Is there a list of alternative internals(non-vw) for our rebuilds that would make our re-builds cheaper and stronger, Example... Chevy rods. Consider this a tips and tricks thread, as well. Also, I don't have good experiences w/the forum search, so please place as many links as you can dig up, here.
I got 2 squirrles, a penguin and a raoch stuffed in there. You should hear that motor scream...
KB 96mm Hyperutectic Aluminum pistons, stock Mahle cylinders machined to 96mms and Raby 9550 cam...the rest was stock and worked well together
I used the same pistons and cylinders for my 2056.
I am also using ceramic lifters instead of steel (NLA, but great if you can find them).
My engine is carbed, so I have more choice in dizzys. I am using a Mallory Unilite, and a Bosch Blue coil.
Zach
2056 motor are a blast compared to any stock motor.
My 2056 consists of Kieth Black pistons, AA cylinders, Hastings rings, Raby 9050 cam and valvetrain, 1.7 rockers with swivel adjusters, 2.0 heads, Manton pushrods, stock crank, H-beam connecting rods.
Those are some nice engines!
With regards to HP, 95 to 115, or 95 to 125, especially with some suspension improvements and weight reduction makes a big difference...
So, which Chevy rods are used? And what about the Buick crank? Loving the pics guys keep it up.
The most popular conversions are :
Porsche 6's, Chevy 8's, Suby 4's
Here's my 2.7
http://z8.invisionfree.com/ClubNARP/index.php?showtopic=1918
A lot of performance VW's use SBC valve springs after a lot of machine shop time, but all the other parts are specific for the engine. There are a lot of counterweighted cranks machined for SBC rod journals, but not SBC rods.
Just for clarity..... I'm talking about the type 4 motor and it's internals.
I am running a 2056 with Keith Black pistons, Len Hoffman heads, Raby cam, stock crank and rods, Jennvey 45mm throttle bodies, Emerald M3D FI management, SS heat exchangers and Triad exhaust. The set-up dynoed 150hp at the wheels. Its great.
Bill
