Printable Version of Topic
914World.com _ 914World Garage _ Heating in Conversions
Posted by: RiqueMar Nov 22 2011, 10:37 AM
For you conversion guys, how have you grabbed heat from the engine shrowd and directed it to the heat exchanger? My question is focused on the passenger side exit, it seems to me that for post 74' 911 engines, the 'Hot Air Socket' would be a different size hole than the one entering the Heat Exchanger. Do I need to purchase/fab up an older style attachment?
Posted by: MDG Nov 22 2011, 11:55 AM
Didn't know about the different size on later models. When I had the 2.2 I used block off plates when I went with headers. On my 3.2 I just put the original guides that were on the 2.2 - it's a direct fit with the same mounting points. You can still get them in steel and fiberglass.
Posted by: Steve Nov 22 2011, 03:44 PM
QUOTE(MDG @ Nov 22 2011, 09:55 AM)
I'm also running early air guides on my 3.2. Beware that some air guides won't clear the bigger distributor on the 3.2. Otto installed an early metal one on mine that fits perfect. I don't know where he got it from. I have awesome heat with my stock 914-6 heat exchangers.
Posted by: GeorgeRud Nov 22 2011, 04:00 PM
I would imagine that there are quite a few folks that have used the block-off shrouds on their racing engines, and hopefully some of the early style parts may be available by putting an inquiry out of the lists ( 911 Birdboard, Samba, etc.) and perhaps some racing lists as those would be the ones that are most likely to have replaced their's.
I don't think it would make sense to try to fabricate a system for the later style system as the original ones worked so well.
Posted by: RiqueMar Nov 22 2011, 04:04 PM
QUOTE(GeorgeRud @ Nov 22 2011, 02:00 PM)
It's not trying to fabricate something as much as to get the same hole diameter for both the heat exchanger and the shroud out-let.
I see that Pelican has an early style, but for close to $90.00 each side! Yikes! Thats a little too much for me, I'm one of the 'Fiscally Impaired' right now! **insert 'empty pocket smiley' here**
Posted by: RiqueMar Nov 22 2011, 04:14 PM
... Picture showing the difference between an early and late model, it's the outlet diameter matching the inlet on the heat exchanger that's my concern...
Posted by: Mark Henry Nov 22 2011, 04:15 PM
The bits in red I got off of my donor '69T engine, they are the steel. Another engine '75 2.7S had the cheap plastic ones and they were all warped to shit. I don't know when they changed, but try to get the early steel ones.
I'm having a hard time visualizing the system, does any have a pic of stock 914/6 heat exchanger and associated plumbing set-up? (engine out of the car pic)
Posted by: Mark Henry Nov 22 2011, 04:17 PM
If the hose side is too small/big I'd just fab adapters...but I can do that sort of thing.
Posted by: RiqueMar Nov 22 2011, 04:29 PM
QUOTE(Mark Henry @ Nov 22 2011, 02:15 PM)
...I'm having a hard time visualizing the system, does any have a pic of stock 914/6 heat exchanger and associated plumbing set-up? (engine out of the car pic)
That would be great for reference, there are a-million-and-one photos of a 911 setup/system out of the car, but none of the /6 setup/system
QUOTE(Mark Henry @ Nov 22 2011, 02:17 PM)
It's not a problem, I can make most anything, just thought I'de post in case someone comes out and says, "No you idiot, they're the same, put it on and move on to the next thing" .... which happens quite often when I think about it.
Posted by: MDG Nov 22 2011, 04:37 PM
QUOTE(RiqueMar @ Nov 22 2011, 05:04 PM)
Where you live . . . go to a dismantler and get what you need. I can't imagine they'd want anything close to $90.00. These aren't a high wear item. The pair off my old 2.2 engine just needed to be wiped clean and they were perfect. Like I said, the screw holes even line up. No need to buy new.
Posted by: mepstein Nov 22 2011, 05:24 PM
QUOTE(Steve @ Nov 22 2011, 04:44 PM)
I must have bought a late one since it needed some metal shaping to clearance the distibutor on my 3.2. I'm no Scotty B but it was an easy mod with a metal pipe to reshape the convex surface to concave.
Posted by: mepstein Nov 22 2011, 05:26 PM
QUOTE(RiqueMar @ Nov 22 2011, 05:29 PM)
I've seen Enrique's shop. Adjustable wrenches, vise grips and a big hammer. He can make anything!
Posted by: RiqueMar Nov 22 2011, 05:33 PM
QUOTE(mepstein @ Nov 22 2011, 03:26 PM)
Lol, something like that.. That's about as advanced as it gets around here.
You forgot duct-tape.... lots and lots of duct-tape.
