Posted by: jimkelly Aug 18 2011, 11:15 AM
i tried to drill a hole in the center of what is left of the oil press sensor - this thing seems to be made of kryptonite ???
i also had to drill out some tin screws - will try to extract as many as i can.
jim
Posted by: Jeffs9146 Aug 18 2011, 11:28 AM
use a dremmel with a carbide tip then a screw extractor.
Posted by: 76-914 Aug 18 2011, 11:37 AM
You need to drill it thru, first. Then the extractor. I prefer the spiral to the 4 cornered extractor. Especially when working with softer metals.
Posted by: jimkelly Aug 18 2011, 11:57 AM
spiral
Posted by: r_towle Aug 18 2011, 01:11 PM
if you drill out the oil pressure sensor, you will be opening up the case on that motor to clean up inside.
So, I vote to procrastinate and wait until you have nothing left to do but drill out that piece, one the bench, with a jig and drill press, and its a nice day with a good cold beer.
When in doubt, procrastinate.
Rich
Posted by: Marty Yeoman Aug 18 2011, 01:23 PM
QUOTE(r_towle @ Aug 18 2011, 12:11 PM)
Do it later when you have more control over the situation.
Marty
Posted by: JawjaPorsche Aug 18 2011, 01:25 PM
I had my oil pressure sender to break about ten years ago. I was afraid to drill because I was afraid of metal shavings in the motor. So I got a good sheet metal screw with permagasket and plugged the hole. Not the idea thing to do but it worked for me.
Posted by: jwc914 Aug 18 2011, 09:51 PM
QUOTE(JawjaPorsche @ Aug 18 2011, 12:25 PM)
find a small nut that fits right on top of the broken piece. weld up the center and now you will be able to back it out with a socket, john
Posted by: 76-914 Aug 19 2011, 08:29 AM
Rich
Use a good shop vac when drilling. The flutes will direct the shavings out. The vacumn will keep the shavings from falling into the engine. Or, if your really paranoid, flip the engine and drill it out from beneath and let gravity work with the vacumn.
