Printable Version of Topic
914World.com _ 914World Garage _ Floor tar
Posted by: Woody Jun 25 2012, 07:44 AM
What's the easiest way to get the sound deadening tar off the floor boards? It's time for my car to go on a diet and this stuff needs to go.
Posted by: jmill Jun 25 2012, 08:01 AM
Dry ice, dead blow hammer and a scraper.
Posted by: balljoint Jun 25 2012, 08:02 AM
When I did it I used a heat gun and a putty knife. Neat and tidy, no wire wheel wires sticking out of my clothes at the end of the day, no messy dust flung all over the place. Heat. Scrape. Dump into a bucket. Repeat.
Posted by: Bartlett 914 Jun 25 2012, 08:02 AM
QUOTE(Woody @ Jun 25 2012, 08:44 AM)
I use a Mapp Gas torch (propane will work). Warm a small section at a time and use a wood chisel or putty knife.
Posted by: reharvey Jun 25 2012, 08:10 AM
QUOTE(balljoint @ Jun 25 2012, 10:02 AM)
Posted by: 9146986 Jun 25 2012, 08:45 AM
Wood chisels
Posted by: toolguy Jun 25 2012, 08:49 AM
Here's what I found worked the best with the least effort and mess. . On sale now Harbor Freight for $19.99 . . buy some extra of the scraper blades though. . and with the 30 day warranty you can use the hell out of it. . you don't need any heat or cold. . just plug in and go. . . you should be able to do you entire floor in an hour or so. . . only bad part is it make a hell of a racket. . .
http://www.harborfreight.com/oscillating-multifunction-power-tool-68861.html
Posted by: rohar Jun 25 2012, 08:51 AM
One of these with the scraper blade. Amazingly simple and leaves things clean as a whistle.
Can cut through about a 12"x12" section in about a minute:
http://www.harborfreight.com/power-tools/oscillating-tools/variable-speed-multifunction-power-tool-67537.html
Posted by: rohar Jun 25 2012, 08:52 AM
almost simulpost toolguy!
Posted by: boogie_man Jun 25 2012, 08:57 AM
QUOTE(reharvey @ Jun 25 2012, 07:10 AM)
Posted by: toolguy Jun 25 2012, 09:02 AM
simple minds think alike. . .
I tried everything i could think of and most of it was messy. . I stripped the entire car, everywhere in a week. . . Bad part was when i went inside in the evening, i realized how bad my ears were ringing from the noise. . On a bare tub, it's like you're inside a giant cymbal so you might think about soem ear protection. .
Back to the old "Homeowners complaint", this is what started the lady next door complaining. . .
Posted by: OU8AVW Jun 25 2012, 09:34 AM
I told my 15 year old...."go get that black crap off the floor of my 914." Then I bought him some ice cream......
Easy!
Posted by: bandjoey Jun 25 2012, 01:09 PM
HF sells EarPlugs for the 1/2 hour it takes to take the tar off with the vibrator tool...
Posted by: stuttgart46 Jun 25 2012, 01:22 PM
QUOTE(OU8AVW @ Jun 25 2012, 07:34 AM)
Easy!
And what a great way to spend a summer day. Great idea. I'm assuming this works with 14 year olds as well.
Posted by: ThePaintedMan Jun 25 2012, 01:22 PM
QUOTE(OU8AVW @ Jun 25 2012, 11:34 AM)
Easy!
Here's to manual labor!
Posted by: vsg914 Jun 25 2012, 02:02 PM
QUOTE(ThePaintedMan @ Jun 25 2012, 02:22 PM)
Easy!
Thats only if your son is named Manual.
Posted by: MikeSpraggi Jun 25 2012, 04:04 PM
QUOTE(Bartlett 914 @ Jun 25 2012, 07:02 AM)
This method was really easy and effective.
Posted by: SirAndy Jun 25 2012, 06:01 PM
QUOTE(balljoint @ Jun 25 2012, 07:02 AM)
Posted by: Rand Jun 25 2012, 06:14 PM
Ayup, heat is your friend. Follow the glue lines and it lets go quickly. A wide blade peels it off fast. Many threads on this.
As I've said before, I can have the tar out of at least one side of the floorboard with tools in my garage before you can even get back here with dry ice. (Although dry ice is fun too. Make sure you pick up a case of plastic water bottles while you're at it. )
Posted by: Woody Jun 25 2012, 06:32 PM
Thanks guys. I'll definitely try the heat method.
Posted by: ThePaintedMan Jun 25 2012, 07:33 PM
QUOTE(vsg914 @ Jun 25 2012, 04:02 PM)
Easy!
Si senor
Posted by: pdlightning Jun 25 2012, 11:53 PM
QUOTE(ThePaintedMan @ Jun 25 2012, 06:33 PM)
Easy!
Si senor
Harbor Freight also makes a pneumatic gasket scraper with several heads for about $25 bucks. It also makes a lot of racket, but HF also sells hearing protection even cheaper!
I used it in mine and it worked well.
Posted by: kwlane Jun 26 2012, 12:33 PM
Propane torch with chisel, comes right up once soft. Just do it outside, fumes are a little nasty.
Posted by: euro911 Jun 26 2012, 01:13 PM
Sometimes neighbors can get a little irritated when we make noise, especially if they're not expecting it.
I try to give them advanced notice ... it helps to keep the peace
