Well after over two months it has finally arrived. Guessing a lot of you are already familiar with this car. Previous threads are http://www.914world.com/bbs2/index.php?showtopic=111004&hl= and http://www.914world.com/bbs2/index.php?showtopic=95381&hl=.
I bought this car for two reasons.
First, back on moaners day 2010 my 76' was rear ended. Got a rear clip for it and was going to have Area 51 Werks straiten it out and put on my AA steel flares. This car handled most of that need. (flares will still need to be done)
Second, I was planning on doing the five lug conversion. Had the parts to convert the 914 suspension to a five lug. (Modified 914-4 parts) This car was a huge upgrade as T.C. had converted it to a 911 setup both front and rear.
Those of you who know me already know this is a car for my son Dan, as I am legally blind and for some reason the stare of Minnesota would rather I not operate a vehicle on the roads.....
After some thought and checking Dan's finances (Porsche Purists Skip this paragraph) We have decided to put a 1966 Corvair 180 turbo in it. This engine will be modified slightly. Heads will have stainless valves and angled exhaust ports. Cam has been custom made by Cower Cams for more torque in the mid range and high end. Just waiting on the rebuild kit from Corvair Underground. We also will be changing the draw through Turbo to a dual carb blow through system. We have asked Steve Goodman (Corvair Guru) for advice as we started down this path.
Set a goal to have it road worthy by the RRC this fall.
Here are some pictures, sorry my son took the pictures and can not seem to center the subject.
Still searching for a name, suggestions welcome.
Irv, since it's getting a Corvair engine, I'm thinking of a Nickname like Nader's Nightmare
T.C.
Congrats on the car. I went to look at it and it was the cleanest shell i have ever seen. I just didn't have the time or money to do with it what it deserves.
Being blind never stopped any Florida drivers, maybe you should just move here!
Good luck with the build
Kevin
What prompted the covair engine?
How fantastic! Congratulations. I wanted this one when it was selling a couple of years ago before I had saved enough to get my first teener. I was looking at one that was selling in Al. that had a corvair engine, but that had floor pan rust. Terry the owner simply loved the corvair power plant and had it to about 150hp carbed, no turbo. How much boost are you going to run?
I'm lookig forward to seeing this car beefed up.
Take care,
Chuck
Thanks T.C. for the nickname.
Well after 5 months and still waiting for engine parts. (Another story but if your looking for Corvair engibe parts, i can tell where mot to go) The car is up at Area 51 Werks to get the flares on.
We found 255x60x15 to go on the 15x9 rims that came with the car. Well with that sized rubber and rim Rick had to add almost 2" to the rear flare's.
We will need to modify or build new rocker covers
Also when he placed the front ones up for fitment, noticed they will need to be modified also. Sloped nose car. so more
I'll post some larger photos if Irv and Dan give me the OK. I would show you the work required to reshape these flares but inprogress photos would likely freak you out. They look really fuggly before they look good.
If I can offer info, advise, or links to good suppliers of corvair parts, let me know
hopefully it was a 1964 spyder so you got the 164ci engine,
That is a better engine. If you want to put more oomph behind ya, bore it out and add VW p/c like I did on the bus
Here ya go guys. Here's a couple from the first day. The rear track is fat so I couldn't just install the flares as everyone else. The sharpie line is where the flares fit without modification. I moved them almost 2" out from the line. These first two photos will kind of give you the impression that I ruined a good set of flares and it will be a miracle if they are even useable anymore. No worries.
I am butt welding these and shaping them as I go. I find it easier to tack them over the stretched lip of the original panel then cut through and hammer and dolly the two edges to line them up, then weld the gap. Here's the underside showing the waste strip I pull down as I move about 3-4" at a time.
The next set is showing a bumping tool I use to shape the panel as I go. I bump the low spots with this tool and a pointed one I have, hammer and dolly the highs and file the panel.
This is as far as I got today. It's starting to take shape.
And here you can see how much I had to modify the flares to fit the fatness. Lots of welding, grinding, planishing and filing before it's done.
In a 914 that will be plenty fun and cheap to maintain
If you going to run the YH rochester carb spirited driving you will experience flooding and there is a simple vent trick to alleviate it.
I had to do it on mine when I autocrossed it when I was 16. I think it is in the how to hotrod your corviar book.
Irv and Dan were here today. We worked on the engine mounts. They were not in very well so we fixed them. We also fixed an inside door handle. I managed to get another 2 hours forming the rear side of the flare. The forward half needs forming and finishing with my bumping tools and file but the rear half is getting close.
Wow Coop, that thing has one fat ass! keep posting pics.
Looking very nice Rick!
.......Ya, the Corsa turbo shits & gits.....but.
there is a problem with flooding?? (especially on cold start-up)
Starting to shrink the extra metal from reversing the shape of the flare to stretch it out.
Tigging up the little pin holes left from stitching the flares on with the mig. some are so small you can only see them with a light shining from the back.
Oh, forgot to tell yous guys, I bought a tig...
Dan and myself where up to Area 51 Weeks Sunday. Dan took some pictures of the flare Rick has been working on, beautiful work!! A lot smoother then I could have imagined.
We also lowered the front suspension so the fronts can be fitted property.
Also installed the Getty dash. Unfortunitly we misplaced the gauge face plate , so no pictures with the gauges at this time.
Last pieces to get the engine together are supposed to arrive this weekend, my fingers are crossed as I wait.
Engine pieces are shipped and should be here by Wednesday. In preparation I have installed the reverse rotation pieces. Hoping to have the engine together by the end of next weekend.
Ran out of wire for my mig and gas for my tig so I'm done for the day. Got the right flare laid out and tacked.
Looking great Rick!
Irv
Engine parts arrived last Tuesday , although it was 6 days from when I expected them.
Worked on it this weekend got the cam, crank and case together
Project came to a stop with the next step. Had to put the wrist pin in. Heated the rod end as I was told to do, wrist pin was supposed to slide right in, it didn't. I then I went the other direction. Picked up dry ice. Wrist pin slid through the rod and stopping before exiting the other side.
Have a 6 ton press, however since I have never did wrist pins, I can only see bad things happening. So off to local engine rebuilder to get this done.
Irv
Well got the pistons and rods back Friday. Got rings on yesterday was trying to install them in the Cylinders. Will not go in , stopped to think about it.
This morning I removed the rings and check fit. Can barely see light through the gap. Should be .007 to .040.
Need to take the cylinders in to take a bit more off.
Can't seem to catch a break!!!!
Lots of bumping and grinding yet but here's a couple hard days stretching, welding and filing.
Looking good Rick.
Cylinders at the engine shop to do a slightly bigger bore.
More bumping and shaping. the last couple nights.
Engine shop call this morning and I stopped by on the way to work. No re boring..... I was sent the wrong piston rings for the Probe Pistons. They require a narrower ring.
Called the shop that had these pistons and they are checking to see if they have rings for these. Way things are going guessing they will not.
Looking good Rick.
What pistons do you have? Probe? Like in Ford Probe?
Sorry work was a ..... This week, everyone trying to get their projects in before year end.
Did not intentionally get Probe pistons, but yes that's what I have.
Was looking for a forged piston (not many out there anymore) and found these. Probe no longer makes these. I was right, he does not have the rings. However he is getting a set. May need to be made if they are nolonger available.
Wow, Rick the front looks great!!!!
These fronts are going to be a bitch to fit. As I suspected the tires are really....Really close at full lock. I'll be massaging them all day.
Progress looks great. It must be nice having a heated garage. The snow flew last night in my parts.
Yep, Very mild here. Here's a sample of the work for this weekend. I haven't decided if I am going to raise the wheel opening yet. At full lock the tire is very close to the lip.
I had to reshape the front of the flares. Here's my slapper and shot bag in action.
Here's the flare butt tacked to the slope nose. Notice how much I had to lower the flare to line up the top surface.
The flares were too close to the tires so I raised the lips.
I made up a clamp with angle iron on both sides to hold the flare while hammering the new lip. This allowed me to give the flare a crisp lip with minimal distortion.
Wow!
This angle is
Nader's Nightmare is going home! Nice day to do 914 stuff on the 14th!
Thats the first time I've seen a slant nose conversion with flares. It looks awesome!
Great work, I cant wait to see this car done!
Nice job Rick!
Never ceases to amaze me what I'll see @914World. Awesome job creating a new lip on the wheel opening. You da man Rick!
Rick dropped the car off this afternoon, he went way beyond what I expected. Flares looks great!
Need to put seam dealer on these and paint the backside to protect them. Will start this process tomorrow. Good thing I have Monday off to finish this.
Sorry no pictures as it was snowing (weather man was wrong again) and I forgot to do pictures. Will post some when I work on it tomorrow.
Special thanks to Rick!!!, this turned out to be much more work then we expected.
Slope Nose Revival
I wonder how some up side down louvers would look in the fender tops? ( probably to much revival )
Hey Irv,
I sent you an email with the phone number of a guy that works out of his garage. He's in the metro someplace. Give him a call when your ready and have him at least look and see if he can get you back in paint.
Wow Wow Wow! Rick has some serious metal skills, no doubt. When this project got under way I was thinking "oh no" and now that I see the finish result I was thinking "that man has got skills".
Rings are here.....
Will be assembling the engine today and tomorrow. We will see how far I get as I will be taking my time and double checking everything.
Will post pictures later this evening
Been offline for a few months due to health issue. Was able to start working on it the beging of this month. Got engine just about ready to be put in the car, Hopefully will be ready by next weekend.
Balancer, dist, carbs, turbo, valve covers (haven't shown up yet) and clutch and in the car it goes.
Pictures
Nice!
If you have a need, I have some almost new rockers and swivels you can have. Since I went to roller rockers, I dont need them and there is about 1000mi on the old gear.
Really like the corvair motor. An American flat-six 911. LOL
Looking good Irv. Nice to see the progress!
Wow Rick, that thing looks amazing. Must have been very challenging to get the flares to look right with the slant nose.
So...this car looks exactly like the one formerly owned by member 1bad914 out of Michigan... if so has anyone else noticed how many times it's changed hands in the last several years!? Nothing against the car or owners AT ALL, just a random fact. It's easy to spot with the color and slant nose.
http://www.914world.com/bbs2/index.php?showtopic=51574&hl=
Since its had a variety of drive trains and setups it's the PERFECT car for a Corvair transplant!
Good luck with it Irv! Your son will love it.
Ok engine is together minus turbo and carb's. Will be coming off the stand tomorrow and clutch
and pressure plate going on. Attaching the transmission and getting ready for it to go in to the car.
Will take a bit to get it in as I will need to build Mount for it. Hopefully in a couple of weeks will be ready to start it up.
Nice. You are not moving the oil filter? I think I have a block that bolts on and you can put hoses to to move it away from the wall.
Making an engine mount for that will be real easy. That engine was built for transplanting.
Nice progress! I wanted to come down and help for a day but I'm working 7 days a week now. I agree, if you can move the oil filter console it will be easier to fit in the engine bay.
Have the adapter to replace the oil cooler and can cut and plug the oil filter mount off, however really would like to keep stock oil cooler. Seen others that have cut off the oil filter mount and tapped the holes to 7/16 with 1/4 18 pipe threads and ran a external oil cooler and remote filter setup. Leaning more that direction. Found one already on line setup this way to bolt on. He also has the correct 12 row oil cooler cover I need, however no reply from him yet. As with everything on this engine, nothing has come easy. Can construct my own cut off oil filter plate but really would like to get the oil cooler cover.
I have a Corvair motor that I bought for this conversion also. It's been staring at me in my garage for a year. Do you have more detail on your experiences getting the motor rebuild and 914 ready?
The wrist pins are interference fit and different for us VW guys. Heat is your friend I like building the Corvair engine. Real easy
Well engine is in the car, not fully secure but in the car. Fits nice as long as you cut off the oil filter mount and remove the original Corvair engine mount plate..
Made monting it more difficult because of choosing a aluminum finned oil pan which took away a 1 1/4 inch of clearance from the enging mount bar, going to be a tight fit. May have to lower the bar a bit depending on final mount design.
Going to be a bit before it is started. Since I did not take the engine out I need to figure out what wires go where.
Also need to fab up the engine mount and there is the filter mount I cut. I think I have two options, Weld in AN fittings where I cut it off and do a remote filter and cooler. Will need to angle cut at least one of them to allow room to thighten fittings to them. Other option that may work is to weld the holes shut and remove the pressure switch, drill a hole at the other 90 degree angle and add AN fittings there. Then do a remote filter, cooler and pressure switch mount.
Here are pictures of the cut filter and mounting plate.
Here is the engine before it went into the car.
Need to find wiring digrams for the engine compartment, Haynes is to small for me to read.
Irv
I can take a pic of my oil setup if you like. Nice and easy. The pressure switch can be moved by using a grease gun hose (good to 3000psi ).
Try these diagrams.
http://www.pelicanparts.com/914/914_electrical_diagrams.htm
You can view them on your computer and maybe print large versions that you will be able to see. Wish I had some time to come and help.
We should be around. Not sure you will have time to hang around but if call me if you get up anyway.
Here is my setup. I have the lines going to a thermostat and cooler.
Thanks, basically what I came up with yesterday. I will be using AN fittings, should have it together tomorrow.
Thanks for confirming I am on the right track.
Irv
Oil filter mount modified.
Engine mount is just about done, hopefully will start it this weekend.
Where is your return going?
I may be turning the key on my science project this weekend as well. Good luck!
Ah, I didnt notice the blue adapter Looking forward to it.
Did not fall off the face of the earth....
Did not get to a place to try and fire the engine yet. Ran into two issues I am working on solving.
-Engine mount. where it looks really nice, I built it just a hair to tight to get around the engine mount bar. Working on fixing that.
- Altenator mount. since I went with a electric fan the mount that does not require the 90 degree bend in the belt. That mount pushes it into the fire wall. Working on modifing this to be in the 911 position.
Metal work is not my strongest skill so struggling a bit with these.
Hopefully with in a week I can get it fired up.
Irv, keep hammering...
Good to read your still going at it.
Thanks for the update. I've been curious as can be about how it's going. I'm really on the fence about a 1911 or Corvair rebuild. I'm all Hypnotoad with attention.
Its heart stated beating 12:53 pm central time on 12/15/12.
Been a while since I posted on this thread as I have ram into some issues that caused me to remove the engine from the car. The engine mount interfered with the shift rod. I also had the wrong ring gear on the flwwheel, 127 instead of the 130 that the Porsche starter needs. Knew I needed 130 and was sure I counted them. When I pulled it apart it had marks every 10 teeth. Must have came to that conclusion when counting them and took the short cut and multiplied the marks by 10. Turns out it only had 9 teeth between 40 and 50, 80 and 90, 120 and 130.
I am getting really good at installing this engine.
Started it and held it at 2300 RPM's for about 25 minutes to break in the cam/valve train. Ran smooth and tach was steady. Needs to be timed still and I need to find the air leak as the lowest I could get the RPM's was 1900. Idle stop screw is not touching the arm and the idle mixture screw is at 1 1/2 turns that the manual calls for, so I am thinking a air leak that is leaning it out.
Also need to locate the correct senders for the oil temp gauge and oil pressurw gauge. Oil temp climbed quickly and pegged but my external oil cooler fan did not turn on. It has a 170 degree thremo switch on it. Oil pan was hot and you could olny leave your hand on it for about 5 seconds before it became uncomfortable. External oil cooler was cooler then the oil pan. Oil pressure gauge goes to zero with the ignition on and dummy ligjht comes on. when started the dummy light turns off but the gauge stays at zero. I can feel oil running though the external cooler lines so I know there is pressure there.
The thermostatically controlled electronic cooling fan I put on to get rid of the 90 degree belt, is impressive. To quote my friend who was helping me "It feels like a low pressure system was generated". You feel a noticeable breeze coming from under the car and if by the engine compartment you feel the air rush past you. I am going to have to put a safety switch on it so it shuts off when the engine lid is opened.
Irv
Alright!
Great job!!
Way to go Irv!
Congrats on the engine startup. You should get us some video - would love to hear it.
Any updates? This project is awesome!
I am seriously thinking about doing this...
Another wave of snow Keep on going! Spring is coming.
Update....
Engine mount is complete.
Shift linkage installed.
Get all gears.
Clutch works and is adjusted.
Speedometer hooked up and working.
Accelerator hooked up.
Axles and CV joints in and safety wired.
Turbo is fitted and installed.
Car can move under its own power now! Have not tested it fully yet as it keeps snowing here. Engine tin and exhaust are next. Then some clean up of wires and then the interior. I can see the light at the end of the tunnel. (hopefully its not a train. )
Irv
Hoo! Excellent work!
Pictures or it didn't happen!
Great job, cant wait till Spring!
Wooo! Great progress! Snow Sux!
plumbed the turbo to the cards today.
Pretty simple setup and not flashy but it should get the job done. It also allows me to get a air cleaner on it. will work on that tomorrow.
Still have the surrounding tin and exhaust to do but getting closer every day. Although it keeps snowing here , supposed to get a inch again tonight.
Irv.
No more snow in the forecast up here! Keep on going. I have that shroud material here if you end up needing it.
Well it has been forever since I posted on this thread. Seemed like every step I took forward on this project I ended up sliding back about 10 miles. I am at a point that I seem to be moving forward again at least until I try to drive it when all the salt gets washed off the roads here in Minnesota.
I had a huge crankcase ventilation problem that I caused by replacing the stock cooling system with an electric cooling fan that the builder forgot to take into account for the stock ventilation items he replaced. I have modified it to add oil separator and ventilation boxes.
Mounted
With shroud
I have hooked it up to a Bugpack breather box and have a drain hose from that to the valve cover if any oil gets up in that breather box, most likely over kill but the way things have gone, I am going the extra mile than having to back track.
Along with the crankcase ventilation problem the blow through turbo was pressurizing the carbs and shutting of the fuel under boost. After researching and talking with Steve Goodman (Corvair geru that has done the blow through system before), turns out I will need the mechanical fuel pump as well with the vent hole drilled and a hose barb attached to feed the turbo boost pressure so the fuel pressure increases as the boost does.
Snow is basically gone as of today but need some heavy rain to clean the streets before I test it out.
Irv
Where did you get that electric motor setup? Home made? Or maybe the one Corvair Specialties sells? I'm very, very curious to see how well it cools.
-marcus
Yeah, no worries there. I'll never buy anything from him. His ideas are good but his way of having stuff manufactured overseas to very low quality and then selling them here never quite seems to work.
Just ask Dr. Evil about his roller rockers.
Anyway, I'd LOVE to have a cooling setup exactly like that if it works. And I suppose some kind of nutty 100 amp alternator to drive it. It's fantastic how one can lose the cooling belt and cleaning up the engine bay at the same time.
Nice to here the snow is going away Irv! As soon as I can get my trailer out I will come get that clip. I bought a real truck now so I can actually tow it.
Some of us in the 'vair world make 3100cc engines by using type IV pistons and cylinders. You can find u-tubes on it.
Great work,
Cheers,
Kurt
Hey Kurt,
Some of us do the same 3.1 liter conversion. You should check out these threads:
http://www.914world.com/bbs2/index.php?showtopic=214258&hl=marcus++corvair
http://www.914world.com/bbs2/index.php?showtopic=82750
Only 914coop seems to be bold enough to go for the turbo though. Fantastic stuff!
I'm kind of bummed about the total fail of those CorvairSpecialties parts.
A costly learning curve.
I've read since that the Ford smallblock roller-tip rockers are a fit (with mods).
(CompetitionCams)
Investment-cast in steel,more ratios.
Made in America,like the GM Corvair.
Could be a solution.
Magnum
Hey guys,
I have a set of these on my desk right this moment. I spoke with Ray Sedman about this a couple of days ago. He said that the trouble with SBF roller tips is not mechanical, that in fact they work extremely well. The problem is that they're very expensive to have modified by a machinist. You have to TIG weld the existing oil hole shut, drill a new oil hole in the stock location with several carbide bits ($22 each!) and then widen the stud hole. It's easily $200-$400 worth of machining time. For $350 you can buy GOOD full roller rockers from Clark's or American-PI. So unless you do your own machine work, it doesn't make sense dollar wise.
Food for thought.
-marcus
The name is probably taken......Porvair...?
Had to bump this thread. Wondering how it's going!
I would like to see some pics, I have a long term plan to do this.
Nice to see your still working on it!
The engine mount and exhaust mostly.
No, no turbo. Probably duel singles.
Hey Irv, Spring is coming! Time to get busy!
Bringing this thread back to life. My transplanted kidney failed 3 plus years ago. My friend finally got me working on the car again this fall. Once I get it moved to my garage I will post updates and pictures
I am really pulling for Irv. He is as tough as nails battling life's challenges everyday and building a bad ass Vair powered 14teener. Be careful Irv but keep it going when your able.
Bumping this thread for my friend Irv. Post when you can man!
Hi Rick, unfortunately this has been sitting way too long. My
buddy came over last weekend and stated we need to give it some time on it. It is now in a 3 car garage that is heated so I do not have any excuses. Although dialysis and my eyesight always are challenges. I'll PM you my # and new address
Saturday plan is fire up the TV, turn up the heat, manually rotate the engine and if all goes well finish alternator and figures out the turbo oil lines. Charage battery, clean out the old gas, and try firing it up. i'll need to adjust the timing since it appears I'll have to remove the dist to get room to get it in.
. more to come Saturday .
Take a video
If Christine allows me to finish and it starts I will take a video.
Okay, Saturday rpdate a day late...
First the bad news, No video as Christine wins again and I did not get to a place where I could try and start the engine.
Good news is I got a bunch of things completed.
1. Moved that car out to the midile of the garage, Dollies are still working good.
2. Took the plugs out and the engine turned over by hand. (':Qarl:','smid_7') (':Qarl:','smid_7')
3. Got the alternator installed. Also reinstalled most everything I had to remove to get it installed.
4. Got the fuel tank drained, also discovered the fuel pump had died during this exercise.
5. Pulled the tank and did my best to clean it, looked great to a blind guy but my friend said I should add a filter to the fuel system before the pump just to be safe.
6. Picked up a new Fuel pump and installed it.
7. Battery got charged and put in the car, needs to be secured.
Last thing I needed to do that I could not get done was to reconnect the oil supply line. The Alternator is in the way of the setup I had so I need to redesign that which will need a couple of new connectors. I have ordered those and they should be here by next weekend so hopefully then I can try to fire it again.
Non 914 re;ated but needed in Minnesota, I installed a new carb on the snow blower, I at least got one project finished.
Tried to attach pictures but cannot seem to figure it out from my phone, I'll move them to my computer and try from there.
Nice to hear about some progress.
Work is still being done but finding much more to do...
1. The alternator bearing froze and needed to be replaced so pulled that and sent to a re-builder.
2. Redesigned the oil line setup, waiting on parts to finish it up.
3. Discovered all the bearings are shot on the fan/belt system. Ordered new parts to resolve those issues. Unfortunately this means taking the top off the engine but this extra work hopefully will help the belt stay put.
Tomorrow I start disassembly of the engine shroud ,fan, and blower housing to prepare for the arrival of the new parts.
Sorry no pictures as my eyesight has gotten worse and I will need to rely on my son to take pictures and post them. hopefully he will be back next weekend to assist putting it back together.
More to come next weekend.
Hey Irv,. Got your PM before I read this post. Have your son send me some photos as soon as he is able. PM me your address. Maybe I can break away for a day and help out.
Work done, waiting on new parts
Time to check on Irv.
I tried to call him but his number is no longer working.
Anyone know how to reach him? Kind of worried about him.
Still no word about Irv. Last we spoke he was moving someplace around Milacs lake MN.
Found two phone numbers for Irv. Tried both but no longer in service.
Spoke with him about 8 months ago. i had his new number but my phone has been shedding contacts for some reason. Anyway his Son Dan now has the car. It may or may not surface again.
