Posted by: oldschool Nov 1 2012, 12:31 PM
Can I just pull on this to remove?
(white)
Posted by: gothspeed Nov 1 2012, 12:59 PM
the stock temp sensor is 'threaded' into the head ...... it looks like this:
Posted by: Jeffs9146 Nov 1 2012, 01:10 PM
Don't just pull!!!!!
Most people make a tool by notching a socket extension so the wire can pass through the socket and you can still turn it!
If you are just talking about seperating the wires then yes you can just pull them apart at the plastic piece!
Posted by: oldschool Nov 1 2012, 01:26 PM
QUOTE(Jeffs9146 @ Nov 1 2012, 12:10 PM)
Yes, Just separating...this is what I have...and thanks for you replay...
Posted by: '73-914kid Nov 1 2012, 01:29 PM
The white wire on the harness has the plastic clip molded around it. unplug the black wire, from the plastic surround. Just do it carefully... that harness is in amazingly good shape Jaime. Looks like you've gotten a lot done on it so far. Looking forward to resealing it
Posted by: gothspeed Nov 1 2012, 01:49 PM
Jeff is correct
However title should have been 'disconnect' temp sensor
Posted by: The Cabinetmaker Nov 1 2012, 02:30 PM
QUOTE('73-914kid @ Nov 1 2012, 02:29 PM)
Not quite. Both the male and female plug ends pull out of the insulator. Is not"molded" to the wire end.
Posted by: '73-914kid Nov 1 2012, 02:37 PM
Learn something everyday.
Posted by: oldschool Nov 1 2012, 03:30 PM
Thanks all.....Just don't want to break stuff......
