Posted by: ahdoman Dec 18 2009, 08:52 AM
Has anybody ever figured a way to put a reverse lockout on a stock shifter? I know people have put in a heavier spring.
Posted by: dr914@autoatlanta.com Dec 18 2009, 08:57 AM
QUOTE(ahdoman @ Dec 18 2009, 07:52 AM)
no need to install one except for the stock plate pins and springs. When the shifter bushings are good, the shifter is in adjustment and the set screws are tight the shifter works perfectly and you will not grind into reverse when shifting.
Posted by: computers4kids Dec 18 2009, 08:59 AM
QUOTE(ahdoman @ Dec 18 2009, 06:52 AM)
When I was running a stock shifter in my v8914 I asked the same question without any luck. I went ahead and adjusted my linkage where R/1 was further to the right and took a deliberate push over to get it in. Then of course, I don't use 1st so it was no big deal. I finally went to a Renshift with the lockout.
My other 914's stock shifter has a lockout.
Posted by: Drums66 Dec 18 2009, 02:08 PM
QUOTE(dr914@autoatlanta.com @ Dec 18 2009, 06:57 AM)
Exactly what he said!!
Posted by: McMark Dec 18 2009, 03:07 PM
QUOTE(904svo @ Dec 18 2009, 07:56 AM)
Heres how I did it.
Brilliant!
Posted by: Al Meredith Dec 18 2009, 06:05 PM
Two years ago at the "Renfest" in Daytona I noticed that almost all the Old 914 racers had a lock out. Most were a simple drop down bolt/ wire .
