For me the induction noise of carbs is too loud. So I went looking for a solution and I thought I would share what I found and trying. 1985 Honda 1200 Goldwing air cleaners.
They seem to be working great. Nice deep sound and quieter. The air horns on top are about 1"x 1 1/2" each. Combined they are bigger then 1 throat of the carb. I don't feel any reduction in power and idle seems about the same. Engine is a basic rebuilt 1.7 to 2.0L specs with carb cam and hydralic lifters.
Cheap too. shipping cost more than the air boxes themselves. A little fabrication of a mounting plate, but pretty much bolt on. Linkage clears.
Whats the height of the box from the base at the carb to the highest point?
They actually look like they belong in there.
How much quieter are they (if you can attach a percentage to them)?
Do they clear a stock rain tray OK?
How did you take out the gap with the different height elements?
They are about 6 1/4" tall. I don't have a rain tray to check clearance but I would suspect they would touch.
The top of the Honda filter has a depression which makes it about the same height as the weber filter. So it just fits.
They are very quiet, better than 50%. Almost silent at low RPM. The sound is not thumpy at higher revs. More uniform, with a bass note.
Nice mod, Ron. Thanks for posting
I don't want to lose my rain tray, so if they don't fit, I'll need to look for another solution
Very cool! This looks like a really worthwhile addition for anyone who uses a carb'ed 914 on the street.
.... Or one with independent throttle bodies in any way...... Hmmmmm.....
--DD
These would negate most of the reason for having a rain tray with carbs... Would they not?
-Aaron
Rain tray also protects the electrical wiring and keeps water out of the engine bay in general. If you run w/o a tray you need to be sure the battery is covered so you are not leaching watery battery acid back down into the hell hole.
Zach
The battery is exposed regardless of having a rain tray or not.
Those air cleaners are really cool...they'd look good if you had some side-draft carbs (on other cars). I remember seeing a really cool Mercedes M110 with side-draft webers on it, for a daily driver those covers would be perfect.
Anyone found anything for a -6?
My battery has a plastic cover (came with the AA battery tray/mount kit), but I like the rain tray because it catches most of the rain water should I encounter an impromptu storm (like the evening we came home from the Rt-66)
I think with the GL housings by themselves, the carbs could still ingest a fair amount of water without a rain tray in place. I know a few folks who have the fiberglass 'hats' (and no tray) and have ingested water while parked.
Maybe a custom (shallower) tray is one solution
EDIT:
Old 911s don't have rain trays due to the lack of space from the stock air filter housing, but there is an optional tray for 912s.
Have you noticed any difference in the air/fuel ratio after installing them? I'm in desperate need of quieting my carbs down with my school commute every weekend... This is a great option, thanks for sharing!
Air cleaners off a 912 work, and can be adapted to fit IDFs.
Before I decided to go FI, this was the route I was going to take.
Zach
I have a few sets of those, but they're set up for Solex P40IIs. I'll check to see if they fit Weber IDFs
Looks good
I balanced and tuned carbs after I put them on and watched my idle very closely and really didn't see much of a differance between putting the tops on the filters and the air box top with the horns. Driveablilty wise there are no flat spots that I can tell. We have some pretty steep canyon roads here in Boulder and it pulled real strong from low RPMs.
I probably spent less then $75 on the project. The 356 or 912 air cleaners I saw for sale were $200 plus and needed adapter plates to work with Webers, and didn't seem to quite fit anyway.
I thought of motorcycles because I have a BMW R90/6 which is essentially half type 4 engine and its super quiet. BMW boxes need more fabrication to fit, so just kept looking and found these. The earlier Goldwing boxes are not as tall and might work also
The GL1000 (shown by RonD), GL1100 and GL1200 should all have something similar. this is a great idea. For those who don't know the setup, this bolts to the top of the air plenum that connects the 4 carbs on these bikes. Any cycle salvage place (Coopers is in Franklin, NH near me) should have these available.
Nominate for classic thread status. This is a common issue, with a very innovative solution.
Nice job!
Interesting. Hmmm....
Seems like you could fab up a couple of air boxes out of sheet aluminum or galvanized steel without too much trouble also.
I took the stock air cleaner off my six and put on K&N watershield air cleaners because I like the sound of the six stacks at full song.
Just got to listen to it too. My car is back up and running.
nice out of the box thinking! a clean look
The triple Webers in the 914-6 used a single combined air cleaner. Almost the same as the one from the 1969 911T, which makes sense because the Six motor is almost identical to the 69 T motor.
I'm pretty sure that's what the Cap'n was referring to.
--DD
I'm to believe any /6 carb airfilter assy. will fit but you might have to cut off the snorkel.
Is this correct?
Is the bolt pattern the same on both the zenith and weber carb tops?
CB performance sells covers for use when turbocharging, why not just run them without the turbo? They have a bunch of different models including a low profile one for 356s that might fit under a rain tray. Looks like it would be easy to pipe the inlets whereever you want.
http://www.cbperformance.com/ProductDetails.asp?ProductCode=7313T
Interesting
No makes no difference,I like this idea for a 4 just makes sense,the sound is fun for a while....
I feel lucky to have a six with stock air cleaner ,hate to have to buy one they are getting a bit crazy pricewise.
Always like the Alfa setup for Dellorto's and Webers on the early carb cars no reason it won't work on a T4 without simple mods.
Congrats! I did this mod too and I met a fellow from Laguna Beach at the G&R Swap that had it as well.
This is an easy 80% reduction of intake noise and I highly recommend this mod to everyone.
I like the noise my carbs make. Especially when I'm wearing these.
