Printable Version of Topic
914World.com _ 914World Garage _ Mated Transmission and Engine now have dumb question
Posted by: kconway Dec 30 2011, 06:36 PM
I mated the transmission to the engine and installed the starter and wiring today. For giggles I tried to pull on the clutch release arm but could not get it to budge after contacting the pressure plate.
Dumb question, is there anything to do but push the transmission and engine together and tighten up the 4 or 5 nuts/bolts? I'm wondering about that clutch, should I be able to depress those springs on that pressure plate by hand? The whole thing kinda when together alot easier than I imagined, did I miss something?
Kev
Posted by: rohar Dec 30 2011, 07:07 PM
I'm guessing you'd have a hell of a time pulling that thing by hand unless you had a lot more grip exercise than most of us. The leverage created by the clutch pedal is MUCH more than you'll be able to generate this way.
Posted by: Krieger Dec 30 2011, 07:16 PM
I think you need to factor in that your clutch is activated by the strongest muscle group in your body with the added mechanical advantage of that clutch pedal/ lever being around 12".
Posted by: BKLA Dec 30 2011, 07:23 PM
on a separate note... you're gunna love that rennshift linkage!!!!
Posted by: toolguy Dec 30 2011, 08:12 PM
Damn. . looks like we are at the same point on our cars. . I'm stuffing mine tomorrow, ,
Posted by: Dr Trichomoniasis Dec 30 2011, 08:59 PM
If you can not move the arm back and forth at all, that is concerning. There should be some play before the throwout bearing hits the pressure plate fingers. If no play, then you have a bearing hitting the plate too soon and it will not completely release. A common cause of this is the pivot ball being spaced too far. I would part it and take a look and maybe some pics.
Posted by: brp986s Dec 30 2011, 09:16 PM
Time to retroactively ask Santa fror a Bendpak scissor lift. Not liking the chunks-o-wood solution.
Posted by: kconway Dec 30 2011, 11:57 PM
QUOTE(Dr Trichomoniasis @ Dec 30 2011, 06:59 PM)
The arm has a few inches of throw before it contacts the clutch.
Kev
Posted by: Dr Trichomoniasis Dec 31 2011, 08:50 AM
Perfect!
Carry on
Posted by: 396 Dec 31 2011, 09:15 AM
QUOTE(toolguy @ Dec 30 2011, 06:12 PM)
Toolguy,
that motor looks 'clean' too.. one question for you, where did you secure those venturies on the webbers?
Posted by: JawjaPorsche Dec 31 2011, 10:00 AM
Wow! That really looks awesome! I bet your Teener is like a rocket ship with that behind your seat!
QUOTE(toolguy @ Dec 30 2011, 09:12 PM)
Posted by: kconway Jan 1 2012, 10:10 AM
How did it go? Did you get yours in yesterday? I've been scratching my head wondering how to get mine off that dolly and on to what to lift it in to the car.
Posted by: Steve Jan 1 2012, 10:26 AM
QUOTE(kconway @ Jan 1 2012, 08:10 AM)
PIA.. I did it that way in the past. I used two floor jacks one on each side and lowered the car onto the motor and trans. I also used jack stands as a backup and then bolted everything up and raised the car back up with the two floor jacks.
I now have a scissor lift and a lift table. Much easier!!!
