Printable Version of Topic
914World.com _ 914World Garage _ Turbo Tie Rod...Is There A Trick?
Posted by: EdArango Nov 22 2011, 05:41 PM
OK....This isn't my actual tie rod but it's the same set up. I've removed the nut on the top of the tie rod end and I assumed that it would come right off....but NO.
Am I missing something??? Is there some sort of trick that only the elite Porsche suspension guys know about in order to separate these two pieces??? I've tried tapping on it with rubber mallett....but nuthin!!
Any hints on separating it??
Thanks!!!
ED
Posted by: PeeGreen 914 Nov 22 2011, 05:50 PM
Ah, that is a secret for those that know
A big hammer is your friend
Posted by: Series9 Nov 22 2011, 05:57 PM
That requires a tie rod separator tool.
There's a simple one that you can hit with a hammer, but it ruins the rubber boot on the rod end.
It looks like this:
Posted by: jaxdream Nov 22 2011, 06:32 PM
Hammer on the outside of the steering arm ( the round portion )the end bolts into , wack it a few good hits , it will pop out. Don't hammer on the end bolt as it will bugger the threads up.
Jack
Posted by: Valy Nov 22 2011, 06:43 PM
QUOTE(Series9 @ Nov 22 2011, 03:57 PM)
It looks like this:
If your rod end is good,
don't touch it with that fork!Use a puller. Here are some options. For the tie rod, I prefer the two arms.
Also don't hit it with a hammer as it will bent and you'll be sorry.
http://www.harborfreight.com/tie-rod-and-pitman-arm-puller-1752.html
http://www.harborfreight.com/3-piece-two-jaw-puller-set-40966.html
Posted by: Series9 Nov 22 2011, 08:02 PM
Yes, if you want to save or reuse the tie rod end, use this:
Posted by: r_towle Nov 22 2011, 08:19 PM
It's simple enough to hit the steering arm with a hammer...there is a flat spot on it just for that purpose.
Rich
Posted by: jcd914 Nov 22 2011, 08:28 PM
QUOTE(r_towle @ Nov 22 2011, 06:19 PM)
Rich
Been doing it this way for a very long way.
Much faster too.
Jim
Posted by: McMark Nov 22 2011, 10:16 PM
Jim, sometime I need you to show me this trick. I've tried it on multiple occasions, on multiple models, and never had any luck.
Posted by: Eric_Shea Nov 22 2011, 10:29 PM
I only use Joes 2nd tool. Not a fan of buggering up nuts or treads with a BFH.
Posted by: a914622 Nov 22 2011, 10:39 PM
You have to use a steel hammer and hit it hard enough to deform the tappered hole and the rod end will pop out. Med-large ball-peen works great. No damage to the boot or threads. That is the reason they are tappered.
jcl
Posted by: RobW Nov 22 2011, 10:54 PM
I used a FLAPS tool to save the threads. A hammer could make meat out of the bolt.....
Posted by: jcd914 Nov 23 2011, 03:41 AM
You don't bugger the nut or threads because you hit the end of the arm not the tie rod end. It does take a good hit with a good size hammer.
If you miss you can bugger any number of things.
Jim
Posted by: r_towle Nov 23 2011, 07:01 AM
QUOTE(McMark @ Nov 22 2011, 11:16 PM)
Its a tapered hole in the steering arm.
I did not believe it would work...but it really is simple...just a BFH.
Most of these arms have a flat nub on the outer most point....the farthest away from the arm portion, so its the most flexible part of the tapered hole....hope that makes sense.
on a 914, turn the offending wheel all the way to one side so you expose the arm out of the fender....so you can swing.
the flat spot is staring at you.
Stand up, car on the ground, ass to the fender.
get a 3lb hammer and hit that flat spot like you are trying to break the fitting...hit it hard and hit it very square...no lazy taps, no lazy side blows that bounce off.
One or two really good square shots dead center.
Its cool once you get one....
You will never use any tools again..just hit it right...and it pops out.
There is no damage to anything and it can all be put back together and used again....so its really good for strut work that does not require new tie rods...CSOB thing to do.
Rich
Posted by: PRS914-6 Nov 23 2011, 09:36 AM
That works very good 90% of the time. It spreads the metal slightly and opens the hole while creating a shock at the same time. Rarely they still remain stuck....
But if it won't budge still, raise the car up an extra 1 ", cut a piece of angle iron, pipe or square tubing and lower the car back down to rest on the arm close to the end. With the arm supported you can smack the tie rod once and it will pop right out. The previous method will help this method regardless.
Posted by: PeeGreen 914 Nov 23 2011, 10:34 AM
QUOTE(jcd914 @ Nov 23 2011, 01:41 AM)
Jim
Never had to do it another way on a 914 as they have always popped loose with a few whacks.
Those other tools are nice to use if you have them.
Posted by: r_towle Nov 23 2011, 10:41 AM
I edited the picture posted.
Right where the arrow is pointing..there is a flat spot on almost every one I have ever seen....its directly opposite the arm...so its the weak spot.
all it takes is one really good hit...but its gotta be right on square.
It compresses the joint for just a second and squirts out the tie rod..
Rich
Posted by: Cap'n Krusty Nov 23 2011, 10:57 AM
QUOTE(PRS914-6 @ Nov 23 2011, 07:36 AM)
I like this method because it allows me to sell more tie rod ends. NEVER hit the threaded portion of the tie rod end! EVER.
The Cap'n
Posted by: sean_v8_914 Nov 23 2011, 10:58 AM
notice teh divot in teh center of teh threaded shaft. they all have this feature. I use a blunt tipped round long cone tip on my air chisel. it fits in that hole. hold teh air hammer in straight alingment to the shaft. it will not damage the TR end nor the strut steering arm
Posted by: PRS914-6 Nov 23 2011, 11:33 AM
QUOTE(Cap'n Krusty @ Nov 23 2011, 09:57 AM)
The Cap'n
NEVER? EVER? As I stated, smacking them on the side of the arm works 90% of the time flawlessly. When it doesn't I provided a method that will get it off. Most people are taking them off to replace so for those it doesn't really matter even if you were to mushroom the threads. The arm is properly supported and it's safe to do so.
Does that tie rod in the picture really look like something I would reuse?
Perhaps your comment should state "NEVER smack it if you want to reuse it" In that case, I might not totally agree but I could understand your concern of damaging a good part.
All good info though
Posted by: PeeGreen 914 Nov 23 2011, 02:59 PM
QUOTE(PRS914-6 @ Nov 23 2011, 09:33 AM)
The Cap'n
Yeah, but even then you may balloon it so it doesn't come out. I have see it happen.
If there is ever a reason to hit the actual bolt I always put a nut on it to save it from doing anything bad. Make sure it is threaded enough if you do this as well.
Posted by: r_towle Nov 23 2011, 03:48 PM
If hitting the arm does not work, add some heat.
