Awhile back trying to fix a trunk issue and while removing the torsion bars one of the Torsion Bar Placement Holder bolts sheared off, currently using trunk shocks that I do not care for anymore.. I want to re-install the torsion bar system but need advice on repairing/replceing the sheared off bolt..
You have a couple options:
* Grind it down and weld a new stud on
* Use a nut-sert and new stud or bolt. I really love nut-serts...
Grind it down and drill through with a nut and bolt, if you're not a welder??
ps. why are you dropping the shocks? I was just considering buying a set to get rid of the torsion bars??
Just installed a set of the shocks from Camp 914. I'm very pleased with the look and function. Trunk operation is smooth and light. Removing the torsion bars also cleaned up the engine bay.
I have the Camp 914 trunk lid shocks on both trunks of both cars and they work great. Mine are mounted a little differently and the roof fits in the trunk perfectly.
The instructions show it connected to the trunk hinge and then a cut on the body just a bit. 3 screws to the underside of the channel for the trunk seal.
Yep, the red car pictured has them installed 'uniquely'. Following the instructions from Camp914 results in a setup that works without interfering with the targa top.
Yep, mine are installed like this, and the targa fits perfectly (even with that big box in there lol)
http://gallery.me.com/rodericdavies#100050/IMG_4272&bgcolor=black
Correct installation = easy roof stow.
Interesting different perspectives. I only put the top on if I need to keep precip out of the cabin.
I don't get all the Qs about the top fitting between the shox. It fits easily!! Oy. Just set it up right, there's plenty of room!
If you can't fit the top between the shox, you have a nasty hack job. I haven't seen one of those yet... Do they exist or are people making ASSumptions?
