I was working on a clucking shifter bushing (firewall) and while I had the console removed I decided to tackle the VDO clock.
I followed the tips on the Pelican Tech sight: http://www.pelicanparts.com/techarticles/mult_vdo_clock_repair/mult_vdo_clock_repair.htm
Trickiest part was getting the crimped bezel off. After that I noticed the Power suply filter cap was blown and needed replacing. I replaced both caps ( 47uF 16v radial capacitors) with replacements found at Radio shack for a cost of $3.00
Im going to calibrate the clock before I put it back together... so far 12 hours and time is still correct
Radio Shack still sells parts down in the US? Up here in Canada it was bought out and it's now more like a mini Future Shop. The furthest they'll get into an electronic device is the battery cover
Jon
1961,
I have fixed more STUFF by replacing Power Supplies filter capacitors than I think I can list... VERY common failure point. Follow the instruction provided by Pelican and take your time working the bezel of the face. the solder repair will be easy
-Robert
