i was wondering?
jim
No one should be.
i believe it is PMB that does 914 brake work, i know they do the calipers, give them a call. I dont have his number right now. sorry
or suggest you call rich at 650 364-6234 and see what he has to offer. he does sell the calipers that PMB rebuilds so he should know.
Proportioning valves can be redone by Wilhoit Restorations in Long Beach, Ca, They do mostly 356 stuff but advertise redoing prop valves.
Take the P-Valve out and put in a tee from a VW squareback....go with a new 19mm 911 master. They are cheap.
65/35 or thereabouts bias to the front. Keeps the rears from locking up before the fronts, which is a BAD thing. Removing the valve brings it closer to 50/50 as the front brake pads are larger than the rears.
Going to bigger calipers on the fronts is good thing with the valve removed.
Technically speaking, it doesn't proportion anything. It's a limit valve. It keeps the pressure that's going to the rear brakes from rising above a certain level, whereas the fronts are free to keep rising. At low brake pressures you have the same pressure at the front as you do at the rear. A true proportioning valve would mean less pressure to the rears even as low levels.
