So once again I find myself going where the sun don't shine.
Eventually, I plan to post the receipt from where the body shop charged the interim owner for "replacing quarter panel"...but that's fun for another day.
Here's my question: Am I correct that, from the factory, the little void in the point at the rear of the quarter panel (above the tail light) is left empty--or full of spray foam--and that there's a very large glob of seam sealer supposedly preventing tire-slung moisture from finding the foam?
I had to open mine up all the way and I'm toying with actually welding in a custom baffle in front of that pointed tip so that I could seal it up tight from the front side of the baffle. I would do this as part of the process when I fit in the new fender section.
What I want to do is make sure moisture can't get into that rear point and fester.
Anybody who's reworked the rearmost part of the fender/light socket, what have you done???
I have had very good results with leaving that area open instead of putting foam/sealer back in.
I'm of two minds here when it comes to that pocket. I could agree with sir Andy if I lived on the gold coast unless you drive near the beach and salt water. That is one of the most diffecult areas to clean out and derust without cutting it open like yours. The trouble is over time the calk will release and moisture gets between the calk and the panel. I think todays urothane seam sealers are far superior to what Porsche used in the early 70's. I would take all the proper steps to etch, seal and paint the inside and then reseal the pocket with modern seam sealer. But that's just me.
By the way, for this and for other areas like inside jack posts, does anybody sell a rattle can paint with a red tube like you get with starter fluid/WD-40?. I was thinking that if I had a small hole on the inside of the trunk, I could get some decent amounts of paint sprayed into the point where I couldn't reach otherwise.
Summit makes a paint for the inside of frame rails. Has a long tube that you can draw down the frame rail while spraying.
Not available in CA I bought some here in NV and took it to my buddy for his Miata project.
Kurt
I can't project myself into the future to know if it works but, it really is a trick bottle/coating method. I did this to my 911 rear torsion tubes back in September
Eric, is that a rust converter, or paint? That looks like the perfect tool for getting into those hard to get at areas like the center tunnel and inside the longs.
I've read that some rust converters need to have a 'stop bath', so to speak (with water), otherwise they keep 'eating' the metal. What IS the best rust converter to use in inaccessible areas, where you don't want to wash down with water?
Hey Mark,
Check this out...
http://www.eastwood.com/internal-frame-coating-w-spray-nozzle.html
I've used the other stuff and this is really great... I hope! Lol
I just checked out the Evapo-Rust site and watched the demonstration video. It appears to do a nice job, but they say you do need to wash down with water to remove carbon residue afterward.
That's OK where the item is a removable item that can be washed down and dried, but I'd be leery of using it in the longs or tunnel where I might not be able to get all the water out
Went to Eastwood's site too. Signed up for their newsletter to get free shipping on my next order ... I think I'll spend a little more time at their site to see what other nifty rust eliminator products they have to offer before placing an order.
Thanks for the tips!
Now, back to the normal scheduled program.
Oops! My mistake Mark. What about the popular ones that are mentioned all the time here? Prep and Ready, Metal Ready or Ospho? They're all supposed to be wiped off before coating, but you could probably just spray over them with that Eastwood stuff. I forgot to wipe off one area where I used Prep and Ready and put POR directly on top of it. Didn't seem to make a difference. If you use a good product (I'm seriously leaning more towards Eastwood as I have had issues with POR in other areas in the past), you're going to encapsulate the rust and choke it off from O2 as well as water. I'm certainly not a chemist, but I would think this is the overall goal anyway.
Thanks for checking out the Evapo-Rust though. I was very impressed with it, though I used it on a pedal assembly, much different than what you're doing. Good luck!
I used it in my longs and everywhere I could feed the tube in on my current project. Works great and gets into all the nooks. Be careful using on a painted car as it travels like water.
Hey Andy, in your last pic, did you spray the Eastwood ('green stuff') into the longs and then cut them open to do some patch work afterwards? ... and was it wet or dry when you took the pic ?
I put the Eastwood stuff into the longs through the seat belt holes with my 914-6 on the rotisserie and painted the shit out of it and turned it. You can work it all around till it comes out of the holes in the bottom of the pan. I think I have gotten the longs sprayed well. I had no rust showing before and my jack posts looked great so this should just add extra protection.
I did my 74 V8 car in the same way. The long nozzle makes fast work of this job. I had some worry because of welding in steel and wanted to stops any rust from forming on the welds from the Engelmann long kits.
I bought 6 cans and 2 cans went far on one car.
Bob
I used the repair opening to clean out and spray inside the longs, first pic is dry and second one of the long is still wet
The Eastwood product looks like it does the trick.
I recently bought one of those inspection cameras from HF (the pricer one with the camera head small enough to insert into a spark plug hole.) Should be easy enough to see inside the tunnel, but I'll need to find a good location to insert the camera head to take a peek inside longs. I'm almost certain that I'll need to spray 'something' in both places.
Do these oval openings allow full access into the long?
so the concensus is to - spray ospho into the long using a garden bug sprayer - and - then spray this eastwood's internal frame coating - a day or two later - ???
thanks,
jim
I like ospho and use it on almost everything BUT. If you leave a puddle and let it dry or a run when you paint over it, it will make a place that is hollow, it bubbles up, and will easily come loose later on. These places are sometimes hard to see till after the coating on top dries. On a 42 ford jeep I had put so much on while I was doing the whole tub, we decided to reblast it to get it nice and clean for the epoxy coat. I know on the inside of longs and places you can't get to this is tough though. I would suggest useing a air hose with a long blower to try and remove the puddles in the cavity, this might also get it in the gaps in the layers of metal between the spot welds. All you can do is try to do the best method you have available.
I haven't tried it but I bet there web sites on repairing unibody cars and re rustproofing the cavities. I know for a fact only high end shops bother with this.
Today, I cleaned up a nose section which will eventually be a donor for at least one headlight box.
I used a cheapy Walmart spray bottle to get the Ospho into the recesses where you can't quite reach below the headlights. Then, I rocked the section around to make sure the excess rolled into the varies crannies.
Wear a good respirator/filter if you go misting this stuff. It's not good for you to inhale.
For now, I'll probably just squirt some primer or paint over the converted rust which will keep it stabilized until I need to start working on this section.
