Just separated the fan wheel from the big steel pulley ring. FYI, it takes the same 8mm 12pt bit that the CV uses. They were harder to get out than the CV bolts.
Anyway, I don't think I have a saw or airtool that will get in-between those blades. There is only like 6mm in between. Any suggestions?
TIA
dr
What are you trying to do?
Remove some of the blades?
Paul
pliers or a screwdriver...the blades should break off near the bottom.....
pardon my ignoragce(normal state)... but why remove fan blades?
wouldn't that change the air volume being pushed?
Lotsa racers do it so the engine will rev better...
Dave, I imagine this would work:
usually called an air body saw, basically an air powered mini sawsall...useful for many other things also...
Tony
I removed some of my blades. I'll post a pic tonight. One was already broken off so I removed the one across from it to balance it out.
The thorey is it will make the fan lighter but you'll be removing very little weight by removing blades. Crank, rods, pistons, flywheel are where the bulk of the weight is.
An aluminum blade don't weight much.
I know, I know, every oz counts. Look who's talking.
Paul
ahh, ok, that makes a lot more sense then... thanks!
To do it right, you need a milling machine to take them all to the same depth...
Please don't leave them uneven when you send it to me, it creates alot of work.
the stock fan is made to run optimally at <4000 rpm. A race motor lives above 5000 rpm where the fan cavitates and looses efficiency. Removing blades puts less of a load on the motor and allows better flow at high rpm.
Its really not about weight.
The pic is not what mine looks like.... yet.
dr
Those are a BITCH to balance BTW...
They air moves differently through the blades and my computer sensors pick the air up as imbalance. I have to make a cover for the fan inlet and cover the blades with masking tape to actually get balance numbers...
I thought the balance machinery rotated quite slowly must still move enough air though
The balancer rotates at 500 RPM, but the air disturbs it enough to aggrevate me.
Jake, I salute your attention to detail......wonder how many other builders go to these legnths??
Wow, over my head!
Is there a optimal number of blades to remove?
What pattern do you use?
I had previously see the pictured blower blade, but I thought it excessively radical.
L. McChesney
I normally remove every other blade, but have ran some with only the 4 impellers that hold the fan together!
My track fan for my car has every other one removed...
