I pulled my stock heat exchangers from my 1.8 today to replace with SSi's.
I was curious on the weights and port diameters. Here is what I found out.
Ports at the muffler end same dia. Ports at the head are just slightly bigger on the SSi's.
Stock: 15.65 lbs short side and 16 lbs long side. Total 31.65 lbs
SSi: 10.42 lbs short side and 10.7 lbs long side. Total 21.12 lbs
Savings of 10.5 lbs off the butt of the car !
Next Bursch vs stock muffler.
pic
the head side ID between steel 1.7/1.8 and ss 2.0 is huge.
the head side ID difference between 2.0 steel and 2.0 ss is not as dramatic.
jim
THANKYOu! I keep a database of parts and weights. the exhaust flange dimensional diagram is a major score also.
