Hello. New here,so here goos.
Back in 2007 started to put the parts and chassie together. I have 3 chassis to work from,2 from Texas and one from Ca. The Texas car seems to be better/less rust but it was hit in the driver front and repaired. Will look into that when I get is up on Rotisserie. Will start building the Rotisserie next.
She will be powered by a JDM Sti using a adapter to the 914 transaxle. Didn't want to go to the Subaru,to much work.
When I get it up on the Rotisserie is this a good time to have blasted clean/paint free?
Here are some photos . Any input is welcome!
Randy
Keep us posted, and inspired
Paul
Thanks Paul!
Also need in put about using the body kit from Sheridan Motorsports . Things like mounting the panels? Thinking about the wide body????? With the little 2.0 Turbo maybe the body is to wide? Will have around 300HP+-? Or should I go with the steel ?
Have you driven a 914 with a side shifter? They are nothing to write home about. I wish I would have gone suby transaxle. My next one will!
Well I drove 140+ miles a day for 3 years with my 73. But I know what you are getting at. They are not a racing trans but I think it would be ok for a old racer? LOL
Always happy to see new subaru 914's, which JDM STI are you thinking? You may want to talk to Britian Smith, as he went Version 8 (or 7, either way RIDICULOUSLY fast)
Ian
What was in it prior? V8?
Thanks All!
The motor is from a 1994 Sti. She is close to a 555, Like 275 HP stock.
Here is the chassis tag.
Andyrew that was what I was thinking! And the glass may not work well with the people on the city streets? Maybe this is the way to go??
The GT look is the most preferred.
I have fiberglass fenders front/rear (Molded in). Daily drove for a year no issues. Just mount them well and dont stand on them.
So ,I have been looking at a lot of build photos. In this photo the center tunnel has been removed. What about making it taller to take the water lines?
Never thought about removing the tunnel. The Subaru trans is TOTALLY worth the little bit of extra work. With the modern trans you can just drive the car without the constant f*(*cking with the 914 trans - ie just drop into 1st gear and go.
Welded up the ends for the mount.
53 " off the ground and 42" to the leg.
So I got the motor a trans out of storage. I am think of going air to water to air for the innercooler. I have one of a JDM,its in the photo. Think it is on a 220 HP motor.????
The exhaust was built,maybe 5 years ago. My bad! But I'm back at now!
When I put a Subaru 2007 wrx engine in my kit car I ran into the same problem.
I installed a 7" fan which pulls the air through the cooler and exhaust the air to the transmission area, the fan is control by the VSS sensor, when it pulses it turns on the fan. Here are some pictures of it.
Thanks 904! Think I will stay with water.
Up front I have lots of room for a heat exchanger for the intercooler.
Been working out the Rad. for the motor and will just ad a Rad. for the exchanger. Thinking a 24" by 12" by 1" would do the job?
Some one was asking,some time back what the FWD trans looked like. Here is a photo of the 914 and the FWD Subaru tran's. Is that a word? LOL
Here is a link to the chassis cleaning/Soda blasting.
http://www.914world.com/bbs2/index.php?showtopic=198596
Cant wait to see your progress. Ive been in DBCoopers car and it was awesome. He is using both the engine and a wrx trans converted to fwd. I think thats the best. He also went with air to water. I have been considering doing the same. How will you vent for the radiator?
Randy,
Looks like a nice setup.
Have you checked the the dimensions on 914 body? You might want to check that they're close before investing lotta time in the body work. I have the paper copies showing where to measure and proper dimensions - could scan them to PDF and send you. I'm sure someone has posted them on this site though.
Keep the pics coming.
I am moving back over here with rust repair of my project.
As you can see I'm back at it. Photos are the only 2 areas on the floor that will nee work. I'm thinking a small welded in panel ? Ideas from what you guys have done ?
From the bottom.
A Little more cleaning.
Looks like I will have some work to do in the Hell Hole ! But not as bad as most have had to deal with.
With me building a water cooled 914 should I pull the air skirt mounts ?
Depends on how far you're willing to go...
I removed most of the engine shelf and made other modifications. There's no going back now but I was not the first one to cut into the car.
And what about the battery tray ? Not sure their is a better place for it but I figured I would ask.
What about the balance of the car ? With moving the battery that far forward is their a down side ?
You're taking weight away from a higher center of gravity point in the rear to a very low COG point just over the front axle. The new engine weighs more so in theory you should be better sorted this way. Should help even out the whole weight distribution thing and still keep the weight close to the center of the car which helps your handling. Would be interesting to see some others battery boxes and ideas tho...
Has anyone gone with a gel-cel inside the passenger compartment? Is it even recommended?
You've already added fans, water and a radiator to the front so I'd keep that batt in the engine compartment. Scales will say it all.
I will need to find out what the Subaru starter needs in the way of a battery. Maybe I could push it more down into the "hell hole" ?
So this is my IDEA list.
Camber & caster weld-in plates?
Coilover shocks,F & R.
Roll Cage (welded in)
Chassis reinforcements.
GT Steel fender flairs.
Vintage Racing seat ( GT )
Front Welded in swaybar reinforcement.
Floor repair (as needed )
Replace jack points.
Right Hell Hole wall repair.
Firewall to trailing arm mount rod.
Cut out air-cooled motor flange.
Windshield post reinforcement. (GT )
GT front hood pins and plates.
4 lug to 5 lug swap.
Racing tow points F & R .
Through hood fuel fill. ( GT Racing ) ?
Repair jack points.
Bigger brakes F & R ?
Cab heater.
Cap A/C .
Turbo steering Kit.
Outside Master battery switch.
Some seam welding.
7" and 8" Fluk's.
JDM EJ20 T.
Megasquirt ECM and harness.
Subaru to Kennedy to 901 trans stuff.
ColdWater mount.
Well its a start. Now I will try to put them into some kind of to do order . Ideas about what to do first ? I'm thinking its the floor,jack points,hello hole ? Kinda work out from their.
Randy
Strip it first of all that's being replaced and fix your metal bits. Then move to the suspension. Get a Subaru trans and dump the heavy, clunky 901 for something that shifts like buttah... Reference Cpt.Tripps build- he's done alot of what you have in mind and it'll save you headaches.
Thanks for the link to Cpt.Tripps build . I was doing fine up to reading about the brake up . Sorry things like that happen. Hope he is doing alright . It is a very cool build . It will help with my build big time. Thanks Cpt.Tripps !
Randy
PLEASE ask me questions if you have them! I've done a lot of cool shit, and I'm still finding myself stuck. It's not as easy as you'd think.
Right now I'm wrestling with the intercooler and how I'd intended to set it up. Getting myself motivated to get in the damn garage and finish the thing is my biggest hurdle right now. That, and money. Ha!
Link in my sig. I'll PM you my mobile number. TXT or call any time. If I can help, I'm happy to.
You'll be helping to motivate me!
Thanks CptTripps !
Been working and thinking about coil over's for the car. So I started playing with some old stuff for a project I never started.
I will try to reuse the front BOGE tubes/spindles but with KYB's in it ? I can always go Bilsten later. Same with the rear but will need to do some more thinking about that.
Here is my first look at making a coil over. For you at home I have a lath to help with making things fit.Will need to turn the cartridge nut. To big and to close to the spring. Spring is a 10" x 2 1/2". Thinking the front will be 175# and the rear at 200# +- ?
Plan is to weld a perch on the front tube and build a spacer for the rear ? Will try to keep its mounts all stock.
Have also been thinking about the 4 to 5 problem. Most of the GT/lookalikes seam to use spacers to fill out the wheel wells. So think I'm going to use a front adaptor to go 4 to 5/130 ? Still working on what to do to the rear.
I know I can just buy it but what fun would that be ?
Randy
I got a set of Boxster hubs. Now I need to know if a 1976 911, 108mm stub will work with it. I have read a little about needing a spacer,and I can make that. And the need to add mounting holes to tie it to the hub.
Thinking about staying with a parking brake. Was thinking after reading, that a 914-6 brake rotor and a spacer on the 914 caliper would be the way to go ? Do I have that right ?
With it being a 930 flange it looks to be a little tight but should work. Think I will use a small offroad CV boot ? Because of the Subaru trans I will build the a flange for another 930 and use 28 spline offroad axles.
What do you think ?
Thanks,Randy
I, cleaned up a 914-4 brake rotor and bolted (one hole) to the Boxster hub. It almost self centers. I then tightened up the wheel lug. Used a transfer punch to mark the 5 bolt pattern. Will drill them after getting a bit for a stud mount ? I want to do a mock up so I'm using what I have. Anybody try using allen bolts for wheel studs ? In dirt racing it is a cheep way to go . With some luck the stub's will be here in a day or two ?
The trailing arm is in the bead-blaster for cleaning. Then some welding. Any body on the board sell the metal kits for the chassis and trailing arm's ?
Randy
I also found a stud set for the hubs. What kind on nut system does the 911 Fluk wheel use ? Is it Man,Ball or conical ? I was thinking its conical but don't know for sure.
Price is right also +- ?
http://www.ringer-racing.com/product.sc?productId=24
Randy
Its a Ball seat. Now I know !
Now here's a pic I havn't posted for a long time.
Aw, come on. the shitbox was always pretty.
So I was looking into do I need the torsion bars if I go to coil overs and found this.
This car was hit on the driver side and I think it got pushed ? I will clean things up and think maybe I will need to cut the mount out of one of my donors ?
All cleaned up.
Back to the coil over with or with out torsion bar. The answer looks to be just leave them out. Rusted in good. But out now.
Randy
In looking at the mount today it will be a pain to remove . So what would be wrong with cutting it out ( dotted line) like the photo and weld it back in ?
Was thinking I can use the tab from the rear tie bar to hold it in place for welding .
Randy
Got some thing out of the doner. I pulled the hole mount . I think I will remove the spot welds from the backside of the stamping. Then I will drill out the centers and spot weld to the chassis. This may give me more metal for the welding ?
I will need to pull the "A" frame on the passenger side and the steering rack to get to the spot welds on the damage part. PAIN !
But it is the best way to repair it. Going the other way was dumb !
Randy
So I trimmed it up,drilled the pilot holes and used the weld cutter.
Now on to cutting out the bad part. Also need to weld up a small mistake. My bad.
Randy
Back to work. I know this is nothing like the work I see here but its all new to me. Installed the steering rear mount. Took about 3 hours. You guys doing hole floors,just incredible is all I can say !
And now its all installed and almost looks stock ? Using the a frame mount work out well. Just make sure that the mount and chassis are in good shape.
Now on to the other holes and the jack plate. I may make my own mount ? Because I don't have the rear fender off it would be hard to install a complete one.
Not bad for a HACK !
Randy
Nicely done!
Hay CptTripps. Found some wheels you liked on a green 914. What do you think,can I make them fit ? Their 996 7" and 9" 50 and 55 offset.. From the photo of the green car it looks to have spacers.
And thanks, I'm still learning.
A little more work on the Boxster to 108 axle. I'm not going to use a spacer. So I cut the spline about .112". (now I'm going to here it?)
After I get the trailing arms cleaned up I will put it together.
The spline on the Boxster hub will need to be cleaned up a little.
Randy
Well you will need a spacer. I forgot the castle nut ! My bad.
So I made one. I will still shorten the spline . Want the spacer to sit very close to the shaft. The space could be stepped but I feel it will hold its shape better flat. Should torque up better ?
You could say its a thick washer ?
A stiffey ?
I now have 5x130 and a parking brake !
Now on to some welding !
[/quote]
Hi Randy,
I'd be alot more cautious about locating those holes. Using a transfer punch and the hub both introduce significant error. That's a job for a milling machine with a rotary table in my opinion. Otherwise the compounding tolerances could introduce some very unwelcome high speed wobble...
[/quote]
Its not the hub he's drilling, its the rotors. Carry on, it should not be an issues. Just set two points, mark and drill. The lugs do not place the rotor in a perfect alignment. The counter sunk screw does that. Just make sure one of them matches up. And a lug bolt matches up, and go for it.
Yes I will use my mill.
I now have one stiffie !
Just need to weld the end.
Is their good way to pull the bushing ? And replace it with rubber or ??. Will be going some track and fast driving.
Thanks, Randy
[quote name='914forme' date='Feb 11 2015, 12:47 PM' post='2144938']
[/quote]
Hi Randy,
[/quote]
[/quote]
My dad was a Machinist, and I make my living as a Mechanical Engineer. I've always been "belt AND suspenders" so any advice I give is coming from "overkill is just enough"....... My name is Brian and I have TRUST issues.....
New paint.
Hello, my name is Randy and I have a car building problem !
Looking at the rotor shield and found some cracking at the mounting holes. So I brazed some AN washers and should be go to go ?
Randy
I was doing some welding and I saw this on the bench. So it got welded also. May not need it but ?
All installed. 930 CV, cut Boxster Hub, and a 108 MM stub. Stock brake caliper and rotor drilled 5x130.
Randy
Cleaned up the front cross bar and added some paint.
Been thinking maybe I will test fit the coil-over idea and see if it will work ? Also thinking about the German VW vented rotors with the 5x130 ? I can get them for $450 +- with shipping. I'm finding the 911SC front ends are big $$$$ .
Back when I started this I could have had all for $750. Wish I had gotten it then.
I know the manual said to drive out the bearing and the hub but it beats the hub a little. So I built 2 drivers.
Installed the crossbar and found the 11/1971 and the 09/1974 don't use the same lower ball joint. So I got the 74 lower arm and installed it.
Test fit the coil-over idea I have and it is going to be very close. With stock Alum. wheels ! Think a 1/4" spacer would be best with stock fenders. Tires in photos are 195/60r15'
I will be adding the steel GT flairs and 7 or 8" front wheels and 8 or 9" rear. At this point I'm not sure what spacers if any will be needed and foresure don't know with the coil-over's in the front ?
But it looks like it will work !
Randy
And no, i'm not going to use a 300# spring on the front. And some idiot mounted directional tire on backwards ! What a dip stick.
Great job on the front/rear suspension parts. I powder-coated all of mine, and I wish I wouldn't have.
Stock 914 T-bars are ~90 lbs/in just to add that little bit. Again I rounded to a spring you might be able to get from Qa1
Thanks.
I was thinking that I would start with 200 F and 175 rear ?
I want to get the chassis with the new motor/trans and stuff first then check it on the scales. May give me a better idea about where to start ?
Randy
Look what I found . 2005 WRX tran's with LSD . COOL.
Also got yelled at by my Wife. So no EG33 for me. Just going to use the STI motor. Also going with MS3-pro. This should be interesting ?
Randy
Getting ready for my winter project. (914) Been a little off track with old project's.
Just finishing up a Rally Forester that I used the Sti motor in. Now I will need to look for another motor ? Did a Rally-X in Tucson and had a blast. Using this motor in a 914 will be so very "COOL" ! Still needs paint but that will come.
I will try to stay on point with the 914.
Randy
Didn't see this thread before. Very cool.
Now for a motor question. What about the EZ30. Because I need a motor was thinking how much I like the sound of the 6.
Good idea,bad idea? I will stay with Subaru so this is another option. Want the water cooled motor because I live in AZ.
Thanks for the input ! Randy
If your asking me I say EZ30 all the way. Sweet engine. I too wanted an EG33 until Bob (BIGKAT83) and Ian (coldwater,com) both steered me towards a EZ. Never regretted that decision. And yes, the sound is sweet, too!
I thought EG33's had the most pwr,..and that the EZ30's were way less pwr,..??? FM
Go 3.6R Most HP from a stock sub -6
I am running a EG33, and yes they can make way more power over 1000 HP. That being said, the EZs make it easier to package in the engine compartment.
I have several EG33s now so I will be sticking with them for a while.
Are you driving or navigating? I have done a few rallies and getting a good navigator is key, who can understand timing, and not get sick. My wife is defiantly not a navigator.
Ahh,..yea, if that's all,. then most likely a EZ is a better setup,..I must be looking in the wrong place for EG33 stuff,..I don't find much but headers and better fuel injectors,..how much is a mega squirt system,..out front quoted me 1800.00 for there stinger box and harness,..Iam so ready to go with a EG33 or the EZ,..but a EZ cost is most likely way higher ???,..can both engines be Camed for performance,.. FM
I'm a driver or at least I think I am ? LOL Been doing the Rally-X thing to start. Then we will see. Over built the car because that is what I do.
This info is great, keep it coming.
Most of the motors (EZ) don't seem to have harness's and ECU's so I was thinking Mega S ? Also do the JDM EZ have more power like some of the other JDM stuff ?
I think I remember reading that there is a performance chip for the EG33. As far as performance add-ons: John at OutFront would know if anyone. Also, his Stinger package ain't such a bad thing if you factor in your time.
Back on a build. But having trouble with what way to go ? Build the want-to be 914 GT or restart the kit car what-to-be a 908-3 ?
Today I got the center diff out and the adapter on and end plate. This tran's could go on ether car.
But I also have a 914 trans with a adapter, starter,flywheel for a Subaru. I have a non-Sti ,turbo motor on it.
Maybe save the Subaru trans for the tube car ???
Anybody know the answer to the color question ?
Got some parts in. Very nice !
But still trying to decide what way to go ? Use the 2.0 turbo with the 901 or sell that setup and go with a EZ30 and the MT5 ?
Ideas ?
MT5
MT5 = Manual Transmission 5 speed, think that is what Subaru calls it.
There really should not be a question at this time. MT5 MT5 MT5
And any Subaru you want
That trans is not 05 WRX. The giveaway is it's a push clutch and that starts in 06'.
There are no factory LSD in the US 5 speeds, did someone install one?
Yes, I found out the tran's is a 06. Male axles and using the case numbers.
I was told by the old owner it has a LSD but we will see.
Also been think over the weekend and think I will just use the 901 and the Turbo " Leg "motor and build a cradle for it. Also think I will leave the GT idea behind.
This will free up the trans and EZ30 for a different build.
IMHO, running a 901 on anything other than a Porsche power plant is akin to driving a square peg into a round hole.
Working on the trailing arm. Does this look ok ?
Went back and reread my build. Only change was I used weld-through paint on this arm. Man I have been doing this car for a long time. Sad. But I'm not dead yet.
After looking at 6 taillights. I now have one left and one right. What a pain. But I saved $$$.
First paint down. Black. In 48 hours I will spray the chrome. Then we will see. But anything will be better than what is not their now.
I've used that paint before and it works great, do light coats and it will really look like chrome. The only problems I've had is when I try to clear over it, the chrome turns dull and just looks like silver paint.
Opened up the right jack point. Lower outer jack cove is rusted. The next inner panel is rusted. The next panel looks ok so far. Take a look and tell me what you would do ?
Need to move the lift arm to cut our the lower spot welds.
Wire wheel and keep cutting back little by little until you hit good metal, then replace it.
I encountered a similar issue when I first got my car.
That was what I was thinking.
Thanks.
Been planning what wheels I will be using and don't want to pay for changing them. So started building a HF manual with the duck thing. Will test tomorrow. Will use the biggest tire and rim I have 295/50r15 on a 10 x 15 .
question. Leave the the motor seal or remove it ? I will be using EZ Subaru motor.
Tested the tire change and it worked Great. Now I can play with any tires I want.
Painted the chrome today also. What do you think ?
Wanted to say THANK's to 914 Rubber. I ordered two turn signal covers and gaskets and for got the screws. I then ordered the 4 screws on a different order. I got a refund for the shipping . They put the screws in the first order. Way to go 914 Rubber. "THANKS"
All most ready. Just need the car to get finish.
First clean up. Used by blaster co clean off the bad paint and to prep for a refinish.
Looking good, chrome paint came out great!
Mounted up a 185/55R15. Looks good.
And the 914 Rubber lens and seal are installed. Simple thing but fun.
Did the math on the Subaru WRX 5MT with a EZ30R using the 185/55R15.
At 2500 rpm with a speed of 62 in 5 gear.
Also tested the tail lights. May need to get new covers ?
Any reason not to go with this size tire?
On a side note I'm not going to go with the GT look. Maybe later but for now .
Just going to do the repairs and get on the road.
One more wheel cleaned and will seal on Wednesday. Using Cerakote Clear - Aluminum MC-5100.
Some more cutting. Need to get a face shield.
Is their a listing for the spot welds on the panels. Like where they are ?
Thanks
I'm running a EG33 with a FuelTech 550. If I change my engine I will go with the 3.6 . But you won't go wrong with the EZ30.
Maybe you have seen this clip:
https://youtu.be/uod6avfs4AM
Here are some pics of my running build... It's stupid fast and make great noises!
Keep it up!!! I would like to see more of this build!!!
Pipe
Yes, great run. But I think you may have cooked your tires .
Things change. Putting up my car's for sale with all the parts. EJ20T with Kennedy adaptor kit with new starter , two 914 motors not running. Exhaust built for Subaru motor to turbo. Two cars with titles one I can't find. Main car is almost rust free but drivers side front has been fixed at some time. Two tran's one side shift. One is a roller the others are on pallets. 5 Fluke wheels 3 striped . Some photos of the other car's. Have a forklift to help load.
$6500
Thanks
OK
I will just build it .
I will try to keep driving.
