Just a few progress pics for the curious. It's not a huge amount of progress but at least it feels like the project is starting to move forward!
This is a pic of the taper lock hub. It's the reason for my question about flywheel distance. I have about 5 cm of play here so I needed to know where the flywheel was SUPPOSED to end up. Thank you Demick for the fantastic data dump you gave me!
The amazing thing about taper lock hubs is that you can remove the bolts completely and the thing still won't come off!
Flywheel: Demick -- the final distance was 44.2mm
Cool. So you can use a stock flywheel/pp/disc setup ?
B
Now THIS is how to spin up a motor on the bench!!!
(and you thought your STARTER motor sucked amps!!! )
Ha ha.. we both posted at the exact same time.. TWICE.
B
Brad, yep it's stock all the way. Ok, I didn't use the engine seal thingy since I don't have any oil in my motor!
Oh and just cuz... here is the P. Plate:
This time for sure..
wow!...
now what do u use as final drive ratio... just 5th gear?
whats the torque on that e motor?
Comparing gas engines to electric motors is always complicated. If I told you that this motor is rated at 20 Hp you'd say well gee that doesn't seem like enough. Problem is gas engines are rated at peak Hp whereas electric motors are rated at continuous Hp. The peak on this motor is rated at 90Hp but many people have run it 2 or 3 times that! Torque is even more complicated.
I'm using a stock 901 tranny so the final drive is stock. And mostly I just use third gear.
Basically I've put this system together to deliver something very close to a 1.7L 914. I'm just trying to make a daily driver not a rocket like Otmar's.
is there any shifting with an electric motor car? I've always wondered... since when you let off the power, the engine stops spinning, wouldn't that make for grinding gears?
When you let off the pedal the motor doesn't stop. In fact it will keep spinning for a VERY long time. You just aren't ADDING any energy. Since there is no compression like a gas engine it will just spin forever. Actually thats a difference in how you drive an electric car correctly. You get it up to speed and then take your foot off the pedal. It feels like you have cruise control. When the car slows a bit you just give it a little pedal and repeat.
Oh and on the subject of shifting.... You don't have to use the clutch at stop lights since you can't stall! You don't HAVE to use the clutch to go again either (I do though.)
how do you engine-brake?
That's very cool, an electric engine in a 914. My "alternative transportation brother would love it!
In MY setup I don't engine-brake at all. Yes that means the brakes get a work out. Hence my upgrading to 320i brakes on the front. Some people do put in regenerative braking to charge the batteries and that makes the car feel like it has tons of compression.
Sean:
send your brother this link: http://www.electroauto.com
