Welcome to my engine build thread. I finally started building my engine today after waiting a couple of months to get machine work done and collect parts. This thread will be updated and this first post will be edited to show the stats of the engine as it's built.
Engine Stats:
57 cc combustion chamber, 2 cc valve relief.
96 mm pistons, stock 71 mm crank balanced, 0.050 deck height.
8.54 compression ratio.
30MM Shadek oil pump.
Drill and tap oil galley plugs.
Web Cam from Jake for 2056 with stock injection.
Red indicates the newest items.
I started off the build by attaching the cam gear to my new WebCam. Wasn't a bolt on procedure as you can see. I did my own machine work this time because I'm on a deadline, but I would have these modifications done professionally in the future.
First I had to drill the holes in the cam gear to fit the bolts.
Then I had to spot face the washer depressions to fit the new lock washers.
Used red loctite on the bolts.
All together.
Tomorrow I drill and tap the galley plugs.
A man of many talents.
Great thread.....A future classic.
Today was case cleaning day. Spent about 2 hours and a case of brake cleaner making it shiny again. I'm very happy with the results. Next step... tapping the case for oil galley plugs.
It's a custom direct from Jake. I don't know what it is.
Modified my 30MM Shadek oil pump last night. The two bosses on the back must be cut down a significant amount to clear the cam. I used the same cutting bit I used to widen the cam washer divots to cut away sections of the bosses at a time. Took me about 3 hours because I took so many small cuts so I wouldn't take too much off. One thing I learned is that you have to cut the immobile post (not the spinning post) not push it through farther. If you tap the immobile post out farther instead of cutting it the pump gear will hang up because the shaft is a tiny bit bigger where it's pressed into the housing.
Here is the pump before I did any cutting. The feeler gauges show how much I'll have to cut.
I bought the oil galley plug set from aircooled.net. It comes with 11 plugs. It would have been nice if they had a diagram to show where they all are. I didn't really have a problem finding any of them, but it still would have been nice. Also, it would have been nice if they sold the drills and taps to finish the job as well. Yellow arrows in the pictures show the case plugs. The red arrows are spots that are not plugs that are commonly confused. The plugs are not screwed all the way in at this time.
Do you have a hand model for a stand in???? Mine look like they went thru the WWII.....no scars and the nails are clean....how ya do it?
Good luck on your project....
Burger grease, softens hands while you do dish....uh, eat dinner.
You guys should see his luxurious curly locks. Truely a lady killer
Those are great pics of the oil galley installation!
Im going to do mine in the next few weeks when i get my case back from rimco and clean it up. They are all saved on my computer and Im going to print them out for reference when I do the conversion.
I hope my engine is that clean... Did you just use that case of brake cleaner?
A case of brake cleaner and that parts cleaning brush (with the plastic bristles) worked wonders. It ain't perfect, but it's really damn clean.
I hope you're using gloves and a respirator with all that brake cleaner. What about steam cleaning or dipping?
Someday I'm going to try electro-polishing a case. It kinda worries me about the bearing surfaces possibly getting damaged by the process, but I have some ideas to take care of that. That would bring the whole case inside and out to a super polished finish.
I like the 1 gallon Berrymann's part solvent, a plastic tub and the brush. No good as a BBQ sauce.
