I'm trying to get the engine bolted back in the car. The trans mounts are bolted in. I have a jack under each end of the engine bar holding the engine into the body. Problem is, the bolts that go up through the engine bar and engine mount on the body aren't long enough. ??? They were the right size when I dropped the engine and I didn't mix them up with other bolts. I need another inch of threads. Help please.
If they are the same bolts, you don't have the engine bar against the mount.
and
The bolts go down from the mount .... the nuts are on the bottom or behind the steering wheel.
also
early or late car?
---the bolt is sticking up through the mount, just not enough threads to engage the nut.
and
---are you sure? The bolts have an allen head. #16 in the picture.
also
early or late car? ---Early
Something is not sitting properly . The bolts goes up to prevent damage to the threads,
Fixed. I had added a washer to the head of the bolt were there shouldn't have been one. The bolt needs to recess into the crossbar. I got my extra inch and mounts bolted up easily. Thanks everyone for putting up with my - duh - moment.
