Howdy All,
This is the start of a new thread and the progress I am making on this little 914 car. First off, let me give you a little history. I had a WANTED ad in the craigslist area for Tucson and PHX. I got a call from a man stating he had a 914 that he wanted 1500 bucks for. We talked about the car. It ran, drove and he said it would make the drive to Tucson. We talked a little more and we determined he would take 1300 bucks for it. I arrange a rental car, drove to Prescott, dropped off the rental and then met the guy. It was a little rough at first but the car did start and drive... Well? No. Badly... Yes. I decided to go for it and started out the drive. It did infact make it all the way home in the heat of the day and over the mountains. = ) Anyway, so its now home, on stands and ready to begin its new life. Here are some pictures to start the thread.
Eric
I have decided to take it down to the bare metal. After a week of a lot of hours in the garage, here is were we are at today. = )
My goal with the car is a light weight -simple- reliable SCCA car. I want to remove the horns, flood lights, rear window and anything else I can to get the weight out. I am also doing the inside long kit as well as the rear end kit to ensure it is strong and secure. I would love a 911 front end but this entire project is going to be spendy to say the least. So I am going to stick with the 914 stuff (front arms, hubs, brakes etc). I just was a high bidder on some rear shocks. I will order some 160 lbs springs for the rear if I can find a used set somewhere. I am going to go with a stock sway bar up front and will see about finding some better tortion bars. Anyway, this is just a little direction for where this is going as of right now. Tomorrow someone might call and offer me a front end for 100 bucks and the direction could change. = ) But for now we will march this direction.
Now from all of you... I have NO IDEA WHAT I AM DOING!!! LOL I need all your help with what to do and why I am doing it. My plan is to get the body work done (welding holes, patching rust etc) and then each day take on a new aspect of the car. Clean the parts, fix anything broken and then install it in the car. So what do I need to do before I paint? = ) Like the front drivers eye lash for the light has a bent edge... Not to bad but a little bent. Thats going to be covered and not seen... Do I do more to fix it then I already have? Do I cut it out and weld in a new piece? (my welding isnt perfect... )
Anyway, I will have lots of questions over the next few weeks. My goal (please take a shot of whiskey before reading more) is to have the car on the road and legal by Thanksgiving. HAHAHAHAHAHH SHOOT ME!!! = )
Thanks all.
Eric
How do I get rid of this box (voltage regulator?)? I dont have fuel injection and I think its all empty except the battery side.
I was told that sand blasting the car is the best way to deal with the rust. It blasts it away (just what I was told) and you know exactly what needs to be fixed. I also was told that within about a week of your car sitting bare without a primer on it or something, that it starts to rust. But I also heard that if you primer it with POR its a problem for the painters(?).
So I was going to get it blasted so when I weld the longs and the rear end that its good perfect clean steel to steel.
LOL So what do I do? Anyone done this before?
I saw one post where the person did all the painting under the car themselves and then built the car and then took it to a painter to do the outside of the car... But I like Patrick Motor sports where they paint the entire car the same color.
Shesh... The choices and the directions to go.
Thanks all.
Eric
Well, I had it sand blasted. The guy came to my house with a buddy. We dragged it to the back 40, put it up on crates and got him started. It took him about 2:15 to do the entire car. He made sure that he didnt sit in one spot for to long to ensure no warping occured. I didnt realize there was so much bondo on the car... But now... There isnt even DIRT on the car. = )
Eric
Hey there Eric,
What you are doing is admireable.
To atempt such a project and do it so fast.
Keep it going and have a
John
Welcome to the madness Eric and congrats on the purchase. From the looks of it you did very nicely on the deal. Most of us would kill for those longs on a project car, but I'm not sure about that engine lid support.
As for "not knowing what you're doing", you've come to the right place because none of us know what we're doing. If we did, we'd be doing something else. However, collectively, we manage to keep each other out of trouble.
Good luck and keep us posted.
Tom
No disrespect to this forum but if you're looking for basic paint advice, check into paint101.com. It's a board specifically for autobody painting and has a ton of good info and a bunch of pros to answer almost any question you have. Beyond that, this board is invaluable for paint advice specific to the 914. I wish I could give you some of that advice based upon experience, but I'm at least 6 months away from that point.
Doing your own paint job is a great experience and you won't regret it.
Tom
Nice job on the sandblasting, sure wish I had done it that way looking back.
= ) Things are moving along. Are these added or factory? Need some input team. = ) Dont want to start putting a stiffening rear kit in if these are going to be in the way.
Eric
I just got the Engman Long Internal Kit installed. Looks good. Neat stuff. Easy to do.
Eric
Stiffened the rear support and fixed the trunk area.
Eric
Put your door back on, RIGHT NOW. Before you go any further, make sure they still fit properly and that the body is in alignment. If the cars is twisted in any way from the addition of the longs, this is the time to address the fix. Also I would start blowing out the extra sand. I can't tell you how many times I used the air line and vacume to clean out the sand from every nook and cranny.
Have you paid a visit to your local auto paint store yet. These guys can be so helpful with advise. Pick a line of products and stay with it. They can help you figure out what fillers go with what primer and paint so the products stick.
Here is the fixed hole where the AC unit used to be. Not as pretty as I would like but will be plenty strong for AX.
Nice work & quick! Way to tear into it
wow! very inspiring.. thank you for sharing the pics!!
I wish I could be half as productive as you are, Nice work!
I decided to brace the sitting area. Here is my work. = )
Eric
I also decided to build a Rottisserie.
Eric
More on building a rotisserie.
Well, I guess I have reached my upload limit. = ) Now I get to go through and start deletting all the old photos...
Eric
Can you give me an idea of how many hours it took you to dismantle the car? I have to do this soon and will have a deadline but I'm not sure how much time it will take to completely dismantle the car.
That's a Delphi car! Going to paint it the factory color?
Nice progress! I would suggest that you consider widening the stance of the engine stands of your rotisserie. There's a lot of mass moving when you turn the car. While you're at, you might also consider increasing the height so that you can get the car fully vertical -- as it sits right now, I am pretty sure it is not high enough and the body will hit the stands and/or ground. Finally, connecting the two stands together will give it better stability, especially if you need to wheel the thing over cracks/lips in the concrete. Keep up the great work!
Widen the stance. You really don't ever want it to tip.
Also, put in t a cross bar between the two engine stands. This ties it all together and allows you to move the car around on the Rot in your shop. Very helpful in my build. I tried to do it your way first (no cross bar) and the whole thing almost folded the first time I tried to push it.
Here is how I did it, using the same building blocks that you are using:
With the cross bar...
Looking great, keep up the good work.
I got 90% of my welding done. Most of the holes are filled. All the rust has been removed except the small corner on the flag that I will tackle this week. My next challenge is the tunnel from the under side... do I need to fix it? The car worked great driving it but I dont want to have to open it up again later...
Here are some pictures. = )
Eric
It looks as though they hit a rock and the car bounced on it down the tunnel area... So there are really 2 maybe 3 areas that need to be pulled out if thats what needs to be done...
More pictures....
On the third picture... Where it shows the rear stiffening kit installed... I added an extra piece to extend the kit all the way down past the support. Figured it would just help make things a bit stronger.
I talked to Brad and got his Chassis stiffening kit. I cut the jack tube out in preperation for the kit thats coming in the mail. = )
Engman Internal Long Kit
Rear Stiffening Kit
Brad Mayer External Chassis Kit
Tangerine's Ear stuffening kit
Tangerine's Front sway bar support
19 MM Front Sway Bar
Bilstien Gas Charged Struts
140 LBS springs in the rear
Koni rebuilt adjustable shocks in the rear
.... Hope its strong enough to handle the stock 1.7 with baby webers I am installing in her.... LOL
Eric
Where we started....
Where we are....
Good work!! If i were to post a where it was ... where it is photo you would be hard pressed to find what i have done damn El Nino
More Pictures. I got the Rob Mayeur Long Kit installed. Nice easy job and it comes out really clean. So the rear end now has the Rob Mayeur long kit connected to a Rear end stiffening kit. The upper arm that has all that extra steel isnt going to budge... I decided not to box my rear trailing arms... I figure I want the car to be more solid than I can stand and the arms be weak. That way if I slide into a curb, it might only be changing a rear trailing arm not bending the frame. Good stuff.
Eric
Argggg I got a 911 a arm verses a 914... Spent hours cleaning, pulling out the bushings, painting putting it all back together to find out.... IT WASNT RIGHT!!! = ) And so it goes....
Tomorrow the guy comes to Soda Blast it one more time. This will mean I dont have to use water and acid to prep for painting. Dont like water on a car you are trying to keep from rusting. = )
Once the blasting is done, I will go over the car a few times with the blower and then get ready for the Epoxy Primer. This will allow me to put the car back together and make sure everything is the 100% correct. Once there, I will pull it all apart again, sand it and then paint it, then reassemble it yet one more time. = )
LOL Did I mention I sold my house and all this has to be done in 20 days? Anyone want to buy a project? I am moving overseas and cant take it with me. Incredible car.... Sad but life.
AHAHAHAHAHAH
Eric
Awesome work! Please store it or ship with you.
All that work! Where the heck are you moving?
So the car has the Engman stiffening internal kit... It also has the Mayeur external stiffening kit... But there isnt anything that ties them together. We continue to add things to the outside of the longs to make them stronger but we dont do much to address the seam or the strength of the weld. I wonder if they flex? Anyway, I decided to put a bolt through the long... I put a 1/8 inch thick plate 3 X 3 and welded to it. This will ensure there is constant pressure on the long holding it together. Okay okay.. I have seen ANY other pictures of something like this and it could be silly or maybe not as effective as I dream, but its new... I will let you know how it goes if I get to drive the car before I move. = )
I also welded in a 3 inch wide plate on the bottom of the car. Here are more pics.
Eric
Door Time. I decided to cut up a door and see about skinning it. Cut it is SOOO much lighter than the regular door. Crazy difference.
ERic
The pics in Post 76 . . . that's a long way in a short time! Great work.
cheers, m.
4 hours of blowing sand out of every hole I could find...
Here comes the primer/etcher/sealer.... = )
Now for the prime-ing.... = )
Tomorrow we shoot the yellow color. = ) Whew... What a shit load of work!!!
Lookin good. Keep us posted!
