Printable Version of Topic
914World.com _ 914World Garage _ Thermostat bellows
Posted by: bigkensteele Oct 6 2011, 07:55 PM
I am putting the finishing touches on my engine reseal project and I just noticed that my thermostat is shot.
Everyone including AA and Pelican lists them as NLA. I found the link below showing how to convert a T1 to work on a T4, and they have the T1 for $107 CDN. I couldn't even find a T1 anywhere else (bughaus, busdepot, cip1).
http://www.germansupply.com/xcart/customer/home.php?gspage=customer/main/tech/tstat/t1_tstat_in_t4.tpl
Anybody else been through this recently?
PS I would be fine with a good used one if anyone wants to PM me.
Posted by: nathansnathan Oct 6 2011, 10:08 PM
The type 1 thermostats are rated at a lower temp so they aren't as effective as the type 4 version for getting the car warmed up. I think they are 150 vs 180. I read that the version for a fuel injected 75 bug is hotter, not sure.
These are from samba classifieds
nos, not bad
http://www.914world.com/bbs2/index.php?showtopic=147112
some others
http://www.thesamba.com/vw/classifieds/detail.php?id=1180908
http://www.thesamba.com/vw/classifieds/detail.php?id=378506
Posted by: vsg914 Oct 7 2011, 06:47 AM
I got one from Rich at High Performance House.
Posted by: 914runnow Oct 7 2011, 08:49 AM
I got one from Automotion a long while back for 75.00 when they were
closing out on Porsche stuff......They told me George at AA,
had bought a bunch....soooo try him...
Posted by: reharvey Oct 7 2011, 09:17 AM
QUOTE(nathansnathan @ Oct 6 2011, 11:08 PM)
nos, not bad
some others
I have a late model FI mexican bug thermostat that I'm going to modify to use on my 914. It uses a bimetal spring instead of a bellows. These were available a few years back. I'll see if I can find the invoice. Ray
Posted by: Valy Oct 7 2011, 09:23 AM
QUOTE(reharvey @ Oct 7 2011, 08:17 AM)
nos, not bad
some others
I've seen cip1.com still sells those
Posted by: bigkensteele Oct 7 2011, 09:23 AM
QUOTE(914runnow @ Oct 7 2011, 06:49 AM)
They don't have them anymore, according to Leo this morning.
Posted by: bigkensteele Oct 7 2011, 09:29 AM
QUOTE(vsg914 @ Oct 7 2011, 04:47 AM)
He has a used one with my name on it for $45. Thanks!
Posted by: Cap'n Krusty Oct 7 2011, 09:32 AM
There's a guy selling new ones on The Samba.
The Cap'n
Posted by: rick 918-S Oct 7 2011, 10:02 AM
http://www2.cip1.com/ProductDetails.asp?ProductCode=VWC%2D043%2D119%2D159
Posted by: PanelBilly Oct 7 2011, 11:21 AM
I had a difficult time finding one until a member here came threw. I tried fixing the crack in the one I had and I bought another that was also defective. Pain in the ass part, but you need it
Posted by: nathansnathan Oct 7 2011, 01:56 PM
QUOTE(Valy @ Oct 7 2011, 08:23 AM)
nos, not bad
some others
The problem with those is they fail in the closed position, where the stock will fail in the open.
Posted by: jimkelly Oct 8 2011, 04:54 AM
so what do i have 3 (apparently) bad or 3 (apparently) good?
Posted by: avidfanjpl Oct 8 2011, 08:48 AM
One on right in pic may be OK. Not perfect, but I have seen worse that still work the air vanes correctly.
The middle one is definitely shot.
John
Posted by: avidfanjpl Oct 8 2011, 08:49 AM
Oops!
I mean the left one. No coffee yet!
John
QUOTE(avidfanjpl @ Oct 8 2011, 07:48 AM)
John
Posted by: pilothyer Oct 8 2011, 02:21 PM
If the bellow itselt isn't cracked the soldered end usually is the source of the leak. They can be repaired by fixing the leak, desoldering the small hole in the threaded piece, compressing the bellows fully, injecting 2 ml 99% isopropyl alcohol thru the small hole in the threaded piece, then resolder the small hole in the threaded piece. The alcohol has a boiling point of about 85 degrees C which will expland the bellows and of course retract the bellows when it cools.......Don't throw those old ones away.....they can be fixed in most cases......even small cracks in the bellows can be repaired.......Jerry
