For the driver's side, is the general practice to remove the P-brake handle resting post or relieve the Engman panel and leave the post in place?
Also, I've read a couple opinions about how much "spread" to introduce to the door way to allow for shrinkage after the tub cools down--and to compensate for sag in the body once it's back on its wheels.
What's my best strategy?
I took both doors off (damn things weigh a ton), made braces for the doors out of 1 inch square tubing and welded brackets to the tubing to bolt in the doorway so the body didn't flex. I also drilled all the holes out to 5/8 inch to make stronger welds. I think it's a great idea to do this. It is a very good kit, takes a little massaging to get it fit up right but you will be pleased with the results.
Cheers, Elliot
Thanks, guys.
What I have is braces I made from 1" square tubing with integral turnbuckles. They fasten at the upper shoulder belt mount and are tacked on top of the longs as far forward as i could get them. The reason for this was so I could adjust them with the doors in place. I kept the roof clipped in place and then removed the door so I could cut out the inner longs, jack post area, and wheelhouse. All that grunt work is done now with new steel in place and I finally made the plunge on getting the Engman kit. Trouble is, my braces are on top of the longs--interfering with where the stiffening kit will go.
My plan (which I started today) is to grind the welds and pull out one brace at a time. I will then clamp the Engman side piece in place and weld it just in the area which would be under the foot of my chassis brace so I could re-tack the brace. Then, put the door back on to check gaps again, adjust the brace as necessary, remove door, and finish welding in the kit.
I just wasn't sure if it was as easy as that or if I needed to actually put expansion tension on my braces as I have read in the past.
And then the P-brake post also raised the question. I had never seen anyone else addressing it being in the way of fitment. I will say I was blown away by the design, quality, and finish of the kit's parts. Nice stuff to say the least.
Cut the Engman piece to fit.
I have never braced a chassis while welding in the kit and I've never had a problem with shrinkage. ( ) I usually set up a floor jack in the middle of the long and raise that side wheels off the ground slightly. Then just weld slowly.
Oh and most importantly, measure the gap between the window hoop and the roll bar and keep measuring as you go.
