I have been searching all the 2056 threads. Their should really be a 2056 for dummies thread
I plan on building a 2056 D-jet from my stock 2.0 1973 motor. I have been collecting parts since 2009
Here is what I got so far:
2.0 motor (havent split it yet)
D-Jet system off my 73
4 cleaned & Tested injectors
new wiring harness from bowlsby
new tps board
new hoses
rabby 9550 cam kit
1.8 rockers and swivel feet
aa 96mm cylinder & pistons
I might be forgettin a few things, it has been a while.
The heads should be sent out within the week to be checked and prepared with new seats, valves, etc. And I will be splitting the case open this week also. All the cool kids are doing it
What other thing do I need to purchase as I begin???
gaskets, bearings, flywheel ???
also what tools are required other than the basic tools?
I never done this before
thanks
Joseph
I think these days you will need to buy a "cam kit" from Jake. That will include everything you need to do the job. You will also need to budget for lot's of machining. You may consider things like:
* Full flow
* Type I oil pump
* External Oil Cooler
* Complete Gasket Kit
* Cam and Main Bearings
* Rebuild the heads with SS valves, upgraded springs, and keepers
* Dynamic balance of all components
* Resurface flywheel
* Replace clutch and pressure plate (prior to balance job)
* Does your MPS hold vacuum?
* Got all the tools to do the job?
- Head CC'ed
- Valve train geometry
- Deck Height
- Torque wrenches (including inch pound)
No wonder my garage is so full...
I think Joe got the cam kit, not just the cam.
You need an engine seal kit.
I'd not bother with the external cooler now. That can be added later, if needed.
You need an engine stand with a VW/Porsche adapter. If you don't have one, you can borrow mine as I am not using it.
You will probably need new main bearings. If cam bearings did not come in the cam kit, you need them too.
If Jake still offers this service, consider sending your rotating mass to Jake to have it dynamically balanced. Also, I had Jake fit the bearings properly to my case. You can do this yourself, but I felt better having a pro do it for me.
If you don't want to spend the money to ship everything to Jake, or he no longer offers this service, call Mark at Warrior Motors in Red Lion. I've had him do a bunch of work for me and he is a good machinist and an honest dude.
If you need special tools, ask me before you buy anything. I may have it. I also have Jakes engine video. Swing over and borrow it if you don't already have it.
Lots of shop rags and carb cleaner. Lots.
Zach
adding to the list...
victor reinz gasket set for a 2.0
engine stand (40 bucks) harbor freight
Yoke (borrowing from Zach)
I also stripped the engine down last night on the floor of the garage. I have to still remove the pistons, and the oil pump, but thats it. Its basically ready to split. I figured I should wait to put it on the stand before i split the case. But what do I know.
once split, what is my next move?
ship the case crank rods flywheel off to get them balanced and new berrings put in??
...remember.... i am learning.....
Joe when you get your rotating assembly balanced be sure to have your clutch pressure plate balanced too. It will likely be out more than the other components.
BTW, your heads look great now that the blue paint has been removed. There actually was a very nice pair of castings under all that paint and grime!
you dont need an engine stand. my yolk is welded to an engine stand. Save yo dough yo!
Zach
You'll need a dial indicator for setting the valve train geometry, and an adjustable pushrod. You'll need a calculator, and pen and paper for recording everything. You probably don't have a screwdriver wide enough to tighten the oil relief valve (I didn't). I made one from the end of an old file. You'll need lots of patience. Clean your glasses, cause you're gonna do lots of reading. And that beer? Leave it in the frig till you put the cover back on the engine after each time you work on it.
I spent a year building your exact engine. It now has 300 miles on it. It has no oil leaks, and just screams compared to the 90 hp, 2.0. 3rd gear acceleration is more than I ever dreamed of. My bro says it rivals his 78 911. I really doubt that, but it is quick.
Good luck. Hope ya have as much fun as I did.
I don't know if anyone mentioned a rear main seal. They aren't in the gasket kit. I can't remember if the front seal is in there or not.
Dave
I bought mine at hf, but I got the better one.
I have an adjustable push rod and dial indicator. Borrow them when you borrow the engine yolk and stand. You will also need my ring compressor.
Zach
See you then my double posting friend.
Zach
These just came today
Sure r purdy
I'm glad you decided tO get them.
Sooo, when I send my case off to Rimco.
I tell them I want it Cleaned, Inspected, and then assuming everything is good... galley plugs drilled and tapped???
Everybody says Rimco is good to deal with right???
I am trying to do everything right the first time.
Thanks
NO!
Send your case to Mark at Warrior Motors in Red Lion. NO NEED to ship it to CA.
Tell mark what you want done, and make sure to have him check the cylinder registers.
Zach
Minor Setback. I was pulling out my stash of parts and found this on my brand new 96mm AA jug. 3 are fine and one is missing a coulple of fins
I assume this is not O.K. to use ??? So now i can bore out 1 of the stockers, or hell... bore out all four of the original jugs???
Please Help me.
I am putting the KB pistons inside these. Such a waste if I cannot use this new set I purchased 2 years ago. It was just sitting in the box and I never checked them
It's toast, and the AA's are a crap shoot anyway. My inclination would be to bore out the stockers, and have the AA's checked. If they are a good batch you have 3 decent ones you could sell if anyone needed one or 2
You can buy just 1 jug from AA.The stock jugs are a higher quality steel and come highly recommended for boring out for 96mm pistons.
Yep, bore the stock ones. They are better then the AA jugs. Sell the AA jugs off.
Zach
Few more pics of the guts before bed
Dropped the case off with Mark @ Warrior yesterday Very nice guy ! I also gave him the stock cylinders and 96mm KB pistons. He will bore them and check the fit. He did not want all my spinning parts yet.
Without my case I decided I needed somthing eles to work on so I got to cleaning engne tin, fan shroud, intake runners etc. etc.
Just dropped all that off at the local powdercoaters
Im almost on the home stretch
I'm a big fan of Marks work. Not only does he work with you to get what you want, he does not set out to break your checking account.
Zach
Warrior Motors in Dallastown PA (near York). Probably a good 2 hours from S/C New Jersey. He does a LOT of v8 stuff, but always has VW stuff in his shop as well. he did my T4 case, and has done all the machine work for the 350 I'm building.
At one point Mark talked me out of the more expensive option as it would not have added benefit from my configuration. That alone save me ~$500. He is a stand up guy.
Zach
Called Warrior motors once a week for the last 3 weeks, never got a call back
I am swampped at work (Christmas) and have not had time to go check on the progress of my case or cylinders. I got a call from Mark this morning... He smashed his hand a few weeks ago hasnt worked on anyones engines and has not even looked at mine yet. He did apologize and told me he will get to it as soon as possible
Now I wait some more.
Dude, I am very sorry.
Mark was always really fast at returning my calls and always was willing to work with me about timelines. His shop is always full.
Zach
Cant be long now....
any day....
In the mean time, I have still been collecting parts, painting parts, drinking beer.
Will post some pics when I am not drinking great beer
Next tuesday stop by marks shop to see if he is in. Ask him if his hand is better and when your stuff will be done. I he does not know then take it home. He will understand and probably has a huge backlog now.
Ask around. I know there is another VW place but don't know how much aircooled work they do. Call the guys over at Broadway Autoparts on 74 in Red Lion and ask them for a machinist. They have one on staff but he is not set up to do your work. He knows other guys though.
Also email some of the SPVWC guys. There are lots of VWs in the York area, and lots of machinists. Some will know VW stuff.
You could also call Translog, Peek Performance in MD. or Bus Depot outside Philly or Aircooled Racing just north of us and ask for a reccommdation.
Sorry Mark messed up his hand. He is good, but should be good in letting his customers know what's going on when they call too.
Joe:
I hope everything works out with Marks shop. If not, here is some info for a "local" guy I used in the late 80's for air cooled VW engine work. He did affordable, top notch work.
Wagner's Vw Service 144 S Fair Lane
Grantville, PA 17028-8814
717-469-0123
His name is Luke Wagner.
Bob
Since we are heading off topic anyway, and I am waiting forever....
I did purchase Jakes video last year. I think everyone should buy one, its a great video. It dosnt have the cool intro like the great Dr. Evils video. I put the video in the garage and it has been lost ever since.
Thanks for the offer Zach
Thanks for the video Jake
Joseph Sayre
So I got a call from the powder shop. Everything is ready for pickup.
I also picked up a few more parts:
Narrow band air/ fuel guage
oil pressure guage
Going to Warrior tommorow. (wish me luck)
will post pics of my tins tommorow, they are
As promissed
I think they did an outstanding job, considering the condition I dropped them off in
And the original Heads brought to life by Len
Next stop....
WARRIOR ENGINE
to see if my 94mm are now 96mm
Would you quit Fuching around and finish this thing already? I need something to in the AX in Hershey this year!
And there's a problem with that? 7 degrees outside gonna warm up to mid 40's later in the week. Sounds like an excuse for an engine build party
Dean told you the truth about the bushings... The material for them is now crappy and for the cost it takes to rebuild a set of OE rods we can replace them with a new H beam that will hold 400HP, already has ARP rod bolts.
Not to mention that the rods weigh 300 grams less than OE.
Those heads make me jealous.
Zach
Talked with Mark just now. He said I can pick everything thing up by the end of the week.
YYYAAAAAAAAAAAAAYY !!
Lookin like a great day today
Everything is ready to go back togeather
Now I just need to figure out wtf im doin
The rods look great, i am very happy with the work mark has done, I would reccomend his services if you have time to wait.
Please dont mess this up
Just ask questions and if I can I will swing over after work. Would have come over yesterday but you had some "birthday party." who puts of ahead of thier car?
Your case and rods look great. I am glad that mark came through for you.
Looks good Joe...glad you finally got all the parts.
You will have this thing back on the road before you know it.
I have heard that the MPS needs to be tweaked to work well on a 2056. Have you found anyone to do this yet?
Joe,
I'm expecting to ship your new exhaust and AFR gauge late this week or first of next week.
THAT!
YOU BUM! Its never going to reach your door, Sayre. It will go, shall we say, up in smoke.
*jealous*
Zach
That may be the cleanest engine I hve ever seen
I now have a case of Loose cannon waiting for the Brave souls that help me out
Next question, What other than assembly lube do I need to purchase from the FLAPS
Mmmm - Nice jugs........Looking very sanitary
Oh man! I love that beer!
Thanks to whomever told me to recheck my injectors
The email I recieved today:
Hi Joseph,
Your injectors arrived and it's a good thing we checked them. Three of the four were indeed stuck closed from sitting. I ran them on the bench and within a couple of minutes, they all freed up. I backflushed them and ran them on the bench for about 10 minutes. They are now flowing fine once again.
That bead blasted case is beautiful!
Bead blast! Ah yes, make sure you clean the case out thoroughly! All the passages and such. You dont want that grit getting into your running parts.
Mark painted that case, didn't he. Is it really that clean?
Zach
Maybe time to put in threaded galley plugs so you can access the oil galleys for cleaning?
I have been doing this stuff with my Moto Guzzi parts that I have been blasting
anybody wanna put my engine togeather sat evening??
engine buid party at joes.
I was over Sat night...
Joe is going to have a very nice engine, no doubt. He needs to clean the case interiors before he does any assembly, but that goes without saying.
He needs input for case sealant though. Is Loctite 474 still the stuff to use for sealing case halves? Is there another product that people prefer these days?
What about for the case bolts and jug bases? What is the sealant that people like for those areas these days?
NO LEAKS!
Zach
Permatex is fine. Anaerobic sealant is what you are looking for.
OMFG
These pipes are excellent Chris. Did I mention that tommorow is my Birthday. Excellent timing
As far as the engine build party, Zach did come and brought Theo So we watched movies with our kids and played Wii while eating pizza and drinking beer. We never actually made it to the garage. But it was worth it.
Fun times
Yep, that's art. :jealous:
And we did make it out to the garage. We just didn't build anything. Clean your case so we can build stuff next time!
Zach
Joe, I'm beginning to think you robbed a bank, or maybe harvested a crop.
Waiting to move foreward on my engine.... I figured I needed to work on somthing.
I went ahead and added some gauges to the teener today. (3) to be exact. I got rid of the clock and replaced it with an oil pressure gauge. It is smaller than the stock gauge, so I used a bit of superglue and managed to get my aluminum ring to fit pretty well. I didnt want to loose the uniform look with the trim rings I purchased.
The other 2 went on the pillar, a fuel pressure gauge to monitor the D-Jet, and a Air Fuel gauge to keep in tune. I did not want to install the pillar at first, but bit the bullet when i saw the alternatives. I actually really like it
Joe doesnt care about looks, its obvious
is it the white thats buggin you guys ??
Its not like i added neon underneath the car....
Delila says it makes my car a "REAL" racecar
I should have the engine back this weekend from Tony @ Translog GT. Once I pick it up, I just need to dress it with my D-jet. I pulled everything out of the box to make sure I didnt lose anything I did. Cant find that damn head temp sensor, no worries cause Tony has one for me. I purchased the resistor to richen up the mix so I could at least break in the engine. Then I may need help with adjusting the MPS, not sure yet. I do have an 02 sensor and I will be able to tell if its close.
Here is my stash as it came from hibernation
Great progress Yesterday, NO pics
Picked up the engine, got it into the garage. Started to dress the engine with the D-jet. Got all the vacume hosees on, fuel lines (ran out of high pressure hose ) got the alternator hooked up, runners, intake, dual pressure sender.
Had a question on the sender. It is a metal hose that sticks up and the end of the hose has a small coupler then the sender threads to that. The question is, why is there almost 1/4 inch gap when the sender is threaded all the way till it is tight. Is that normal? I used a tiny amount od red gasket maker on the thread. is that good?
next question
I am missing the decel valve, and I remember that it is not necessary. What is the correct way to bypass this, connect the two larger vacume hoses togeather and plug the smaller hose that come off the intake?
next question
I can find the firing order but i forget if the distributor spins clockwise or counterclockwise I dont want to get the plug wires wrong
Next question
What gauge wires to run for the oil pressure sender to the gauge and same thing from the fuel pressure sender to the gauge up front?
last question
Do I use a sealent when putting the sensor on the bung from the tail pipe, if so what type. This is for the oxygen sensor
More questions to come.
I am very very close
No decel? Just plug all the ports on the plenum that you don't use.
clockwise. 1-4-3-2
Edited: cause I'm a dumbass sometimes
got it!
Thanks for the replys.
Next question:
Initial startup is confusing to me. I put the break in oil in. Pull the plugs and disconnect the coil. Crank the engine till i get pressure. Then put the plugs back hook up the coil and start the car up from the cockpit for 2500 rpm for 20min.
No problem
Except
How do i check for oil leaks when i am sitting in the car holding the gas. AND How do I setup the initial timing while doing all of this.
Should the timing be set right away??
Seems like a lot to do for 1 guy, almost impossible
Get a 2nd guy?
Start the car with the deck lid open. Get out and walk to the engine bay.
Hold open the throttle while looking at the tach through the rear window to ~2500 rmp. clamp it just strong enough to keep it from slipping with some vise-grips or a C-clamp.
Zach
I'm doing this in the next week or so too. What about the timing issue? I was wondering that too Joseph.
for timing, hold timing at 3500 rpm from the engine bay (you will get to know when the rpm is right by the sound of the engine) and shoot your timing light down the hole. Adjust timing, and do it again. Faster with 2 people, but most of the time I have done it its just been me.
Zach
Once you have done the 20 minute cam break in, you should be fine. Just make sure break the cam in first.
Zach
Take a minute to set the timing approximately. You don't need it to be right on - only close.
That will also give you an opportunity to check for big leaks.
Then move right on to the cam break-in phase.
Few Pics for Ya.
The engine is ready to go back in.
I have been busy doing other projects on the house. so no start yet. Tommorow is a new day
Looks nice! Start it up!
First Drive !!!!
WWWWEEEEEEEEEEEEEEEEEEE
I have adjusted the timing valves etc. Car runs very smooth at idle. There is some bucking at high speeds, I forget what causes that. TPS? its a brand new board. And I noticed that I cant keep idle after engine is hot, keeps stalling.
I was gonna adjust the bypass screw, but why does it idle perfect when cold? I did try the ecu knob fully in both direction with no change.
I love this engine, it has power in every gear, thats insane
Congratulations on the first drive!
That is a great looking engine, I am sure folks here will help you get your idle under control.
I have been following this build since you started.
John
Joe:
Congrats on your build...just in time for Hershey!
I look forward to hearing this beast run.
Catch you Saturday,
Bob
Ecu knob won't affect idle speed, just mixture, but it will cause it to hunt for idle. If it doenst hunt when leaned out with the knob them the tps is suspect. I installed one of those new boards and had the exact problem. Switched tps and it ran great. And you are right the 2056 is a fun driver. I love mine so much I wanna do a 2270 now.
Way to go Joe, look forward to my 3 laps around the parking lot. I know you are loving all that extra power. Hell, you have enough power now to haul around some more stereo components.
Dyno Results. (not Bad)
I got 2 pages from Tony, but no graph
I did a search for a stock 2.0 d-jet Dyno graph, then I added my numbers to the chart by hand and connected the dots for comparison.
Yellow =HP
Purple = Torque
You could even say that this motor is OFF THE CHRTS !
That is fantastic.
Zach
Welcome back Joe!
Awesome DYNO results!
When's the six going in?
