All,
I have some pictures of my radio, which certainly appears original to the car, and I have a couple of questions.
First some front shots: (Note the black button on the side on the station select buttons, it pushes in and out, anyone know what it does??) I have not seen any other pictures of a radio with the "Porsche" AM/FM slide select (what have I got here?).
Here's some pics of the tags, what a bitch to get these pictures. In searching this site and google I've found some links to the FTZ-Nr. U108 number, but none look like this radio.
It has two DIN jacks in the back, both have 'tethered' plastic covers. (I'll try and get clearer pics, but the blood was rushing to my head..) One cover has two 'pins' in it, and the other has 4 'pins' in it, the pins appear to be aluminum, but not really sure:
anyone else have a radio like this and can tell me a bit about it?
thx,
Turk
I dig it! I've been thinking one of those or another period correct radio will go into whitey.
I'd suspect your button to be one of two things:
1. stereo/mono or local/distant switch or
2. memory button for the mechanical presets
just a guess
Mono/Stereo button. Very common for this era of radios.
awesome, thanks guys, I see the red stereo light illuminate when the station is tuned just right.
Does anyone know if the Right round dial (the tuning dial) is suppossed to have a balance left and right? The Left Volume dial has the other 'back dial' that adjusts bass/treble, but I don't see that I can adjust balance.
Pull the knob off and see if it is a dual rheostat.
Here's a somewhat similar unit I found for VW, you can see it only has a dual on the driver side.
I found a picture of an old blaupunkt with a hole on the side labeled "Balance" does your old one have something like that?
I'll get upside down one more time to see if I have something like that...
Great pictures! Hard to get.
From the lettering style on the clear dial this looks like a later model radio maybe ~1975 or so than would be original to a 1973 car, installed behind a 1973-correct dash cover plate. The PORSCHE lettering on the center selector bar switch is not unusual. I have a small gallery of 914 radio photos on this webpage, dated correctly to the best of my knowledge. See their subtle differences:
http://bowlsby.net/914/Classic/Accessories.htm
I couldn't find a balance area or a potentiometer anywhere that might do it.
So this was bugging me a little, and I was looking at ordering a "din to 3.5mm" connector, so I took the radio out, to make sure what I have.... You can see in the pic above that the radio seems to 'sag' a little in the faceplate, and it seems its some non-correct hard plastic faceplate with some cobbed cutouts.
So after taking it out, you can see a little better the faceplate doesn't seem to be original to the radio. It doesn't have vinyl on it, its molded plastic to resemble the rest of the dash vinyl.
When looking at the back of the faceplate, you can see that the "Porsche" slider doesn't slide, just glued in place, and the general cob job of the installation:
This is what the radio looks like in its 'stock' form, with the other faceplate removed:
Which matches pretty much exactly what JeffB. has on his site as a '75 model Blaupunkt radio:
http://bowlsby.net/914/Classic/zAcc_1975_BlauFrankfurt_AmFmS.jpg
So, now I wanted to document just a bit of the radio itself...
These are the 3 stickers on the top of the radio:
Side Stickers:
Here are the back connections:
I have a 6pin and an 8pin?? I believe the 6pin is a mono connection, but I thought the 7pin was stereo, and I've never heard of an 8pin...
the other connections for power and speakers
These are the pin covers, the 2pins go into the 6din, and the 4pin goes into the 8din:
So I actually do have a couple of questions (not just being a post whore..)
I want to put in the correct faceplate with the correct fabric applied. I think in looking at AA that this would be the correct option:
http://www.autoatlanta.com/Porsche-Dashboard-Radio-Faceplate-914-For-Blaupunkt-Frankfurt-And-Becker-Radi-Parts-PN-B91455204010BA.html
(Unless someone has a faceplate they would like to sell, I'm interested!)
That would be for a 73 dash (2.0 with center console if that matters...)
Another question is the screw type of adjustment in the face of the radio. I'm still looking for the balance adjustment of this radio, and I suspect this may be it...but not sure:
Another question is the fact that I have dual reostat's on both sides, the left(driver) side is the bass/treble adjustment and has the second adjustment knob:
The right(passenger) side has one as well, but I don't have the second knob here, and it appears this is the AM/FM switch, as I see the green FM indicator behind the number 10 on the glass face start to move when I turn this. Its very stiff, and I don't want to force it:
Anyone know where to get the knobs for this radio, especially the 'back' knobs. If you have some to sell, I'm interested!
Appreciate any insight on the questions, or parts needed, thx,
Turk
There is a guy on eBay that sells knobs for your Blaupunkt. He has all sizes. He also sells faceplates.
Here is link to vendor:
http://myworld.ebay.com/iprangen?_trksid=p2047675.l2559
Found the owners manual online on the Samba, confirms what I thought about the AM/FM control on the tuning knob...
http://www.thesamba.com/vw/archives/manuals/1977_Blaupunkt_Frankfurt_Stereo_US_User_Manual/cover.jpg
http://www.thesamba.com/vw/archives/manuals/1977_Blaupunkt_Frankfurt_Stereo_US_User_Manual/4_5.jpg
And the elusive Balance control:
http://www.thesamba.com/vw/archives/manuals/1977_Blaupunkt_Frankfurt_Stereo_US_User_Manual/10_11.jpg
Still can't find Knobs anywhere, Jawa if you have a link, would be much appreciated.
Go to:
Send him a message. Click Contact Member link on left.
Tell him what you want. He will respond.
Terry
BTW, I found this place has the 2Din style speaker connectors, for a buck, but they have a $5 handling charge unless you buy more than $5 bucks worth of stuff.
I'm thinking of buying a few sets of the connectors to have them handy.
http://shop.vetcosurplus.com/catalog/product_info.php?manufacturers_id=11&products_id=7167
The connectors on the back are used to connect the tuner part of the radio to the amplifier section. You can make up a connector to allow you to add a MP3 player or iPod to the radio. Someone had posted the pin connections somewhere.
Same radio as mine, someone said it is for 75-76 years, my car is 74 so I'm off one year. Far left is am/fm knob, mine does not have the slide buttons yours does. Left round knob has a treble/base adjustment in back or it.
Picture installed, I had to ask for the speaker plug-ins from the same person I bought it from, could not find them to buy.
