I have now attended the Hershey Porsche show three times without an operational teener...NOT being part of the caravan is getting old.
Finally got my new inner long welded in with doubler plates on all seams. Verified the incline of the new long with an incline gauge (with the car level) following Jeff Hails build thread. Door operates well! Entire inner long has been coated with rust encapsulator.
Still have a long way to go but I am hoping that this was the toughest part.
Thanks to Scotty B, Jeff Hail, and everyone else who has posted a build thread on this topic. I have read all of them & learned a lot.
Bob
That looks real good Bob!
That long is a thing of beauty. Good job
Looking good Bob. Keep up the momentum. Remember only 11 months left until Hershey 2012
Looking good Bob, stay focused and keep up the good work!
Bob, I agree, your work looks great . Keep it up. I have not made the trip to Hershey, but plan to in the future. I've mostly been lurking here the last year or two. I am hoping I may have my car roadworthy by next year as well. I have 2 boys in college, so even though I have time, my budget is the limiting factor.
Nice job Bob, ya hob nob snob:)
I think you should post some action shots next time. Let us see you working.
There that's my tip for motivation
is it done yet ?
Bob, that is a thing of beauty! I'm kinda jealous .... I've haven't been that intimate with either one of my cars.
Looks great!
Now drive it down here to York and lets have a beer
Finished reinforceing plate:
Cutting back end of new long...indexed off rear trunk torsion bar bolt:
Needed some side pressure on the inside of the new long in the rear so it would fit flush, had to improvise with a wedged in 2 X 4:
Got some more work done over the weekend.
New channel formed and welded into front trunk channel....
Before:
After:
A shingle tab blew off the neighbors house, they werent looking for it, and I needed a new tar plug for the inner long, as I melted my old one while welding. Scraped most of the stones off of it...not show quality, but will work fine for me.
Jack post support welded on with advice from the world in another thread:
Holy crap!
Fantastic!
Zach
More weekend progress...outer clam shell welded on after coating inside with weld thru primer/rust encapsulator & seam sealing the heater tube. I still had part of the original clamshell in the front, so I was able to index proper fore/aft placement by taking measurements from the cheese head screws in the bottom of the still intact drivers side clam shell. A long straight edge along the bottom kept it true horizontally.
Looks like someone is gaining a little bit of momentum
Very nice Bob, you look like you have been taking lessons from Scotty. Very impressive work. Git 'er Done!
Beautiful work like that is the reason we never want to give up our cars, I don't think there are many shops that would be that picky about angles and straight lines. My hat off to you, gonna be a great example of a nice teener when done, hope to see it at Hershey or some other event in the future. Oh and don't forget what a great motivator cash is, your jackstands will bring a better than normal amount when you are finished if you show pics of what they have been holding up!
Ian Stott
Moncton
Canada
While waiting on the inner "ply" for the outer wheelhouse from Restoration Design, I decided to start tackling the passenger side firewall and some other miscellaneous items. This is what I started with:
I opted to cut out all rusted metal in one chunk:
Cutting - continued:
Luckily, it looks like the rust only crept about an inch or so up into the firewall...this shot is looking between inner & outer firewall.
The damaged area:
Short on money, but long on time & sheet metal, I decided to try to fabricate a replacement piece...started by cutting the bottom curved piece at the base of the firewall and went from there. The most difficult part for me was the compound bend, where I had to cut slits to get the right contour, then fill with weld. I left it a little long in all dimensions, so I could trim it as needed for the final fit. Still need to weld all seams on this, but I am pleased with how it is shaping up:
Fabrication - continued:
Finally finished the front hood channel. One section was fabricated & replaced. All rust was treated with Ospho, two coats of Rust Bullet then two coats of brushed on acrylic enamel:
My virtual junkyard:
Shingle tar plug glued in:
Nice work!
Looking good Bob keep it up
Thanks gents!
11 months till Hershey...11 months till Hershey...11 months till Hershey
Like Spraggi says, don't set yourself a deadline
Zipped up the seams on the replacement floorpan piece today, the piece is now in the crawl space (paint room) drying, after getting sprayed with primer:
Pulled out the gas tank, following the Pelican article...was not surprised to find more rust under the tank:
Found another large spot of rust where the front trunk latch cable attaches under the dash. The mounting point is completely gone and all that remains is a hole. My question is...what would cause this area to rust out so bad? Fender to cowl seals?
Finally, my gas tank is rusty inside. How rusty is too rusty? Can I dump all the rust out and expect this to not get much worse if I keep gas in the tank? My goal here is a reliable daily driver...am I asking for trouble if I don't re-seal this tank?
Restoration Design shipped me the inner ply for the wheelhouse section last week:
Drilled holes for the rosette welds:
Fabricated a cover plate for inside of the jack post & welded it on. Sprayed both parts with weld thru primer:
Two plies welded together:
Finished product...weld thru primer on the seams, rust encapsulator everywhere else. I hope to start welding this in tomorrow:
Dropped the rusty fuel tank off at the radiator shop today. The guy said he needed to drop it in an acid bath and see what is left before we make a determination. I had to take it apart at the shop and I forgot to take note of the layout of the tank outlets. Does the large one go in the front or rear with the tank in the car? Sock on the larger line?
The area where the front hood release was rusted so bad, the hood release was just hanging there under the dash, supported only by the cable tube:
The cable assembly had to be removed to gain access to the area. Plus, the bolts were a rusty mess. Vice grips were the only way to break them loose:
Welding upside down really sucks! I had better access to this from under the dash. After hitting everything with a dremmel tool wire wheel attachment, I bent up a doubler plate out of 20ga sheet metal and tacked it on with my body folded up under the dash. I had some burn through on some of the weaker metal so I had to rule out completely welding the seams, but was able to get it tacked in place. Raked my spine on the body braces twice getting out of the car - ouch.
With the burn thru problem and the fact that it was such a PITA working in this tight space, I opted use a liberal application of JB Weld on both top & bottom to fill between the tack welds. It is certainly not my best work, but I believe it will be strong and functional. This area will be inspected once in a while after the car is on the road:
From above:
From below:
I am not sure my liver can survive the rush of 40th birthday parties this Spring...but anyhow:
Got word from the radiator shop last week that my tank was repairable. They said they can patch, clean and seal it for no more than $200. It seemed reasonable to me, so I pulled the trigger on it.
Picked up metric allen bolts at Home Depot for the front hood latch attachment point:
After reading a thread on the world about proper cleaning of a transmission, I realized that I never plugged the overflow when pressure washing mine at the local car wash last year. I got worried about water in there, so I drained the old fluid out...did not see any water but the magnetic drain plug was chock full of filings. Tranny was re-filled with proper fluid and put back in the shed:
2nd ply of the outer wheelhouse was welded in last week, prepped and ready to be installed:
10 months till Hershey...10 months till Hershey. It was a scorcher today. But I really wanted to get the outer wheelhouse welded in:
I measured the distance from the middle screw on the original drivers side long to a plumb bob off the front of the jack post. Matched the 20.5" measurement on the passenger side for proper fore-aft fit:
Everything lined up pretty well, except for one section at the rear of the inner long. This area was rebuilt 6" at a time hand formed in a vice. The last section seemed to twist up in the rear when I was welding it in. However, it lined up well with the inner long section previously welded in. All things considered, I decided to add a small extension piece to the bottom so the rosette welds would line up properly:
Final fitment outside:
Final fitment inside:
Fabricated & installed a doubler plate for the rear...had to modify it several times to clear the inner ply of the outer wheelhouse:
DAMNIT!!! After filling about 7 rosettes, I realized I forgot to drill the holes directly above the jack post support. Improvised with a large screwdriver wedged in to get enough clearance to drill new holes. Snuck a dremmel tool in to deburr the backside of the holes:
I found the fitment of this piece to be challenging. It was clamped on and removed about 25 times before finally filling the first rosette. Probably due to the "learn as you go method." Overall, I am pleased with how it has turned out so for. The heat started to get to me, so it was time for a cold beer and cold A/C. Will zip up the seams this week and should get the gas tank back:
Picked up my gas tank from the radiator shop last week. Cleaned, patched, sealed, pressure tested, primed and painted for $160. The only problem is that they painted it in gloss black. So I spent a few hours sanding it down and re-painted it in semi-gloss black. The shop used "Red Coat" as the sealer:
Looking good Bob keep with it. Hershey is right around the corner
Welded up the seams on the outer wheelhouse, then started grinding...
The inner long needed some trimming at the bottom for a flush fit. A cutoff wheel made quick work of this:
"Finished" job - outer:
"Finished" job - inner:
Closeup of rear seam:
There remains a slight (about 3/16") alignment issue with the upper portion of the lower wheelhouse under the rear door jamb. I should be able to get this aligned with a hammer and block of wood.
Progress continues at a slow, but steady pace.
Continued working on the area under the gas tank and the front trunk attachment point. Areas were cleaned, rust treated with ospho, followed by two coats of rust bullet and new seam sealer. Note to self...when working upside down applying opsho with a hollow acid brush, do not hold the brush in your mouth while getting out from under the dash.
A crazy hail storm interrupted my work on Thursday...it sounded like someone was shooting a machine gun at the house!
Put the tank back together with a new Foley fuel sock. The threads were a little gummed up from the red coat the shop used to seal the tank, so I had to run a tap through the holes to clean them out. The fiber washer on the small line was in bad shape so i picked one up at the local ACE hardware and modified it to fit.
Flash rust is a bitch! I understand that it has been humid and that my washer & dryer are in my garage, but this is ridiculous. This area was freshly welded just last week:
I took a look at all the other bare metal...it was happeneing everywhere. Time to treat with ospho and get some primer on:
I wasn't in the mood to spray primer yesterday, but I must admit that finally seeing these areas a single color was motivating. Primer - inner long:
This project has become bigger than my one car garage can handle...teener parts now have a strong foothold in my shed as well:
Shed - continued:
FWIW the panel fit issues you have encounterd are 100% normal. The aftermarket pieces just do not line up perfectly and will always need some reshaping to fit the car. Thanks for posting pics of those spots so everyone can see what they are in for. Keep up the good work
Got a decent amount done last weekend. Installed a section of the Restoration Design upper wheelhouse panel. I didnt need a whole lot of it, but I did need the indented section. Indexing this piece was a challenge. All I had to go off was matching up the curve on the indented section of the piece I cut out to the new panel and a bevel gauge to get the proper pitch of the rise. I opted to weld a bolt on to the piece so I could hold it in place and tweak it slightly while getting it tacked into place. The panel seemed to shrink along the bottom edge while tacking it in place, so I had to bend the back of it out and trim it down for a flush fit. I ended up with a non-weldable gap where the lower wheelhouse meets the original metal, so I had to cut up a small filler plate for this area.
I was also able to get the rear chunk of floorpan (previously made) welded into the passenger side floor. After trimming it up a bit, it fit quite well!
Finished up the repair of the front hood cable attachment point. One coat ospho, two coats Rust Bullet, seam sealer and two coats of brushed on acrylic enamel.
Wow Bob, your almost done, Looks great!!
Wow, keep up the good work!
It's nice to watch someone else work.
You're doing a great job. Keep it up.
Problems with both the Mazda and motorcycle have cut into my 914 time over the last few weeks, but I was able to get some more done.
Drilled holes in new metal patch on drivers side, installed new allen bolts and re-ran front hood cable.
Took a wire wheel to the inner wheelhouse section to prep for primer...discovered a lot of surface rust in ths area that will require treatment before primer.
After reading other build threads on here, I have been pretty vigilant about keeping an eye on the door gaps and taking my time welding to keep the heat down. I have made a couple of small tweaks along the way, but the gaps have held well. Checking gaps after welding in the upper wheelhouse section, there was a more noticeable difference. After some adjustments to the turnbuckle, I was able to able to get it within .030" of the drivers side and still have the door close OK. The door now requires more effort to close it and will need some final tweaking.
Ended up with a bit of a mess where the floorpan meets the firewall on the passenger side & will have to make pieces to fill the areas. Hindsight being 20/20, I would have bought this section(s) welded them in and been done by now.
Needed to fabricate the verticals of both the inner and outer firewall. I was able to get a close measurement by measuring the rise of the old piece and adding the width of the metal cutting wheel. Something warped in the floor, leaving too narrow of a gap on the outside. Had to drive a solid wedge between the original firewall and new floorpan to pry these apart for the correct spacing and weld a chunk in to hold it in place. The wood splitting mall was crude but effective.
Outer firewall patch:
For the front firewall patch, I opted to make a template to simplify things:
Both pieces finished:
Bob you are making great progress keep it up
Welded in the lower inner vertical firewall piece:
I had a large rusted section above the long on the firewall that had to be farbricated and replaced. Went with a posterboard template to get the shape accurate:
Finally, a solid inner floorpan on the passenger side! I decided to prep this 1/4 of the pan for finish...one coat of rust converter applied:
Nice work
Looking good Bob, I better see this car at Hershey if I drive up for the 3rd year in a row.
Seeing two stellar teeners at Matt's cookout as hurricane Irene approached made me realize it was time to get back to work.
18 GA patch pieces were made to close up the hole in the outer firewall:
Finished the rear passenger side floor pan on the inside. Two coats ospho (on rusty areas) followed by two coats rust bullet (again, only on rusty or pitted areas) two coats rust encapsulator and new seam sealer. It was nice to look at a small section of the car and say "this is done."
The jigsaw puzzle that is the rear floor pan on the passenger side continues to get pieced together. It became very complicated trying to make this part all in one shot, so I decided to go with a section at a time and weld it all together:
Experienced some cracking after applying the initial primer on the upper wheelhouse. I suspect it is from over-doing it on the rust converter, as I have run into this before using the product. From now on, I will only apply one coat. Wire brushed affected areas and re-sprayed primer:
My welding skills have improved significantly, but it still seems like I spend a ton of time grinding...
Tying the firewall, floorpan, and inner long together has been a challenge. Two small patch panels were fabricated and welded in where the outer firewall curves rearward to meet the inner long. Final piece welded into the floorpan where it meets the long. Took the wire wheel to the whole area to prep for a light Ospho treatment in one area and I hope to get this area primed tomorrow:
Tomas donated a used set of plastic MC lines to the cause as my originals were accidently strafed by a wire wheel. While the Ospho was drying, I installed them, taking any means possible not to disturb the new master cylinder. Thanks Tomas! Started cleaning up my rusty muffler bracket as well:
Great progress!
You are getting there.
It will be worth it.
John
Shot two coats of primer on the rebuilt pass side firewall/floor pan. It was a lot of patchwork, but I am pleased with how it all worked out.
Cleaned, treated and painted the exhaust bracket.
Very nice work; you should be proud.
Looking good Bob whats the current status?
The outer suspension console and engine mount were completely shot on my car, so I bought a relatively rust free chunk of longitudinal from a member of 914world and started disassembly. What a PITA drilling out all of the spot welds and grinding down the outer welds, then beating the pieces apart with a large hammer and screwdriver. My "original" inner suspension console must have been replaced at some point, because it was in better condition than the one I bought as part of the used longitudinal. All three pieces were treated with POR-15 on the inside while the weldable areas were shot with weld thru primer. I continually ran a piece of safety wire through the drain hole of the inner console while treating with POR to make sure the drain remained open.
Parts:
I decided to start with the inner console. It was a real bitch trying to measure exactly 28 1/4 inches from the hole in the center of the firewall to the front of the suspension ear hole with a tape measure while holding everything in place. Plus, this needs to be spot on for proper alignment. I decided to cut a piece of steel brake line to exactly 28.25" to simplify the task.
The inner console had a little bit of "rock" to it on the new long that seemed to be coming from the indent behind the bracket. Had to beat this area with a hammer for proper fit:
Still nervous about having the measurements EXACTLY right before tack welding this thing in place...I decided to call it a night.
Great Job!
Keep it up!
Got the inner suspension console tack welded in place today.
Figured out the slight rock I had in the piece was from two previous rosette welds on the new longitudinal not ground completely flush.
I spent quite a bit of time bending, hammering and adjusting the areas to be welded on this piece, to make sure it fit as good as possible. There is a slight gap at the top of suspension console that will be addressed with a big hammer and block of wood after the rest of it is tacked on.
Took one more measurement, from both the front and rear firewall, dead on both ways.
I started with the leading edge, because of the alignment mark. I was amazed to see how much the whole console moved forward from two tack welds! Re-checked the measurements and they were off. Had to grind off the spot welds with a dremmel tool and start over again.
The trailing edge needed some side pressure before tacking it on, so I broke out the special tools.
Needed to put a little pressure on the bottom of the console before tacking the bottom on.
Before finishing all the welding on this piece, I double checked all measurements. Firewall hole to front of inner console hole was still dead on and side to side came in at 33.5".
As another sanity check, I leveled the car and took a measurement from the garage floor to the bottom of the ear and checked it against the original drivers side...both were right at 14.25".
There was a slight gap (less than 1/8") at the top of this piece where it forms around the top of the long...reformed with a big hammer while tack welded in place.
Top edge before adjustment:
I decided to seam weld this piece on. I am re-using a replacement piece in very good shape installed by the PO. There wasn't enough meat on the some of the edges to drill holes for rosettes. I had to re-use the previous monster rosette holes on the top. I took my time and cooled the area with compressed air after every few welds. The roughest part was welding the bottom area near the seam where the inner and outer long meet upside down.
Well done my man
Beautiful work! Thanks for posting all of your photos. Excellent!
Indexing the right engine bar mount took some time. I had saved the original chunk of long I removed the mount from, so I re-aligned the holes and took a measurement from the edge of the inner suspension console to the edge of the mount and came up with 1 3/8". The suspension console that I welded in was aftermarket and did not have as much meat on the edges as the factory piece. I measured off the start of the bend of the installed console and marked a line on the long to match the factory edge. Up & down was verified at 3 5/16" (taken from the original long) with a combination square from the top of the mount to the top of the edge of the suspension console.
Used a big C clamp & jack to hold it in position for welding and verified all measurements one more time:
Re-filled the factory rosettes and seam welded a few 1" or so sections on both sides.
impressive!!!
Looking good Bob dont make me break out the whip. You know its right around the corner. Your work is looking really good. Glad you are remeasuring everything before welding
Fitted the engine shelf yesterday & today. This piece caused me a lot of frustration, largely because the front and rear firewall sections that hold the engine seal channel were not there to index from.
I got nervous that the engine mount was welded in too high, so I leveled the car and took measurements from the floor to the bottom of the mount. Driver and passenger side both came in at exactly 12". Additionally, I double checked all other measurements on the engine mount. Everything was good.
The shelf itself needed to be flattened a bit in the front where it meets the inner long. I also had to adjust the top edge of the engine mount in the front where I had welded a repair in.
I will need to fabricate both front & rear firewall metal to tie them into the engine shelf. Waiting until these pieces are made until I start welding anything. Filled holes in the rear firewall left from removal of the old sheet metal.
Fabricated and installed the section of rear firewall that holds the rear engine bay seal. I leveled the car and measured from the floor to the lower edge of the engine shelf on the drivers side (19 5/16") so I could determine proper height of the passenger side engine shelf:
Made a template out of poster board for the replacement piece. I was able to use the mirror image of the drivers side to get the proper curve:
I measured the thickness of the original metal - it was about 19GA. I opted to use 18GA metal for the repair panel. Finished product:
Very nice work, keep the pics coming.
Got some more done today. Started treating rust on the front firewall engine shelf. Part of it is missing and some areas have a little rust - thru, so I fabricated a doubler that will be welded on the bottom. It will serve two purposes...beef up the remaining factory shelf and serve as a backer/support for the piece I need to fabricate to tie in the passenger side engine shelf. I had to make relief cuts every 3/4" so I could match the factory bend:
There were a couple of small holes under the gas tank on the passenger side that needed to be patched. This will not be a show car, just a fun, reliable daily driver. I cleaned the area, fabricated a doubler for the bottom, rosette welded it on and sealed the edges with JB-Weld:
Started fitting the outside suspension ear before I ran out of steam.
Awsome work, Keep away
we are on the same journey!!
With the nice weather, I had to finish some painting on the house...but I was able to get a little more done.
Welded the engine bay seal channel on the rear firewall. This product was not available pre-bent from Restoration Design, so I had to make relief cuts to get the proper bend:
Treated the rear driver side engine shelf with ospho:
Brushed two top coats of acrylic enamel on the patch panel, passenger side under the gas tank:
Thanks Andy...do you have a build thread going? I am surprised that you have these rust issues on the left coast!
Bob
[/quote]
Really, Its all that work your putting in on your car, no time to watch 914 World
let the sharing of rust begin
http://www.914world.com/bbs2/index.php?showtopic=101062
Welded the doubler plate that I fabricated for the front firewall engine bay:
Applied two coats of rust bullet to the drivers side rear firewall:
I needed to trim the lower edge of the outer suspension about 1/8" on the bottom for proper fit:
With the inner suspension console and engine bar mount in, it was time to tackle the outer suspension console. PM'ed Scotty B about the best way to index this piece. He said the best way was to take measurements before cutting out the old long. I hadn't done this, but I still had the chunk of old long in the garage so I was able to make a template. I really hated drilling holes in my brand new long, but I had to temporarily attach it with sheet metal screws to mock-fit the suspension:
As a double-check for the template, I measured from the drivers side jack post to the front edge of the suspension console and came up with exactly 12.5". This number matched on the passenger side. Additionally, I ran a straight edge accross the bottom of the inner suspension console to make sure things made sense:
With everything in place, I decided to mock fit the suspension before starting any welding. It was a relief to see things line up properly!
SO you'll be driving it to Hershey in a few months right ??
Got some quality shop time in today. Fabricated the connection piece that will tie the engine bay sheet metal together up front. Made a template and hammered out the piece I needed. I had to cut back about an inch of the engine bay seal channel on the replacement piece. A dremmel tool with a cut off wheel did a fine job:
Hit the passenger area under the tank with ospho, two coats of rust encapsulator and new seam sealer:
Welded the outer suspension console on today. Pretty smooth installation overall with the sheet metal screws holding things in place. Cycled between welding and cooling with compressed air. Put two coats of primer on:
Brushed two coats of acrylic enamel on in the area below the tank on the passenger side:
Great work Bob !!
Looks like you will have it up and running in the next few days
Hershey is gettn closer
Been rollin pretty good on the teener...
I had to cut back about 3/4" of the engine bay seal channel up front for proper fit. Tack welded channel back on:
Started fitting the passenger side lower door sill. I took measurements from the drivers side from the sill seam to the jack post - 3 3/4". With the replacement all the way forward, the passenger side was 3 5/8". I trimmed the front of the piece 1/8" and re-bent as needed. This was one of the easier replacement panels for me to fit:
I realized that some areas would be tough to get to after the engine shelf is installed, so I prepped the area below for ospho and primer:
Drilled rosette holes where possible on the engine shelf & gave all areas two coats of weld thru primer:
Started fitting the sill triangles as well...measured the drivers side setup and used these measurements for the passenger side. It was 24 11/16" from the front triangle to the middle triangle and 4 1/2" from the rear triangle to the jack post:
Welded in the brake line attachment point on the passenger side and made/welded a metal strap out of sheet metal for the front engine shelf to replace one that was rusted away:
Welded the engine shelf in. I rosette welded this piece in when possible and "stitch" welded areas where there wasn't enough metal to drill for a rosette:
Attached the door sill with sheet metal screws to make fitting the sill triangles easier:
Cut and installed another section of engine bay seal channel in the front of the engine bay...had to make relief cuts to get the right bend:
Fitted and welded the passenger side rear jacking donut replacement. I had to go back and re-grind some welds on the fabricated floorpan for proper fit. Additionally, I had to trim the piece a little and mess with the curve. The bottle jack worked well holding this thing in place. After it was tacked in place, I removed the jack and used a hammer and a large drift for any final tweaking to the metal. Finished it off with two coats of rust encapsulator:
Sprayed a coat of rust converter on consoles and engine mount. I was amazed at how much surface rust already formed on these pieces:
Followed up with two coats of rust encapsulator:
Prepped the passenger fender area for welding:
The engine shelf on the passenger side looked a little higher than it should be so with the rear trunk closed all the way (and fitting evenly), I measured from the underside of the trunk to the bottom of the shelf on both sides. Drivers side came in at 17 9/16 and passenger side was 17 1/2...going with "close enough" on this one.
Snapped some pics of the old longitudinal and the reason for this thread...
Impressive
Wanted to verify the sill angle, so I leveled the car and used a HF magnetic inclinometer in the same spot on both sides of the car. Drivers side - 27 degrees, passenger 26. Angle was easy to adjust with the sill screwed on:
Started fitting the lower rear part of the door jamb that had been removed for rust repair. I picked up a set of body panel welding clamps at HF - definately a good $8 purchase to help hold things in place. Had to fabricate a piece to connect the sill with the jamb. I used a scrap of metal from a RD replacement panel for better corrosion protection (galvanneal):
Amazing work. You've really taken on some serious rust. I thought mine was enough work. Hat's off to ya.
Curious - you mention repeatedly about using "One coat ospho, two coats Rust Bullet". Why both - don't they do the same thing?
Inspirational work. Makes me want to go out and start hacking my POS passenger long out and fix it.
Keep it up
Upon advice from the world after seeing the rust in the gas tank area, I needed to check the airbox seal. It wasn't to bad, so I popped it in the dishwasher for a good cleaning. I broke one of the plastic arms for the spring clips...but the airbox will still seal well so I am not going to worry about it. Cleaned out the nest in there and blew out with compressed air:
Prepped the passenger rear fender for re-installation. There was a decent amount of surface rust, so I applied a coat of ospho. The stub of the fender to outer suspension mount brace had to be removed as well:
Fitted the rear fender for welding - everything lined up quite well:
With everything in place, I wanted to make sure that the outer rocker fit properly. I referenced the drivers side...passenger side matched near perfectly. I measured from the lower rocker seam to the outer rocker panel and both sides came in at 11/16":
Prepped the front passenger floorpan for ospho. There was only light rust in this area. Backing plate for lower front fender repair will be seam sealed:
Shot two coats of weld thru primer on the sill and inner rocker:
With everything in place, I took a measurement from the inner rocker seam to the edge of the new door sill. Measurement was 3/16" greater on the passenger side. With all metal components lining up well and the outer rocker fitting well, I decided to roll with it:
I am pleased to report that I am becoming a good mig welder. I hated taking the door off again after getting it to fit well, but I figured it may save me some grief while welding the front areas of the sill. Started with a few tack welds to hold everything in place. I needed to apply a little torque on the sill with vice grips for proper alignment where the new sill meets the rear door jamb:
One of my poker buddies stopped over last weekend. We were in the garage and he asked what was going on with this piece of shit car. Told him that the plan was to drive it to Hershey in April. He said - no way that is happening, care to wager some cash on it? I agreed. The bet is that the car has to make it to Hershey under its own power.
Forget personal pride or a sense of accomplishment - I need to win this bet!
With winter setting in, I have more garage time. I started keeping the heat on low in the shop at all times so paint & rust proofing will cure properly.
How much we talkin bout
Great work man!
You are really making some progress.
You might want to install the door and check the gaps while welding the rear fender back on. You can easily adjust if needed now, but once it is welded up it is hard to fix later.
John
Considering how critical this area is to the strength of the car, I ran a bead of weld on the backside of the door jamb & sill:
Fitted the sill triangles. They didn't need much and held themselves in place for welding. I have struggled with small rosette welds and can't describe what goes wrong without cueing a barrage of "that's what she said" jokes. So I tacked welded them on both sides:
Ground down the welds on this piece. Scrubbed everything down with scotch brite and shot two coats of primer. Overall it turned out well, but the primer revealed a few low spots at the seams that will need to be re-welded.
Ospho'd and sprayed undercoating on the outer edge of the floor:
Hi there,
reminds me to my projekt, but differnt colour.
Very clean work. Keep on
Started mounting the new Billstein shock on the passenger side. The nut holding the bottom of the old shock was frozen. Tried penetrating fluid and a big hammer with the console clamped to the workbench. I don't have a regular torch to heat the nut with, so I used a heat gun - it actually worked. I am sticking with stock springs initially...may end up switching to 140's later on. I will have to move the lower spring mount up on the shock about 1 1/8" by moving the circlip.
Noticed some rust on the bottom of the passenger door. Removed the seal for inspection. There is some surface rust and about a 2 inch area rusted through. I don't have time to fix this the right way, so it got cleaned & ospho'd. I will do the best I can to rustproof this area until I can do it right or buy a good set of used doors:
Garage at capacity:
Two coats of rust encapsulator on the passenger front floor pan & applied undercoating to new metal in the rear passenger floorpan:
Went back and added some weld to the upper seam of the door jamb:
I hated the idea of putting the gas tank back in with the original carpet pads because they hold water. Wandering around Home Depot, I think I found a cheap solution - polyethelene pipe wrap. Cut three pieces and tie wrapped them overnight to help flatten them out. Removed remaining carpet and cleaned mounting area:
great progress!!! I'm dealing with my doors now and yours are way better. Need to cut the seal channel to patch the rot holes
I will, I think I may be posting to many pics on my resto and SirAndy will start asking for dues!!
Finished putting the new Billstein on the trailing arm. The factory shock was slightly pre-loaded when I removed the hold down nut on the old spring. I ended up using the 2nd groove from the top for the circlip that holds the lower spring holder to match the spring load:
Took a look at the lower suspension consoles. The factory had "caps" of 14 GA metal that tie the inner and outer suspension console together. I snapped a shot of the cross section from another chunk of long. Other than buying 14 GA metal and beating out these parts, has anyone found a good solution for making these?
Loaded up the parts cleaner for another round:
Glued the new gas tank vibration dampeners in with 3M weatherstrip adhesive:
Seam sealed front passenger floor pan:
I realized that I probably won't have time to give this car a complete and proper paint job before Hershey, but want it to be presentable. Tested what two coats of brushed on acrylic enamel would look like on the door sill:
Started fitting the battery tray...have some questions about placement on a separate thread:
Who cares what it looks like at Hershey as long as its there Making lots of progress Bob
Original suspension "caps" were made from 14GA metal (~.075"). I picked up some 1 1/2" flat steel for $12 at the local hardware store that measured .100" thick. These things are complicated because they twist in some areas along the consoles. I opted to make these pieces in two stages...side pieces welded in first, then tie them together. Made a template for each piece and hammered them out. I was able to get the most of the twist with a big pair of vice grips and fine tuned with a ball peen hammer against the suspension consoles. I still had parts of the old caps on the outer console that I plan using:
Sprayed two coats of Rust Encapsulator on the rusty areas of the lower passenger door:
Bolted/clamped the battery tray together so I could see how it wanted to fit and compared measurements to those received from the world. I came up with 3 3/4" from the leading edge of the tray to the firewall (without pad) and 11" from the top edge of the engine bay body panel to the tray. The vertical matches perfectly and I am close horizontally. I still need to level the car again to make sure the battery tray is level for final fit:
While welding upside down, a chunk of hot crag fell on my chest & burnt through my sweatshirt. The burn looks like a comet, because as a reaction to the searing pain, I rolled on my side causing the molten metal to roll across my chest leaving a very nice line! This only needed to happen once for me to pick up a welding apron.
Finished making the caps for the suspension consoles yesterday and tack welded them on. I want to wait until the door is back on and I can verify door gaps before seam welding these pieces, as three chunks of the car are joined with these. The factory piece had drain holes in it on the bottom, so I added them on my reproduction pieces:
Finished up the "quick fix" on the passenger door. Shot two coats of hi-build primer on a low area, sanded, then two coats of Zambezi Green acrylic enamel from an aerosol can. There is absolutely a paint line, but it will look OK from about 20ft:
The air duct in the door jamb is loaded with surface rust and started pitting in some areas. Wire brushed with a dremmel tool and sprayed with ospho:
The last thing I want is to get hung up with the DMV a week before Hershey, so I started looking into classic/antique plates for the car. It looks like you have to take pictures of the car to submit with your application which would not bode well for me right now. Depending on the timing of everything, I may have to get a regular registration this year and apply for antique or classic plates next year.
It's possible I had one too many beers working late on the car the other night. Without thinking it through, I drilled holes for rosette welds in the bracket of the battery tray thinking I would weld it all together before installation. The problem is that I would have no real access to the rear metal tab on the bracket that gets welded to the long. I tried bending the tab the opposite way, but it rested on the innser suspension console, not the long. The holes needed to be filled. I found some old copper pipe to clamp on & use as a backer:
I have decided to wait untill the car is on all fours to install the battery tray...it will be easier to get it perfectly level.
Pulled the engine bay cover out of the shed to address some rust:
My lower passenger door seal was in remarkably good shape. Ran it through the dishwasher twice, treated it with RV slide out seal conditioner and put it back on. The "J Man" stopped over to help fit the passenger door. Wanted to have this in place to check door gaps before final welding on the caps on the suspension consoles and the passenger fender. We put the top on as well to make sure everything still lined up. Everything looks about as good as it can with old seals...it was nice to see after all this work:
Bob, I admire the time and work that you've put into your resto work. The PO of my car did alot of metal with the pans and such. But I could see a difference in the quality of work as he progressed in different areas of the car as I think he was getting tired or in a hurry. I'm gearing up to do some rustoration work in the areas he didn't do as well and the downtime is going to drive me nuts. So where I'm headed is, keep taking your time for your quality work. If you miss your Hershey deadline it will be a bummer because youv'e worked so hard and we won't get to see it, but you won't have any "I wish I had" regrets down the road. Keep up the good work, you are my inspiration!
The Optima 34R arrived today. I look forward to installing it.
Finished zipping up all the seams on the suspension console caps. This was the hottest setting I had used so far on the welder. I turned down the wire feed where the gaps were close, took my time, cooled with compressed air often, and wore a welding vest. Went back and touched up a few areas with the mig. Pics are after grinding.
There was one small area on the engine deck lid that had some surface rust. Wire brushed it and applied ospho. Took inventory of the P O R S C H E letters I had picked up at swap meets. I had a few duplicates, but couldnt make a set that all had the studs. Dremmeled the plasitc studs off, drilled the letters & installed #6 X 32 machine screws with the heads cut off. They will work well with the nylon nuts from home depot:
I guess I haven't been following this thread close enough Bob, sorry!
I have templates to make the console caps - shaped from single pieces of 14ga. (I could have sent you a jpeg)
Looks real good!
I went with the antique tags. Drive the car every day. I always have extra parts in the car (working on it) and I have never had a problem. I also have a speeding ticket on those plates and the issue never came up. I think there is a big gray area on the antique tags.
p.s. I live right next to brimmers tag and title and penndot if I can help in any way. As far as the pics YES there are certain angles they require. Piece of cake
Light work on the car yesterday. Got a set of letters ready and installed. Seems as though every time I touch one of the original speed nuts, the associated stud breaks. Lost another "H" trying to tighten it up.
Sprayed acrylic enamel on the passenger side door vent:
besides.... who would drive an antique car to work 100 plus miles every day
Seam sealed a few areas:
For the first time in about a year and a half, my car has four complete fenders! Final fitted and tack welded it in place. It took me a long time to get everything right. I had to go back a couple of times and grind a spot weld off, tweak the metal and re-weld:
The door needs to be lowered about 1/16, but overall things are looking pretty good:
Finished welding up the seams on the fender. I took my time and went in about 1" bursts rotating around the panel until it was done. The toughest part was the lower door jamb where it meets the door sill. I had to go back and re-weld this area about five times to get it right. I will need to use a thin coat of bondo on the exterior:
It has been a while since I bought good quality (Dupont) automotive paint. Yesterday I picked up all the painting supplies (paint, primer, activator, etc) I needed to paint the car...got jacked for $350...this stuff ain't cheap! I went with single stage acrylic enamel.
Applied bondo to the outer seam of the rear fender. Hard to believe how many hours I have invested in this one repair:
Primed the inside of the fender well:
Seam sealed the inner fender:
I noticed a small bubble on the paint below the windshield on the passenger side. Went to work with a small, sharp screwdriver. Scraped the area down to bare metal and treated with ospho:
Took a look at the drivers side "hell hole" area and jack post. While this is in much better shape than the passenger side, it is still pretty bad. There are rivets & bondo holding the jack post support on. It would be nice to be able to fix this area without cutting the fender. A screwdriver easily made its way through at the outer seam:
My Dad's old Sears Craftsman 2 HP, 20 gallon oil-free air compressor gave out on me Thursday night. It had a heck of a run. Started getting really loud then siezed up. I am still finding ball bearings and chunks of metal throughout the garage.
I needed a new compressor quick, so I bought a 30 gal twin cylinder oil filled, cast iron Husky at HD. I like it so far and it is much quieter than the old one. Had to re-organize the garage as the built in electric garage heater was blowing hot air on the cylinders of the new compressor.
Ladies, please...one at a time here. How could you not be impressed with this unique blend of washers, dryers, mig welders, air compressors, laundry supplies, hot water heaters and Porsche parts:
After three coats of bondo and three coats of spot putty, I am STILL finding imperfections in the fender:
I got zero replies for my WTB drivers side engine shelf post in the classifieds, so in between work on the fender, I started fabricating what I need. I cut out the old shelf about 1/4" forward of the blower motor mount. Naturally, I nicked the steel brake line that rides directly below the shelf. I started with the recessed area for the motor and went from there using 20 GA sheet metal:
Slightly lesser known than the LE "Grasshopper" and "Bumblebee" models...I present the very rare "Green M&M" 914. One final coat of spot putty got the fender where I wanted it:
Conditioned the airbox seal and re-installed the airbox. I remember reading about what a bitch this thing was to install...I agree with all comments on the subject!
I have an airdam on the way from a member of 914world who told me that both sides were the same. Took measurements off the drivers side and drilled holes for the passenger side:
Like many before me, I ground down the edge of a socket extension to make a CHT tool. I found BOSCH 012 on Ebay, reasonably priced. My D-jet was running pretty well when I pulled it, but "hunted" at idle. I will put in a new CHT sensor before the engine goes in:
Finished welding up the front section of the drivers side engine shelf. This part turned out well. The recess is a little deeper than the original, but will be just fine:
Picked up an "E" clip at the local Ace Hardware to fix the rear roof hold down:
I didn't want to have to pull the suspension back off for paint, so I shot color in the fender well and the underside of the suspension consoles:
Wrestled the trailing arm assembly into place with a floor jack and a pry bar. The strap that holds the rear part of the fender was in the way, so I had to adjust it with a big pair of vice grips, a hammer and a large drift. The strap will have to be re-welded at a later time:
For the first time in about a year and a half, the car sat on four wheels and saw sunlight. The J-man stopped over to help roll it out of the garage and back it in so I can gain better access to the drivers side:
Went to work with a screwdriver on the bottom of the drivers side long. The worst spot on the bottom is at the curve between the inner & outer firewall where it curves to meet the long:
The sail vinyl on the passenger side was peeling off at the bottom and it looks like it "shrunk" a little bit as it would not go below the line of the crome trim. Installing new vinyl is not in the cards at this time, so I gently pryed up the vinyl, applied 3M adhesive using a fine paint brush and clamped a piece of kindling on to hold everything in place. I was left with two small bubbles about an inch up from the bottom:
Started cleaning/inspecting the tunnel. I had to remove the shift rod for better access. The car was shifting pretty well before, so I measured the spline depth at the shifter as a starting point for re-assembly. Overall, the tunnel itself doesn't appear to be too bad...but I discovered a few small holes about half way back:
Looking good, keep it up.
Wow, great progress, looking forward to more
Amazing Bob.
now get crakin'
I am soooo excited to see it at hershey this year.
Great progress, and I think it looks awesome out of the garage
Thanks! It dawned on me last week that Hershey is about 80 days away...it's "go time!"
Eric - I get your posts confused with Zachs now - not sure why.
Joe - looks like we may both be putting an engine in shortly before Hershey. Let me know if you need a hand with the install and I will do the same. We live pretty close.
Picked up a pretty awesome tool on Monday. I wanted to be able to look in the tunnel and the rusted out areas between the inner and outer firewall to know how much I need to cut out:
With the car sitting on all fours, I relieved the tension on the passenger side body brace turnbuckle. The gap is slightly smaller at the bottom of the door, but it opens and closes very well:
Leveled the car and installed the battery tray. The Optima 34R battery is a full inch taller than the old Interstate that came with the car. After tack welding it in place, Hollywood stopped over and helped me get the engine bay cover on (with rain tray installed) to make sure everything would clear. With the terminals on the inboard side, there is interference with the rain tray...I should have bought the 34. It should be fun returning a battery purchased off the internet. Plus, I will beed to trim about 1/8" off the bottom of the battery case for proper fit. Side note...the MFG installed the red protective cap on the negative terminal and the black one on the positive.
Good work!
Removed the drivers side jacking donut and most of the drivers side jack post. Found a large mouse nest inside the long...looks like it has been holding water and rusting for a long time.
This side is nearly as bad as the passenger. I am bummed out and taking the day off:
My quest to drive the car to Hershey this year ended upon discovering how bad the driver's side "hell hole" was. Had to take some time off and step away from the project.
Like Spraggi says..."next year."
I was devastated about it, but got back to work today.
Started drilling out spot welds on the underside of the long, sill and clamshell and cut the rusty sill and door jamb out...trying to do it without a massive cut on the fender:
Wire-wheeled the seam between the upper & lower firewall....this looks eerily similar to the same area on the passenger side:
You are making great progress and got serious skills.
Loving this thread.
Keep the faith.
John
GO BOB GO !!!
Bob your car is in very capable hands and will be a nice treasure when your done!
The cutting continued yesterday.
Got a line on a drivers side longitudinal from Bruce (Bdstone) on this site from a recently restored car with front end damage. The problem is that I need tell him where to cut it at.
Drilled out the spot welds on the rear firewall that held the rusty metal in place and cut out the bad section & cut away part of the rusty clam shell forward of the jack post and the long aft of the jack post. I was able to get a good look back into the long. It looks pretty solid aft of the engine mount, but I still need to get in there to clean to make sure. Damn that mouse nest held a lot of water!
More cutting. Just like on the passenger side, there was rust through at the bottom of the front fender well where it meets the long. I opened it up to take a look. The front 2" of the inner long is rusted through on the bottom and it crept up about an inch on the outer clamshell. With both sides open, I was able to blast compressed air through the remaining section to get the loose rust out:
Cleaned the bottom with a wire wheel. The rust through on the bottom is isolated to the very front and about 9" around the old jackpost...right around the area of the mouse nest:
After cutting out most of the rusty sections of longitudinal, this is what I am left with. The car started to sag so I tightened up the turnbuckle...still not sure I want to replace the entire long, but I am scratching my head for another solution. I have been in contact with Brad Mayner about his long kit:
While figuring out the best way to repair the long, I started tearing into the "box" below the front door jamb. Three layers and all had serious rust problems. I saved what I could of the old pieces and added new metal. The innermost level was completely shot and had to be made from scratch. Additionally, the vertical support piece in the front of the wheel well was rusted out about an 1 1/2" up from the pan.
Went to work fabircating all the pieces. Sprayed all rusty metal with ospho & hit everything else with weld-thru primer:
Found some rust under the seam sealer in the front fender well, cleaned the area and prepped for ospho:
Dude, you are amazing!
Had to pull the antenna out to get at some rust in the wheel well. While it was out, I cleaned it up, lubed it and ospho'd/painted the rusty mounting point:
Primed, seam-sealed and painted the passenger door jamb:
The drivers side inner suspension drain hole was plugged solid with dirt & scale. using an assortment of screwdrivers, small picks, safety wire and compressed air I was able to clear it:
Picked up a rattle can extension for use with Eastwood's rust converter so I could reach into the clamshell to protect the metal...it made a hell of a mess. I have had problems with heavy coats of this stuff staying tacky so I applied a little extra heat with a space heater for a couple of days:
2 weeks left
Just put the engine in and the wheels back on. Its not so far
Prepped all parts for welding the lower fender well and front box & started welding. I had some problems with burn-thru on the inner layer of the box, so I had to turn the mig down to a lower setting:
The lower fender at the door jamb was rusted through so I hammered out some small patches. It was a royal PITA welding & grinding in the bottom of the front door jamb:
Welded in layer two of the rebuilt front box today & applied rust encapsulator. Progress is slow in this area due to the rustproofing after each layer:
Welded on a newly made holder for the gas tank expansion lines:
Finished sanding the spot putty on the lower fender & shot it with primer:
Welded & ground the outer layer of the front pillar box:
Had to modify some tools to clean the inside of the remaining long. A small wire brush fit well into a 3' piece of PVC so I could reach into the long to remove some scale. To get the crud out of the outer suspension console, I taped some hose on the air chuck and fed it through the holes on the inside of the long. The area was then sprayed with Rust Encapsulator:
Fantastic thread!...discovered it just in time before I start some major hell hole repairs of my own.
Meticulous work Bob, nice one!
Cheers, Ollie.
Went to work on the bumper I bought at Hershey. It was pretty clean, but there was some "surface" rust under one of the tits. All four bolts broke off when removing them. I tried pulling the tits off my old bumper and the same thing happened. I wasn't a big fan of the look of the 74 bumpers, so the bumper got backdated. Welded backers on the holes & filled with weld. There were still a couple of slight low spots where the tits were, so I had to apply a light layer of filler before priming and painting:
Started cleaning between the inner & outer firewall on the drivers side. I pulled out a lot of scale with an extension magnet:
Treated rusty areas of the door jamb and painted. I wanted to knock this out early so I don't have to remove the door again:
There was some more rust up in the long that has to be removed. The only way I could reach it was with a Dremel tool and a cutting wheel...very tedious:
Ospho'd, primed and painted the air channel in the rear door jamb:
Did the same with surface rust in the inner fender well:
Looking good Bob. Great to meet you at Hershey!
Had to cut out some more rust on the inner firewall:
A small section of the rear pan was shot. I couldn't justify buying a full replacement panel:
The rust from the boxed section crept into the bottom of the front sill triangle. Fabricated and installed a replacement:
Wedged a wire brush in a chunk of copper tubing so I could reach in between the inner & outer firewalls to remove some scale, then welded the new floor piece in:
Started rebuilding the inner long hand forming pieces in a vice. Pine 2 X 4's provided a near perfect curve at the bottom where it meets the floor. I forgot to drill holes for rosette welds on the bottom before tacking it in so I wedged a screwdriver in between the pieces and used a spot weld cutter:
After the dust settled, I was left with about a three inch strip of the original drivers side long at the top. Luckily, there was a bend in the good remaining metal to keep the car relatively stable. I didn't want to buy a used longitudinal from a donor car. With new replacement panels not being available for this side, I bought the Brad Mayner longitudinal reinforcement/repair kit at Hershey. The plan is to weld in a section of 1/8" steel bar on the inside (both vertical and horizontal) for strength on the inside, use the Mayner kit for strength on the outside, and fill the rest in with a single layer of sheet metal.
Started fitting the Mayner kit:
Mayner kit fitting continued:
Welded in the front wheel well piece and finished this area off:
Fabricated and installed the final inner flat piece on the long. I was able to take measurements off the passenger side to determine where it begins to curve up:
For extra strength on the inside of the long, I picked up a strip of 1/8" steel plate, 3" wide and started fabricating the horizantal section (a vertical section will be added). It was welded to both the egnine mount and long at the rear and tied into the long at the front with rosette welds. It was tight welding in the rear section...I have a lot of grinding to do back there to make sure the weld is solid all the way around:
That is some rocking metal working and welding!
I know how time consuming this stuff is...
That will be one solid car when you are done.
John
Yes, we are still waiting for you to finish !!!
as always
p.s. Looks great, nice job!
Mayeur Mayeur Mayeur Mayeur Mayeur Mayeur Mayeur Mayeur Mayeur Mayeur Mayeur Mayeur Mayeur Mayeur Mayeur Mayeur Mayeur Mayeur
Great stuff!...brilliant fabrication..very impressive.
Ollie.
Thanks to all for the props on the metal work, I am learning as I go. John (fourblades) is right...this stuff is extremely tedious.
Its time to get this thing ready. Dont make me drive up there and finish it
Updates ??
Business expansion got in the way of my shop time there for a while. Went back to work today. I had some touch up welding to do inside the long on the horizontal reinforcement piece. It was tight working in there - at one point, I used an inspection mirror while welding so I could see where I was at. Stuffed some rags into the "completed" portion of the long to keep scale and grinding dust out. Started fabricating the vertical portion of this support piece out of 1/8" steel. The toughest part on the vertical was matching bend of the original long:
Got some more done on the teener last week. Welded in the 1/8" thick vertical inner long support that ties the engine bar mount to the inner long. It was tight welding the rosettes at the engine mount. My first attempt was an epic failure as the welds didn't hold. I re-drilled for bigger rosettes:
Fabricated an inlay to match the factory lip in the area of the reinforcement. I should have made it about 1/8" longer vertically...but I should have plenty to weld to:
Fabricated the final piece to close in the inside of the long, rustproofed and seam sealed a few areas:
Go Bob Go!
914 gatherings are awesome for two reasons. First, I get a chance to catch up with 914world.com members. Secondly, I get additional motivation to actually want to drive a teener to such an event. Been firing on all cylinders after Matt's event.
I have decided to go a different direction and only use part of the Brad Mayeur longitudinal reinforcement kit. This is not a knock on Brad's product in any way, shape or form. His solution is both well-engineered and well made. It would be nearly impossible for me to replicate the double wall design of the original long. I took a look around the shop and realized that I had a surplus of RD clam shell. With the 1/8" thick reinforcements already welded into the long, I decided to use ribbed sections of clamshell to complete the remainder of the outer flat section:
Welded in the aft piece of clam shell, indexed to matched the passenger side. Flattened out a piece of copper tubing I had laying around to use as a heat shield for the heater hose that runs through the long:
Aligning the jack post was a lot of work. I mock fitted the rocker panel cover and held a ruler behind it to see where I needed to be horizontally. Vertically, I measured down from the fender lip. For depth in the clam shell, i measured out from the rocker cover:
Would you quit screwing around and finish this thing already!
Keep up the great work!
A key concern with using the ribbed clam shell in this section is the strength of the jackpost area. Both sides of the post itself were welded to the clam shell. I had previously bought a standard jackpost support, so I cut it down to use on the inside. I will be using the Brad Mayeur support on the outside. The post was capped on the backside to prevent crud from getting in there:
Took advantage of the nice weather and shot weld thru primer on the post supports and "clam shell jack post" outside. I added drain holes to both the inner and outer support plates:
There is a section aft of the flat part of the long that was completely rusted away. I started screwing around with templates to make the piece by hand, then looked at the surplus clamshell again. The overall fit is nearly a match, it just needs to be bent. I made some relief cuts so it would bend and went to work. Still have some more to do on this, but I think it will be a solid solution:
The current state of affairs in my garage:
Sweet work Bob! I am envious of your metal shaping skills. Keep up the good work and she'll be back on the road soon enough!
Welding is a skill; it is also an art. I'd like to learn it, the abilities shown on this forum are nothing short of amazing.
Looks like you're getting close Bob, keep pushing.
Incredible stuff as always Bob...you should write a book!
Ollie.
So you're gonna drive it up to my open house on 09/15/12, right Bob?
Thanks for the encouragement gents.
This project is daunting. So many times I roll out to the shop with the best of intentions but end up doing something unnecessary like sorting bolts instead of actually working on the car.
Bob, great work as always!
Roll man roll!
Hershey 2015!!
Seam sealed and applied "rustproofing" to areas that will be enclosed when the jack support plates are welded on:
Finished up the final piece of outer long fabricated from surplus clam shell. Going this route saved me a lot of time:
My calculations were a bit off on one of the pieces for the drivers side long. Needed to add a filler piece:
Welded the outer jackpost support on and sprayed piece with primer:
Need to fabricate a rather large panel to fix the drivers side rear firewall. The plan is to make this with one piece and weld it in. The reinforced area for the engine deck lid cable was still pretty solid, so I opted to cut it out of the old panel and re-use it. I had to add a little weld to it to fill some holes. Measured from the outer edge of the panel so I know where to install it in the new panel. Traced the old panel on new metal to get the rough shape:
i've just spent the morning reading through this thread.
You really should be very proud of the work you have done in saving this car. Bloody fantastic.
No it wont be concours , but it will be one hell of a good strong resto, and something you'll be driving for years by the looks of it.
Well done,
Cheers
Dale
Seam sealed the clam shell jack post section & prepped for welding:
Did one final alignment check on both pieces. I needed to shave a little off in two places for the best fit. Ran a long level accross the bottom ridges of the existing clam shell to check how true this new section was vertically. It was within 1/16" with everything else lining up well, I decided to roll with it:
Welded the final two lower long pieces in place. Took my time and cooled with compressed air regularly. I tried to remove as little of the fender as possible, so there was some tight welding at the top seam behind the fender. The door opens and closes well and the gaps look pretty good :
This is an awesome thread for the fabrication, welding, and thorough documentation shown alone... but even better knowing it's all going towards the restoration of a 914! Keep up the good work, I am impressed!
Spent a few hours grinding down the welds on the jack post area. Had to go back and touch a few areas up, but overall, I am pleased with how it turned out:
Made a poster board template for the final patch needed to close up the drivers side long. There is about a 3" section at the back that is missing the vertical lip to rosette weld. I opted to leave that section flat and rostette weld it to the top of the old long to button it up. Whenever possible, I use leftover steel from Restoration Design panels because they are galvanealed:
Gave the long a final cleaning with the shop vac before spraying a liberal coating of rust encapsulator into the long using the extension nozzle:
Spent the evening welding/grinding the final patch piece of the drivers side long:
Fired up a template and banged out the final piece of the inner firewall that joins the firewall and floor pan:
Welded in the lower inner firewall patch on the drivers side. The angle of my bend was slightly off, so I tack welded the vertical section, then used a hammer and drift to beat down the piece that meets the floor:
Man, this is almost like watching Chip Foose
I like your work and admire your fortitude
Finished up the firewall patch. I decided to make this a one piece repair for simplicity and had to bend it to match the existing factory firewall. Installed the engine bay release attach point and the tab that holds the brake line:
Naturally, the edge of the front firewall shelf had some rust damage, but most of it was isolated to the forward portion. Rather than re-make this entire piece, I cut out the bad areas and welded in new 18GA metal. Brushed a coat of ospho on the surface rust:
The final section to fabricate is the wheelhouse above the long. I had to cut into the indented circular area behind the blower motor to get rid of all the rust. Went to work making the main piece...I will add a small connection piece after this one is welded in:
As many of us have experienced during a restoration, my engine ended up out much longer than expected. The engine will be sitting in my shed for another winter & I had never done any type of preservation to make sure it stays free and will fire up without a lot of hassle when the car is finally done. Poured oil in the cylinders and rotated the engine, stuffed rags in the exhaust ports and duct-taped the throttle body. Swapped out the CHT sensor as well, in hopes that the engine will be "plug & play" when the time comes. Under advice from the world, I used a dab of superglue to hold the CHT washer on during installation. Used an inspection camera to view the inside of the tin to make sure there were no mouse nests in there...all looked good:
While I had "easy" access to the inner drivers side rear fender, I hit it with Ospho to halt the surface rust:
While checking out what I need for what is hopefully my last Restoration Design order, I took a close look at my drivers side door sill. I only needed about 5" at the rear. I had a pretty clean section from the passenger side so I cut out what I needed. The factory piece dips down at the rear (about 1/2") to allow the door jamb to rest on top of it. To re-create this, I cut off an extra 3/4" chunk of the donor jamb and welded it to the bottom:
Way to go Bob. We'll see the car at Hershey 2013 for sure.
Got some light work done on the car the last few days. Brushed two coats of color on part of the underside of the engine decklid (previously ospho'd) where there was some surface rust:
Took a close look at my supply of used sill triangles and found two of them with only minor surface rust. Drilled the welds out of the old passenger side clam shell from the inside. Cleaned and treated with Ospho:
Applied rust encapsulator to the inner portion of the drivers side rear fender before welding in the final wheelhouse piece:
Removed seam sealer from portions of the rear trunk. I was pleased to see surface rust only. Hit rusty areas with a wire wheel and applied ospho. Did the same on the lip under the rear trunk lid:
Applied weld-thru primer to the top of the clam shell where the sill will sit:
Took a look at the drivers side jacking donut...I need to do a little more grinding on some of the floor and long welds for proper fit, but didn't want to stir up a bunch of dust with paint & opsho drying in the shop:
Used a mixed assortment of three grommets from the local ACE hardware held together with permatex to make a new sheet metal plug for the CHT:
Prepped the jacking donut for installation. I had to trim a little off the piece where it meets the pan and add a little bend:
Needed to replace some more engine bay seal channel...removed the bad stuff and sprayed weld-thru primer:
Received what I hope will be my final order from Restoration Design for this project. I only needed a small piece of the door jamb...but I knew it would take me a long time to make it by hand so I just bought one along with some engine bay seal channel:
Seam sealed trunk and brushed on two coats of color to the repaired areas:
Welded the inner wheelhouse patch in. Using the Dremmel tool to add the holes after installation was a bad idea - I tore through a lot of Dremmel supplies. I only had half a hole to index from, so I got a pic of the layout from a 914world member. Temporarily installed the firewall patch with duct tape to mark the hole. I had to add a small curved piece of metal to match the circle in the remaining wheelhouse. Holding it in place with welding gloves was the biggest challenge:
Very nice work...
Needed to zip up the seam on the inner wheelhouse forward of the firewall:
Re-attached a section where the firewall meets the door jamb where I previously drilled out the spot welds:
Welded in the firewall patch. I started with the rosettes where the panel meets the door jamb, then tack welded the panel on the back to hold it in place. Seam welded from the passenger compartment, then touched up the engine compartment side:
The repaired section of the front engine bay shelf and the fabricated drivers side engine bay shelf had to be fitted at the same time. It took a lot of forming and some trimming to get everything to line up right. Needed to add about 1/4" to the tab where the side and front piece meet:
This year for sure riiiiiiiiiiiiiight?!?!?
Great work as usual...I don't know how the hell you made that shelf piece with the indent...amazing!
Looks great Bob !
At least tow it to Hershey next year so we can see it
Welded the last section of the drivers side door sill on. Used a 12" rule to make sure everything was true:
Started fitting the lower chunk of the door jam. Hated to cut such a small piece out of the replacement from Restoration Design, but had to do it to as the rest of the jam looked good. I used the old piece for a rough measurement of where to cut, then trimmed to fit:
Nice work Bob ............. Lookn good.
Welded the drivers side engine shelf and reworked piece of front engine bay sheet metal in. I hit a couple areas with seam sealer before welding, as they would be difficult to get at after the piece was installed. It took a wide variety of grinding wheels and Dremmel tools to gring down the welds in the tight areas. Overall, it went well, but I took a hit from some molten metal in the arm and scalp when filling the rosettes on the bottom...just very minor burns:
14" or so of the tube that holds the enging bay lid cable was rusted away. I had a chunk of brake line in the shop, so I cut it down, bent it and tack welded it in. Used a #1 phillips screwdriver through the firewall hole to keep it centered up front. Ran the cable through to make sure the alignment was correct, then applied a coat of JB weld over the seams:
With my fantasy football season in ruins, I blew off the early games and welded in the bottom section of the door jam from Restoration Design. I have had consistent problems lately (bad batch?) with Eastwood's Copper Weld-Thru primer, so I switched to a product I found at Home Depot. Eastwood sent me replacements cans for the ones I had problems with - they kept clogging and left a rough finish. When the replacements did the same thing, they issued a full refund. I started with the inside rosettes and worked my way out. Had to beat it into place with a hammer & drift as I went. It took about seven passes of welding/grinding on the vertical part of the jam to build the metal up to where I wanted it...very time consuming, just as the passenger side was:
Had to fabricate a small patch piece that connects the lower fender to the door jam. Made a template and banged it out of leftover galvaneal steel from Restoration Design:
Dug the used sill triangles out of the scrap heap. Had to fill the holes in top of one of them. The rear one needed to be "slimmed down" to fit under the door sill in the area I used modified a piece of clam shell to patch the long. Sprayed the areas to be welded with weld-thru primer:
Welded the engine bay seal channel in on the drivers side and a small piece at the front. This stuff comes straight from Restoration Design. Used a tape measure pressed against the curves to get the exact measurement. Drilled holes for rosettes about every 3". Starting with the back, I welded one rosette at a time and moved the welding clamps forward as I went. This piece went in nicely and didn't even distort along the bends:
That's odd..the engine seal channel came pre-welded to the RD shelf I bought. It came from a German supplier...???
Seems I have trouble with just about any kind of rattle can spray nozzle that I get.
About half come DOA and won't fire up.
Nice work ................ things are coming along good.
Nice work! I need to do the seal channel on the right side of my car one of these days. Thanks for posting your progress pics.
Welded in the drivers side sill triangles. Measured position of the rear off the jackpost with a combination square using measurements from the passenger side and the front using a tape measure off the front triangle. Checked for square against the bottom of the door sill before welding:
Installed the drivers side jacking donut from Restoration Design. Used a bottle jack to hold it in place. Started with the area that joins to the floor pan and worked my way back, moving the jack as I went. Took a measurement from the passenger side to determine the distance in from the longitudinal seam:
Prepped and applied ospho on the door sill, clam shell, outer floor pan and rear wheelhouse area. Always amazed at how black some areas get with very little visable rust after applying ospho:
After hearing a few horror stories about engine decklid hinge points breaking loose, I took a close look at mine. Passenger side looked fine, but the drivers side was weak...the lowest spot weld had failed. Cleaned the area, used a hammer and drift to bang the lower section back in and seam welded the edge:
Prepped the door sill & sprayed primer. With the cold weather setting in, I heat up the garage, shoot a coat on the car, immediately open the garage door & window to get the fumes out and repeat as necessary:
Started the final prep for ospho/primer/paint in the engine bay. There is surface rust in a lot of places. This is taking a ton of time. I have been using a combination of wire wheels with a drill, die grinder with scotch brite pads, dremmel tool with with wire wheel attachments and gool old wire brush to remove any loose material. The factory firewall heat barrier will be replaced with one purchased from Mark that won't hold water:
Bob, looks like a productive day.
Light work on the teener today. Sprayed two coats of Rust Encapsulator on the clam shell, part of floor pan, rear fender well and suspension ear:
While crawling out from under the engine bay, I noticed a lot of surface rust in and around the drivers side shock tower. Checked the passenger side and it was much better. Hit the area with a wire wheel to prep for ospho:
Seam sealed the drivers side door sill and inner fender well, paying careful attention to the patch on the inner wheelhouse. Decided against braising the door jam as the factory did, mostly because I don't have any braising equipment :
On another trip out from under the car, I caught a glimpse of something that didn't quite look right on the inner drivers side suspension ear. A few taps with a hammer and screwdriver and I was through...made me very nervous about the integrity of the entire piece, as the drian hole was completely clogged. Hit the whole lower section with a wire wheel and hammer/screwdriver. Discovered a hole on the outside as well. Will be contacting Chris Foley @ tangerine racing about his suspension arm reinforcing kit. While I'm glad I found it now, it will set me back a bit:
Hit the entire engine bay with scotch brite, gave it a good cleaning and applied a coat of Ospho:
Applied Ospho to rusted area in and around shock tower:
Found some surface rust in the fenderwell. Hit it with a wire wheel and applied ospho:
Hollywood stopped over & helped me remove the door and rear trunk lid...the garage is filling up again:
Great progress!
Wanted to pull the door off again so I could give it a close inspection. I thought it was in much worse shape than it actually was and even started looking for a donor door. It was just surface rust on the lower door skin and seal channel with a single small rust hole near the front. Welded the hole shut up front. Measured the placement of the negative "PORSCHE" decal and removed it as there were a few rust bubbles under it. Cleaned everything with a wire wheel & scotch brite wheels and applied a coat of ospho to the rusty areas:
I hate to tell you this, but that suspension console is probably bad. If you have rust holes like that, it's always worse than it looks.
Had to pull the pedal cluster out in to clean the drivers side pan for opsho. Followed the Pelican article, which was helpful, except that my clutch cable was screwed in...not a "cup" connector. Disconnected the accellerator cable, then removed the bolts. Screwed the clutch cable out after getting the pedal assembly loose. If I remember right, the PO said that they had this unit rebuilt at some point. Ripping around the neighborhood a few years back, everything worked well, so I cleaned it and banged a coat of ospho on the surface rust:
Hit an area on the left front of the car with ospho after discovering more surface rust while removing the petal cluster:
Had to weld the tab of a replacement piece to the interior of the car. This piece was fabricated to repair the drivers side fender well. I must have forgotten about it:
Removed the glue and cleaned the rear firewall with a host of chemical glue removers, wire wheels & scotch brite pads...what a job! I wasn't concerned about the residual glue as much as rust that could be hiding beneath it. Cleaned, prepped and applied ospho on the drivers side pan and firewall as needed:
Hit the door with a light coat of filler and spot putty:
Hit a few areas with surface rust with some opsho & rustoleum:
Finished the drivers side floor pan and most of the inner firewall with with 2 coats of rust encapsulator and seam sealer:
Looks great, your moving right along. Great work!
Spripped the paint back with a wire wheel further up the drivers side suspension console to check for any more rust through. Hit any area that showed any kind of surface pitting with a hammer and screwdriver to verify its integrity. In the end, I was left with four small holes, two on the inside and two on the outside. Welded the holes as prep for the installation of the Tangerine inner console reinforcement:
Started fitting the inner suspension console reinforcement:
Ran the drivers side door seal through the dishwasher a few times & treated it with RV slide out seal conditioner:
Shot two coats of primer on the drivers side door. Upon opening the garage door to let the fumes out, a gust of wind blew the plastic back onto the wet paint. It will need some touch up:
Completely out of space, the front trunk of my teener is now doubling as a hamper for work clothes :
Looks great Bob!
have you ever drivin this car
Great stuff as always Bob..
What was your rationale for putting the suspension re-inforcement in?
Welded the inner console reinforcement from Tangerine Racing on tonight. I started at the back of it and worked my way forward with tack welds to get it in place, then zipped up all the seams, cooling regularly with compressed air after every 3/4 inch or so burst. I was welding thicker (16 gauge) metal, so the settings were different on the mig...took me a while to get used to it. Gave everything a good cleaning with a wire wheel, then went back and touched up a few areas with the welder on a lower wire feed:
Damn Bob, good torch work for a rookie;-)
I gotta learn mig all over again. I was always good with the torch and reshaping metal as a kid, wish I hadn't stopped to play with electronics for 35 years - welding has improved, but it's still a job that exudes satisfaction when you are done, especially if done right:-))
Dave
Brushed two coats of acrylic enamel on the section of door channel with surface rust (previously oshpo'd):
Before buying the cheap HVLP paint gun from HF, I read the reviews on it. Everyone who had success with it recommended a thorough cleaning before use. I tore the gun completely down and cleaned everything up. There was some type of silicone substance packed in there. Ran some mineral spirits through it under pressure to clear it out after putting it all back together:
Started taping everything off for primer and paint in the engine bay. Masking this area was a royal PITA! To cover the wiring harnesses, I cut strips of plastic from a trash bag to wrap the wires & masking tape to hold it in place:
Drained the compressor tank of water and added an inline water separator to the air hose. Set the pressure regulator to 50PSI as recommended by the paint gun manufacturer. Practiced using the spray gun on an old piece of plywood to get used to the settings, then shot two coats of primer in the engine bay. Getting into all the crevices with a gravity feed paint gun was rough. I had to go back and hit a few small areas underneath with Rustoleum primer as I couldn’t position the paint gun properly. The gun clogged on me several times and I ended up with a rough, almost "sandy" finish in a few areas...not sure if it was due to overspray, the gun, or the amateur using the gun. Hit the whole area with sandpaper and/or scotch brite to prep for color, then applied a coat of seam sealer to the drivers side:
Gave the engine bay a final once over with scotch brite and sandpaper, blew it out with compressed air, wiped everything down with a tack cloth, then shot 3 coats of acrylic enamel. There are so many curves & edges in this area, I tried to keep the coats light to avoid runs. It was tight working in there with a paint gun, respirator & wires & cables in the way. I looked like a slightly milder version of the incredible hulk when I was done. I had two cans of rattle can paint to match that I used for areas that I couldnt get to with a gun. I had a few runs when I first started on the firewall...adjusted the trigger on the gun for less paint:
Looks good to me Bob...and with any luck you won't have to do that ever again!
How d'you keep your garage so tidy?! Mine's a mess although I guess I'm still doing alot of paint and underseal stripping. It's about -5 centigrade outside right now and my garage isn't heated....brrr.
Ollie.
Used a heat gun on low setting and a plastic razor blade to remove the PORSCHE decals from the car. Once the heat gun softened the plastic, it peeled right off:
Strafed my emergency brake cable with a wire wheel while cleaning the engine bay& damaged the plastic. The ebrake worked well a few years ago, so I used a piece of heat shrink to cover the damaged area:
Had to go back and add some more weld to the passenger side fender brace. I had to bang it up a little with a hammer and drift to get the suspension bolted on. I couldn't get it to sit properly without a lot of heavy banging on the lower part of the fender, so I worked with it the way it was. Brushed on two coats of acrylic enamel:
Put two coats of color on a section of the rear firewall and door jam:
Bolted the drivers side suspension:
The body braces came off last week. I cleaned up the areas and brushed on two coats of acrylic enamel. Hollywood and Flying J came over to help me push it up on ramps to gain better access to the floor pan:
I was never a fan of the luggage rack that came with my 914, so I removed it and welded the holes shut with a copper backing plate. Overall, it was a smooth operation:
Started putting parts back on the car. The first one was Mikeys center cap which I bought about two years ago. Installed aluminum rollers for the engine bay deck lid using a deep well socket and extension, re-installed the brake proportioning valve:
I knew there were a few small holes in the underside of the center tunnel. I hit the area with a wire wheel and gave it a closer inspection. A good cleaning revealed more than a few pin holes...I estimate about 30 or so holes spanning the rear 24" of the tunnel. Cleaned the bottom areas of the adjacent floor pan - they looked good, aside from some surface rust. I was pretty irritated with all the rust thru and really want to be driving the car this spring...wasn't thinking clearly, so I Ospho'd the area and even cut a fiberglass cloth patch for a quick repair. After some thought over the last few days, I decided to order a new floorpan from Restoration Design, cut out and replace what I need. My deal all along was to do this right, once and then enjoy the car without more major rust work:
Had to go back with a brush and touch up a few areas in the engine bay that were impossible to reach with the spray gun or rattle can:
Looks great Bob!
(as usual)
You keep working this hard.
We're going to put you on like permanent. LOL.
Looks like your tearing it up. I might have to skip the Super Bowl and get back to work.
Un stinking believable! I am inspired to do real repairs on my 76 as a result of the crazy incredible repairs you did on this! wow!
My e-brake cables weren't in terrible condition, but after closer inspection, I decided to replace them with a set ordered from PMB. It just didn't make sense to NOT replace these "while im in there."
I needed more room under the car to inspect the entire floor pan, so I raised the front as well:
Started to fiddle with the new rear sway bar bushings:
Applied a thin coat of bondo to the filled holes in the rear trunk:
Ordered a new rear floor pan from Restoration Design. Cut out the damaged area with a die grinder and cutting wheel right at the seam where the tunnel is spot welded to the floor pan. I took a good look around in there and discovered very little rust on the verticals of the tunnel where it meets the pan. The tubes show some surface rust, but no rust-thru. Started cleaning the area with a Dremmel tool and wire wheel attachment. The plan is to clean everything in the tunnel well, treat the surface rust, and rosette weld the new section to the existing pan from the bottom. I really hate welding upside down, but I think it is my best option. I know it's not a concours repair, but I feel it will be a good strong repair as the original spot welds that connect the tunnel to the pan will remail intact. To prep, I had to grind down some weld on the rear edge and straighten it:
With the temperature over 40 on Sunday, I was able to cut down the new floor from Restoration Design outside. I bought the "rear floor pan half" and cut out the center tunnel, leaving enough of a flange to drill for rosette welds. My die grinder kept binding on me, so I switched to the angle grinder. Found it ironic that I ended up buying an entire floor pan after all the time spent fabricating and installing the rear section on both sides...lesson learned:
Finished sanding the rear trunk lid and banged on two coats of primer:
Finally got three of four bushings installed in the drop links for the rear sway bar. I did a lot of reading on how others did this before actually starting. After trying heat guns & boiling water on the stove, I ended up having my best results boiling the inserts in a coffee cup with water in the microwave, applying pressure with a vice and working the edges in with a small dull screwdriver. I ruined one before figuring out the technique & ordered a new set:
I realized that I would never have better access to some areas of the center tunnel & areas in between the inner & outer firewall than I do now. Ran an extension magnet in between the firewalls & tunnel & drug out a bunch of grinding dust. Followed up with a blast of compressed air, then applied a coat of Eastwoods "Internal Frame Coating" to all areas before buttoning up the bottom. I have an extension wand & nozzle that lets the product get into places that are otherwise unreachable:
Fitted & installed the bottom section of tunnel on the car. Used a floor jack and an assortment of 2X4's to line everything up. Measured off the ridge of the remaining pan for proper fore/aft orientation. I was left will a little excess at the rear that had to be trimmed off. Drilled holes for rosette welds & coated everything with weld thru primer. Started at the rear and worked my way forward. Angle cut a 2X4 and used a bottle jack to apply up pressure along the sides & front.
My biggest concern was getting burned during this operation...I did not. After filling the first eight or so rosette welds, I pulled the welding helmet off and leaned up...forgetting that I had the rear trunklid on sawhorses very near my head. Managed to bury my scalp about 1/4" deep on the corner of the trunk lid & immediately had a face full of blood. Managed to get the bleeding stopped, so I was able to avoid a trip to urgent care for stitches. The head wound set me back a few days.
Refinishing the floor pan was supposed to be a weekend project for me after I got the car on the road. But after finding all the rust in the tunnel, I decided to knock it out now. Wire brushed all suspicious areas, blasted with compressed air, wiped everything down with mineral spirits and brushed on a coat of ospho. After seeing how much rust the old undercoating hid, I will be painting the pan with good old rustoleum so I can see if there are problems down the road:
Burnt some of the rust encapsulator off the top side of the pan when welding from below. Hit the areas with a wire brush and brushed on another coat:
My snorkel tube had some holes near the bottom of it. I did not want to pull the wiring harness out to install one from 914 rubber, so I used some mastic rubber waterproof tape...I am pleased with how it turned out and hope it will hold up over time:
The dishwasher did a great job cleaning the rear trunk seals:
I got burned by a set of rear jacking donuts and supports bought from Restoration design. They acknowledged the problem and immediately shipped me a new set. I compared the new ones to old and saw that the donut was installed backwards on the originals (there should be more rise on the rear half to keep the donut parallel to the ground). I realized it would be less work to flip the donuts on the support than to install the new pieces. Drilled out the welds with a dull spot weld cutter and re-welded the donuts:
I think all welding is done on the car now!
Damn I've got a pair of those to weld in...better check to see if they have the same problem. Did RD say it was just a bad batch or what?
Ya there was a batch a while ago that were welded incorrectly. Im not sure how long ago this set was purchased, but if there are anymore sets out there get in contact with us and we will sort it out.
BTW, your car is looking great Bob. Looking forward to seeing it in Hershey this year!
Pete
"Tented" the lower section of the car and fired two coats of Rustoleum gloss black on the floor pan:
Used the rest of Eastwoods "Internal Frame Coating" on the new section of tunnel just welded in:
Took a look at the hood...it is in good shape aside from some surface rust. Wire brushed the bad areas and applied a coat of Ospho:
With the car supporting its own weight, I took a look at the door gaps. Overall, I am pleased. The doors open & close well and the windows are snug against the seals. The Drivers side gap is consistent all the way up. The passenger side becomes slightly more narrow at the bottom. I found during restoration that the front right fender was replaced at one point, so the car was hit at some time in its life. I regret not checking the gaps before major structural repairs started:
So, are you driving the damn thing to Hershey this year or what?
Ran new accelerator & clutch cables:
Touched up the underside of the hood with two coats of color:
Seam sealed the floor pan:
Cleaned the area under the gas tank for SS fuel line and tank installation:
The J-Man came over to help last Friday. Got a lot done. We ran the stainless steel fuel lines & firewall grommets I bought from Chris Foley a few years ago at Hershey. I shoved a 2 X 4 under the wiring harness to avoid getting hung up in it. Jacked up the car and removed the passenger side rear wheel to get the right angle to start them. Installed new fuel line (about 2') on the tank and connected everything. After dropping the tank in, I had a kink in the line that I was able to work out from the access hole in on the bottom of the car:
Rear trunk lid on...we ended up leaving the bolts a little loose and lining it up with the latch, then raising it slightly and tightining the bolts:
Got a new set of rear sway bar bushings and pressed the last one in the drop link. Installed them on the sway bar:
Installed the pedal cluster, being careful to NOT cross the accelerator and clutch cables:
Bought a shifter bushing kit & started replacing all of them. For the one on the firewall, I microwaved it in boiling water to make it pliable. The others I pressed in with a large vice and assortment of sockets:
Re-installed the airfoils on the bottom of the floor pan:
Hollywood stopped over and helped me get the hood on:
Disassembled, cleaned & re-greased the shifter mechanism. Getting those springs back in was hell. I ended up holding one end with needle nose vice grips while starting the pins:
Cleaned the back of the engine bay sticker with mineral spirits, applied double sided tape and reinstalled it:
Measured the height from the floor to the rear fender wells and discovered that they was a 1/8" difference between the driver & passenger side. Had to drop the passenger side suspension console and add a washer under the retaining nut. Then installed the seals & buttoned up the rear trunk:
Great to see it all coming together! Nice one...
Light work on the car over the last few days. Finished scraping out the remnants of the rear window seal:
Re-installed the hood seal with 3M adhesive. Applied the adhesive then closed the hood to apply pressure:
Decided to paint the rear targa area separately from the rest of the car, hitting this area well during the "full" body paint job would have been a hassle. There was some surface rust in the cravaces, so I applied a coat of Oshpo followed by two coats of primer. Not to mention, I want to black out the areas where the engine grills sit. Will follow up with custom fill Zambezi rattle cans. Masking this area was a bitch:
Sanded, primed & painted the engine deck lid:
Installed the tunnel shift linkage...it was shifting well when I pulled the engine so I set the shift rod at the shifter at the same setting (about 1/4" splines exposed):
The J-man came over to help install the rear glass. We first tried installing it with 1/4" butyl tape with epic failure...there just wasn't enough meat on the tape to seal properly. I did a search and found Eric Shea's rear window install write up and made a trip to NAPA for their 3'8" butyl. SUCCESS!!!
Painted the two tone area below the rear targa:
you amaze me outstandinh
GO BOB GO !!
Front hood needed more spring tension so I moved the springs to the most forward notch. After reading a few threads on 914world on how to do it, I went with the "Heavy coat hanger/large vice grip" method:
Picked up some lengths of brake line at the local NAPA to replace the rears that run from the rear controller to the rubber lines. Used an $8 HF brake line bender. Installed new rubber lines from PMB Performance on all four corners. Discovered two of my line retaining clips were so rusty, they lost their spring. Mr. Shea was kind enough to sell me two at a very reasonable price - thanks Eric!
Picked up a pair of 1/4" body plugs at the local ACE hardware store to fill the old fuel line clips on the firewall. New fuel lines were to fat to fit in & will be tie wrapped in place. Added a dab of permatex on the back to make a water tight seal:
Installed a new rear window to engine decklid seal from 914rubber. Easy install:
Two-tone targa area:
No way this car makes it to Hershey this year. I can say with 90% confidence (it's a teener, come on) that it will make it to the ECC in the fall. I thought about banging enough parts in to make it driveable to get to Hershey 2013, unpainted & all, but decided to not rush and do it right.
Hershey 2014!
Pulled the front bumper. Removed the "tits" and welded the holes shut. There were tiny spots of rust throughout the whole thing, partially covered by at least two paint jobs. I decided to strip the whole thing down to bare metal. Started with chemical stripper and ended with a DA air sander, scoth-brite pads on a die grinder and wire wheels, applied a coat of Ospho to the backside:
Bob,
Great work, looks better than new.
Let me know if you want to sell the bumperettes or 'tits' as you call them. I'm working on my daughter's car and don't want to fill the holes on the bumper.
Dave
Installed a brand new set of engine bay seals that Matt gave to me at the ECC last year - thanks Matt! They were from 914rubber.com and went in easily with a dull screwdriver:
Finished painting the front bumper. Shot Rustoleum gloss black on the back (over the ospho) and semi-gloss Rustoleum on the front:
After a lot of research and posts on 914world.com, I pulled the trigger on some sound deadening material. I went with rattle trap, a thicker version of Fat Mat. I would like this car to be my daily driver, so I want it to be reasonably quiet & comfortable inside. Thoroughly cleaned the entire interior, wiped it down with mineral spirits twice, then started installing it, leaving the channels open as recommended by Scotty B. & others. The stuff isn't bad to work with, but the process is a bit tedious:
Took a look at both front & rear valences. Both had some damage that had to be bumped out. The rear had some rust-thru on the outer layer above the stock muffler exit. With specks of rust everywhere the only way I could get a decent finish was to strip them to bare metal. Did the front with purely mechanical tools, then went back to three coats of chemical stripper for the rear. Managed to get some paint stripper on my wrist where the gloves didn't cover. Suddenly I have hours invested in these things. Fabricated a patch for the rear.
Sweet
A friend gave me a fine Porsche key ring. Put the key on, sealed it in a zip-loc bag and taped it above the work bench as further motivation:
My rear bumper top was trashed, and I wanted them to match, so I went with a set of fiberglass bumper tops from 914rubber. Installed the front on the bumper - it looks great!
Using the old bumper top as a reference, I started figuring out the cut outs I will need in the rear bumper top to mount the license plate lights (which I can't find)
Continued work on both front & rear valences:
Getting tight in the garage down the home stretch:
Kept moving on the tedious task of soundproofing. I ran into a some problems installing large pieces over irregular areas, so I started using 3-5" overlapping strips - much easier to work with:
Great progress, must feel great to be putting everything back together.
How much would say all the sound deadening stuff weighs?
Hit both valences with a coat of ospho & Rustoleum gloss black on the backsides:
Finally found my license plate lights so I cut the new fiberglass bumper top with a Dremmel tool and a cutoff wheel. Taped the finished side of the fiberglass to keep it from splintering:
Removed everything reasonable from the car so I can get sanding:
Cleaned the rear emblem with scotch brite and shot it with primer:
I bought one of the 914rubber.com replacement firewall pads through a group buy a while back. I went with the stock mounting system + velcro. Installed the pad and ran a pick through the pad to guide the plug. Marked anywhere I wanted extra hold with masking tape. Stuck the velcro together on the pad, then starting in the center, removed the adhesive from the velcro so it would stick to the firewall. It turned out nice!
Finished soundproofing the interior:
Nice work - you are making progress.
Looking great! More pictures please
Fired two coats of Rustoleum semi-gloss on the rear emblem & windshield wipers:
Finished the front & rear valences:
Ran a load of parts through the dishwasher:
Bumpers, tops and valences everywhere:
You ran the taillight buckets through the dishwasher and they came out that nice????? WOW
My fog lights were a mess...heavy rust & pitting on the back with surface rust on the inside. Brushed on a coat of ospho, followed by two coats of Rustoleum semi-gloss:
Picked up some heavy duty electrical tape & ran two rows across the lower edge of the rear window using the seal as a guide following the Shea installation instructions:
Aside from the airbox and master cylinder, few parts have caused me as much grief as the rear sway bushings during reassembly. After trying a bunch of different methods to install the lower links, I lubed them up with silicone grease, cut a 2 X 4 to length and used a bottle jack on its side to press them on - it worked well:
The finish line is in sight! Started sanding the entire car in preparation for paint. There are a few areas with surface rust that need to be treated. I refused to drop the airbox again, especially with the tank in...wrapped sandpaper around a paint stick to sand the louvers above the box. Masking this area should be fun:
Found some more rust on the underside after removing the front valence. "Tented" the area & sprayed on a coat of ospho & two coats of rustoleum:
Car is ready for paint!
Hit numerous areas with spot putty & re-sanded. There was one high spot on the passenger side where I cut the fender that I couldn't blend. I didn't want to beat on it with a hammer at this point, so I cut a 2 X 3 to length and used a bottle jack against the wall to push it in:
Bumpers, valences & an Optima 34 on a trickle charger ready to go:
A little nervous about shooting $400 worth of primer and paint with a $12.99 Harbor Freight (on sale) HVLP paint gun, I bought a spare at the same time, tore it apart & cleaned it with laquer thinner today. I don't want to get hung up in the middle of a paint job because of paint gun paint gun problems. I must admit, I was impressed with the job it did in the engine bay:
There's light at the end of the tunnel....
Are you going to paint the final colour yourself or take it to a shop? Looks like you'll have to do alot of masking...
NO BOB!!! You can't finish it yet. It needs to make it's first run to Hershey, so you will just have to find more repair work to keep you busy until April. I could always bring Christine up if you need some more practice.
Great Job man, I look forward to see her in person.
I never knew there were so many uses for a bottle jack!
Awesome work!
Getting close...
John
Took a look at my backpad. Overall, it is in decent shape, except for the upholstery coming off the back. One of the bottom corners was broken so I used fiberglass cloth on both sides to re-attach it, then worked my way around re-gluing it with 3M adhesive:
Your turn signal bucket is shipping out tomorrow. Anything else you need before I ship?
I was not happy with my rattle can paint job on the engine deck lid so I re-sanded it. It will be painted with the rest of the car:
Started sorting out the interior parts. Most were covered in four years of grinding dust. Overall my interior was in pretty nice shape. There are a few odds & ends to be addressed after the car is on the road, but I am rolling with what I have. The targa pad plugs didn't stay in, so I picked up a couple packs of 5/16 hole plugs at Lowes - they look good. For the door sills, I went with stainless steel screws. I couldn't resist cleaning the dash:
Re-connected the emergency brake cables in the cockpit with help on the from 914 world, completed the installation and adjusted the parking brake:
Installed the back pad and dome light, I realized tonight that I have to yank it off again to attach the seat belts :
Had to remove the speakers so I could run the grills through the dishwasher. Two of the brass inserts started spinning in the holes. One broke when I tried to remove the screw. Ran to Ace Hardware & picked up an aluminum insert, drilled the plastic out to 1/4" and installed it with a thin coat of epoxy:
The drivers side suspension arm is plenty strong with the Tangerine racing reinforcement welded on, but I really don't know the condition of the inside of this area. Sprayed a heavy dose of Extend rust treatment in through the drain holes. I will follow up with some Rustoleum:
Donald (Hotshoe) donated a front turn signal bucket to the cause. It had some corrosion on it that I wanted to clean up. As soon as I hit it gingerly with a wire wheel, holes started to appear. It had a good plug on it, so I transferred the socket to my old one. Thanks Shoe!
Installed the eyebrows with new grommets from 914rubber:
Re-attached the rear-view mirrow with a kit from Autozone:
I am pleased with how the interior went back together. The drivers side seat upholstery needs to be replaced, but it will do for now:
In preparation for paint, I dumped the garage and gave it a thorough cleaning to remove four years of grinding dust. Don't want any of that crap landing on my freshly painted car:
After reading a couple of horror stories on CV joints coming loose, I decided to install the CV's with new schorr washers and safety wire. What a PITA running safety wire in here:
Looking good Bob, nothing like a good garage clean out! I seem to be spending most of my evenings rolling around in dust and sharp bits of metal..need to get the broom out.
Interior is looking sweet..can't wait to see the exterior all freshly painted.
O.
Interior looks great, it really came together nicely.
It must feel great to get that done. Cheers
Hah!..with you on that. I get my wife to pick the wire out of my face after using the wire brush on my angle grinder - I call it the hedgehog effect.
Pushed the car out and made an attempt to turn the garage into a paint booth. Installed a window fan backwards to draw air through the garage and cracked the garage door. Was hoping for a venturi effect, but the fan is not strong enough. Pulled the dehumidifier out of the crawl space and ran the tube outside. It will remove humidity from the garage pretty quickly. Everything running (including the air compressor) was to much for my 10 amp garage circuit breaker, so I ran an extension cord down from the kitchen:
Bent up a test panel for painting with a piece of 2' X 2' sheet metal and prepped it for paint. I am glad I did this before I started painting the car. The $12.99 HVLP Harbor Freight paint gun came with a 1.4 tip that did not allow enough primer to flow. I ended up with a very rough finish shooting primer. I ordered both a 1.7 and 2.0 tip tonight and found it amusing that each replacement tip costs as much as the gun itself . I won't touch the car with paint until I can make this test panel look good:
Started sorting put the ECU and MPS mounting & wiring. Picked up the mounts at car shows over the last few years. Had to replace the female connectors on two of the ECU wires:
..noticed the link wasn't working.
http://www.mig-welding.co.uk/spray-painting.htm
Ran all new J30R9 spec fuel injection line and fuel injection hose clamps on the engine. Working in the shed in the summer is always a good time:
My rear tin was not aligned correctly. Had to take it off to correct some of the bends. Naturally, half of the cheese head screws were frozen. After breaking off an easy-out, I bent the tin down and used vice grips to break them loose. Used stainless steel screws as replacements:
Mounted the ECU and MPS:
Pulled the fuel pump and hoses out of the crawl space. It was covered in some type of ?sealant/undercoating? Cleaned it up. Consulted the Haynes manual for the original mounting location...not happening. Went with firewall mount. Cut down some 3/8" rubber tubing to mount the pump. Filled some holes with body plugs & permatex:
Still waiting on additional paint tip sets for the paint gun, I mounted the fuel pump to the firewall and ran all new FI fuel hose and new FI hose clamps:
Fitted the fiberglass rocker panels. Picked up all new stainless mounting hardware at my local ACE Hardware. I had a lot of holes to drill due to the replacement panels installed. I had fitment issues on the passenger side...the new sill triangels hung down further than the originals and kept the rocker cover from fitting properly. Measured the drivers side (with original sill triangles) to determine clam shell seam distance to edge of rocker cover, then cut the bottoms off with a die grinder and cutting wheel on the passenger side. Passenger side came in almost exactly the same:
Banged a coat of ospho into the drivers side cowl channel:
Time to send that engine tin, intake runners and air cleaner to the powdercoaters. Needs to look as good as the rest of the car...
Got some more small stuff done on the car. I am pretty much out of work now until I get the other tips for the paint gun.
Found some left over Rustoleum appliance epoxy from another project. Sprayed two coats into the drivers side suspension console. I'm glad I remembered to wear gloves:
Had to cut back the wiring harness to gain more wire for the fuel pump connection. I am running the wire through part of the front of the engine bay seal. Used a combination of heat shrink & mastic rubber electrical tape to re-do this section of the harness:
Ran as much of the engine bay wiring harness as possible:
Got the battery cables ready for action:
Place rubber spacers between the bottom of the rocker covers and the long.
If you do that, the rocks and sand will have a way to escape and you won't start the rotting process all over again.
Rich
JZ stopped over last week to help me bleed the brakes using the old fashion pump, hold method - everything looked good. Car continues to fight me every step of the way. Coming in from mowing the grass, I saw some fluid on the garage floor near the drivers side wheel. There is brake fluid all over the caliper, disc and pads. Checked all connections and bleeder valves and found everything to be tight. I found it leaking at the top seam of the caliper. Wiped it off with a rag and saw more fluid weeping in a matter of minutes. Just placed an order with PMB Performance for front rebuild kits and new Porterfield pads:
Your engine compartment lines are installed incorrectly Bob.
Screwed around for a few weeks with the $12.99 HF HVLP paint gun. Took my test panel down to bare metal multiple times. Could get a good finish, but always had fish-eye problems, cleaned guns multiple times and installed two water separators in the compressor line and started using a new air hose after talking to Zach...got the same result:
I got myself priced in on painting this thing myself. Chatted with a few folks (including scottyb) about how much it would cost to have someone shoot the paint that I already bought - not cheap! My low compressor SCFM output limited my choices in paint guns. So I went with a low SCFM Eastwood setup for about $200.
Results yielded a finish I am happy with. I found one tiny fish-eye in a 2' X 2' test panel:
I hope to paint the car this week.
Checked the weather around July 10th. Saw the heat wave rolling in for the next week. I had a few days of reasonable summer weather to get the car primed and painted. Carefully masked the car:
Had some old floor lamps around so I could get better lighting near the front of the garage:
After laying down a very nice finish on a test panel, I was finally ready to paint. Working with Eastwoods Concours low SCFM HVLP paint gun, two water separators and a new air line. Car cleaned with compressed air, two wipe downs of wax & grease remover (using a new rag for 2nd pass). Followed up with a tack cloth immediately before painting. Shot two coats of primer using the 2.0 paint nozzle. Primer went on relatively smooth and thick with no defects. Sanded entire car smooth with 400 grit to prep for paint after priming. I was very happy with the results:
It got ugly two days after spraying primer...
Finished sanding the car, cleaned the garage, wiped car down twice with wax & grease remover and followed up with a tack cloth right before shooting color with the 1.4mm tip. About 3/4 of the way into the first coat, I noticed a few fish eyes forming in the paint. Tried applying less paint to bridge them closed, but nothing worked. Not completely realizing how bad it was getting, I shot the 2nd coat of single stage acrylic enamel:
Cleared out of the house for the evening due to the paint fumes. Came back the next day to inspect the paint job. There were fisheyes everywhere in the paint! . The worst part about it was that aside from the fish-eyes the paint job was decent. Devastated, I tried filling all fish-eyes with a small tiny paint brush...made two passes over the car filling holes. Started color sanding with 1500 grit, hoping to save the paint job. Started rubbing thought the color down to primer while trying to get a good finish.
I need to sand the car down to primer.
Frustrated as hell, I need to find someone to shoot color for me. I am 90% certain that it is water getting through the air line of the compressor causing the fish eyes. I don't plan on painting a lot of cars. If I do, I will invest in, or build an air dryer system. What I don't get is why I didn't have problems shooting primer in similar conditions two days prior:
Ahh man, what a PITA!! I feel for you Bob. To be honest, I think when I come to paint mine I'm going to get someone else to do it. It looks so difficult to do a decent job at home...
I was trying to spray primer this weekend myself but my gun has packed up - need to take it apart and give it a good clean.
Onwards and upwards!!
Stopped by a restoration shop very near my house this morning, introduced myself to the owner and told him what was going on. He stopped over tonight to check out the car. The car is going to his shop next week. To keep costs down, I can supply all materials and help with all the prep work in his shop. I will leave the painting to the professionals and have him shoot the car.
Frustrated over my inability to produce a decent paint job and itching to get the car on the road, I like this option.
If all goes well, the car will be painted next week.
Painting seems to have a long and steep learning curve. The good painters make it look easy but I'm sure they have all paid their dues.
Admitting defeat on my ability to paint a car, a local restoration shop stopped over to load the car on Wednesday:
I put in about 11 hours at the restoration shop. We sanded the car with 600 grit D/A sanders, then wet-sanded. The shop owner saw one spot he wasn't happy with on the passenger side fender that I had to cut to gain access to the hell hole...he fixed it while we were working. Car was back in my garage on Friday with a nice paint job. We are going to color sand a few areas and buff it out after the paint fully cures. A big thanks to Bryan Campbell at CSS Auto Restoration of Dillsburg for bailing me out on this :
Nice!
I used to live in Mechanicsburg, nice country!
Nice!
It'll be good to see this one on the road, you've put alot of time and effort into it. Now
Got the parts from PMB to rebuild my front brake calipers after blowing one out while bleeding the brakes. Referencing the Haynes manual, rebuilt both calipers. My rotors were well within spec, so I am rolling with them. One of the rivets broke on the pad holders, so I drilled it out and riveted it back together with a stainless steel pop rivet:
Started final reassembly:
Looking real good!!!
How long now til your 'first' drive do you reckon?
Now Bob, you know Matt's BBQ is the 17th ... plenty of time to get finished by then...
Your car looks awesome Bob!!
Bob,
Just amazing amount of work you did. Read the entire post this a.m.
Be proud and enjoy. It looks great! Looking forward to seeing it at
Hershey.
Cheers,Dion
Banged in a set of 914 rubber front marker boots. Great fit & nice part. Lubed it up, ran the main wires around the 90 bend, then ran a piece of safety wire back through to hook to the other wires:
Attached the fog lights:
Got the engine & tranny out of the shed & installed them with some help from Hollywood. Everything went smooth. He brought over a floor jack..it was great to have one on each side:
Lookin good !
Congrats Bob on being so close to the finish line. You should feel good that you're making this much progress over just a couple of years.
I figured I would be driving the car by now, but re-assembly is taking much longer than expected, of course.
Re-installed the factory antenna and fished the wire to the back of the radio:
Attached & adjusted the clutch cable. Took me much longer than it should have to figure out how the banjo clip worked:
Cleaned the mating surfaces of the inner CV joints, added some fresh grease, installed new gaskets from PMB, tightened new bolts with new schorr washers to 31Ft Lbs and safety wired them on:
Had to use vice grips to remove the decal valve from an old chunk of engine shelf:
Made sure the engine bay seals from 914rubber were positioned correctly on the bottom lip of the engine tin. The seals fit nicely:
Ran the plastic EVAP lines from the fuel tank, through the triangle sills to the engine bay & hooked everything up:
I discovered during restoration that the front passenger bumper had been replaced at some point. They did a decent job braising it on...but the headlight always rubbed the eyebrow going up & down. I could not get the eyebrow far enough forward to prevent this with the factory eyebrow grommets, so I went with industrial strength Velcro. Certainly not concourse, but an effective solution:
Installed the front bumper with my old factory top that was still in decent shape:
Started connecting everything in the engine bay. Like many, I used regular fuel injection hose for the connection from the fuel rail to the injectors. I ran into problems with the MPS mounted in the factory location, as the MPS put pressure on the elbows, causing them to kink. I will order the formed lines for this side. Didn't want this to prevent me from starting the engine, so I temporarily installed the MPS with velcro on the long:
Installed the rear bumper with a fiberglass top from 914rubber. Some light trimming where it is meets the side recesses of the car body and on the top was all it took. Nice fit and looks great:
Installed the tail lights with new seals from 914rubber:
Took the time to brush a coat of paint on the rocker panels where the paint gun didn't reach. I realized if I didn't do it now, it would never happen:
Wired the starter:
Connected the speedometer drive at the transmission. My protective boot was a disaster, so I used mastic, water sealing electrical tape to seal it up:
I was hoping to get the car started today. Everything was going well. Poured three gallons of gas into the tank...no leaks. Checked oil. Pulled coil wire to build oil pressure before starting. Installed battery and saw no smoke. Hit the ignition and the engine turned over. Immediately smelled gas. Fuel pump was leaking like a sieve at the seam and running out over the electrical plug. I think I learned why the pump was covered in some type of sealant. I am in the market for a new fuel pump.
Today ended badly. Fuel continued to drip from the pump. Jacked up the car and crawled under with a gas can. I had to use some force to yank the supply line from the filter to drain the tank. When it popped off, fuel sprayed everywhere, including my mouth and eyes. Managed to get the line into the gas can with my eyes closed as tightly as I could make them, then felt my way outside and flushed my eyes with the garden hose. Decided to call it a day after that adventure. On the bright side, I know my fuel lines aren't kinked under the tank!
Damnit!
I had this engine leak free before pulling it a few years back. After installing the engine, I noticed an oil spot on the garage floor. It is coming from a "bracket" at the front of the engine very near the oil screen plate. The area above it is dry. What is this thing and is there a gasket that can be replaced at my next oil change?
Bob, that's the taco plate for the oil temp gauge.
Seems to be a bit wet around the front edge of the plate.
New pump is big bucks.
I think when mine gives up the ghost on my white car I'll convert to a
2 holer newer pump.
The orange car will get a 2 holer from the get go.
Did you apply for the tags yet? LOOKS AWESOME !
Hang in there Bob..you're almost there! I'm envious you're getting so much time to work on it...
That bracket on the front of the engine is one of the motor mounts. I doubt thats the source of the oil leak.
I have a 2 port fuel pump in stock.
Its easy to replumb in the same location as your original pump.
http://www.914world.com/bbs2/index.php?showtopic=213056
Posts #31 & 32
Installed the new Bosch two port fuel pump from GPR yesterday. Made a trip to the local ACE for the hardware I needed. I ended up going with a 59 cent pipe mount to secure the pump to the firewall. I didn't want to drill new holes, so I modified it slightly to line up with the mounting holes of the original 3 port clamp. Cut pieces of rubber hose as vibration dampeners where the mount meets the firewall. The pump itself pulled up tight against the firewall as well, so I ran a piece of thick mastic electrical tape along the back of the pump. A couple lengths of hose on the supply side, some brass hose menders and it was done:
Pushed the car out of the garage to snap some pics for the insurance company:
From here it looks like all you gotta do is slap some rocker covers on her and go
Your car looks beautiful. Enjoy driving her for many many miles.
Got a package in the mail today from AA - my pre-bent fuel injector lines. Went to work hooking everything up. Then mounted the MPS and Decel valve in the stock location. I forgot how tight it is working in there with the deck lid on. Naturally, I dropped a ratchet and dinged my fresh paint job. I had to disconnect the fuel lines and re-route the wiring harness under the MPS as well:
Dumped a gallon of gas in the tank. Turned the engine over with the coil wire disconnected to build oil pressure and prime the fuel pump. At 6:57 PM on this fine day, my 2.0 D-jet came back to life after about a three year wait in my shed. I couldn't wait for the exhaust to go back on:
https://www.youtube.com/watch?v=1BUMculE0Fw&feature=youtu.be
American woman...stay away from me!!!
woohoo!
Hoorah!!
..ahh just leave the exhaust off!!..I'm liking the 'afterburner' effect!
Awesome. A fine reward. The slightly extended weekend gives you a little more time to get her ready....
Hooked up the shift linkage:
Installed the SS heat exchangers that I cleaned at the car wash 3 1/2 years ago with new copper gaskets:
Installed the Monza muffler that came with the car and the license plate:
Drove the car for the first time in over three years today. Wow, it was awesome!
Sounded like it was running on three cylinders for a while. Re-seated all the FI plugs. I had dumped a decent amount of oil in the cylinders when the engine was in storage, so one plug might have been oil fouled? Not sure exactly what it was, but I got on it in a straight away, saw a puff of smoke and the 4th cylinder came to life. It is running amazingly well.
Still have some light final assembly to do, need to adjust the clutch and have a few electrical gremlins to work out, but it is 99.9% road ready.
Took a video of the engine running today:
https://www.youtube.com/watch?v=jP-Yr21YXwM&feature=youtu.be
WOOHOO Theres some motivation for me to get my bloody motor done.. :-) Well done !
Priceless. Love the big cheesy "I'm going to Manchester Connecticut on 9/14"smile near the end....
Now dump a can of Sea Foam in that bitch and go driving, get her cleaned out.
Bob
Car looks great! Go have some fun with it
Been finishing up some small stuff while hunting down the electrical problems.
Re-installed the factory drain funnels. Thanks to Donald AKA "HotShoe" for donating a good one with a hose to the cause:
Installed new fender to cowl seals from 914rubber - nice seal:
Installed new engine decklid welting from 914rubber - nice part:
Banged on the rocker panels:
Installed the rear valence:
Picked up a good used relay board from Aircooled Racing this morning...I was glad they had one laying around they were willing to part with. Cleaned it up and installed it. My fuel pump no longer runs constantly when I put the car in reverse with the engine off.
Spent the day cleaning grounds and checking connections. 90% of my electrical problems came from the tail light wiring - it was affecting a lot of stuff. I had marked each wire the way it came off and installed them the same way. Problem is that they were installed incorrectly when I took them off and marked them. Broke out the Haynes manual and was able to identify where the five wire connections back there should go by using the current flow diagram. All exterior lights are now fully operational:
Adjusted the brake light switch behind the pedal cluster to get the brake lights working...the tang that actuates the switch had slipped behind the washer:
Hazards aren't working, but I have a new flasher unit on the way. Other than that and installing window scrapers, the car is good to go. I hope to get it inspected this week!
Installed the rear emblems. Didn't have any speed nuts left so I cut pieces of fuel injection hose, poked them with an awl and used them for the installation:
Cleaned and reinstalled everything in the front & rear trunks:
Installed new window scrapers and end caps from 914rubber with new stainless steel screws. Put a dab of grease in the head of the screw to hold the screw in place while installing the inside one:
Dug my heating system out of storage with the new gaskets I made a while back. This is the last part of reassembly! :
All I am waiting on now is a new hazard relay. State inspection is scheduled for Tuesday...then I am completely legal! First trip will be to a get a four wheel alignment.
Bob, it looks awesome!
I can't even imagine the satisfaction it must give you to get that thing back together and drive it... I know its inspired me to just dig in and start tackling the things I need to get done.
You done good, now...
Turk
GO BOB !!!!!
let me know if you wanna race
Living in the Northeast, I need heat. I plan to use the teener as my daily driver until the roads get salted. Took me a while to figure out how all the pieces went, but the install went pretty smooth. Heater & defrost work very well, but it seems as I always have at least a little hot air blowing in on me. I may need to make a few adjustments:
Needed an auxiliary 12V power outlet. Tried the stock cigarette lighter, which still works, but it was to big for modern plug ins. I didn't want to bastardize anything on the dash, so I put it under the passenger side of the dash & installed it with tie straps. Picked up a dual spade connector at the local hardware store and ran the wires:
Passenger side sun visor was a disaster. Removed old Velcro, cleaned it up, installed new Velcro and re-installed:
Update:
After approximately four years, thousands of dollars, countless hours, five small welding fires (including my pant leg once), one minor explosion in the garage, multiple burns, nicks & cuts and a trip to the eye surgeon to remove metal from my eye...I am driving the car regularly.
I've put close to 1500 miles on the car since passing inspection (and I was on vacation for a week). Overall, the car is running great!
Aside from two drops of oil on my garage floor coming from the taco plate, it doesn't leak any oil. Ordered parts from Pelican to fix this at the next oil change.
Checked gas mileage on multiple tanks and I am right around 27 MPG.
New ignition switch should be installed this weekend to fix my starter issues.
There are a few other minor things to work out this winter, but I would feel comfortable driving this car nearly anywhere once I get my spare parts road kit in order. I should have another month of driving before the salt hits the roads.
I've been getting compliments nearly everywhere I go with it. It pulls hard in all five gears and is a blast to drive.
Thanks to everyone on 914world who helped out along the way with parts, advice and knowledge.
A special thanks to my local guys, JZ and Bryan who helped me out when I needed an extra set of hands.
914world.com rocks!
Bob,
If the cable pulls just a little on the flapper you'll get heat. That's fine now but not so much in July. If you run out of adjustment with the cable, you can rotate the whole flapper a bit to get that little extra slack to ensure it's closing entirely.
Looks great.
Fantastic stuff!..wish I could go for a drive. Post some pics of the finished article. Nice one Bob!
I was still having starter issues, ordered a new Hi Torque starter from ebay...hadn't come in yet so I ran a remote starter switch into the car. Changed the oil & adjusted the valves. Noticed some carbon in the oil sump. Hoping it's just the oil poured into the cylinders while in storage burning off. Tested the oil temp wiring & sensor and found the sensor to be bad. Bought new tires. After reading past recommendations from the world, I went with 195/65R 15's all around.
The only logical thing to do after spending four years and thousands of dollars on your car is to take it on a 1380 mile road trip to meet friends from Florida & Connecticut that includes a drive on the tail of the dragon. Packed up the car & hit the road. Hit light snow on my way home.
Drove the blue ridge parkway & went to Clingman's Dome.
Tail of the Dragon was awesome! The plan was to take it easy, but I couldn't. I locked up a rear wheel while braking hard in a corner. I toned it down a notch after that, but still hit it hard. The car performed well, and probably would have done better with a more experienced driver. Saw one cop, parked at a photography area with a food stand. Saw some amazing cars on Saturday too. Took some video & a few pics:
http://www.youtube.com/watch?v=SZdX51XjSNE
The trip wasn't perfect, but I got there & back.
- The remote starter switch stopped working at my first stop on the way to North Carolina . Parked on hills the rest of the way there. We stopped to get our bearings on the Blue Ridge Parkway. I wasn't in a place where I could push-start the car, so I left it running. Between driving up mountains & idling for a long time, it stopped running on it's own. We tried push starting it on the parkway but it wouldn't fire & had traffic stopped in both directions at one point pushing it out of tall grass and turning around to get downhill. Let it cool for an hour, then tried again. Car started and ran fine. I will be relocating my fuel pump under the tank this winter. I was sitting in the car when I heard the fuel pump start to whine & lock up. Not having an operational starter compounded the problem.
- My clutch slipped pretty bad when pulling on to the tail of the dragon the second time and it didn't engage until very late in the pedal release. I was out of adjustment on the cable end, so I put a 3/8 socket under the adjustment nut as a temporary fix. I think there is something wrong.
- When I slithered under the car to check how hot the fuel pump was, I saw a bunch of oil on the heater plumbing. I put 4Qts of oil in before I left home when I changed the oil. Never added any. Dipstick showed full on a completely cold motor before I left Tennessee.
- Odometer stopped working. Fixed before. May add some epoxy to the drive gear this time.
- Every once in a while the car bucks at highway speed.
- I still have a "hunt" at idle. Car rarely stalls, but sounds like it wants to with the stock ECU set to full rich.
Once the car was running it ran really well...great trip overall!
"buck at highway speed": throttle position sensor.
Now pack it up again and head down to the Tropical Ramble in Florida.
Backed on to ramps and climbed underneath the car today. I dumped about 3/4 qt of oil on the road trip. I don't think its burning much either. However, the engine got hot enough that the fuel pump vapor-locked in the mountains on the trip. It is worse on the passenger side. I have oil from the top of the firewall pad to the rear valence. I may have more than one leak, but most it is around the oil filter area. Oil cooler seals? Additionally, the seal around the inner CV joint on the transmission is leaking gear oil.
My car regularly had a gas smell in the cabin. After doing some research on 914 world, I bought 5 lbs of activated charcoal pellets from an ebay vendor and replaced the charcoal in the canister. Bought a scale. If anyone else is going through this, you will need 1.708 lbs of activated charcoal for the job (milk jug tare factored in). It was a pretty easy task...gas smell gone:
Thanks to 914 world, my oil leak appears to be fixed. It was the pressure sensor. Installed a new one from Pelican. Got a break in the weather so I could pull the car out and use some FLAPS degreaser in the driveway to get rid of the oil that leaked out from the old one:
The upholstery was coming loose on the headrest of my drivers seat. The snag was that the material wasn't long enough to just re-glue it to the foam as it left white fiberglass from the seat exposed. Removed the panel screws on the back and noticed 2 screws in the area. Re-glued the panel with 3M adhesive, then used a pick to poke holes in the covering, ran five runs of string down to the screws and buttoned it back up. Anyone not reading this thread would be none the wiser:
Miscellaneous car pics:
Took another shot at the clutch adjustment. After warming the engine up, I am able to burn rubber in 1st gear. I had the clutch adjusted to tight.
Great progress. Keep us posted.
My transmission was leaking at the output shaft seals. Jacked up a side at a time and went to work, using the Haynes Manual as a reference. Even with two electric heaters running in my one car garage it was chilly, but bearable. Needed to drain the transmission fluid, so I reached in the toolbox and used a tool my Dad ground down from hex stock in 1987 so we could check the tranny fluid in my 69 Karmann Ghia...ahh, the nostalgia! One side is done...should be able to finish up tomorrow. Took a measurement with a dial caliper of how far the seal was inset in the flange and came up with .230." Didn't disconnect anything extra to do the job. Contorted my arms and fingers above the heat exchangers to drive the new seals in with a block of wood and re safety wire everything up. Running safety wire with only one set of holes just plain sucks, so I shipped a set of bolts off to my brother who has a drill press to be cross-drilled for the next time:
Got my new VDO oil temp gauge & sender from Pelican. Drained the oil, removed the taco plate & installed the new sender. Research on 914world showed that the new gauge is slightly smaller in diameter, so I bought the black trim ring as well. I liked the plastic mounting "nut" that came with the kit, so I rolled to Home Depot to find something that would allow it to tighten the gauge in place. I bought some type of PVC union and trimmed a little bit off the inside diameter with a Dremel too. It worked well and I am happy with the install:
Install looks great Bob, very imaginative.
Wish I could get the motivation to get into the garage, but its been cold and wet here.
CHT on R, oil pressure on L
Time to address my auxiliary heat fan in the engine bay. Wires were simply electrical taped together in my haste to get the car on the road. I could not find a better solution to the factory plug, but one of the connectors was broken. Used a dremel tool to remove the rest of the old connector and soldered a new one to the remainder of the old one. "Bench" tested the fan and found it to work...I may have a problem in the wiring or switch:
I've been getting some small projects done on the car. Started the car to test the new VDO oil temp sender...couldn't get the needle to move. It didn't even twitch when I turned the ignition on. Went back and checked the wiring. I had to swap two wires in the connection at the back of the gauge. Ran a ground to the light using a dual spade connector. Took it out for a drive between snowstorms - it is working well now:
Addressed some carpet coming loose in the front trunk:
Replaced the 3/8 drive socket on the clutch cable adjustment with a section of copper tubing & a recessed washer so it would stay centered in the tube:
The front & rear holes on the passenger side rocker panel cover had pulled through the fiberglass. The covers are otherwise in good shape. Pulled off the rocker cover and went to work. I enlarged the holes a little to make sure the fiberglass patch would fill it properly. Cut small strips of cloth for both sides. Applied semi-gloss Rustoleum with a brush to the repaired area. The finish had a little more gloss than the rest of the cover, so I went over the painted area with some fine steel wool to get a closer color match:
Installed a new set of inner door seals from 914rubber - well made and easy to install (first picture is the old one):
The snowstorm on Tuesday gave me a great shop day. Tackled a project I have been dreading. There was some rust starting in the area under the passenger side headlight bucket. Man, it's tight working in there! Went to work with an assortment of dremel wire brush attachments, screwdrivers & small hand wire brushes to clean the area. Brushed on two coats of Rust Bullet, new seam sealer and a topcoat:
It doesn't take long for the garage to get cluttered when working on a few car projects at the same time:
Love these projects, gives me lots of stuff to check on mine...
great work as always....
On my way home from Zach's Saturday, I realized I still had a few 914 projects of my own to tackle before Spring.
I wanted some decent tunes in the car, but didn't want anything to flashy. I bought a Blaupunkt head unit and some 6 1/2" Polk Audio speakers from Crutchfield.
Ordered the speaker pods and dash vinyl from Appearance & Performance.
Pulled out the factory stereo that received exactly one AM station - no FM. Removed the old foam tape. I fabricated a mounting plate out of 20 GA sheet metal. I was able to trace the factory backing plate to get the precise layout of the glove box key cutout. Temporarily installed the plate with masking tape so I could trace the cutout from behind the dash.
I had to file the corners of the factory opening alittle bit to get the sleeve to fit. Ran up to Ace for some wire. I was able to match the color coding on most of them. I wanted some support at the back of the head unit, so I took some measurements. Fabricated an adjustable bracket from 1/8" steel to support the rear of stereo. Attached a piece of thick mastic electrical tape do dampen any vibrations.
Ran the wiring and tied it into the fuse block with dual spade connectors. Cut the vinyl for the dash plate and installed it with heavy duty double sided tape.
Screwed the speaker box on and used the supplied template held on with masking tape to figure out where to drill & cut. Ran a straight edge along the sill to take measurements for the speaker mounting holes so both sides would match.
Installed the face plate with double sided foam tape. I left the vinyl a little long in one area to cover a spot where the old vinyl has shrunk slightly.
I am running without speaker grills. The supplied grills just didn't look right.
Everything came together nicely and it sounds good. The system won't be vibrating any spot welds loose, but I think it will do the job for me.
Bob, that looks like a nice install. The 20g plate was a nice touch. The speaker boxes look to be something custom-made for round speakers. Did you make or buy, or perhaps I missed an earlier posting?
Looks great, but I'd suggest getting some grills installed on the new Polks.
If you wanted great sound to listen to, you should drop a 3.2L in that engine bay.
Joe would be proud
Ummmm, when are you available to come down and get my car on the road? Didn't you finish w/ Zach's car last weekend? ;>)
I didn't get nearly as much done over the winter as I expected, but was able to tackle a few more projects.
Took the advice of a world member and installed the grills on the speakers. I don't like the look as much, but decided some protection would be good:
Pilot drilled the holes with a 1/8 drill for the repaired rocker panels. As soon as the larger drill hit one of the holes, it ripped the fiberglass out. I went through it again making sure the area around the hole was completely saturated with resin:
I noticed some rust in the passenger side front fender well. Additionally, there was some substandard work performed by me early on in the restoration that I wanted to fix. My right front fender was replaced at some point and there were two gaps that I didn't think seam sealer would fill properly, so I cut down small pieces of polyethylene pipe wrap to fill the gaps. Cleaned the whole area with a wire brush, banged on two coats of rust bullet & a coat of seam sealer.
I couldn't handle getting jacked for big $ for another custom fill Zambezi green spray can, so I found something very close at Lowes for the topcoat:
I bought a replacement TPS from Dave Sprinkle a few years back as part of a group buy. It solved my idle hunting problem immediately. The car now idles perfectly through the entire warm-up sequence. The instructions supplied with the board were excellent. I used the Pelican article to test the old TPS and calibrate the new one.
Trying to hold the VOM leads while rotating the TPS body proved to be difficult for me, so I used some solderless handshake connectors and wire to make it a little easier.
Unfortunately, I broke one of three plastic fingers off the TPS trying to remove the circlip. When I reinstalled the clip I didn't notice any problems just using two of the fingers so I rolled with it.
I messed up my old throttle body gasket & made a new one. Soaked the throttle body in carb cleaner while it was off:
Bought a set of negative side stripes from Van. Nice decals with great instructions - thanks Van!
For prep, I sprayed and dried the lower part of the car with water twice, including the wrap-around areas, then followed up with two wipe downs of denatured alcohol.
Trimmed down the bottom of the decal to the edge of the vinyl.
Ran a strip of 3/4" masking tape across the bottom of the door for up-down placement then adjusted the fore-aft with a few pieces of tape on top of the decal. Evened up the excess on both ends.
Per the instructions, I made a hinge with masking tape on the bottom. Sprayed everything down with 2 drops of dish liquid and 1 qt water, then applied the decal using a bondo spreader as a squeegee.
Ran a utility knife through the seams and worked the vinyl around the corners.
Turned out nice!
Looks Awesome
My first odometer repair failed last year. I tore back into it last week. Carefully pryed the ring off with a pick and screwdriver. I used the Pelican article as a guide. Taped the gears, removed the shaft and pinched the pot metal gear with vice grips. I wanted to add some Loctite, but I was nervous about getting it where didn't belong.
Something kept slipping in the odometer mechanism upon reassembly, causing the numbers to be half visible as the ODO rolled forward.
I ended up re-aligning all the gears. Took me multiple tries to get it right. What a PITA.
After having it apart twice, I got smart and tested it with a drill and a square bit before reinstalling the ring.
Lubed the gears with some new grease.
Nice, good to see the inside of that thing. Something I'm a little too chicken shit to dig into at this point...
Car is doing great overall and has been my daily driver since late Spring. It's been a lot of fun! My winter project list keeps growing and I've got an oil leak. Clutch needs to be adjusted. Still have a hesitation around 3000 rpm & need to clean the distributor. As long as nothing too bad happens, I'll keep driving it.
Passed state inspection, but I've had some intermittent problems with my right rear brake light. It just goes out on its own and stays out until I pull the bulb out and re-seat it. Cleaned everything up today with 220 grit sandpaper, bent the tabs tighter in the housing with a pick and reinstalled the bulb with dielectric grease. It was to bright to see the brake lights on the garage door, so I pulled into the garage and broke out the special tools.
I'm in the process of adding up the receipts and will post the whole truth so folks know what they are in for before closing this thread. Regardless of the total, it was all worth it.
The hemlock 2x3 is indeed, a very special tool...
Added up the thick folder of receipts for my project...came out a little more expensive than estimated and I know I missed a few things. I post this for 914world so folks know what they are getting in for financially when taking on an amateur restoration. Bear in mind that the only labor charge was to shoot the car with paint ($350).
The car is serving me well as my daily driver.
Here we go:
Purchase price of car: $3,075. Yes, I know I paid too much. Like many who buy their first 914, I didn't know where and how these things rusted. However, I was fortunate that I ended up with a complete and unmolested car with a strong running 2.0 D-jet. Engine was free but not running when I bought it.
Body/Appearance: $670.57 - mostly stuff from 914rubber.com
Brakes: $418.49 - Rebuilt front calipers using a kit from PMB. Porterfields up front. Back brakes untouched, will rebuild this winter.
Electrical: $333.52 - new Optima 34 was a big chunk of this.
Engine/Transmission: $718.18 - vac lines, seals, gaskets, stuff for new oil temps setup, oil & tranny fluids.
Fuel system: $437.32 - 2 port fuel pump, FI hose clamps, FI hose.
Interior: $232.40 - overall, interior was very nice.
Misc parts: $173.70
Paint: $1405.16 - includes primer, paint, sandpaper, masking supplies and charge to shoot the car with single stage acrylic enamel. Good driver quality paint job.
Rust repair: $2656.88 - Repair panels from Restoration Design, welding wire, shielding gas, weld-thru primer, rust converter, sheet metal to make other parts.
Sound system: $349.87
Supplies: $1,102.06 - expendable materials used in the restoration - wire wheels, sanding & grinding discs, etc.
Suspension: $489.23 - New rear billsteins, uninstalled front billsteins, stock springs, new sway bar bushings.
Tools: $1,757.65 - includes anything I had to buy to continue the project. I had a lot of tools before starting. The bulk of this is a beefier compressor and mig welding equipment.
Wheels/Tires: $399.90 - 195/65-15 Hankook Optimo Tires
For a grand total of $14,194.53
I was shocked that it got this out of hand. Agreed upon value with the insurance company is $12,500.
So, not counting the car purchase, the tools and consumables, and the paint labor -
you spent $7909.82 on parts and materials for your restoration.
That's not a lot, all things considered.
Heck, I've charged that much labor for rust repair on a 914 before.
Bob, good on you for keeping such good records. I haven't got the discipline to even consider keeping records like that as i consider the car to be my therapy...it's not so complicated that I wouldn't consider doing any repair by myself or with the help of so many of the members of this community. What a fantastic resource.
So now, do yourself a favor. Take all those receipts and put 'em in a small brown paper bag. Pour yourself a beer, or a nice single malt, and take the bag outside. Prop open a lawn chair, sit down, and nearly finish your beverage. Take a deep breath of this cool, late summer night breeze. Lay the bag on the ground. Light it on fire. Let it go out. Finish your beverage.
Allow yourself to acknowledge that you can't put a price on what you've done, so let it be. Take it for a drive tomorrow knowing that whatever it cost, it was worth it. Your car looks great.
At least that's how I look at it...
If you lived in the UK Bob, you could probably double that!!…you are on the right side of the pond for affordable 914 ownership! Anyway, it's not about the money right?!
Bob,
You did a great job.
The car looks great.
Now go get laid.
