I know this relay was involved in the seat switches, which mine is by passed, but does it run anything else on the car?
Was there a smaller relay next to it?
Mine does not seem to have the smaller one.
Thanks
large is the interlock the small is the buzzer.
your yellow and yellow with red leads have not been connected together (factory bypass) so you will have to keep your relay plugged in.
I have one in my '75 and it was bypassed. I'ed like to know how they were wired and worked. Is there anything out there that explains how each of the terminals function ?
Per George's reply: What is the interlock? All I had ever heard of was the buzzer.
I would like to know how to remove it permanently.
Is there a difference per each model year?
Do all years have the buzzer? The Interlock?
Good question. For sure 74 and later. Not sure about earlier cars.
You need the double male connector.
What about all the other (under the seat) wires? I would like to delete as much as I can. Thanks, mark
I had my father (retired EE) reverse engineer this thing a few years back...maybe more than a few.
I posted the diagram here (club/world prior to break)
I no longer have the diagram...it may be here.
Its all useless stuff...
Its all related to the seats pressure sensors, the seatbelt latch sensors, and the door opening light switch/sensor, and all of that starts a buzzer (which needs power) and lights up a light on the dash( which also gets power)
the rest of the wires are grounds.
Rich
I want mine gone to... I'd love to dredge up Rich's thread. It should be here somewhere.
From Blowsby, Rich has posts here also;
http://www.914world.com/bbs2/index.php?showtopic=41066&st=25
Dave Darling;
The only power-in on the relay is on the following terminals:
15 (black wire) constant power.
L (yellow/red wire) switched power--after it goes through the warning light.
C (yellow wire) power when the key is in "start" only.
H (grey/yellow wire) switched power, which runs the "door ajar" buzzer
Another classic thread resource!
I agree, re-wire that crap.
FWIW, My '74 still has the interlock. I think it's kind of charming or something. Although annoying when all you want to do is test something that requires a running engine.
It's a little strange how it works, and it may be due to some loose connections, but here's what I've found:
1. The car won't start unless the driver's belt is buckled.
2. If there's a passenger in the RH seat (pressure sensor), the car won't start unless both belts are buckled. (In my car, this one is sporadic - sometimes works unbuckled)
3. The seat belt latch has to have a pretty solid connection. I've had to unbuckle/rebuckle to get it to work on occasion.
4. This is the one that confuses me - When I have to start the engine a few times in a row, I've tried to buckle the belt without being in the car; just across the seatback. Then I sit down on top of belt so that I can clutch/brake and turn the key... and it doesn't work! Somehow it knows I'm faking and I've had to unbuckle, put the seatbelt on correctly, and buckle before the engine will start.
Supposedly, there's some sort of bypass... holding the key to "start" for several seconds, or trying several times in a row... i just can't remember what it is.
The "bypass" is give it the "float test"......then connect the yellow's together.....
