Doc,
The engine's finished-
Remember this 3 speed you created?
I'm ready to stuff the tranny for thanksgiving-
The original gasket shims measured = 0.021"
The "elring" kit shims are 0.009" each, so the closest I can get to 0.021"
is 0.018". So what do I do? I need 0.003" more?
WAIT! - False Alarm Dude! I just re-measured the original 3 shims:
0.007"
0.007"
0.005"
0.019" total < -------- so I'm O.K.!
Any final pointers before I sew it up?
I'm confused about why you'd want a three-speed transmission... ![]()
I know you built it for that case...but it begs me to wonder if you could section that case and reduce the length now....
Rich
What question do you still have for me?
It looks like you figured it all out
The shift pattern you drew is correct, except it is 2-3-4. The 5th gear slot is empty.
, cooling of heads and cylinders , Bill D.
http://www.thesamba.com/vw/classifieds/detail.php?id=968764
given the light load that this engine will face in a bike, I doubt the cooling ducting is needed.
Zach
For the moment I'm more concerned about cooling my shins.
Oh ya, to your original question to me, close is good enough with the gaskets. These boxes are far past needing super fine tuning. Plus, with your bike it would be no issue with the low weight.
