Printable Version of Topic
914World.com _ 914World Garage _ 911 Struts and Hubs
Posted by: rickthejetman Jan 12 2010, 09:13 PM
ok gang new guy question. if i have 1972 911 struts (boge) do i have to buy 72 hubs as well? or can i use later or earlier ones?
Posted by: bdstone914 Jan 13 2010, 12:51 AM
QUOTE(rickthejetman @ Jan 12 2010, 07:13 PM)
I have a pair of hubs that should fit your struts. I am in Riverside. If you come down here you can try them out.
Bruce
Posted by: rickthejetman Jan 13 2010, 12:56 AM
QUOTE(bdstone914 @ Jan 12 2010, 10:51 PM)
Bruce
wow! thats awsome. i dont have them yet i was going to bid on them on ebay just wanted to see what my hub options were. i'll let you know if i win them.
thanks a bunch
Posted by: ArtechnikA Jan 13 2010, 05:00 AM
QUOTE(rickthejetman @ Jan 12 2010, 10:13 PM)
1969 and later (which in 911-land is basically through 1989 at least) the spindles (and therefore hubs) are the same. (Technically, even the very early spindles and hubs are the same - but the very early struts are not, and if it were going to get iffy it'd be with the solid-rotor hubs.)
Posted by: Cap'n Krusty Jan 13 2010, 09:46 AM
Actually, the hubs aren't all the same. Hubs made for non-vented rotors are different. The Cap'n
Posted by: rickthejetman Jan 13 2010, 12:51 PM
well i'm putting willwood brakes on so if either hub will work its fine with me. my niner has a wrx engine in it now. wanna make sure it will stop as fast as it will go now
Posted by: ArtechnikA Jan 13 2010, 08:18 PM
QUOTE(Cap'n Krusty @ Jan 13 2010, 10:46 AM)
I wondered about that. It appears that 1969 911T still had solid disks front. 1969 E, S, and all Sporto had vented, and by 1970, everything did.
Posted by: Eric_Shea Jan 14 2010, 01:39 AM
You can use them all but, they're all different.
Solod rotor hubs will work in a vented circumstance but your calipers will hit the wheels with most wheels.
As they went to vented rotors the hubs widened the spacing. When they switched to A-Calipers they got an even wider stance.
Good advice herein... stick with a 70+ hub and you should be good to go.
Posted by: rickthejetman Jan 16 2010, 02:19 PM
thank you all for the great advice. you have been most helpful
Posted by: kg6dxn Jan 16 2010, 04:19 PM
QUOTE(rickthejetman @ Jan 13 2010, 10:51 AM)
You could alwasys try what I got on my car...
930 brakes with vented rotors. Not cheap though...
Wilwoods are nice. I had them on my Mopar.
Posted by: Spoke Jan 16 2010, 05:31 PM
QUOTE(rickthejetman @ Jan 13 2010, 01:51 PM)
Did I miss pics of your car? Let's see what you got!
Posted by: rickthejetman Jan 17 2010, 09:58 PM
Posted by: rickthejetman Jan 17 2010, 10:00 PM
Posted by: rickthejetman Jan 17 2010, 10:08 PM
sorry for the crappy cell phone pictures my digital is broken. i'm no fabricator i'm just an airplane mechanic thats learning this as i go along. so no mean coments on the poor quality. its strong it will hold thats all that matters to me.
Posted by: rickthejetman Jan 17 2010, 10:14 PM
my trunk was totally rotten so it didn't bother me to cut it out. so my engine ended up nice and high and ground clearance is perfect.
