Hello' I am looking to buy a complete set of hoses/vacuum lines for my 2.0l engine. I know I can buy all the individual hose by the metre from Pelican but, is a there a complete, pre-cut set available?
Thanks'
Jon
I believe auto atlanta sells a kit
http://www.autoatlanta.com
Type in "914 vacuum kit" in the search field - several results
Here is link:
http://www.autoatlanta.com/Porsche-Vacuum-Line-Kit-73-74-2-0-Parts-PN-BAAVACKIT3.html
I purchased the kit for my 1.7 last fall.
Here is link for fuel line kit.
http://www.autoatlanta.com/Porsche-Fuel-Line-Kit-914-1970-74-Parts-PN-BAAA20100074.html
Thanks for the quick replies!
I would caution you about using that cloth covered fuel hose. Its not compatible with ethanol fuels. It will breakdown the rubber inside, and leak thru the fabric hose. Use only hose meant for modern fuels. Goodyear 30R, or Cohline, or even napa now has a high pressure hose that is rated for use with any fuel. Use the proper FI hose clamps too. Not the serrated worm gear clamps with the holes in the band.
