Replacing my Monza muffler with something quieter and noticed one side of the exhaust was a good bit lower than the other. Once the exhaust was removed, it seems the whole engine + transmission is rotated a bit towards the driver's side.
Any clue as to why this would happen? Pics below. Thanks in advance.
Mark
Has your left transmission ear broken loose from the mount? Is it bolted into place without the bushing between the right ear and the bottom of the trunk?
Either your mounts are bad / damaged / ?? or the body is twisted.
take a picture of the rear of the tranny looking up at the mount, you may even be missing some harware
also from the top of the engine does the tin line up on both sides or can you get your fingers in there. Scarry
ok, found it. see pics below. this does not look cheap.
what is the fix? [attachmentid=319
574]
Looks like it's been fixed before. It's not as bad as you would think. Dr. Evil can hook you up with parts. I have two nose (or is it tail on a teener) cones hanging around my garage. I'm sure others closer to you have spares. I'd check the front engine mounts too. The rubber may be torn up.
Replace it. Has the car been in a wreck? That is usually what happens when it gets in hit the rear or from one side. Have two here with both sides snapped on impact.
Easy fix, you will have it up and running in a day
No kidding,
Has not been in a wreck as far as I know.
Ok, so I need to replace the tail cone. Where does on find one? Should I look for a used one? (note my "newbie" status)
Also, what else should I do while I'm back there? New rubber mounts? Anything else?
ok, thank you.
Since the ear broke twice in the same place there are 2 possibilities:
1. bad welding the first time
2. there is some stress on that ear due to body deformation. Make sure this is not the case before you make the repair and brake it again.
Got it, thanks.
Think you should change both the motor mounts and trans mounts. You don't want to go through this twice if you can avoid it.
I'm amazed you were able to select all 5 gears.
Wow, let me know if I can help.
I was able to select all gears but did notice that 1st to 2nd wanted to go to 4th.
There should be someone real close to you that has the parts you need. Maybe if you go in person you'll get the right stuff.
Was quoted $160 to fix it or $395 for a used one by that "someone real close to you". Thoughts?
If you can find a tail shift cone (usually cheaper), that will work, too. Will just have that ugly appendage sticking out
Don't be in a hurry. I will get back to u tonight. I can bet those prices by a lot. Tail shift cone would be free if u go that route.
Great, thanks Dr Evil, (Mike?). I'm in no rush. 103 degree in Atlanta today, the 914 without AC is not the current ride of choice.
Whoa... It's 100+ in LA this week too...
The 914 is ALWAYS the ride of choice.
