I've been slowly sorting through the mess I made for myself about a month ago at Willow Springs, and have 1 quote to fix the dent.
I'm trying to decide between (A) repairing my chassis, and (B) getting a new chassis and moving all my parts over.
I feel ridiculous even considering scrapping my chassis when I see some of the crazy "rustoration" threads here, but the fact is it's probably going to be about the same cost to straighten this chassis versus buying a donor chassis/car and building it back up.
I'm going to take this "opportunity" to fix/improve some other things on the car while I have it all apart, but I need to figure out my chassis plan first. Here are my options:
A: If I repair my current chassis ($10k - $12k):
- Find front clip
- Remove Brad Meyeur kit (to be replaced with Engman kit)
- Remove/cut existing reinforcing tubes
- Celette bench, weld new clip
- Fix front right fender/flare (it was also damaged, that strut broke)
- Add Engman kit
- Add back reinforcement
B: Build up a donor car/chassis and move over all my parts ($10k - $15k):
- Find a donor car/chassis
- Remove all rust/prep chassis. Rust repairs.
- Add 4 steel GT flares
- Maybe also put this one on a Celette bench first too to make sure it's straight.
- Add Engman kit
- Add chassis reinforcement
- Lots of small modifications I had already made: lower drivers floor/seat, close up a bunch of unused holes/make it cleaner, lots of seam welding, dash modifications, etc, etc
... plus full R&R on the front suspension/etc, but I need to do that regardless of my chassis plan.
With A it "my" original car, but with B I actually think I might end up with a nicer end result because I'm going through almost everything again, but it's probably a little more money and A LOT more work for me (versus 95% of A is just me writing a check). Am I off on my prices?
So, what do you think? A or B?
-Steve
p.s. And... the other strange factor is that this car/chassis was my first car and I've had it for almost 20 years. But, given how much I've already modified the car, most of those "original" parts aren't there anyways. I think if I got a new chassis and moved over all my parts, it would still feel pretty much like "my" car... I'm not super attached to that specific VIN... Or am I?
[attachmentid=272618]
[attachmentid=272617]
914
A couple hours earlier...
That front bumper had been built and chromed about 4 months ago...
I have been facing the same dilemma, unfortunately my original chassies wasn't as nice as yours. I decided to just start with a new chassies.
Is that a 915 and what shifting mechanism is that?, sorry for the ot question.
Yes, 84 915 w/ factory LSD and Vellios "916" kit. It was the best option at the time (1997), but I think their are better options now (Wevo, etc).
-Steve
A.
You know for sure what you are dealing with, you know your $$$ estimate is solid, and you know that the rest of the car is already done. And, it wil make for a better story
If you have 100% confidence in a proper, correct repair under scenario "A", then I would go that route. That car has history, will now be resurrected and put right, and will then continue to provide pleasure (and frustration to a degree) and just add to the cars' "provenance". Yeah, that's a sentimentalist point-of-view, but you must admit that you are somewhat attached to the car after all those years.
Paul
Sorry to see your car.
Been through something similar.
Your biggest problem are the reinforcements that passed the stress to the rest of the car so everything is off.
It's _very_ difficult to fix and it will never have the same stiffness again. Best you can expect from the fixed car is a crippled DD.
I see that you like to race/AX/enjoy the car so, if you have the patience and time, buy a new chassis.
Also consider that you'll have to strip the care to the bone anyway. I bet that fixing your chassis will be more expensive then painting a new one.
I like A too. It's the devil you know vs. the one you don't. Beautiful set up.
That's a tough call and toss of the coin. If you decide to strip your chassis and transfer the parts to another car. I will buy your bent shell. I have a trailer and can come and get it.
The shop that would do the work (European Auto Body in Escondido) knows 914s and I think would do great work.
I had that same concern. What do others think on this? Does a straightened chassis lose a lot of its strength? I was thinking that by adding reinforcement (and maybe more than before for a semi-tube frame build) that the car could get be even stiffer than before. But would those same reinforcement on a new chassis be even better...
Hmmmmm...
-Steve
Remember, once this is all fixed up, there is nothing preventing it from happening the very next time you get on the track. At least accidents on the road are usually covered by insurance. You might want to decide how much you can afford to write off on a racecar when you plan the next build/rebuild.
Either way, best of luck. mark
Steve,
1st of all. Sorry about the car!
Just my $.02... This car can be repaired... You are going to need a frame puller and a lot of jig building. Judging by how far that the roof is tweaked makes me think that the damage is further into the car than the nose. Inspect the longs and see if there are kinks in them or creases. If there are post photos of them. If they are ~ shaped than that means you have some shrink, that means somewhere else you have stretch... Not the end of the world because folks have been fixing that sort of thing since the beginning of auto repair... But it may mean replacing some pieces that you didnt anticipate. I do agree with your statement of strength though. After an impact it is very hard to get the car back to the rigid piece it once was, not that these 914's are super rigid to start....
I would say rebuild if you can! That car is very nice!
Thomas
W are talking steel here. If the chassis is properly pulled by someone who understands these chassis there is no reason it can't be pulled back to where it should without overworking the metal. Once the chassis is in line on the Cellete and it has been checked to make sure the chassis is straight, then putting it back on the Cellete and welding in the reinforcements will pose no problems and you can make the chassis stronger than it was before. The cost difference is pretty much irrelevant. The chassis swap would be easier, because your not having to go backwards, but there would be more work involved in getting the chassis back to where the current one is.
To me it seems like a toss up. If I were doing the work I would find starting with another chassis easier, but either way can be done.
Yes, we know we have to put on on a Celette bench with the 914 fixtures.
Yup, as much as I love driving this car on the track, I think this accident has ruined it for me. I don't do track days often, but if I go again I'm going to get a $15k boxster (or something) that can be my simple "track car". Not that I want to throw $15k away crashing a boxster either, but in retrospect I'd feel A LOT better about wrecking a $15k boxster than causing $15k of damaged to this car. This car was too nice for the track (nice paint, leather, etc) and I drive it 99% of the time on the street anyways.
-Steve
Steve,
Sorry to see this. As stated before you've got one of my favorite 914s around.
I guess your tough situation comes down to the question of how sentimental you are about this chassis? If you're confident in your shop's work that they can straighten this one back out, go for it. As you stated before, you'd be putting the rolling chassis on a cellette anyways. Keeping it seems like a whole lot less work.
One thing I didn't see you mention in your approx. cost is paint. I can't imagine it'll be easy paint matching panels, but I guess that depends on how old your paint is. Would you repaint the whole chassis?
If you do get a wild hair, Racer Chris has a Ravenna Green chassis located in CT: http://www.914world.com/bbs2/index.php?s=&showtopic=141802&view=findpost&p=1533132
I'm not sure how fond you are of Ravenna Green, but I think it'd look awesome if you swapped everything over....
Good luck!
Steve,
I'm so sorry to hear about your car--I've always admired your sense of detail and perfection for afar.
Question: Your dime or insurance? I ask because, will you end-up with a "salvage" title? To me that is a deal breaker for fixing the car. I know it really doesn't mean a thing for those who understand, but it just becomes a dark cloud that follows the car.
I know your car will be awesome once again even if you fix it.
Mark
man, this sucks big rotten goose eggs! Professional consult is required here to make a sound descision. call Trever! let him look it over with his experienced eyes. he loves 914s like us but he will give a fair dose of reality about this chassis...good or bad.
the bend may be at the A pillar and forward only. this woujld affect B pillar door gap and could be isolated damage forward of the B pillar...
Trever AKA "TWISE" will know as soon as he sees it (European Auto Body)
Sorry to see such a nice specimen in any accident. IMHO, do all you can to save it since you've owned that vin number for twenty years...not many can say that about their 914's.
Yup, it's there now and where I got my quote. Their advice is pretty much the same - they can definitely straighten it, but they can also build a new chassis/flares and the cost will be about the same...
So we know it can be straightened, and also think they do great work, but what's the right decision. I am leaning towards fixing this chassis, but I'm not in a huge rush to make a decision either.
-Steve
My dime, and no, there would not be a salvage title.
Wow Steve what a bummer, I've always been impressed with your car. It's funny, initially, I felt B, but since you mentioned that you probably won't do the racing as often once you rebuilt it, I'd probably go with A. There is a sentimental attachment to the car for you.....just like I have with mine. Now if you were going to continue racing it, then that attachment kinda goes away, then I would have said B.
I have helped several guys find a clean donor chassis. it is getting harder to find low rust donors
Why do you think that?
Honestly, I think I'd want a car that I'm going to track to be even stiffer and safer than a street car. I've never quite understood that... ?
And... I'm still not convinced that the repaired chassis with reinforcement still wouldn't be very, very stiff.
I'm been toying with the idea of building some sort of "half cage" this time around (door height and lower, and as easy as possible to get into (with a cage)). I'm still not likely to track the car again, but want the car to be stiff and correct.
-Steve
No kidding, I have been looking around just to see what's available (even if just for a front clip), and so far... not much!
old photos...
Maybe this point of view will help:
Let's assume you want to buy a 914. You found 2 identical cars that are just what you were looking for and priced the same. The only difference is their history:
- One car was completely rebuilt using some beautiful parts from a concurs car that was damaged in an accident.
- The other car was severely crashed, cut in two and a front clip from some other damaged car was welded in. The combined chassis was measured and aligned using the best available tools.
I would pick the first one without blinking and I'm sure all those who commented on this thread will do the same.
Why would anybody prefer something that was damaged when a perfectly good alternative costs the same ?
And from my past experience, trust me, that old car of yours will never be the same.
Sorry about the old car but I believe it's for your own benefit.
I'm not sure if that's exactly the plan, but I'll find out more details next week. I think the idea is to graft in a corner, but regardless it still could be ugly.
How do you deal with the glass?
Have new glass made? I really have no idea, but I'm sure it could be done...
I'm just brainstorming, but it is interesting.
Seriously, Repair the chassis you have. You know the car, You just had it painted so color match shouldn't be an issue.
The car looks worse than it is. Really, I would leave all the welded body panels on the car, drop the engine and front and rear suspension, gas tank, dash, ect.
Get it up on the Celette and pull the car. You will need to remove the tubing stiffeners. It will pull easier with them cut out. One the chassis is stress relieved and the front sheet metal is as pre-dimensioned. THEN remove the left fender, both headlight buckets and front nose panel. The rest is simple.
If your not putting the car back on the track forget all the extra tubing. You won't need it. Besides, it's dangerous in a street car. Just check over the chassis spot welds for signs of stress. If the spot welds were stressed you will see it. Seam weld the area or drill and plug weld the area and you'll be fine.
That was a beautiful and it can be just as nice again.
Here's a thread I have started on Sandys Ravenna car. The one was headed for a sawsall party. I saved the fenders. They werte totally kinked.
What does your little girl think?
.....Remembering 914 day, July 26th
Good choice, whatever you decide. The only bad desicion I've ever made was to not drive my 914 when I could have.
Conrad
Whoa, I am so sorry to see that and shocked...you car was seriously beautiful and kind of like how I wanted to build my car if I had the money...I am very sorry but I hope you decide to rebuild it and not swap parts to another chasis...good luck to you.
Here's a walk down memory lane.
I would fix it. while a celette bench would obviously be best I do not think it is a mandatory tool to get it straight.
those diagram/pics show alot of extra steel being added that dont do you any favors street or track.
a street car should be allowed to crush to manage deceleration of impact. this absorbs energy that will not be transfered to the ocupant
> veltror
> I assume my car is out of the question then...
You are exactly who I was thinking of when I've been considering a chassis swap. I mean, how could I give up my this chassis when I look at what you are working with?!?!
> Sean
Several of those pictures/reinforcement designs are from pretty well respected builders. Do you really think they are worthless additions or ? What about the Engman kit?
-Steve
each example must be discused in context of the car its in. whats good for a car with a cage is different than what is needed in a non caged car. we should optimize based on how we will use our car.
Steve, I sent you a PM
Fix it.
You never had a straight chassis to begin with...so some TLC on a cellete will deliver you a really straight chassis.
If its apples for apples, I would invest in the time on a bench to adjust a few other things (aside from fixing the damage) and you will end up with a better car in the long run.
Rich
All the best with either decision...It was great seeing you at the event...maybe next time I will be running with you in the fast group.
Hmmm... That makes sense but there sure are conflicting opinions on this. It does seem to me that that the fixed car could be even straighter/stronger than a stock car that never had any damage or extra work done, but there others who say the opposite is true (it will never be "right").
Sort of like "blue printing" a factory engine... A blue-printed and rebuilt engine can be better than a 100% stock factory engine, right?
-Steve
Talk to Bob Saville about Huey...
Wrecked at Targa Newfoundland
Now autocrosses and shows
1- It wasn't "right" from the factory. Or at least, it wasn't perfect. These cars were made by hand on a production line, and none of them is exactly right.
2- It looks like you have extra tubes; a car with those in place will be stronger than any original 914 if the tubes are in a reasonable place. If you're worried about strength, then put in more tubing in the right places.
3- If you do the work on a bench with the correct fixtures, it will be at least as straight as when it rolled off the showroom floor.
I say fix what you have. In the end, it will be straighter and stronger than a fresh shell, as long as the people doing the work know what they're doing.
And this is also time to pick a good shop to do the work, and then listen to them. If a good place digs into the body and tells you it would be better to get a new shell, then ignore all of us "experts" who haven't actually seen the car and get a new shell.
--DD
I sure hope ya fix it.
did Trev see it yet?
I've decided I'm going to try to repair the car first and see how it goes. If it can't be 100% straight and strong, then I'll look at replacing the chassis.
I found some of the parts I need from Glenn in LA via Craigslist. Really nice guy and I'm surprised we've never met before (at least I don't think I had met him). He had 8 914s in his backyard, and was pretty knowledgeable about the cars. I don't think he's on the forum...
I've never cut apart a 914 like this before. I certainly got a new perspective on areas of the car I hadn't seen before.
The rust looks worse in the photos than it really is. It should clean up well.
-Steve
thats great news. I think he will turn out just as fine as he ever was
Did you get the VIN?
Someone with experience can work magick with a Celette bench.
Glad you're making progress.
We'll I'm almost done tearing the car done for my "re-build" and came across this surprise tonight. The inside of the drives side longitudinal is cracked. That is a crack in the metal, there is no tar (removed long ago). Anyone ever seen that?
-Steve
close up
BTW - the crack looks sort of old and the metal is solid there (no rust). I don't think this was caused by my off track excursion (but who knows).
-Steve
That crack is very very common. Good to see progress!
common, most crack there. I could come up with 5-6 pics of 914 ive fixed that on in the last 2 yrs alone
Thanks for the input. Glad to hear it shouldn't be a problem...
That's another good reason for the Engman kit. I think Sean mentioned mine was also cracked there before he installed the Engman kit. That spot is pretty much the fulcrum point for the chassis and has the most stress on it, besides the firewall.
Well, I think 914 torn down as far as it needs to go. Probably a little more than was really necessary, but I plan on cleaning some things up "while I'm in there".
I made a wooden dolly to move the car around that works great in the garage, but I'm not sure if the casters are going to be strong enough to handle moving the car on a flatbed to the body shop. Hmmm... I may have to rethink that...
-Steve
Good luck with the fix Steve. Mine looked like yours for 4 years after metal work. Dont loose momentum.
Dolly should be strong enough. Mine went about 15 miles and it looks weaker than yours. The hard part was moving it up the Flatdeck on 4 casters.
When I opened this thread I was hoping it wasn't about Steve's orange 914 that I remembered. But it was, and that sux. Does it still have the 3.6?
There's an old saying: "if you can't afford to push it off a cliff, don't put it on a racetrack".
Note to self, get an old beater for track days.
Not trying to derail your thread.
I just met the owner of this car that broke the inside front upper control arm just going into turn 1 at Willow Springs last month. He walked away (well, got checked out at the hospital) with no broken bones or lacerations. This is more the "push it off the cliff" type of accident. The car rolled multiple times and then went end over end. Very scary and pretty amazing. It turns out that the little roll bar is surprisingly effective.
good progress!
> With all the metal cut out in the front end, If I were you, I would put a brace across the front between the front suspension pick-up points
Yeah, I was thinking the same thing and several other improvements, "while I'm in there".
Good luck with your journey... I think you are going down the right path.
BTW - there is a 914 / 6 GT build with a million pictures on the bird site. Just in case you are looking for some inspiration.
Steve. Glad your coming along with the " fix". Hope to see you out at the track in 2012.
Maybe in some un-loved Boxster than nobody cares about!!!
-Steve
Thats what this site is about, Saving these cars
Go Steve
Good to see that you chose option A.
As was stated previously, it's good to save these cars.
I'm sure we will see the progress on your rebuild.
Finished the tear down this past weekend and got the car to EAB today. Adding some straps and 180 pounds of concrete (still in the bags ), helped alot to make the car more balanced on the dolly.
I've also emailed Toyota and suggested they re-brand their bed options as: (a) long bed, (b) standard bed, and © 914-width bed. I haven't heard from them yet.
-Steve
At this point, I was 70% sure I was going to show up on fail blog tomorrow morning...
But it worked out ok.
-Steve
Hopefully it will be back together when he's ready to face forward in the car seat...
-Steve
Slow progress at the shop, but it should be on the Celette bench in about 2 weeks. The front end cleaned up ok, and a lot of the bad spots on the fender are going to be removed for the flare anyways...
-Steve
I feel your pain Steve! My car has been in the shop almost months now...hang in there!
Some progress was made this week.
First, the Celette jigs arrived, but they only work on the "old style" Celette bench. The shop's bench is from the late 80s, and evidently that isn't old enough. So then we had to rent an old bench too (which was remarkably less expensive than the jigs - go figure).
Anyways, it's all bolted up and the suspension points were quick to line up. The rear was correct to start, and once the front fender got pulled out, all the suspension points are perfect, except for the top front left shock tower (where the main impact was) is forward on the car by about 1/4". That should be easy to dial-in, but where there is still a significant gap is the between the top of the door and windshield frame. Larry @ European Auto Body is working on it more today, so we'll see what happens...
-Steve
And some shots from the bottom if you're curious how this all bolts up:
And another patient that 914 is sharing the room with:
And it's straight again. Lots of strange pulls, but things line up really well again - susp points, doors, lids, and the top all look nice and square. Whew. Hopefully it stays that way once off the bench...
Now just lots of body work - I am looking for a better front left fender and headlight bucket than what I provided the shop with. The clip I got is pretty rough...
-Steve
914 torture chamber.
Glad to see you didn't swap out the chassis. In the end you'll know exactly what you have and that is IMPORTANT.
Your orange machine is going to be perfect again.
Keep up the great work!
Going to do any more cage work?
This looks familiar ...
Not planned at the moment, but I am putting on the Engman inner long kit in addition to the Brad M. outer kit that is already on the car. We'll see how flexy it is once off the bench...
> Put out another WTB.
Yup, done, and thanks!
Wow Steve! Sorry this happened! Looks like you made the right choice to fix the original tub. Keep up the good work!
Looking good Steve! I'm sure a good front corner will present itself soon
And these photos just in from European Auto Body... (real time updates here!):
-Steve
one of my favorite cars.
hope to see ya on the road again soon!
Really nice to see good celette pics. It appears the "worst" is over. I too am happy that you decided and were able to preserve the original chassis. It'll be better than ever when finished.
Paul
it's a race car - not a garage queen
just fix it and race it again
More progress photos.
And last call looking for a really nice front left fender, otherwise we'll use the one we have (which needs a bit of work itself).
We did get an OEM front left flare to match the others - the only corner that we could find anywhere. I guess I was "lucky" to scrunch that corner.
-Steve
pics
more
Lily thought 914 needed a hug.
Making some more progress. Headlight bucket and fender should be going on soon...
-Steve
Nice Save !
That pic of your daughter with the car is priceless.
Hopefully she'll be driving it someday (with you of course). LOL
Looking good Steve! Glad you decided to save the shell you have. Once they pulled it it's not as bad as it looked is it. These cars are pretty repair friendly.
Glade to see your toy is recovering from that Streets boo boo.
Getting closer... Paint next week perhaps...
-Steve
Put a tilt front end on it. Anklebiter is going to have one....
Looking good~
OEM flare to match the other 3 OEM flares.
I got lucky in that the only OEM flare we could find just happened to be the corner I needed.
-Steve
Congrats on your progress! It's been a long road, but you are getting closer to the end. It made me cry to see the initial damage, so this is great to see.
Excellent repair. I was very sad to see the damage too. Glad you are fixing this car.
Excellent Steve! Congrats on getting it back together. It will look great again very soon . Thats going to feel so good once it is finished. Can't wait to see you again
just read through this thread...amazing transformation and beautiful car. You had/have what 95% of teener owners would build if they had the $ and time.
Bonus points for doing this with 2 young kids!!
Can't wait to see it back on the road!
Thanks everyone. Hopefully it does turn out nice. So far so good...
Plus I have a few extra new treats for 914 going in too... Photos coming shortly. (Crash your car on the track? More horsepower!!! )
-Steve
He's back on 4 wheels!
There was a bit of a delay, but in theory he's heading into paint this week...
-Steve
Are they shooting the whole thing or just blending? Would like to have pics of that as well!
Nice!
it will be like it never happened, Great work!!!
Just blending. The whole car was repainted about 6 months prior to this... :/
-Steve
A question:
Should the long edges of the Engman kit be welded to the body as well? A stitch weld? As it's currently installed, just the holes were welded (I think).
-Steve
i stitch teh edges top and sides but NOT the floor. i also use a self leveling seam sealer on top edge and a firmr seam sealer on vert seams
SEM 39??377. i dont recall teh exact part hnumber
> i stitch the edges top and sides but NOT the floor
Hmmmm, ok. I'll see what their body guy says.
Thanks,
Steve
Slowly getting closer...
more
Congrats! Your -6 is coming along just fine.
Just read thru most of this- great recovery. The pic with your daughter- priceless.
Getting closer...
-Steve
It is funny how toy-like they look like up on dollies or jackstands like that.
-Steve
Lookin good!
That is looking great!Be awesome to see it on the road again. So glad you saved it .
I should have another update tomorrow...
Makes me wonder how those builders on TV seem to do EVERYTHING in 2-4 weeks sometimes...
Several times over the past decade I found myself saying, I wonder whatever happened to that really tall guy I met at Pomona with the bitchen orange teener that used to eat 901s for breakfast.
Now I know.
The 901 was replaced with a 915, but now he eats portable lights.
Back in the garage now... Hopefully I'll have him back together in a couple or 6 months...
-Steve
Of course I had my helper with me to inspect things.
Congrats on rebuilding the car. Looks great.
Fixing the car was a good call.
John
Great Thread
Awesome rebuild
The last couple months I've had basically had zero time to work on the car, but I did actually have a couple hours over the new years break to start on a couple of things. I got the new Tarrett sway bar installed to replace the Weltmeister. The build quality and parts are 1000x better than the Weltmeister, but I hate the ugly color the parts are anodized in. Oh well...
-Steve
I can live with the ugly color under the car, but the monoballs on the top drove me crazy - pink/red in the trunk was quite ugly.
Plus, these parts weren't finished that great as the CNC marks were clearly visible on the top part. So, I sanded them smooth and plan on powder coating these silver or something.
Unless I really screwed something up and those marks were intentionally put there to put some "bite" into the parts when they are tightened against the body. But I don't think the stock part has that... ?
-Steve
Ut Ohhhh... Shouldn't-a-done-that!!
I think most people pay extra for the anodizing because they think it looks cool...haha
Looks like they forgot the Finish Pass
Doesn't this look much better now?
-Steve
"While I was in there" I put a light coat of black paint on the air box (and sanded off the BEHR logo (no idea why that always bugged me too)), and also had the clips cad plated with everything else. Not factory, but looks much nicer than the tarnished grey clips that were there.
Too blingy?
-Steve
Very nice. Glad to see progress on this exceptional car.
Like!
And I just got my wheels back from Weidman's. He had them for 7 months, but I guess he's still faster than I am. 2 were bent in my offroad adventure but no more.
I went for an RSR finish this time instead of polished spokes.
-Steve
Those wheels turned out beautiful; love that finish!
Love the wheel. Note to self: gotta get mine to Weidman.
A fix it. And get her back on the track too. If she could talk that is what she would say.
I have the suspension back on all four corners now, and I've started the brakes.
And... I learned some 911s have 16mm front spindles, and some are 18mm. My old struts were 16mm (one broke), and the replacements are 18mm. The old wheels bearings work fine, but the washer and lock nut thing at the end of the spindle need to be replaced.
Strange that wheel bearings are the same, but the nut is not.
-Steve
Koni's early versus late
Starting to get parts back on the previously ugly corner...
Two questions:
1. I've never figured out exactly how tight to make front axle nut/wheel bearing. I tightened these and then backed them out only 1/8th of a turn or so. The wheel spins fine, but it is possible to "wiggle" the top of rotor on the axle just a little. So... how tight?
2. Both rotors are new, but there is a *very* slight wobble when spun. It's only detectable when the you look closely at the distance between inside of the caliper and rotor. That tolerance is very tight to start, and you can see the rotor move back and forth slightly within the caliper. I've never noticed this before. Is this normal?
-Steve
Spec for the axle nut is "until you can just barely move the washer with a screwdriver". Seriously.
I'm not sure how the rotor is attached to the hub on your setup. The four-cylinder front rotors obviously have it as one solid cast piece, so there should be no wobbling.
The rears have a separate rotor and hub (like most cars do), and in that case it is normal for the rotor to be a little bit loose. Remember that the rotor is in those cases sandwiched between the hub and the wheel, which is put on with 90 lb-ft of torque...
So, uh, I guess I'm not sure about your wobble.
--DD
You have the same setup in the front that I just recently installed.. It's a coleman racing products brake rotor, with an aluminum hat, bolted to the aluminum hub. There are now 2 interfaces that must be bolted up almost perfectly, and they are sometimes hard to get lined up. I'm fighting some brake pedal pulsing becasue of the "wobble" you speak of. It's just run-out in the brake rotor from things not being seated in the right position.
If I were you, I would remove the caliper and start unbolting, and rotating things until you find a position that it is all happy. Check run-out with a dial indicator.
Did you disassemble the rotor/hat/hub assembly after the crash? you might have gotten things seated back properly...
Years ago when I installed the "Brad" 4 bolt alloy hubs and vented rotors with M calipers there was some wobble when at rest with the wheels off the ground. After the first practice session there was no more. If the hub spins true with a dial indicator I would then check the hat and then finally the rotor. My guess is the rotor mating surface is machined a bit off or possibly the bolts are not torqued evenly.
As for tightening the spindle nut, I always tightened it so there was wheel drag, then loosened it, then tightened it again and finally loosening it just enough so there was no wobble at the outer edge of the tire. When the wheel/tire on it gave an old guy like me more leverage.
Thanks for the tips.
Yes, it's been a bad case of "while I'm in there" and have basically rebuilt everything. Actually, in regards to the front suspension, I have rebuilt everything.
New Tarrett sway bar to replace the Welt, Elephant bushings to replace the plastic, new von struts to replace the Bilsteins, etc.
Thanks - that's sounds about like what I did. I'll try again and check.
-Steve
I think I'm the worldest slowest car mechanic, but I am making progress. Headlight mechanics and wiring are done now, but I probably put everything together 5 times before I got things right.
The headlight mechanism is tighter and better fitting than before.
One weird bug is that sometimes (5% of the time) the passenger side headlight motor cycles and makes an extra trip before it stops closing. I think there is a dirty internal microswitch or something.
Another strange problem I've seen is that the wiper relay is warm to the touch, even when off. All other relays have no temperature to them, even when being used. Maybe I'll just replace it.
-Steve
I also cleaned up the driving light wiring a little. "While I'm in here..."
-Steve
car looks wonderful steve! I am glad you saved it!
Thomas
It looks like you're doing a great job. Even if it takes longer than planned, you'll know everything was done right.
I'm glad you fixed it. If you want a track car get a shitty one like I did and only do what u have to do to it. Single stage garage paint, fiberglass flares, cheaper.... Your drivetrain will always have to be good, but that's something that can be moved to another body without worrying about scraping the other. No attachments.
And while I was in there, I filled in some unused holes, and made the battery box a little narrower to fit lightweight battery.
I think the stock battery location is a good spot for a street/track car, and I'm hoping this cleans up the engine bay a little by keeping the battery "tucked in" on the side more and not such a large eye sore.
Or maybe I should start watcher fewer American Hot Rod re-runs and just put my car back together and drive it...
-Steve
I had two helpers with me on 9/14 today...
I got the car on four wheels for the first time in 18 months or so.
The primary motivation is I wanted to re-spray the engine compartment. When it was last shot they did so with a lot less care than the rest of the car - I think they were just assuming it was an "engine compartment" and not a place to worship wonderful flat 6 sounds.
Anyways, there were some runs in the paint (ugg), and I decided to make a custom, small battery box for my new smaller battery, and I've always wanted to close up some of the extra holes in the engine shelf that were no longer used. Very anal retentive, but whatever...
The problem is that I'm a pretty welder, and an even worse painter. Fortunately, plenty of grinding can make welds looks decent, so that's done.
But in regards to paint, I'm looking for some advice. Any tips on exactly what steps I should do next to have this turn out nice? What's the easiest way for someone who can't even paint a bedroom wall well?
As the photos below show, I've completed the primer. I was planning on letting this dry for a week (I should have a couple hours next week free), and then I plan to:
1. lightly sand the primer to get rid of some of the big bumps. I'm not going for anywhere near a perfect/mirror finish here, I just didn't want ugly paint runs like I had before.
2. blow out the dust with the air compressor, and clean up further wet a damp rag. Is that right? ok to get the primer slightly wet again? (again, I told you I really have no idea what I'm doing with paint).
3. then, I have an extra pint of paint from when the car was refinished. That pint is about 9 months old now. Think it's still ok? I have a cheap LPHV spray gun from the home depot that I used for a furniture project several years ago. I was planning I just using the paint straight (it seems quite thin/liquid). maybe spray 2-3 coats and then I'm done?
do I need to sand the paint as well? color coat? Any other tips?
Or should I just try and get some signal orange spray cans made up?
-Steve
Yes, that's birthday wrapping paper. And towels. My paper roll ran out.
My paint gun looks something like this. I've never really been able to get good results with it.
-Steve
And yes I also realize this is horribly out of order (painting the engine compartment now?!?!), but I bought some new toys for the engine and it's going to look quite nice, so I'm hoping the engine compartment can step it up a notch as well.
I actually did a respray on my engine compartment over the last two weekends. It is not too hard if you do your research, and take the time to prep everything correctly. First I bought a couple of books on the topic, then went to the local Auto Paint supply store and asked a lot of questions. Told them what I was looking to do, and they helped me select everything I needed. This is what I ended up doing.
1. Fixed all the rusted areas with a wire bush and rust converter. Patched any holes in the normal way with new sheet metal.
2. Sanded out all the rough spots with progressively finer sand paper until I ended up with 400 grit Wet/Dry
3. Masked and papered everything so that the overspray would not be a problem.
4. Cleaned the whole compartment with De-greaser/wax remover.
4. Went over eveything with a tack rag after I had blow it out with air.
5. Shot the compartment with Sealer/Primer. Let dry for 24 hours.
6. Sanded the primer with 400 Wet/Dry, then cleaned, and tacked as before.
7. Used Urethane Paint to shoot the compartment, using a $40 HVLP Gun I picked up at Harbor Freight. The key is to practice and get the spray correct before you start on the car. I used a large cardboard box. The Paint was a 2:1 20% mix.
Paint/Hardner/Reducer. Be sure you use all the right safety set up, respirator, including goggles, as you are going to get lots overspray when painting that compartment.
8. I sprayed a tack coat, waited 15 minutes, then cover coat, 15 more minutes, then final coat. Let it cure for 24 hours.
9. The great part about Urethane Paint, is that if you have a nib or run, you can color sand it right out, and polish to get it back to a high gloss.
Very impressed with the work I did on my first try. The key is to get your gun set up correctly, and to paint with proper technique. 6-8 inches from the surface, with the proper setup and pressure, and you will do a great job.
IMHO, it is all about taking your time, and asking lots of questions at the paint shop. Modern Paint is much easier to deal with than the old enamels.
Best of luck!
74914LE, thanks for the tips. I'll give that a try this weekend.
And... I think I've solved another long term problem with my car. Actually, I didn't solve it but Sean at SD Autosport had some good advice on the phone this afternoon. The background and theory:
Now that I have the car on the ground, I noticed that the passenger side door gap is changing - even without the engine in the car! And it now has an outer Brad Meyeur kit AND inner Engman kit.
But, to make a long story short, I installed the Brad Meyeur kit long ago (~10 years?) and when I did it, I removed the front "box" on the front end of the long to run my oil lines through. I had entirely forgot that I even did this, until I compared the left and right sides (photos below).
Sean's theory, and it sounds about right to me, is that the front of the car may be flexing, not the rear, and that's causing the change in door gap. And the passenger side (where the box was removed) changes much more than the drivers side, which is barely measurable.
Plus, as a test this evening I just jacked up the front passenger side of the car from the front donut just lifting the front wheel off the ground but leaving the rear on the ground. So there is still weight on the rear (and I guess even a little more weight), but the nose "drops down" (the car is flexing) and the door gap opens up. That is, if I just jack up the front, the gap opens back up and all is well.
So, what does 914world think? Does this sound about right? Am I my own DPO for removing that box? (yes)
Now to figure out how to fix this...
-Steve
Drivers side with box still there (Brad Meyeur kit cut short, as I think it supposed to be done):
Bump... Is it a bad idea to remove that front "box"?
-Steve
Torque box. Helps prevent cowl shake or flex. Early Mustang convertibles had a floor stiffener welded in the foot well. If you have the Engman kit and it extends to the location of the dead peddle I would think you could run a 14 ga. plate on the back side of the "A" pillar where the speaker is located from the door to the inner wheel house. This will make a vertical "L" shape from your Engman kit and support the cowl.
Let me see if I can diagram what I'm referring to.
EDIT: Hope this works.
My sketch is crude but the idea is to transfer the weak cowl section into the stiffener to carry the rear stiffness through the cowl. Short of cage with NASCAR door braces This could be a solution.
Thanks for the idea Rick. I'll give that some thought...
-Steve
I wouldn't have expected to see that much movement from removing the outer section at the base of the a-pillar but your explanation and observations seem to bear it out.
Most times I've seen oil lines in that area the box was simply cut open at the front and rear for the lines to go through.
Yeah, that's what I'll do *next time*. I think the accident and straightening exacerbated the problem though.
-Steve
What's taking me so long on this project? Besides having a busy job and two little kids, I've also been adding to it with projects like this. I'm switching over from the factory motronic to ITBs/Pectel.
After I polished and cad plated the intake horns, they were too pretty to cover up so I made a lexan cover for the air filters. The air filter base is just powder coated. Next is to make a small trim to cover up the ugly glue/gasket I used to attach the lexan.
A bit blingy, but oh well, I've always loved the look and sound of ITBs.
-Steve
Nice! I would paint a black edge around that lexan. Might be easier than an edging.
Yup - that's what I'll do next time!
Rick, yes, I think this is in general what I'm up against. Sean thinks it may be something around the inner front fender/gas tank area (as I understood how he described it), but he hasn't seen it yet.
Having said that, short of shipping my car to Rick ( ), anyone have other suggestions on who might be able to fix this in Southern California (stiffen up my car)? Sean likely can do it, but he has been quite busy and unavailable lately. I called a couple well known mechanics, but this is too far down the body work/chassis work for their comfort level.
Anyone? Recommended chassis / roll cage shops in Southern California?
-Steve
Bump for response on ITB. -
ITBs are TMW 3006, and I'll be using a Pectel SQ6 ECU.
UPDATE: Decided to use Vi-PEC i88 instead.
-Steve
What a beautiful car ..... great job on bringing it back .....
> Hope to see your car on the road in spring of 2014
Me too! I'm really close now, but this flexy front end problem has set me back again. I'll get it resolved shortly.
914 is on his way to SD Autosport Sean's to resolve the flexy front end problem.
-Steve
Good choice. Sean will get it handled.
I am also rebuild my 914 after an accident on the Nürburgring Nordschleife in July 2013.
he will be back on the road in April
-Sven-
Nice Job!
> Sven914
Thanks for posting - your crash and repair looks very similar to mine. Except I think mine was pushed in another 8 inches or so...
-Steve
My car is still at Sean's place, and I think he's making some progress...
What the "H" "E" double tooth picks is that?!
Your son and daughter look concerned!
Wiring harness for this:
http://www.vi-pec.com/ecus/i88
-Steve
Yes, they miss him. My son is 914 crazy now. He loves them. I'm not sure how that happened...
-Steve
Has anyone heard from Sean lately? I haven't been able to get a hold of him for a couple weeks...
Try to PM him. Unless something has changed, he is a one man band with no voice mail or receptionist. He had my car for six months. Rarely answered the phone. Most communication was over PM from this site. Since you are local, I would just swing by.
Yup, I know he's normally hard to get a hold of, but this is much longer than normal. He's been radio silent for about a month now. PM has been sent as well.
I'm getting nervous, so I will "swing by" his shop sometime this week, but it's about 45 minutes away for me.
-Steve
Still at Sean's place, but he's got some time now and we're aiming to have in done in a month (at least less flexy and ready for re-assembly).
The ITBs and the Vi-PEC i88 is ready and just waiting now. Stay tuned...
-Steve
Repairs have taken a LONG time at Sean's, but might be done on 9/14... Could it be... ?
Vroooomm!
-Steve
Great. .still going to see you 'run' at Willow in the future?
I'll be there at some point for sure, but I'm not sure about with this car again. I think I'd rather get a beater 914 or maybe a stripped down Boxster for my next off road adventure.
-Steve
The 914 is still at Sean's, and he's been radio silent for the past week or so now. Has anyone heard from him?
-Steve
The car has been what, a year, at his shop now?
He called me last week...
was asking if my cable throttle linkage can be adapted to a six.
Unfortunately, almost a year - a little over 10 months now. This is exactly what I was hoping wouldn't happen when I dropped it off, but here we are 10 months later. And it's really not clear to me if it's going to take another 10 months (or more), so I'm just going to move on and find another shop to finish the work.
It's just been way too long and we've been "a week away" from finishing the project since June. Argh.
My hunch is there is probably only 20 hours or so (or less?) to finish the car, but its just been impossible to find time in Sean's schedule for some reason.
-Steve
Sean is still radio silent on me. If anyone hears from him, I'd appreciate it if you would ask him to give me a call or email or PM.
-Steve
Wow - it's been a year since I last posted.
I did eventually get my car back from Sean. If I remember correctly, I was only billed for ~40 hours of work but he had the car for 11 months. That was really frustrating.
I had been hoping to get it back together before I moved, but that didn't end up happening. But now the new garage is mostly unpacked and ready to go, and I hope to find some time in the next several months to get him back together...
-Steve
Ha. Reposting this photo from earlier in the thread (he is above; now 4 years old).
-Steve
It seems like he would be a sophomore in high school by now….
Jeez….
So, so glad you saved this car. It was beautiful before, and is again.
Too cool.
pete
This is sort of what it looked like:
https://www.youtube.com/watch?v=iXbQKstN4j8
-Steve
now that my green 914 is 99% and the new garage is mostly functional, its time to get this 914 back on the road. its been almost five years.
i spent the evening cleaning out the cobwebs - literally.
need to spray the engine compartment and wheel wells after the metal repairs and then hopefully is a fairly straightforward reassembly.
Glad to see this car moving forward.
Surface rust cleanup done for the welding done, and black paint to protect things.
-Steve
Yes we clean the inside of the car and the outside...
-Steve
What does this say about Sean? Have you heard from him at all? Is he OK?
Almost 6 years (!!!) into this and still not back together. Amazing how much having kids, a house remodel, and a job get into the way of 914 time.
Anyways... I really want to get him back on the road and I've found a couple hours in the evening lately to resume re-assembly.
A ton of cleanup and redo-ing and detailing after the car has spent time in three different shops. Here are some photos of the small stuff (over spray cleanup, wire harness hold downs, fuel pump wiring, etc, etc).
-Steve
Very little progress for most of the year but I got back into him over the long holiday weekend. oil tank in, rear brakes, sorted out a lot of wiring, front sway bar in, gas tank in, front hood back on...
oil tank and cleaned up the wiring harness
hmmm... i forgot pictures of the front trunk where most of the work was.
anyways, i also put my led light kit in. big difference in the front.
https://youtu.be/mbeliMwJF3c
-steve
Caught your thread for the first time the other day and pretty much read the whole thing. Was sorry to see what happened. I can relate to your project and the time it is taking to get er done. Your doing great work and I am happy to see it is coming along so well. I live in Poway.
Replaced the new repro trunk seal with a new OEM seal. It fits much better, but unfortunately, I think it's an old OEM seal and some of the corners are coming unglued. Anyone know whats a good glue to re-glue the corners of these rubber seals?
Also, I'm pretty sure this is an Porsche OEM rubber seal (purchased from Pelican Parts), but it is not marked "Germany" as the OEM seal on my green car is. Hmmm...
-Steve
green car still has it visible even after many car washes
Nice to see it coming along.
What's up with the big loop in the front trunk oil line? Looks like it is folded or kinked from this angle...
--DD
Wow, I guess that wouldn't buff out.
But at least you were using it for what it was intended for.
Looking awesome
Yeah I made that line last night to try something new. It's not kinked, just looks like it from the photo.
I used to have a short 8" line or so go from the bottom of the cooler too the thermostat, but it was very tight and always a huge pain to get on. I just made this long line to make it easier, and it gets covered by the shroud anyways.
-Steve
Well… I’m back on this project and I think I may have the momentum now to get this finished. Its actually amazing how little HOURS are actually required to finish this project, but now how many YEARS its been.
I crashed him just over 10 years ago. Yikes. In the last ten years a lot has happened that delayed things (to say the least).
- had my second child (he turns 10 next week!). daughter is 12 now.
- coached 7 seasons of kids basketball and a little soccer. i really miss this…
- started another company (adtech), operated it for 7 years and sold it. this also involved a 4 year lawsuit (went to trial) with some unethical partners (i won, yay; but honestly the lawyers are really the only ones who one in that drama).
- moved to encinitas and remodeled the entire house and yard.
- bought and sold 2 (3?) other 914s including completing a full restoration on the 1970 irish green six.
- got divorced and starting dating again.
whew. i cant believe its been 10 years since i crashed. i have owned this 914 for 30 now - since i was 15.
-Steve
@http://www.914world.com/bbs2/index.php?showuser=654 - Glad to hear you're back on it, cannot wait to see the progress and the car on the road!
And to restart this project I’m just making myself go to the garage (I actually love spending time there) and do *something*. So I’m just getting anything done because eventually it all has to be done. So I’m working on this that dont really matter (rubber trim) and things that do (eg brakes) as I find parts.
fitting the wiring harness…
And another decision I’ve made is to just get it done and it doesnt need to be perfect. This car is a very odd assortment of generations of Porsche parts and repairs so will never be a show car. So I’m just putting it together as-is and not worrying about things being perfect.
Done is better than perfect for this car now.
-Steve
You are very close!
Words of wisdom from my good friend: A little work every day!
I try to apply this rule, but it certainly is not easy.
Very good looking car!
A few questions on your oil lines:
How close are the lines in the sway bar lever area (potential interference)?
Are these -10 or -12 size?
Can you post a picture of the lines going up in the rear fender. I also have a Brad Mayer kit and it seemed tight to get lines past the kit's top fold that reaches the rear suspension pick up point. (non flared car though).
Also planning on running oil lines on the passenger side. I still have the front box, not sure yet how to go through it. The Brad Meyer kit sitting on these vertical ribs on the outer long actually ends on the rear part of the box covering part of it preventing the lines to go through it, unless maybe going in the box via an opening on the back and side (back corner) provided the lines will not protrude too much and touch the rocker panel.
Comments welcomed
Thank you!
half way in…
i installed the itbs ~5 years ago but have never had the engine running with them. thats going to take a bit of tinkering.
-steve
Good to get back to resurrecting the car. Life does get in the way sometimes lol, but sounds like you had the priorities right. And there is life after divorce!
Nice! Keep it going
Amazing. Talk about Tempus Fugit!
That engine wow, Great job on the rebuild.
Nice work Steve
Won’t be long before your on—the—road again….
engine is fully bolted up and i rolled it out to readjust it on the lift.
there is zero clearance between the velocity stacks and rear trunk. ooops. i thought this would fit better.
im considering just cutting that one stack at the rear so its just a 270 degree circle. any thoughts? obviously not ideal but would the different airflow really matter that much?
-steve
“factory seconds” fog light grills arrived today and they are just fine. 9.5/10 and not perfect but way better fitting than my carbon fiber hood.
and in the “not pretty but get it done” category is this hacked together battery strap. seems to work but…
-steve
more little things finished.
side valance… b- fit
front valence. this is a d- fit but oh well. im in get it driving mode and maybe will pay someone to make nice metal valences at some point. but this works for now.
-steve
Nice progress and what a beautiful car
Antoine
Great progress. Looking forward to seeing this beauty soon.
Beautiful
Does anyone know where this extra small bushing goes that came with the pedal rebuild kit?
@http://www.914world.com/bbs2/index.php?showuser=1319 should be able to help.
No hand throttle?
Clutch arm
Thank you for the oil lines pictures.
Yes, I am thinking about rigid lines, homemade.
BTW, nice clean look of the rockers sans square jack hole.
Beautiful car!
Ah, thanks! That's it.
pedals in with working (led) brake lights.
-steve
chopped the velocity stack (“air horn”?). massive hp loss?
-steve
sort of looks like the velocity stack graphic asset is still loading…
-steve
Bleeding the brakes took me FOREVER because I forgot these calipers have two nipples each. Oooops.
driving light switch replaced.
i committed the ultimate sin and took a couple parts from my orange car when restoring others. sorry orange 914. now he has a driving light switch again.
-steve
some pretty parts have been gathering dust
this rube goldberg machine is assembled. i think. its like springs fighting springs fighting springs fighting springs.
914 clutch action!
https://youtube.com/shorts/fZYkHk4By8U?feature=share
new seatbelts from seatbeltplanet are in. ive bought these before and they work well.
i do need to refurb my latch or get new ones or something. hmmmm.
-steve
914. floor has been lowered about 3/4 of an inch and seat is bolted to the floor. this works really well for tall people.
-steve
And the OBC is working again.
https://youtu.be/yHRcrnXf-8U
-Steve
Nice added modern features.
well im not going to get it running by 9/14 but maybe by the wcr…?
shift rod is in and working
throttle cable is in and working
i got an amazingly nice set of headers from ben/mb911 but im having clearance issues with my vellios transmission/cvs and the shift rod. so for now im going to put on the old
b&b headers.
-steve
made a little heat sink for the ignition modules.
-steve
Coming along nicely ! Loving the lowered seat setup !
ive talked with ben about and we are going to try to lower them a little with a thicker flange.
but then i found i need to redo the shift rod too. that wont be a problem but im going to get it running and together as is before tackling new projects.
-steve
weird how this happened. two worn, two not… fronts? left side? who knows.
-steve
anyone know what hood shocks these are?
-steve
Still at it... Got some of the engine wired up and some sensors working. The engine has oil pressure and the computer sees it too!
-Steve
Hi Steve - Your car is looking good and coming along quickly. I totally agree with getting it together and running/driving before tackling additional issues re exhaust.
I spoke with Ben about his Gen. II heat exchangers and he told me if I were to swap out the Gen. I for Gen. II I would likely have issues with the oil lines, and the shift rod. I am going to hold off and see if there is an adjustment to the design. My Gen. 1's are perfect, but I do admit to loving his new collector design.
is there a difference between the chrome and all black interior door handle cup things?
im 99% sure i had these early/chrome door handle cups on this car but…. the interior door handle does not work with these installed. weird. i just wont open all the way. without them it works fine. hmmmm.
and a ton of work on the new fi ecu. nearly all the sensors are hooked up now.
There is also a "glider" difference. On late its a disc that mounts tween the winder & the door card vinyl. On early its more of a ring.
The door looks great. The chrome surround and handle base 'pops'.
A - isnt it great when the right hardware arrives?
B - I think this is the only m12 x 1.5 nut i have ever needed (weird threads). what is up with that?!?!?
thats a bosch intake air temp sensor.
hi. whats the best way to remove this seemingly pressed in round cam cover? im adding the cam position sensor here.
and here is my interior door latch problem in all its glory.
its a 1974 car, but with early 73 doors (late window mechanism but no safety bracing).
https://youtu.be/F7BavNNqkHA
and getting closer, but a couple small steps backwards. for whatever reason my fuel pump started leaking badly while sitting for the last 10 years. or maybe the accident caused this?
https://youtu.be/IHpxFlYUa34
try removing the cover of the passenger side latch, my experienced before I have a longer screw to hold the cover, and it won’t open all the way.
Your driver side does not have the cover yet and that is why it opens.
Hi - correct. It is the cover that is interfering as I mentioned in a previous post. And it interferes even if I just hold it there (no screw). Very strange...
-Steve
thanks all - i will test the screw theory again on the door handle…
getting closer - the fuel lines are all new and i had some leaks. all sealed up now.
this y was seeping at the bottom but i added some gasoila thread sealant and that worked. but honestly not sure if its the right fitting - maybe i need an o-ring there?
-steve
had to hack into the harness again to extend some sensors.
-steve
got the clewett cam sensor installed. why didnt i do
this with the engine out of the car?!?!?
-steve
and… it idles! (sort of)
https://youtu.be/D30ioB0K5wk
-steve
@http://www.914world.com/bbs2/index.php?showuser=12023 good idea - read the instructions!
This is the one I have:
https://www.holley.com/products/plumbing_an_fittings_and_hose/adapters/distribution_and_y_block/parts/100181ERL
So it is an NPT fitting on the bottom. And I guess they never use orings then... ? I really was just looking for AN -6 all around and this is as close as I could get. Hmmm.
-Steve
well i had hoped to get him running for the wcr but i didnt make it. pretty close and i actually drove out of the garage for the first time in 10+ years today, but still a lot of sorting out to do. i got the oil to temperature and turned it around.
a short video:
https://youtu.be/Is1f_RtVD94
i was a but nervous about the brakes (and clutch and shifting and alternator and thermostat) but all that stuff seems to be working fine.
ill be taking the 997 to wcr tomorrow so ill see some of you there.
-steve
Still lots to sort out but I took him on his first short drive with no problems - 9.14 miles around the neighborhood.
dyno tuning day and an alignment are scheduled for the next week or two.
-steve
Very Nice!
I bet it feels good to get it on the road.
Where are those gauges from??
those are all 964 gauges (same as engine). the tach has the obc (on board computer) which was an option on some 964s and standard on others (the turbo i think).
-steve
no leaks up here so i put the shroud back on.
i didnt even realize it, but this was bent too from the accident. fortunately was fairly easy just to bend back…
-steve
Awesome, glad you were finally able to get this back on the road. If you don't mind me asking, were are you taking it for the alignment and tuning? Just to keep it in mind for when I get mine to that stage. Thanks
Yay! Back on the road again!
Getting aligned and sorting out the ride height and rake. As is, front is 11mm lower than front. What do you think... ?
-Steve
Is the rear 11mm lower than the front? Looks high in front. Love the car though.
Yes - front is 11mm lower as-is...
-Steve
An update, still not done... Car was aligned and after a bit of fiddling it came out great.
Next up was a dyno day to get the new ECU (Vipec/Link) fully tuned and sorted. To make a long story short, leak down was bad on all cylinders. Upon further inspection, the cylinders are way out of round.
So... I took about 20 steps forward but now 3 big steps back. So the engine is out and I'm having it fully rebuilt by 911 Design in Montclair (outside LA). It was rebuilt in 2002 by Andial, but now I'm at it again I suppose.
"While I'm in there" (argh, again?!?!?) I'm going to upgrade from 3.6 to 3.8 (only about $2500 more in parts and machine work needed) and probably going to upgrade the Vipec/Link ECU to the latest model since now the one I've purchased is about 7 years old.
So... stay tuned... Aiming to be all done April 1, but we know how that goes. The biggest lead time is machine shop has a massive backlog due to employees out with Covid or something.
-Steve
Sorry to hear about the rebuild Steve, but going to 3.8 will be amazing and it will all be fresh then. Looks like a pretty serious shop with a nice 914-6 hanging around.
Best of luck with this next leg of the adventure Steve! My car's return to action is now looking like late spring as well - getting anxious
Machine shop was backlogged, but making some progress again now. Bottom end is assembled.
-Steve
Curious did you look at the cost of going to 4.0? Pro's and cons? I asked PMS about the 3.8 and they said its not that much of a power difference over a 3.6.
Right. It's not much more power but it's "only" a $1,500 difference on an expensive rebuild. And at the time 3.8 was available and 3.6 was who knows when.
I think going to 4.0 was a lot more because a lot more machining was required.
-Steve
Also, if you want to make it much easier to change the alternator belt, get one of these:
Clewett serpentine belt kit. It makes life much easier.
Well... like everything else, that took longer than expected but I drove home yesterday with a fresh 3.8.
I'll post more details and photos once I get things sorted and cleaned up a bit.
Next up is the interior and... I think that's it! Oh maybe new tires...
-Steve
Been watching this since the “bump”, hits close to home. Bravo on bringing her back the right way! Nice job!
Congratulations Steve. Looking forward to seeing pics of the fresh 3.8 and hearing how it runs.
I’m learning.
What Piston/Rod/crank makes a 3.8?
What case can be used?
What heads can be used?
How big can I build a 3.0, reasonably ?
Nice!
Charlie
Great to see that you are back on the road!
Woohoo, great to see it back in action again!
Getting the interior back in... It is crazy what a difference a little sound deadening and the back pad makes in the interior volume.
-Steve
Seats in. Can also see how my drivers seat is a bit lower than the passenger seat (I'm 6'6").
-Steve
914rubber carpet kit. I was dreading having to install this but it was actually pretty easy.
-Steve
And the first repair. Ha. The clutch cable broke for some reason. Was new. Really strange. Everything appears to be working right and aligned and no binding/etc. Hmmm....
-Steve
New clutch cable in.
And showing off Marty's headers. They were jet hot coated and look great.
-Steve
