Why did I wait so long to buy one of these? Yes, the job can be done w/o one and I've done it w/o one. But never again! I like it so much that I will share it. Anyone of my SoCal Bro's need to use it just stop by. It's the cat's meow. Damn you Eric Shea. Your an expensive man to hang around with.
Awesome! Having the correct tool makes mincemeat of any job! Wish I had more toys for my garage.
I was banging a stud out of hub and hit my pinkie so fricking hard I thought I was gonna pass out. Said to myself "what the fuch am I doing" ? Drove over to HF and bought a press. Not only does "having" the right tool make the job easier, it makes it safer !!!
It'll pay for itself over and over and over again...
Wow, there's a bearing in there.....who knew
I know what scotty means on bending 1/2" bars, then I figured it out and pressed it the correct way. Anyway its great to have the right tools.
Definitely looks like Porsche approved "plumbing" pieces to push out the bearing... whatever works!
Made a trip to HF a couple weeks ago and bought the same press to push out the hubs and bearings in my rear trailing arms as well. Folks like us keep them in business!
nice, this is the reason for tool whoring
Kent, what's the tonage rating on that model? I can't read the jack.
I gotta get one of those!
Looks like it says 12 ton.
I read several reviews on the HF presses when I was in the market. First thing is to assure you assemble it on a good flat surface, then weld gussets in the corners to keep it straight.
I decided not to purchase one. Instead, I take anything that needs pressed to my auto shop class. IIRC, it's a 100-ton press
I've had that press for 10 years now without a single problem. Other than welding the two handles together (the one you see in the press and the one on the grinder) it's been flawless. It will do any job you need it to do on the 914.
Kent... I didn't realize you had any money left over from our last excursion. My bad!
thanks for the pics : )
pics of reinstall of arm into car would be awesome!
jim
Maybe I will take you up on your offer to use it in the near future! I have family in Temecula I visit every few months and I will need to press out my rear bearings to install the new ones with my five lug hub that Eric will be sending soon
