I need for someone that has a 914 project that can take a photo of how the e-brake handle mounts to the tub. I have an e-brake handle that I wish to use in a different application.
Thanks in advance:D
I could have sworn I had a picture of that on my flickr site from my tear down, but I can't find it. I'll check tonight at home, and go out and take one for you if I don't have one on my computer.
Zach
Here's a photo that I had from when I pulled apart the interior.
Note: The bolt that connects the ebrake to the car is removed and sitting to the left of the hole it goes into. It gets installed with 2 washers on either side of the ebrake- at least that's the way mine was when I took it apart. Also the clip that helps to retain the cable to the handle isn't on all the way in the photo.
Here's the mounting poles for the e-brake.
