Is there any reason this master cylinder wouldn't fit my 1975 1.8L? The ad lists it as '72 and older only. They say the have only the ATE part ($309) for the 1975.
http://cgi.ebay.com/ebaymotors/911-912-914-Porsche-Master-Cylinder-w-Pressure-Switch- _W0QQcmdZViewItemQQhashZitem27b863b5e3QQitemZ170597266915QQptZMotorsQ5fCarQ5fTru
ckQ5fPartsQ5fAccessories#ht_2274wt_996
I don't see any reason why not except that it's a Chinese MC and they had a very high failure rate (and it's retailing higher than most others sell them for). So much so that Pelican stopped carrying them (so I was told).
I'm not a big China hater but, in this case I'd probably use ATE and get the 19mm which is much less than the 17mm.
Their quality may come up in time... but I wouldn't want to guess with brakes.
if 914 355 012 00 (17mm) or 911 355 012 02 (19mm) it will fit the ate are expensive 012 just over 200 and the 19 just under 200 but the "euro" parts 19mm is around this part you are showing.
Does AA sell rebuild kits for the OE Master Cylinder?
Is the 19mm a direct replacement, or will I need to do other modifications?
we used to but they have been discontinued by the factory and also ate
