I finally got to drive my 914 again! Back in June I was having fits with the L-Jet system that was on my car so I decided it was time to tackle a project I was wanting to do for some time, a CIS conversion.
I retrofitted a CIS Basic system to my stock 1.8L engine using parts from various VWs and Mercedes and today I fired it up for the first time and was able to take it for a long drive. It felt AWESOME. Smooth reliable power all the way to redline. It has a nice growl to it too. I'm quite impressed. I still have to make some small adjustments but at least now I can get back to driving the car daily and the best part, NO MORE JACKSTANDS! I'm going to drive the snot out of the car this week to get the system dialed in and hopefully next weekend I will take it for a day drive in the mountains. More details and pics to come later.
The cat is happy too!
I always thought CIS off a VW Rabbit would work nicely. Post lots of details!
Great idea and congratulations. I'll bet a lot of folks will be interested in hearing about what you did.
Were's all the pictures from the build?
Information please!
Zach
Smokey wants more pictures!
Here kitty kitty.
CIS ='CALICO IS SLEEPING' ???
CIS works great on TIV engines.. I had the set up on my Grey shop Bus 10 years ago along with a stroked TIV.. The torque was phenomenal and so was the MPG.. The simplicity of the system is what I appreciated most.
I didn't touch it for 7 solid years.
CIS? Would that be "Cat In Situ"?
The Cap'n, typing with a cat on my shoulder.
you guys are nuts...I don't let the cats on my cars because they scratch the sh$t out of the paint!
Easy to train them. Just wait till they're settled in on the hood and fire it up!
I am working on the same thing except from what Rick suggested, from a Rabbit. Actually, Someone else is working on it (already installed one on his son's Teener) to teach me how to do it. I absolutlely love what he did.
Okay here is a break down of everything I used.
Fuel distributor – VW Rabbit
Warm up Regulator- VW Rabbit
Fuel lines-Audi
Fuel Injectors-Audi
Fuel Pump, Filter, and Accumulator – Mercedes 300 class
And assorted flexible hoses and fittings from various German cars
I used stuff that was readily available at the local junkyard and I spent less than $150 putting this system together. The easiest route though would have been to just get everything off a VW rabbit and be done with it but the junkyard didn't have a complete Rabbit at the time.
The pictures show my initial installation of everything. I’ll clean up some of my workings now that I know the system works to my liking. The airbox/ fuel distributor is simply bolted to the intake runners, the warm up regulator is mounted to the firewall, and the Mercedes fuel pump assembly is mounted on the firewall under the engine.
Sorry for the crappy pics...
For the injectors I had to fab up some brackets and spacers so that they sit at the correct depth.
And finally since I was completely new to anything CIS, this book was a great reference!
Oh and the cat is 18 years old and a HUGE 914 fan
One of these Volvo 240 Aluminum Air Box Tray's would probably fit in there a little better than the Plastic box.
Jeffs914/6 was or is installing CIS on his 3.0.
http://www.914world.com/bbs2/index.php?showtopic=113796&hl=
I was drooling over Dan & Jeff Dixon's CIS setup on Dan's Type IV at WCR and asked for detailed info. Jeff sent me this great site http://www.ferrari400parts.com/page3.php. The is a lot of documentation there.
Volvo 1800s also used this system and I've found some info by searching for it.
This is definitely something that is in my future since I've got my own 914, my son's 914 and my other son's VW Bus to think about. It certainly looks superior to anything VW/Porsche ever put on a Type IV!
Are there particular years of Rabbits that you want to find for this?
Thanks for all the photos!
whats with the long pipe on the air box?
Why didnt you just put a k&n cone on there instead of the pipe?
I would think CIS would also be great as the basic system should do well with minor engine mods ( cam ) and even small displacement changes ( 2056 ) I too am considering this setup. I've had a couple 924's and my dad had several rabbits when I was young. CIS is stupid simple and brilliantly effective
It's "basically" a mass-flow system so displacement and altitude correction are built in, up to the excursion limits on the flapper.
However, like D-jet, it hates intake reversion and needs a mild cam with not a lot of overlap. Pulses in the intake drive the flapper batty...
There has been proof that CIS actually does fine with radical cams....I need to find where that was. I am putting CIS on my tweaked out corvair engine in the bus Already have it in the 914 on the 2.7 (stock).
Ok, Jake says it's a good system. He's the man who's done the testing.
Will this system let a 2056 make the kind of power that one with carbs would? What I'm getting at is that I often read a 2056 with D-Jet will be limited to 100-115 hp whereas a carbed motor can make 130.
I like the thought of injection AND the bigger power.
I have thought about CIS for my 2056, but have held back as I think my cam is too aggressive for it. I'd love to find otherwise.
Zach
Is this hard to integrate with a stock ECU? What are the drawbacks, if any?
I just thought I would post some links that I found helpful before I started down this road...
http://www.shoptalkforums.com/viewtopic.php?t=114309
http://members.rennlist.com/evill/ed1.htm
http://www.thesamba.com/vw/forum/viewtopic.php?t=417142&postdays=0&postorder=asc&start=0&sid=ff5cdef039cb981bac9d130f4f1aa114
http://www.stits.org/DMCVEGAS%20DMC%20Archives/archive/Misc./General%20Automotive/CIS%20Thing.pdf
http://www.aircooledtech.com/CIS_injection/
http://www.thesamba.com/vw/forum/viewtopic.php?t=309085&postdays=0&postorder=asc&highlight=cis&start=0
I'm not sure how that system would interface with an ECU:
"K-jetronic is a mechanical continuous fuel injection system which does not require any form of drive whatsoever." "K-jetronic: a fuel injection system from Bosch"
Its not simple -- rather mechanically complex, but it is modular and not electronic so in that way it might be simpler to work on:
Here's a picture of the air flow sensor that controls fuel:
Here's a diagram describing how it enriches the mix when you stomp on the gas:
I'm not qualified to comment on how a high duration camshaft might affect the operation of the sensor, but it is clear that strong pulsations in manifold air flow might. I thought that valve overlap acted to mitigate exhaust gas resonance, permitting more fuel to enter the combustion chamber? In the Bosch K-jet material they mention overlap as an important part of their performance/economy/emissions strategy.
I want to know what those who have actually worked on it (K-jet system) feel about the durability of all those the mechanical movements over 25-30 years. Are the necessary components obsolete? Are used parts reliable?
One thing I found very interesting in my research is that later K-jet usedan overlay electronic feedback loop with a lambda sensor.
Thanks to Thinair for providing the informative links.
I can't speak to the overlap limits with CIS (K-jet) but I spent a number of years working 5 days a week on cars with CIS FI.
The system as a whole was relatively trouble free. The common issues were typical of most FI problems, vacuum leaks, injectors wear or get dirty, fuel pumps fail, fuel pump relays fail and of course vacuum leaks.
Also there seemed to be a number of techs that would "adjust" the pressures to improve something (drivability, performance, mileage, etc...), this was usually a huge disaster that cost a lot to fix. Fuel pressures are used throughout the system to control everything and they all have to work together.
Fuel contamination (water/rust or dirt in the fuel) could be a huge problem and required replacement of most components that had fuel going thru them. We had quite a few cases of fuel contamination in the late 70's early 80's but after gas stations started paying some big repair bills there seemed to be a big drop in contamination cases.
It was just a few years ago I sold my last Audi quattro with CIS and it worked fine with an unknown number of miles. It had 190K miles when I bought it and the speedo cable was broke, after I fix the speedo cable I found the odometer only counted miles sometime. I drove it 7 years after that and only replaced a fuel pump relay and an ignition module, well those were the only parts related the engine running at least.
Used parts seem to be available but watch out for dirty parts.
Jim
Thanks Jim, I value your "narrative of experience." I take that the major cans/components are not normally serviceable and the typical cause of failure is contamination of some sort.
My 81 Scirocco, daily driver, has 417,000 miles on it and i have never had a problem with the FI system. I would think that qualifies for dependability.
The later CIS did use a fequency valve (lambda control) system that you can still use. Need to set it to 50 pulses or minimum to negate the 02 sensor but still it would work without the 02.
I had been thinking of doing this also as the system is trouble free and i have access to about 50 of the cars for parts. This thread was just what i needed.
Rex
I have to take that back. I had to replace the Lambda relay a couple of years ago. Damn FI anyway.
Since the system is volume based it is imperative that the engine have an excellent, very steady vacuum signature.
When I was building lots of these CIS engines I designed them like an engine that would run stock FI, but they loved more compression and head work.. Thats something that stock FI doesn't care much for.
It is VERY easy to over do it on the cam side of a CIS based engine, I used split duration and lift on the exhaust side to make my power along with a very mild arrangement on the intake side and was never disappointed.
Jake is your carb cam (the one similar to the 494) too aggressive for CIS?
Zach
Jakes probably under a boxter looking for a oil leak.
Maybe one could get some stainless lines made up from Chris Foley ( Tangerine Racing ) to run the pump up front and have lines that would take the pressure for this. A fella on evilbay sells stainless lines for the Mk1 Rabbit with the bubble flair on them for Rabbit replacement , Chris might be able to do this as he's familar with 914s.
Jack
curious?
if one were to use a megajolt jr with edis parts and mcmarks crank position sensor for ignition only ...
http://www.914world.com/bbs2/index.php?showtopic=97550
could cis be used with it - versus carbs?
or does cis tie ignition to fuel some how?
jim
I've followed this thread hoping to find relief from the oppression of the MAPS, a part that is, in my limited experience, too fragile, too hard to find, and too critical to operation of the d-jet system for my comfort. Under that criteria, and given the fact that I don't have a super-sized motor to fuel, I don't think of k-jet as a viable alternative to my imperfectly stock FI.
The OP, jcl914, and Rex-n-effect are obviously talented mechanics and/or have identified a supply of spare parts. They put their talents and resources to good and productive use. I'm very grateful they shared their interesting information about CIS
but...
I've been checking pull-a-part inventories for three cities for the past two weeks for a 1977-79, Rabbit, Dasher, Jetta, or Scirocco and have only found one (later models had the lambda circuit and an ECU).
Assuming I found a donor with its fuel system intact, after the conversion I'd be in the same position as I am now with d-jet. No, the critical k-jet components are not obsolete, just insanely expensive (mass airflow sensor/fuel distributor = $1800 at Rockauto). I didn't check the e-bay but with that new price as a point of departure, used k-jet parts are probably just as pricey as d-jet parts. At (new) $200 for an accumulator $75 for an idle air regulator, $200 for a high pressure pump, and $50 for Bosch injectors, repair costs could be prohibitive.
I don't know where a stash of late 70's VW' donor's are anymore than I know where a supply of early 70's 914's are. so tracking down a solid ECU MPS, TPS, CHT, and dizzy fuel points for my stock motor doesn't feel different that tracking down a fuel accumulator, mass air flow sensor and fuel distributor, idle air valve, and special injectors. Maybe easier since the stock components have fewer moving parts?
Now if you went the next step and converted to K-L - jet ('81 Scirocco's were really neat cars, BTW) with an O2sensor and a lambda control circuit, that might be a different and even more interesting story...
This mod would be a great alternative to buying a complete carb setup , if one didn't have a fuel induction system to begin with. If you already have a fac. FI setup , then it is probably the best way to go , although the critical parts are getting harder and $$$ to source. The CIS was used on a lot of different cars and is still more plentiful .I checked over eBay for a current price check gauge and the hard parts didn't seem any more expensive than what it would take to piece together a d-jet or l- jet setup from scratch. There seems to be alot of fellas that have had good experiences with the CIS a very good gauge of reliability of the system. It's not modern FI by a long shot just another way to get air and fuel to the cylinders. I like what I have read about it and probably will in the future ( when the engine side of my project gets there ) dig into this mod for my induction needs , as what I have at present , carbs that may be junk , this setup would be very doable .
My $.02 and I hope my posting doen't kill the thread .
Jack
jcd914 wrote: "I put a 1.7L long block in a 74 1.8 914 using the 1.8 L-jet system and it ran better that any 1.8 car I ever drove. The L-jet system really like the extra compression the 1.7 had."
You are the third person I've heard say something positive about l-jet on a 1.7. One was a member here, who referenced to me a thread from several years ago. The other was a local guy who I met the other day. I'll look for some more threads on that topic. If there's some information I'll report back in a new topic. Sorry for going off-post.
I can speak of it's reliability and performance, I currently have owned the Evil Ed 914 GT Turbo for the past 7 years. I was building a clone of Ed's car when he put his car up for sale and I bought it.
the CIS system that I got from Gary Miller that Ed used I recently sold to a friend who recently installed it in his 914 2.0 with grest success!
I have tweaked the CIS in my GT Turbo with the injectors fro a 6.9 liter V 8 Mercedes which has provided increased fuel flow as well as 20 degree lower cylinder temps, also changed the WUR to the one used on the 930.
The CIS components are avaliable and as far as the intake runners if you find a set out of a VW bus that accept the CIS injectors you don't have to mod the 914 runners they bolt right up.
A little update on this….
The car is running great! I had some trouble getting the fuel mixture set correctly (long story but I shouldn’t have messed with the mixture in the first place) but I got through it and have been driving the car the past few days. Everything is running smoothly and even in extreme heat the car runs fantastic. I filled up the tank tonight and will be doing some mileage tests to see what kind of numbers I’m getting. I’ll report back.
Great , I was wanting to see an update on this mod. Keep the info coming please.
Jack
great thread!!
After sleeping on it, I could be convinced to go out and pull full systems and bench test them if the money's right. Might take me a little time as I'm packing right now for the move, but it's an idea.
Zach, for you I would gladly assemble a MSII for free
As for what happens with a radical cam with the CIS, I can't speak to how a T4 would act with one, but I can say that my dad raced a circle track 1.8 rabbit with CIS.
The class limited lift to .425" but had no limits on duration or LC. He ran a seriously radical cam with lots of overlap. He also had 14.0:1 compression. It was actually very drivable at lower revs (which it only saw driving around the pits and onto the trailer), and was unbelievable strong on the track (he won a lot of races with it). It idled great with a little lope, but it never bucked and throttle response was instant, even when heavily loaded.
It surprised us both how well the CIS handled the overlap. Of course I'm sure the compression helped and if it had been a street car (with lower compression) it might not have been as tame, and the myriad driving situations that come up on the street might have revealed some shortcomings. But I have driven carbed engines with a lot of cam on the street that were much less behaved.
To bad it's such a PITA to change cams in a T4. It would be pretty cool to see how one responded with a lot of cam. I suspect that the lighter 914 would be more forgiving to it than a heavy bus. I also thing that a larger engine would handle the CIS with more cam better.
Small Update:
I've been driving the car alot and it hasn't missed a beat. Last weekend I took it to the mountains and drove to the top of Mt. Mitchell (6500 ft) without a problem. Today I took it on a charity car cruise through some hills and lots of back roads. Over 200 miles today and I got 31 MPG! That's pretty good considering I was driving it pretty hard at times. I have been getting about the same with mixed driving around town. I'm pretty pleased with these result. I think I'll keep it.
Most Excellllent !!!!!
Jack
That GREAT!
Zach
So I thought I would give one last quick update... The car has been performing flawlessly. It hasn't missed a beat. Still getting mid 30's for mileage and still very pleased with everything. Now that its gotten cold though, it can be difficult to start but that's simply because I never installed the cold start injector and thermo switch initially. That's on the project list for this weekend
How cold? The cold start injector does not fire until in the 30s F*.
Doug, what do you think is a fair price for this setup (sans injector brackets) for a guy to pay? I can't help but think one might be better off buying a clunker. My neighbor can't get rid of his rabbit for $500.
i hope to build out my next 914 with a cis 1.7...rather than a six, primarily for milage over brute hp
Doug,
Nice build. I have the CIS on my 2.0. It worked so well this past summer I wound up blowing 1st gear(40 yrs old,never touched)with the improved torque.
I was wanting to dyno it before this mishap. On paper it should be in the 120hp range. It has 96mm P&C with a FAT cam lift 413, and duration of 258.
I had posted my build titled "16 mos in the making" or search under Dion.
I received a lot of nice feedback from the forum.
914Dave and I installed it. We placed the airbox on the drivers side with a short run
to the thottle for better response. The Volvo box looks like a good idea. I have the Rabbit/GTI box.
Nice fuel economy numbers you have. We'll back to taking the tranny out....
Cheers,Dion
Hey Doug,
Looks good.
Glad you got it worked out.
-Peter
Dion,
I like that set up, and a very clean install.
I used to own an '86 V-Dub, so it all looks very familiar &
very tempting, but my f.i. system works flawlessly right now.
So, how did you guys transition from the boot on the intake air sensor to the throttle body? This pic looks like black ABS pipe
but I can't, yet, find a good way to get to the throttle body. I'm trying to get to a 2L throttle body in pic below:
The mixture system is not in final position for installation; this is to hopefully see if I/we can get the motor running out of the car.
2 more questions:
Do you have "stock" fuel lines or SS fuel lines? Any problems with adequate flow of fuel thru the lines to the fuel distributor?
What initial adjustments were needed to make the system run on a motor? Was it just bolted on and it ran?
I ended up switching to a 2.0L intake and Throttle body so I made a special elbow to connect the two. Lets see if I can find a pic...
That's beautiful! I have a plastic "S" shaped pipe that is used in the VW intake system. One end fits the boot at the oval end but then goes to about 2.5" circular opening which is what I'm looking for parts for. I think I'll try to mount the injectors like this:
an idea I found in my searches. I got the concave washers today from some core heads in the parts stash. Thanks to root for letting me work at his shop today.
Nice work Jim,
My set up is using PVC pipe and Jubilee clamps for connecting the Rabbit/GTi
airbox to the throttle body. Good solution on the injectors. My fuel lines are a bit of a mix right now. Rubber & braided steel. I think they are from a 924 set up if I remember correctly. I have a 911 cold start injector on the plenum.
Thanks for the pix, Dion. I asked this ? before; did your engine start right up when the CIS system was bolted on? What kind of adjustment did you have to do on first start-up, if any? Plans are to fire it up at the ECC Oct 12...
will second generation jetta etc, cis work as well?
k
Hey Jim,
Glad Dave responded to your question. Didn't see till late (too many patients).
As Dave said, car coughed,sputtered then cleared its throat.
Once idle was dialed in and timing adjustments done all
was ok. Co2 sniffer helped narrow the rich/lean
questions. Nice progress. Look good.
Keep at it.
Found an even better way to mount the injectors. 1-1/4" fender washers; drilled out the center to fit the injector. Rod machined 1" spacers ... thanks root!
still have to paint and mount/replace intake air distributor. Don't see why it can't be ready to try to fire up at ECC. Oh, no exhaust; just stubs ...
This has been a great thread to follow . I have a question about the injector retention methods shown here , sequence - o ring, spacer, larger o ring , washer, clamp - correct ?? and this does hold / keep the injector seated into the injector cavity even with the hi pressure that they run under , also does the hole at the end of the injector get covered or uncovered. Gotta ask if you don't know / haven't experienced.
Jack
Thanks Jim , that was a great clarification , mentioning that the far left seal is actually a D-Jet system seal specifically. Look forward to more info on this setup as it progresses. It seems to be a very simple system with a few adjustments as long as certain parameters are addressed and maintained. TIA...
Jack
Progress is on schedule to try to fire this thing up at the ECC Oct 12 at roots. Just a couple of questions for the collective brain trust:
1) do I need to have an accumulator in the fuel supply? We are "bench" testing this set-up; the engine is mated to a tranny mostly for the sake of having a starter and is out of the car on a caster system. I imagine we only start and run it for a short time, 30-45-60 seconds. I have an accumulator for the final install, just not connected at this time.
2) Do I need to connect to a relay board? We will supply power using a car battery with a trickle charger connected. Can we run the engine off battery power alone? I think since there will be no current in the alternator field windings, there is no need for a voltage regulator since without field winding current there would be no alternator output. Correct?
3) I think the ECC brain trust collective will be able to wire up the starter and power to the dizzy with Pertronix (before ). I have gauges: VDO oil pressure that can be connected to a dual sender, vacuum ...
The project is on the bill:
You shouldn't need an accumulator. I don't run one on my car and I have had no issues.
http://www.youtube.com/watch?v=gRLyDnp7G_0
stainless steel braided fuel lines of CIS is way cool.
https://www.youtube.com/watch?v=a4fJAfXYxWk
Jim,
enjoyed that film and the narration...
