Printable Version of Topic
914World.com _ 914World Garage _ Heater Pull Cable
Posted by: Eric_Shea Jun 17 2012, 05:36 PM
Hey Gang,
Installing the heater control cable and ran into a problem. Yes, I realize there is a left and a right (longer/shorter etc.) but, after trying both ways it appears the cable is bent wrong from the factory. I'm about 3.5" off each way.
Has anyone run into this in the past?
Too Short:
Too Long:
Posted by: A&PGirl Jun 17 2012, 06:10 PM
That's the same as my new Porsche Cable. The old Porsche is the right length/bend.
I haven't experimented yet with the new cable to make it work.
Posted by: Eric_Shea Jun 17 2012, 06:14 PM
So I'm not hallucinating from the brake cleaner fumes.
Maybe Bruce has an original...
Posted by: A&PGirl Jun 17 2012, 06:20 PM
Maybe they used a batch of 911 cables and slapped the 914 p/n on it for the 914's to use up stock. Either that or Volkswagen cables.
Posted by: JimN73 Jun 17 2012, 06:34 PM
I had the same problem and ended up using some other cabling and small cable clamps to make it work. but it's ugly.
Posted by: Spoke Jun 17 2012, 06:52 PM
Are they equal lengths from the bend? Can you straighten and re-bend?
Posted by: Eric_Shea Jun 18 2012, 02:51 PM
I was successful in re-bending the original. Had to take 3 5/8" from the long side to the short side. YMMV
Posted by: tomeric914 May 18 2013, 09:39 PM
QUOTE(Eric_Shea @ Jun 18 2012, 04:51 PM)
Doing a heater pull cable today and ran into the exact same issue as Eric did a year ago. WTF Porsche?
Posted by: Cap'n Krusty May 18 2013, 10:21 PM
WHAT? If the long side was 3.5" too long and the short side was 3.5" too short, it seems pretty obvious you had the ends reversed.
The Cap'n
Posted by: jeffdon May 18 2013, 10:33 PM
Heat? Oh, All that stuff.
Posted by: Eric_Shea May 18 2013, 11:29 PM
QUOTE(Cap'n Krusty @ May 18 2013, 10:21 PM)
The Cap'n
No... The long side was still longer. It just needed to be balanced a tad more in that favor.
Posted by: tomeric914 May 19 2013, 06:13 AM
QUOTE(Eric_Shea @ May 19 2013, 01:29 AM)
The Cap'n
Exactly.
Posted by: mepstein May 19 2013, 06:20 AM
I had to rebend mine. Worked perfectly when the passenger side was 2" longer than the driver side. (as per eric's suggestion)
Posted by: JawjaPorsche May 19 2013, 09:10 AM
QUOTE(mepstein @ May 19 2013, 08:20 AM)
I had the same problem. Tried it both ways then measured old cable and rebent and it worked.
Terry
Posted by: SLITS May 19 2013, 09:37 AM
I'm not that anal ... I just clamped the wire in the barrel nut ... it works.
Shame on you Erc ... those aren't real 914/6 flapper valves ...
http://s239.photobucket.com/user/professor914/media/flapper.jpg.html
Posted by: 76-914 May 19 2013, 10:30 AM
QUOTE(SLITS @ May 19 2013, 08:37 AM)
Does this mean Erc is banned from future 914 events until this oversite is corrected?
Posted by: mepstein May 19 2013, 10:46 AM
QUOTE(TJB/914 @ May 19 2013, 12:37 PM)
Hey,
I am having the same problem with too long & too short.
Dang, jack the car up, crawl under & hook both sides up then crawl back out to check the red lever inside the interior. What the heck, I had the red lever in the wrong position. Should the red lever be moved forward to set the correct tension before I crawl back under the car again??? I need a lift.
Getting ready for Parade is not fun.
Tom
Red lever forward. This will create slack on the cable. Tighten barrel nut on the flapper valve. Now when you pull the red lever up and back, you will pull the flapper valve lever and open the heat loop. Passenger side cable should be 2" longer for perfect fit. Lube up cable with light grease before you thread into hard metal tubes in tunnel. If the solid cable end gets stuck in the tube before it exits into the engine compartment, open up the radius of the hard metal tube - just a little bit.
Posted by: TJB/914 May 19 2013, 11:10 AM
QUOTE(mepstein @ May 19 2013, 12:46 PM)
Hey,
Tom
Thank you, thank you, I am tired of crawling under more than once.
Tom
Posted by: Drums66 May 19 2013, 11:59 AM
QUOTE(jeffdon @ May 18 2013, 09:33 PM)
......Go Heat,(Miami)
Posted by: Eric_Shea May 19 2013, 02:04 PM
QUOTE(76-914 @ May 19 2013, 10:30 AM)
No. It means slits is going to send me a pair of -6 boxes for the trailer queen.
Posted by: Jeff Hail May 19 2013, 10:48 PM
QUOTE(Eric_Shea @ Jun 17 2012, 04:36 PM)
Hey Gang,
Too Short:
Too Long:
Shame on you twice. Put washers on that suspension stiffner nut and bolt. Its gonna gall that purty paint.
