Printable Version of Topic
914World.com _ 914World Garage _ Just had to have them!
Posted by: pcar916 Sep 15 2010, 01:50 PM
Lookin' good!!!
Posted by: Sleepin Sep 15 2010, 02:32 PM
Very nice!!!!
Posted by: type47 Sep 16 2010, 06:11 AM
What stub axels did you use?
Posted by: Eric_Shea Sep 16 2010, 07:15 AM
Looks awesome Mike.
Hows the first drive impression with the sway bars? I remember that being the only thing I added to my -6. All 914's should have come with them... Manditory.
Posted by: mgphoto Sep 16 2010, 10:01 AM
QUOTE(type47 @ Sep 16 2010, 05:11 AM)
Hey type47,
The very last items I found were a pair of 914/6 stub axles, I was going with a 4 lug converted hub set up, so when I found the stub axles I changed, since I had a pair of '72 911 hubs on the shelf that had 60mm studs which I swapped out for the standard 45mm,) I am a bit happier because the 4 lug hub does not line up with the screw holes in the brake disk. Fastening the disk to the hub this makes it much easier to adjust the venting clearance and the brake disk is centered on the hub so balance does not become an issue.
Mike
Posted by: mgphoto Sep 16 2010, 12:17 PM
QUOTE(Eric_Shea @ Sep 16 2010, 06:15 AM)
Looks awesome Mike.
Hello Eric,
First off, thanks, without your help I would never have gotten this off the ground.
As for the anti-sway bars, I can tell you that the car seems to want to take the turns before I even think about steering input! I have not taken any really fast corners yet as I need to fix an exhaust leak and bleed the brakes again.
Mike
Posted by: Eric_Shea Sep 16 2010, 03:56 PM
Gone but not forgotten is that "I'm piloting a Chris*Craft" feeling! LOL
Posted by: oldschool Sep 16 2010, 05:04 PM
QUOTE(mgphoto @ Sep 16 2010, 09:01 AM)
Hey type47,
Mike
what do you do in the media world?
Posted by: mgphoto Sep 16 2010, 05:13 PM
bump
Posted by: mgphoto Sep 16 2010, 05:14 PM
bump
Posted by: mgphoto Sep 16 2010, 05:16 PM
QUOTE(oldschool @ Sep 16 2010, 04:04 PM)
Hey type47,
Mike
reconstituted photojournalist, I am now a Hollywood Celebrity event photographer, I own a website called Superstarimages.com also videographer for the Hollywood Chamber of Commerce for the world famous Hollywood Walk of Fame.
Posted by: oldschool Sep 16 2010, 05:39 PM
QUOTE(mgphoto @ Sep 16 2010, 04:16 PM)
Hey type47,
Mike
Very cool, I'm in the local 600,If you need any help let me know.
Posted by: mgphoto Oct 24 2010, 01:05 AM
A bit more than a month now and I needed to remove the drivers side front strut to tighten the ring holding the cartridge in the strut, (might have forgotten to tighten it down on assembly.)
I readjusted the front wheel bearing, used the Motive Power Bleeder to bleed the brakes, also cracked the fittings on the brake pressure regulator to bleed it, now the pedal is really firm.
The car handles GREAT! Glad I did it, anti sway bars and all....
Only one regret, I didn't install cross drilled rotors, I need to bring the weight down.
