These are new, and drilled for safety wire. The beauty is that you don't have to replace all the bolts, so if you want piece of mind that your CV joints will not come off, you can safety wire the bolts on. This will make it much easier.
Who needs em?
I'd like a set, which is what, 8?
Do you use them on the tranny side as well?
John
How much are new schor lock washers?
I'm in for 8 with washers if you can get them.
Id be down! Throw the wire in there with washers!
Ya, I threw in wire, washers and bolts
Thanks for taking this on!
I'll locate the washers. The wire is cheap. I know you don't have to use a drilled on on each, so for those of us that want to just alternate you can save a few bucks. I'll round up the wire and the washers. May take a few days.
Truth is if you have the safety wire the washer really makes no difference, except on the ones that don't have it.
-Mark
I'd feel better knowing ALL of mine were wired, with schnorrs underneath them too (at both, the tranny flanges and the stub axles). Cheap insurance
Wire them all! If you wire only a few, then that is what will be left if any of them come loose. Then, those may just likely break and take the CV with them. All or nothing
I need a full set (16). Are you drilling 2 holes or 4? I would prefer 4.
4 is the preferred method
i lost the set I got from the Doc.
Each bolt is drilled with 2 holes, I'll have the washers figured out in another day. The wire is inbound and I'll be able to ship by Friday.
-mark
I'll take a set of 16.
Installed photo -
Washers and wire will be in this week
I am certainly in favor of this modification, however the two holes per bolt can be a problem.
I drilled some for myself back in 2006. Only did 1 drilling per bolt, that would be one hole on each side of the bolt 180 degrees from each other. Put them on and guess what, over half of the holes lined up to point right at the flange that holds the rubber. Spent a while trying to get lock wire thru those to do the lock wire thing and gave up. There is just not enough room to grab the end of the lock wire and pull/push it thru. So I purchased a set from Dr. Evil. They had two holes also. I haven't even bothered to try them as I figured they would be the same , not lining up for easy lock wiring. 4 holes per bolt would solve this problem.
I am going to revisit this as I have the axles off now. Maybe between mine and Dr. Evil's I will have enough that line up OK.
The other way to only drill one hole completely thru the bolt would be to make up a jig that would line up the bolt to the correct angle every time before drilling.
Tom
I'm in for 2 sets.
Tom, my bolts all had 4 holes.
Correction, my early bolts had 2 and I switched to 4 for the same reasons mentioned above by others. Tom reminded me that he got his in 2006 or so
4 holes would be better.
I'm in for a full set shipped to 21403
Thanks guys!
Update
I,m in for a set of 8 with washers. Thanks
Is this going to happen?
My old set only has 2 holes, and I nevr had a problem wiring them. Push the wire with lineman pliers on one side, pull it through the other with a set of thin needle nose pliers. Never had one unable to get through.
Zach
are there bolts avail in the same size, pitch, and strength that would work with #2 or 3 square drive bits? bits are cheap, the correct tool not so much and once they spin they're doomed.
k
Where are we at on this group buy
I wonder how many of us know how to correctly safety wire the bolts? And I agree w/Zach. One should be able to thread it thru. Might want to get a smaller ga. I avoid safety wire any where I can. I've pricked my fingers enough working on A/C. I do recommend the HF safety wire pliers. Aircraft Spruce keeps a few different sizes of safety wire. Reality=You can't be too careful!
Safety wire is best if used with a twist tool. There is a really good write up here
http://navyaviation.tpub.com/14014/css/14014_116.htm
I charge $11 for the tool if you want me to throw it in.
I will take a complete set of 16 and the tool.
I Pm'd you yesterday. Need 8 with wore and washers.
PMs sent to all. I will keep the GB open til the 15th of Nov.
-Mark
I will do a full set (16) with wire and tool.
Thanks Irv
I will take 16 with the wire!!
16 with wire please.
I will take 1 set of 16 with the wire and the tool please.
Im in for one full set with wire.
It does not matter usually if you have two or four holes in the bolt. It is important that you radius the outer sides of each drilled hole to prevent a weak spot developing in the safety wire. I am assuming that the holes are drilled to accept .032 safety wire Stainless steel type. This wire can be obtained at most aircraft suppliers.
I use 108mm CVs and am drilling the heads myself. The bolts are 10mm and I am safetying two per wire connection (total four bolts per each CV
Got mine today.
They look nice, thanks!
John
I'm in for 1 set w/ wire and washers.
I am in for a full set of 16 plus wire.
Richard
HI Mikey
I'll take a complete set (16) the wire, the washers and the tool.
Just made it in before the Nov 15th deadline
Thanks for doing this group buy.
Regards,
Curt
Should have covered everyone here. Let mek now if I missed anyone here.
Thanks,
mark
