I haven't got a clue what I'm doing here
Damn I put the head on upside down,,,,
OK, kidding aside....
A borrowed set of DP valve covers...nice to see other peoples mistakes, so you don't make them yourself.
I have to cut the half cap on the chain cover and then I can make a perfect hole on my turbo cover.
Isn't there also a minor mod you have to do on the turbo covers for the 914?
Of course I'm not happy just working on one project
I'm almost ready to zip up the case on my type 4
This engine was originally for my 914 but DWS set in (and I took a break for a while, something like 4-5 years ago) and plans changed to a 3.0 /6
This puppy is now destined for my '67 bug
Nothing I build for myself is stock
2.6L in a bug
Going to couple that to a 901...in a bug
Been making major progress this winter.
2.6? Are those 103s?
If you're using turbo valve covers on a 914-6, you need to machine some of the ribs off the end 1/4 of the lower valve cover to be able to remove the cover when the engine is in the car. Pics have been posted somewhere,but I don't remember where right now.
yes I found this one and other threads
http://www.914world.com/bbs2/index.php?showtopic=100517&st=20
ahem.
Well it will be here on monday or tuesday . . . I'll let you know and bring it over.
Danm... now i gotta get my 2316 going together... can't have you building 2 engines faster than I bodger together 1... :-p
Have you sent your T-4 in for balancing yet ?? I gotta get mine there but finding a day to goto Toronto hasn't happened yet..
Mill the whole covers fins down to the stud bosses....looks better.
So on the /6 I'm up around 9.9 to 1 CR, I think I can bump that up a bit by off-setting the rod small end bushing.
I need new valves, I'm thinking of going totally custom and using 8mm stems
Still didn't get the timing chain housing hole straight, had a brain fart
Oh well, not critical any ways. Milled the ribs.
open....
Closed
Getting ready for the clinic....
