine to thermostat and then to front mounted cooler. If someone could make a tank maybe not quite as nice as Don's and maybe just a little cruder they could probably sell a few. But the market is not too big. I'm glad I got one when they were still available, as a matter of fact I got the tank,oil filter console and the filler neck with cap for $750.00 on special. I now realize how good a deal I got .
The AUS one relisted for $500 on ebay.
Not an easy item to obtain or build ..good luck.
Keep looking you'll find one.
photobucket ate my pictures..
but i finally found these tucked away:
my template and
the internal baffling
these pictures were taken before welding was finished.
some of the seems are only tacked
Thanks brant! any more pics?
If it was mild steel it wouldn't be too hard for me!
What about repairing a rusty tank? I know were I can get one cheap.
a couple more pictures, but they don't show anything more really:
mild steel would be fine
just use steel fittings
it helps a ton to have access to a big break
I did this tank in my votec welding class, and they had a number of helpful tools around that shop.
An old style radiator shop would be a good place to start with a rusty tank
I would think it could be easily brazed or repaired
clean it well with a wire brush to expose all of the rusty areas
Is a 914-6 tank and the tank from a -'83 930 turbo the same or close?
Not really.
Can I ask why having the oil tank reside in the left quarter is so critical? It would seem to me that it could live virtually anywhere in the car. Front trunk, rear trunk? Would that not take away from the complexity of building a very specificly shaped/sized container to fit in that odd location? Why not put it in the front trunk and add a little weight bias up there? You could shape it anyway you want and probably buy something off the shelf that would work for far less. Just my $.02.
I want a clean install, I like the stock look, but what is hidden from sight is not my concern.
The reason I asked about the 930 tank is because someone is offering me one for my ceramic lifters.
Mark - I wouldn't do that trade. You're lifters are worth way more than any 911 type oil tank unless it's a plug N' play tank (i,e, real 914/6 tank). Another option (since you're going to the /6) is to put the tank in the engine compatment where the circuit board is. Witha carbed /6 you really don't need the circuit board. You'll have to add a couple of relayed power leads for things like the ECU but that's easy and can be put anywhere. It's amazing how much space you have in the engine compatment behind the driver once the board is removed.
I'm surprised no-one here mentions the PMS tank?
Seems exactly like what's being talked about, and fairly well priced compared to what others have been advertised for?
Must be some "inside reputation" or other "Motormeister" type scuttle butt keeping it off the list?
Jeff
Keep your lifters and make a tank. It doesnt have to be fancy, just make a torpedo that stands up at an angle and sits behind the fire wall once the circuit board is removed. You have the skills.
Doh! OK, back to keeping my keyboard shut!
Jeff
Is this a turbo tank? Dipstick starts off part # 930 XXX XXX....
Don't think I'm that lucky Doc, I know this tank has rust issues.
i ran across this trick setup on cl. it's not my favorite because my rear trunk is the "clean" one...
now i wish i'd bought the tank i saw for $50.
So sad
I'm using the PMS tank and have no problems. Got it about 12 years ago when there weren't many others to choose from. It has the later oil filter console for the later filter and the bigger inlet....
Do people with real /6's ever switch to a repro tank just to preserve the real one they've got or only replace it when it starts to rust/leak?
S
The stock tank is long and narrow. This is not a problem in most instances....
at autocross it can be. It gets to sloshing back & forth and oil gets caught up in the windage. I usually found approx 6-8 oz of oil in the catch tank after an event. If I didn't keep that tank drained I ended up with oil in the trunk....that happened twice & it's messy. Non-violent AXers shouldn't have a problem.
Don't know if this http://sfbay.craigslist.org/nby/pts/1546257917.html would help anyone or not.
Has anybody ever looked into using a 964/993/996 tank in a 914?
In the 911s they mount in the Passenger fender ahead of the wheel and are plumbed in with hoses and pipes.
It seems the hoses and pipes could be fabricated to place it in the same local in a 914 but I'm not sure there would be room or if the mounting is feasible.
Jim
