I've got a Carter fuel pump and I'm trying to find a place to locate it. I was thinking there would be room up under the car where the steering rack is but I looked there but can't imagine where I could put it. Not real comfortable with cutting open an access hole where the later cars had them located.
Any good ideas in these photos?
Kev
Maybe this will help:
The grommets came from a $4 HF kit. http://www.914world.com/bbs2/index.php?showtopic=117077 I know you know how to but this might save you a few minutes measuring time. I have more detailed pics if you want. Originally I planned to cut an area out like the 75-76 but for some reason I questioned the tank shape on my 73 and decided that it either would not allow it or it was too close to call and I didn't want to end up with a hole cut out for nothing. The blue tape was just a reference to the floor board.
Take off the cover that shields the steering rack, and you should be able to fit the pump next to the rack. This will save you from having to cut holes in the front trunk, and if a leak would develop, it would just drain onto the ground.
Also, the cover will protect the pump but still have it serviceable. Since the fuel lines are already there, why not?
+1 Mine is that same one, and it's underneath on the cross member by the steering rack.
You could put it up about 1' from where it is located in your first pic. In that indentation. Some 911s had them on the front aluminum suspension crossmember. Some people go as far as getting a later access panel cover (75-76) and cutting a hole in that indentation so the pump sits just above/infront of where brake resevoir hoses go through body to the master cylinder.
This is where mine ended up. I drilled the two holes for my fuel line and grommeted them and the larger hole for the wire. Used clamps to secure to the inner fender well.
Kev
Looks good! I like how you used the line between the filter and the pump to make that 180° turn. So both to/from lines will be a straight shot.
Thanks for the follow up pics, it looks good!
