I managed to find some photos that we had thought were lost. This doesn't take me all the way back to the start of the project, but I've decided to start the photo story of the project.
April 2004
The 2 liter engine I sold with the fuchs
Here's some shots of the damage that I found when I got the car in the air and cleaned it off
The car was walnut blasted and sealed with primer. Now I could see even more work to be done.
I enrolled in autobody at the local CC and stared working on the doors. Making the metal strips that hold the rubber strip on the doors was my first big job
Flares from AA arrived and I started the process of fitting them. One of the photos shows a view of the work I did on the sail panels. I'll find the photos I took of that process and share them soon.
I cut away the rust holes on the inside of the sail panel and found more rust. Surprise, its a good time to practice welding. I goated everything with POR and then ground it off the endes so I could weld it. I should have used weld ready spray, but didn't know about the stuff at this point.
After I welded I recoated with POR. I purchased some defective sail panel skins from AA and reworked the metal to match my car. My welding skills were poor and I spent more time fixing holes than I did attaching it.
Next came the installation of the Engman kit. I didn't brace the door openings, but the car was solid and I didn't let any one area get too hot. A weld here a weld there. I moved around the car alot. I had ground the surface were exch hole was so I was metal to metal. At this point I had discovered welding paint.
When do we get to the Gulf Blue part?Looks like you did some extensive rustoration.Nice Rotisseri.
Great pictures! I have really enjoyed watching your restoration.
John
have you checked your door gaps since welding in those reinforcements?
This is a retro thread. I'm going back and shoping what I've already done. And yes the gaps are fine.
I don't have a lot of photos showing the flare installation, but trust me I spent way too many hours attempting to line everything up. I think tacking the flare to the body and then cutting the old part out with an air saw is the best method because it leaves an equal gap for welding.
The entire car was sprayed with fill coat and block sanded
The bottom was coated with Poline. Later I had it coated with kevlar LineX, but this gave the underbody an extra layer of protection.
Here come color, trunks and interior first.
Taping off trunks and interior. Trusty helper who worked for beer and dinner. I did feed her more than tape. (I think she was having fun too)
And now for body color (the first attempt at finding Gulf Blue)
And the color is on (but not for long!)
The color I used was from a code that matched a powder blue, but after it dried, it just wasn't a rich enough color. On top of that I wasn't happy with the clear coat. Out came the sand paper and off came the color.
Resanded the color off the car, resealed it, color and six coats of clear.
The /4 engine mounts were removed the /6 welded in, and the relay board post cut out The underside and engine bay were coated in the kevlar LineX
In the last group of photos, you can see part of the Prelude I worked on while I let the 914 sit for six months. I've heard different opinions, but I choose to let the paint and clear sit and shrink back. I guess some folks like to cut the clear right away and let it breath...., but that wasn't my direction. Lots of sanding and lots of water came next.
The body wire harness was rewrapped in the best electrical tape I could get and reinstalled
The headlights were redone and installed
The air distribution was installed
Some odd parts were painted
Billy,
The teener looked great when you had the gathering at your shop.
WOW! Now I see all the hard work that went into the finished product.
Mine just gets rougher all the time. I spend most of my time rebuilding the mechanicals from all the wear and tear from track days. The cosmetics just get more duct tape and Krylon.
Hope to see you again soon.
Cheers,
Eddie
The only mechanical I've completed to date is the tranny and the suspension. I've got the engine hanging from a stand in the garage and I've only started to figure out what to do with it. Know anything about changing cams?
Hey Billy
We had fun looking at the work you have done on your 914 baby. It was good chatting with you.
j & s
I should have taken some photos, but this weekend I actually got some forward movement on my car! The windshield (with the help of Jurgen) got installed 2 weeks ago and this weekend I finished the chrome trim and putting the window in the passenger door. Goes up and down and the squeegies stay in place. Next week I plan to get the door panels on and work on the glove box.
I'm really glad to see you moving forward on your car again. What a SWEET ride!! the photos just don't do your work justice. What's next with it??
I finished assembling the drivers door and mounted the interior face that I had made many years ago. Its leather and I should have stored it laying flat.
Hopefully the wrinkles will relax. I couldn't find all the square nuts that fit in the retainer clips for holding the passenger door handle on, so that one isn't on yet.
Next I need to figure out the interior trim for above the windshield. Mark hade one recovered for me with the clips deleted for the visors.
They just get in the way on my line of sight anyways. There was a little confusion and the center mount wasn't deleted, but at least it doesn't have any holes drilled in it.
oops, the photo is up side down, but it shows the part just fine
Tonight I got the passenger door panel attached. Lining up the bolts was a pain in the ass. I finely put the bolts in backwards so the stuck through the
new panel and put nuts on the interior side.
Then I worked on installing the frame that holds the ash tray. Note to anyone else who is doing a total restoration. The ash tray goes in BEFORE the dash cap.
Otherwise you need to remove the plastic nuts the hold the cap in place.
One step back...
Progress is always good. Even when it involves removing something to make progress. Just means your actually working on your car Congrats bud
Billy, let me know if you need a helping hand again, happy to come down!
- Juergen
I got the interior trim for the roll bar screwed in tonight. I used square drive screws so I could hold them on the screwdriver. Nice to have something else finished.
This was another part that has new vinyl on it that's to 914Rubber.
Dadgum , that do look great !!! Not to hijack , but is the lever cover plastic or metal ?? I got a set of those top lever covers that are made of metal as well as some plastic ones . Just didn't know that they ever came in a metal edition.
Fantastic color and build here dude !!!!
Jack
I put on plastic, but I had a metal set in my garage too. The plastic ones fit better with the reupholstered trim
Looks Awesome!!! Nice work
With Jurgen's help, I figured out that I needed to cut a slit in the reupholstered upper windshield trim, so the targa latches could grab the catch
I got the trim screwed into place
I got the lower seal for the targa installed (thanks to the one I got from Rich)
Here's the vertical trim on the windshield
Installed the vertical trim on the roll bar and the coat hook clip
and now that's done
Nice new trim sure looks good
Next, I need to figure out how the seat belt attaches and what hardware I need to use
yer killin me
I read too many stories about how the sound of the /6 was sweet, but would quickly cause pain to your ears. The under carrage and engine compartment are coated with LineX, but I lined the interior too.
I installed the seat belts, although i know I'll need to pull them out again when the carpet goes in. I'll also need to pickup a set of "PRESS" stickers for the belts as these have long ago faded
I edged the rear window with black gorilla tape when it meets the top of the back pad
I got this crazy idea to make my own fabric dash face. After carefully making two of them trying to get it right, I decided I didn't like the look. I glued on the OEM one that came with the car.
I got the glove box door installed now and the springs on both sides weren't difficult to install.
I installed new rubber seals in the front trunk and the doors today. Not sure what direction the seal between the fuel and tire should face, but its easy enough to reinstall.
Looking great man!
Nice progress! I will try to come down in the next couple of weeks, hope you have something to do then so that I can help.
I needed the retainer clip that holds the fog light lens in place, so today I made one. Just need to get a set of seals from 914Rubber. Looked like it was going to be easier than it turned out. Forming small parts is harder than larger ones.
Just curious: What did it cost to have Line-X spray the underside?
I did the cabin with roll-on stuff on my last build, but there have been a LOT of advancements in the last 10 years in the DIY Bedliner market. If it's easier, I'd just have a company like Line-X spray the bottom and interior when I was all done with the body.
Rock-It Liner from SEM looks to be the "DIY" version of Line-X. 2-part system that I can spray on at home. That may be the better route, so I can control how much is applied and how thick it gets.
On the same note, what product did you use on the interior for sound deadening? That's up soon on my to-do list....
Mike: look on eBay for a roll of "fat mat". I picked up 3'x33' roll for $60. Nearly identical to the Dynamat I bought last time...for about 8X the price.
I also saw a few YouTube videos about this stuff. I'm half tempted to try it.
http://bit.ly/1dUpnwe
Billy; Glad to see you making progress again on this gem.. Go Billy go!
I use Fat Mat here at my shop with fantastic and affordable results. A heat gun or even a hair drier is a must to get it properly bonded to the metal. The adhesive stick like crazy with a little heat when applied. If no heat is used, it could come loose on roof sections when it gets cold (not an issue with these cars. . .)
I never even thought of using it on my roof. Interesting idea.
Made the down payment on the machine work for the engine today. Also placed the order for new pistons. Valves and a shit load of misc stuff. Not everything I'll need but a large percentage of it. I'd love to do the assembley, but after investing so much I to materials, I'm scared of screwing it up.
Let's see if this works. Its the 3D of my piston
Piston.pdf ( 588.77k )
Man you do nice work!
What's the ETA on the engine?
Nice Billy. Using the old art skills again.
I said art, not fart,,,,,,,,,,,,,,,,,,,
I can't take any credit for this. It's the final mock up from Wiseco.
Little jobs done, but every step is one closer
New radio delete plate
New interior light
So when's the debut?
Eta is April. Then comes install and tuning.
Very good work !!
Nice work ................
I got my message today that Webcam is shipping my cams, Jerry Woods is sending the modified distributor and new plug wired and my half shafts are clean and ready to go to the powder coater with the shift rod section that is exposed in the engine bay. I worked on my list of things to do/buy last night and I added more than I marked as done!
You deserve alot of credit for sticking with this for ten years!
Running Soon
I can use help. Willing to feed you and keep the fridge in the garage stocked if you want to come by this weekend. Lots of things to do. Some take talent, some don't.
Today I stopped at Triad to pick up my headers and muffler. I dropped them off on the way home to be ceramic coated a gloss silver. When I got to the front door, I found my cams!
Today I pulled the stack out of the transmission to send off to Dr.E. Since he can't make it to Seattle next month, I'm sending it off to him for a transformation.
I spent the rest of the day digging in every box in the garage as well as the storage unit we have. I pulled out everything that was 914 and turned the spare
bedroom into a parts shop. Found the 2.0 muffler bracket I needed as well as a bunch of other stuff. Next week I need to drop off a batch to be powder coated.
Put the car back on jack stands, so I could pull the wheels off. They need to be cleaned and re-painted.
I need to get the tires pulled off, so the wheels can be cleaned up and painted. I'd like to find a center cap with an unpainted crest in metal for them
I have a set of wheel caps off some phone dials, might do the trick. Silver, basic crest....
I got my distributor back from Jerry Woods. Its been modified for the carbs and has the wire for the MSD.
I also dropped off a pile of parts at the coater today. Half shafts will be red, bunch is misc will be black and the fan and its housing will be titanium. I need to get the rocker covers from the machine shop as they will be titanium too.
I got to see my headers, but they weren't ready to be picked up yet. Maybe tomorrow
Looking good! So great to see this build coming together. Such a beautiful car. Can't wait to see it on the road. Keep it up
Got the re-chromed fog light grills back and mounted. Used the specrachrome paint process on them and it works
Having a hell of a time with the locks for the targa top. After I got them installed, one of the c clips popped off. Everything still works, so I think I'm going to leave it for now. To access the clip I need to pull the pad off the top of the targa bar again and that's a pain. It will be a good job to do next winter when its too wet to drive the car.
I had the tires dismounted from the wheels and dropped them off to be powder coated.
The flywheel from Kennedy showed up today. Now the crank can be balanced.
Lots of stuff today! The diffusers that go between the cylinders and guide the flow of air came back from the powder coaters
The alternator that was rebuilt and the fan casing and fan (the ring that secure the fan belt is still at the shop).
Its actually titanium colored, but the camera lighting made it look black
And the headers and muffler
WOW... Everything looks great!! Ill give you a call tomorrow...
I couldn't get much done this week. Work and St Patrick's came first. I did get the half shafts, the muffler hanger and the shift rod back from the powder coater.
Lets see what showed up now....
Lower valve covers with the ribs already machined
Hardware for oil lines with a drain
Oil retun tubes ( or whatever they're called)
and pistons the old ones on the left and new on the right
and a starter that I had rebuilt
Great to see you working and painting again
Now you just have to assemble all those parts,,,,,like a real life jigsaw puzzle
Will that shift rod work with a six ???
Jacck
Yes the Triadwest headers work with a stock shift rod
I asked cause I've seen pics of sixer's with other rods . you obviuosly have done your homework .
Jack
p.s. Love the Blue !!!!!!!
Today Tom came by and helped me figure out most of the engine wiring. We also installed an inertia fuel pump cut off.
Yesterday I bead blasted the upper valve covers and the covers for the timing chain cases. Today I blasted the timing chain cases themselves. The valve cover and the case covers are going to be powder coated. the cases will just me natural. Before and after
I also used some scrap vinyl to over the "press" lable on the seat belts that wsa faded away and ugly. Not OEM, but the car is so modified, it doesn't matter
I also made a deal to move my car to a shared garage in Seattle. There's 5 GT3's there and a bunch of other cars in various stages of life. All the tools I could ever imagine and a lift. Sure will be easier to install the engine with some room to work.
Strange the photo double posted , but only shows once on the page where I typed.
Tonight's lesson.
You can't pre-assemble the wiring harness to the alternator because the wires only fit through the schrod in one direction. Well I got practice screwing the alternator to the fan housing
Billy, your car is looking GREAT!!!
Picked up the air cleaners from powder coat today. Wheels are done too, but the tires aren't mounted yet. I'm busy tomorrow, so I'll get them on Friday
Time for me to come down and take a look as well as help you I think, great progress! Where will you now install the engine, Ralph Meaney's place?
The shared shop is run by a fellow named Scott. I think it will be a great place to finish up the car.
Scott...Ralph...Colin... and renters
Today, I got my wheels back from the powder coated. Outside is silver and inside in custom color to match the car. I also got the valve covers and timing chain covers back. Now if the machine shop could just get to my engine
Just read all 6 pages, this is a great looking build. Keep up the very clean work. Can't wait to see this car completed.
Nice !! What kind of car is the steering wheel from? Very cool and the entire car !!
Wheels are on and the car is off the jackstands. I thought it was time to update my avatar, but with this tile operating system, I can't seem to resize the picture so it will work. I need to buy another camera. This phone has a crappy camera
SWEET!
Great looking car, love to see it in person.
Dave
Rods are on the crank and assembly is actually in progress. I was told that the Kennedy flywheel wasn't in balance (at least to the standard of the guy who is doing the engine). I'm glad he's got high standards.
I picked up two of the metal targa hinge covers and replaced the plastic ones that I had on the car. The plastic was OK, but they were both a little warped. I painted the covers with some undercoat spray and they came out looking very much like the leather on the pad. I'm sure glad I had used stainless steel square head screws on the pad. Made removal and installation much easier.
Today I added some vinyl under the seats where the carpet didn't cover the silver sound padding. I also installed
the thresholds that I got from 914Rubber.
Have just spent the last hour reading this when i should have been working
Must say, the standard of your work and attention to detail is impressive, car looks to be coming along very well.
A question, who retrimmed the seats and is it a kit that is available online ? They look great.
Cheers
Dale
Ordered a Quickjack today. In about a week I should be able to work under the car a lot easier
Billy,
I have everything ready on my end. Put together the hot start relay harness this weekend and tested. All OK, just waiting for the engine to be assembled to the point where we can complete the electrical work on the harness. Can't wait to see this all come together.
Don't forget the tach adapter for the MSD unit.
Tom
Nice build, looks like your doing a 3.0 or 3.2? What are you doing for heads?
Justin
I got a set of metal letter from Bruce Stone and cleaned them up with some sand paper. Didn't find the thread on spacing, so I got out the ruler and put them on as straight and even as I could. The camera phone just doesn't get the color right
Billy, you car is simply a stunner!! I can't to see and hear your car in person at a future GTG.
The lift arrived today. I'm splitting the cost with my brother. I'll post a photo of the car in the air later. For now, here's what it looks like right out of the box.
Looks nice, when will we see it in person, any work get-togethers planned to help with the car?
Waiting on the engine. Tom is helping me get all the electrical lined up, but engine goes in first before we run the wire.
Billy,
I will need about two hours prior to engine install to get everything ready. It can be after engine install, it will just be harder with the engine in.
Tom
Just read it all, and it looks awesome. Nice work, and great to see you getting a long term project going again. I'm interested to see how your Quickjack works as well. Hope you get the lump back soon!
I sent my oil pump off to Henry Schmit for a rebuild and flow improvement. Came back 6 days later! That's service!
Billy,
Got off my butt and finished your trans console bushing today. New one inner dia. is 0.590" while the old one was 0.617". So now it will be 0.027" tighter. New ones are 0.605". I guess they do not think the shift rod wears down over time as well as the bushing.
Tom
I slotted the brackets that attach the engine lid to the body and used the new quick disconnect hardware to install it. I don't remember if there is a rubber trim between the grill and the lid. I'll need to check 914 Rubber's site. Never painted the ribs under the grill black. Not sure if I'm going to or just leave it alone. Blue looks nice through the grill anyways.
Finely some good news on the engine. The heads have been machined and the new valve guides are installed and reamed. The builder is off in the San Juans for a week, but his assistant reports that assembly is close. I see where he ground some material from the inside of the head where the valves seat. I have know idea what he's doing. Something about flow is all I heard him say. Just trusting that he knows more than me on this stuff.
nice! looking good.
I was at the engine shop yesterday and found out that they were looking for the green vitron o rings that I had requested they use for sealing up the case. They had a gasket kit, but it has the blue rings (which I understand leak) and I want the engine to be as leak free as possible. Tried to order them from Pelican, but can't find them in the catalog. Left a "help" message for their parts department. Damn, I knew this would happen. Thing is ready to put together and were waiting for a part!
Got the o rings from Pelican and dropped them off at the builder yesterday. He said the assembly would begin next week.
Don't know if I'll ever install a radio, but since I left a hole in the fender, I put in an antenna. One of the best deals I got for this car. Only $15 from Pelican
Put the refinished trim on the sail panels today
Looking really nice man!
John
Mr Stone
Looking great Billy! I vote for painting the ribs black on your engine lid. While the blue looks nice. I think it looks better with the Ribs black. The ribs themselves really aren't that appealing(to me). So I like them being the same black as the grill. Having said that your car is gorgeous & will look great however you do it.
Great news on your motor . Good to hear things coming together for you. It's been a long haul but will be totally worth it. I see many awards coming your way
Got a call from the shop today and the engine is nearly done. They just need to do a few more things. Somehow I misplaced the oil sump cover (or its in their shop somewhere), so it looks like I need to get another one.
The engine work is nearly complete and I'll be bringing this baby home to get it ready for INSTALLATION. I need to figure out why the 2 bolts hanging out of the
timing chain covers are so long and if they should be replaced with shorter ones. There's also some long bolts for the engine mount that i suspect should be
Get that thing back on the road!
The engine is in my garage now!
So the engine goes together. First the alternator wires need to be pulled through the shroud and the rubber grommet needs to be set.
Then the wires slip through the inner cover that directs air evenly over the cylinders.
Then bolted to alternator.
Ground wire to alternator case is a challenge to do.
Fan housing strap was more fun.
And now I'm trying to decide what hardware to use to secure the shroud.
Just used some bolts that were in the scrap pile.
Looking nice Billy. Sent you a PM about the wiring harness mods.
Tom
When I checked the size of the holes in the shroud with the insulators, I could see that I needed to trim the holes a little larger. I've read that this is normal, so I was prepared.
It wasn't too hard to grind the holes, I just had to make sure that none of the dust ended up in the engine.
I figured I'd mock up the carbs and see if there was going to be any more problems, but it all fit great.
But I'm missing one of the fastener clips to finish the fiberglass block off trim that mounts to the front of the shroud. I have 3 of the 4. Anybody have an idea where to find them? I check 2 stores today, but no luck. I'm going to Ace tomorrow. They seem to have a large selection.
And I see that there are 3 holes in the shroud. Anybody know why they are there?
And do I need these 3 bolts sticking up from the block?
Looks great Billy! Something so perfect about triple throat Webers on a flat six.
Those 3 bolts are for an accelerator bracket for the CIS injection. You don't need them with carbs.
In regard to the 3 holes. The one on the right, in your picture (passenger side) gets a plastic plug, the one on the left is for a bolt holding a "heat source" funnel to push air down to the heat exchanger (see my picture). The one on top is for a plug that holds spark plug wires on CIS engines.
More work done today. First I have the braided ground cable attached
And the block off plates for the front of the shroud
And since I had a box of plastic plugs, I capped all the holes in the shroud
So this is where it stands. Now I need to figure out what sending units will be mounted to the engine and order up some new ones. Tomorrow I'm going to start the headers and fan belt. Then the tin
Too pretty to put in a car.
Not paint, they are powder coated. Wipes clean
Mcclendons has a pretty extensive metric selection. Try the Renton store.
Beautiful engine! I'll be curious to see how you like the PMO's.
WOW!!
Good things really do come to those who wait. . . I'm lovin' watching this car come together!!
That oughta run good!!!!
Headers were installed today, but i quickly learned that you can't Install both of them and turn the engine back over. So the second one goes on while you sit on the floor and try to hold the gaskets in place
And then the exhaust
But I assembled it without the gasket. I thought I had one. I'm going to look a little more before I order a set
The engine is looking closer to ready
Looks fantastic! Can't wait to see it in the car.
Just wondering if it might not be easier to put the headers on after the motor is in the car? You will definitely want them loose at the heads when you go to mount the muffler and bracket to the back of the transmission. I learned that the hard way on my 4.
Keep it up - I have been watching this thread for a loooonnnngggg time!
Seriously - get that baby in the car already!
Today the oil pressure sender arrived and I have the throw out bearing finished
Broke one of the exhaust studs yesterday while I was torking them up. I should have just replaced all the studs before I started!
Today I got the timing marks scratched in the flywheel and color coded them.
Here's the clutch mounted up
And the transmission mounted up without much fuss. Rebuilt starter needs one more bolt. I'll need to pick one up next week.
Now I need to find the gaskets for the muffler and get that mounted up.
Very nice
I needed the car high enough so I could slide the engine in, so by combining the new lift with some wood blocks, I got. I just didn't trust the lift, even though it has a built in cross bar to lock it. I stacked up some wood 4x6 blocks and stuck the jack stands on top. Just another level of safety. Not too much work to be done and I'll be dropping it back down to bolt in the engine.
While the 6 x6 blocks rarely fail, I always use something to tie them together like a crank strap or pipe strap with a wood screw into each block.
Working on details before the engine is in the way. I have the 14 pin connector back together and secured the brakelines so they didn't rub on the firewall.
I also ran the fuel lines up to the regulator and fastened them so they were out of the way. I drilled out the original holes for the lines so some larger grommets would fit. I need to find a clean way to block off the intake for the heater ducting that runs in the longs.
Billy, go to mcclendons and pick up a set of rubber pipe caps and ss screw clamps for the tubes. Next time run the center pieces of 6x at 90*. Less apt too tip over. What purpose does the piece of tubing, between the headers and case in post #182, serve?
supply or return?
I did find some rubber caps at McLendons and they worked perfect.
I need to clean off some of the dust!
I got the last of the engine tin mounted up and the throttle cable is done. I need to get the wiring organized and figure out where to mount the regulator.
I posted over at the bird site for suggestions on how to organize the harness. Figured lots of folks over there have done this. Any suggestions?
Mounted the MSD with nutserts or rivnuts (whatever you want to call them), so it could be removed and reinstalled easier. Pain in the ass making the single rubber
mount where the firewall angled back.
While I was mounting nutserts, I redid the fuel pressure regulator replacing the metal screws with bolts
Should have cleaned off the dust before I shot the photo
Billy,
Finished with the wiring diagram except for a few final issues. To get the oil pressure gage wiring to the console, I am using #9 on the car harness that ran to the heater lever. That wire is green/white and will have to be extended about a couple of feet to reach the console. I have the soldering type connectors and heat shrink to make a great splice, just need a length of green/white wire, 14 gage and about 10 feet long. I will need to add a connector to the engine harness at position #9 with about 6 to 8 feet of the green/white also. Would you have this wire already or can you get it? Also the coil wiring from the MSD to the coil is black( I have some) and orange ( don't have). Same thing here, about 8 to 10 feet of orange ga.12 (14 ga. will do also). If you can get those let me know and I won't search for them.
Here is a picture of what I have. View it and let me know if you see something I have missed or done incorrectly.
Tom
Very nice build !
Randy
Here's the new main fuse block that Tom makes. I'm not sure if the wiring is configured the way he likes it yet, but its easy to unbolt the bar and move them around.
Panelbilly,
First, your build is simply incredible and following this thread has been a treat.
Maybe I missed it in some earlier post but can you tell us about the origin/displacement of the engine?
The engine is a 3.0 out of a '79 SC. I picked it up from a shop that had agreed to sell it for a customer who was having a 3.2 or 3.6 put in for them. It was a running engine, but I never started it. Somewhere on this site is some documentation of me taking the engine apart
I installed some more nutserts in the back of the engine bay to bolt in the voltage regulator.
Nice build ...I like it
I had the vent tube cut off and a bung welded on the filler neck so the hose would fit to both it and the oil breather. Axles should be shipped tomorrow!
Looking forward to seeing this car running.
Today my brother Al and Jurgen (did I spell your name right) came over to give me a hand
Here's the engine ready to go
The axles were put on
The engine was slid into place
A few issues:
I need to get the plates that are on top of the transmission mounts and the big washer that goes on the bottom. Can't find them in my pile of parts.
I went to connect the axles to the transmission flange and realized the wheels would turn. It was the bolts! They're too long. Here's a photo of them on the transmission side. Looks to me like the wrong size got put with my order. I hope I didn't mess anything up when I tighten them to the wheel hubs
Super clean & looks great (engine) & thanks for "no plumbers ass" but....
Awesome Billy! So close to firing it up
Are we going to have a "fire it up" day where we gather on a Tuesday?
Teener Tuesday?!
That has to be so satisfying to finally see the engine and car together. Great job.
Congratulations!
Got the engine mounts in, but still need to tighten all the bolts
And here's the transmission mounts, but I need to flip over one of the top plates
And the axles are bolted up
Now to make sure the engine is lined up right. Not sure how this is done yet.
Man that is looking very nice.
What's with the dust on your suspension? Just kidding! Your car is awesome. Mine will never be that clean.
Jim came by yesterday and helped me get some more work done. We got some of the bolts in the tin on. Its one of those jobs that takes one person
above the engine and the other under. We got the transmission rod installed, but I still need to do the alignment.
I got the muffler ( or is it called a final) installed and I relocated the MSD box because it was too close to the rain hat.
I was hoping to get the clutch and trottle cables done, but needed to order some hardware to finish the job. Also needed to order the hard oil line that comes off the bottom of the case.
I got the fittings attached to the braided lines. That was more work than I expected. I was hoping that I measured them correctly, because they looked short.
I attached the bottom oil line to the tank before installing it
Then I bolted in the tank
Maybe this will help me to remember what a pain it is
to get at the back bolt
Here's the view of the line as it comes off the oil cooler
Its not touching anything, that's an optical illusion.
My son in law dropped of a claws foot wrench I can use to
tighten the fitting
And I still need to install a support, but the drain is in a good location
nice work Billy ..address that E brake cable touching the header
Got the filler neck. filter mount, and all of the rest of the oil system finished today
Needed to use a mirror to put the bolts into the filter mount.
Got the fuel lines and filters connected today
Changed the angle of the oil pressure gauge on the block, so it
is easier to read
and added some hangers for the cables so they were out of the way
Then i connected the clutch cable so I could figure out how much
I want to have it shortened. There's a guy in town that makes cables and he said most likely he could fix it for me
I go the bolt to plug the o2 hole in the headers
and I have the battery installed, but didn't do the negative yet
I attached the negative side of the battery today. Headlights were backwards. Raised in the off position and lowered in the on. Easy fix. The alarm for the key in with the door open seems to be going off sometimes. I'm thinking that's one of the door switches.
Added oil.
I cranked the engine over just to see if the starter worked and everything sounded normal. I need to find my spark plugs. They must be somewhere.
I thought I'd update the build thread now that the car is moving under its own power.
I installed a new exterior mirror on the driver's side. It sure is nice to be able to see what's behind me.
And thanks to Bob I have a combo gauge now
and I drove the car to gas station tonight. I still need to bleed my brakes and get
an alignment. Front end sure is light under power and I'm thinking a corner balance will reduce that.
Outstanding! Ready for prime time.
Very cool thread to read and an inspiration for guys like me who are starting out on the other side of that tunnel that you are almost all the way out of.
unbelievable!
Congratulations! You should be proud of this build. Look at what a beautiful car you now have. Awesome.
Very nice
Time to tie up some details. I got the alignment done last week and one of the trailing arms is bent, so it will need to be replaced. Even though its not perfect, the drive home
from the shop was much better than the one before the alignment.
I got the front spoiler painted with some texture paint so it will be a reasonable match to the LineX coating I had put on the rockers. This winter, I'm going to modify the spoiler
so it matches the flairs better, but for now, it acceptable.
I got the wipers painted and installed.
Finely, I installed the engine cover. The car looked kind of cool when the engine was exposed, but now it looks complete.
Now I need do get all the gauges operational
Its beautiful!
I got my new targa trim in the mail today
and here it is on the car
Looking beautiful
Where did the front spoiler come from? Is it wider for the flares?
Awesome build, Billy! Makes me wish I painted my shroud and valve covers when the engine was out.
Purdy sweet Billy.
Let's see a pic of the whole car Billy!
you have got to get us a nice long DRIVE video once you get her on the road. she is beautiful
Lots of little details to finish up. Got some badging mounted today. Now the holes in the trunk are covered up
Well documented and an EXCELLENT BUILD!
