I saw this on Ebay and picked up a set. Each kit contained 2 RUBBER bushings and a new shaft. There were no instructions with the kit. Just for grins I tried to put the bushing on the shaft and it was very tight. I wonder if you have to heat these like the Europarts front replacement ones. Seller had no instructions about these parts. Cost was $55 shipped.
I got the same thing. Planned to use just the shafts with new delrin bushings. Got mine Monday and noticed that the shipping address was less than 10 miles from my home.
Also went to Ebay to add good feedback and the auction was flagged
Bob
Another curious minds just want to know:
Why replace the shaft? If the bushings are not totally worn out, where would the shaft wear? Or is it just the money thing. bushings and shaft for the cost fo bushings?
Mark,
I bought the Elephant Racing rubber bushings that come with installation tools. I can send you the tools if you need them. Not much too it, just gotta lube everything up real good with liquid soap and use a heavy duty pipe clamp. As I recall you insert the bushings in the trailing arm and then push shafts through them. The tools keep the bushing from pushing out. Might want to look at the ER website, they might have the instructions, I dumped my instructions.
Kev
