I am usually good to measure twice and cut once. Not sure why I messed this one up.
I have spent much time and a few dollars rebuilding this engine, so I wanted to be able to monitor it. Nothing too fancy or expensive, just some VDO gauges. I guess it is a little late now, but let me ask. Where can I put an oil pressure sensor that is 3 times as tall and twice as round as the OEM idiot light sender?
The distributor gets in the way damn it. I can get it installed, but I lose some range of motion for the distributor. Then there's the cooling tin issue. My engine is assembled so, if the answer is to drill and tap somewhere else, that option is out.
Somewhere online I saw an aluminum block that mounts to the oil filter attachment, then the oil filter screws into that. That block has 3 or 4 tapped holes to mount stuff. Where did I see that? And would it give me decent pressure?
What can I do?
Clark
Picture of the VDO monster
And the OEM version
Grease gun hose or paint gun hose in between.
1/8th NPT will fit the 10mm thread pretty well (same pitch). You need an extension. As mentioned above, use the greese gun hose or braided paint ball gun hose.
This might be your cheapest option:
http://www.harborfreight.com/engine-oil-pressure-test-kit-98949.html
It contains all the connectors you might need and the hose.
Clark,
Where did you mount your VDO guages? Any picts?
Dave
Grease gun hose works great, and it's good to about 2000 PSI, more than you'll ever need. You'll have to buy a 1/8 NPT female/female coupler to join the hose to the sender, and you MUST ground the sender for it to work. Mount the sender to the fan shroud.
The Cap'n
Here's mine.
I used a paintball hose. They come in different lengths. I made a bracket that attached to one of the case perimeter bolts. That way, I didn't need to use a separate groound wire.
Harbor Freight has a small ass't box for < $6
Bumping an old thread with a request
Can I get a close up picture of the hose where it threads into the dual sender.
Please
