I just picked up a set of Koni Yellow's for the rear of the car (used of course). While my Koni Red's have a 1.5 thread pitch for the threaded insert, the yellows have a 1.25. Is that normal? If so where do I get the threaded insert in a 1.25 tp?
Thanks!
I should mention these are labeled
Koni 8241 1050 Sport
Correct... This is rears. The threaded insert I'm talking about is the T shaped piece that threads on to the top of the shock that has the rubber bushings on it at the top of the shock.
I don't recall any "T" ?
do you see it in the pictures of my Koni Yellow?
I know what he's talking about. Sorry, when you said "insert" I thought you were talking about the common collar issue with inserts.
Odd. Should have come with something. I'll check to see what I have.
This is the piece...
I had the same issue when I installed these....
I retapped the aforementioned piece and then found two new nuts with the correct thread for the top...
Worked fine..
My, my, my... those look beautiful
Sorry I couldn't come up with a fitting.
Mine are "almost" done. TrueChoice has been "dicking" around with them.
Film at 11:00
Hey, how do they ride?
Eric,
on full soft with the 140# rear springs they are just about like a normal 914 ride...
on full stiff, they are going to be great at the AX....
After an event I will see if I can get the balance right with just the shocks and air pressures...if not then I may look for a rear bar to get the back end to rotate. I always like a car that is a bit loose...Kind of freaks out some of my students, but that is the way I like it, especially in a low powered momentum car
This winter I plan on doing a little detailing on the trailing arms and associated stuff
