Printable Version of Topic
914World.com _ 914World Garage _ Anyone know of a 911 to 930 CV adapter
Posted by: kg6dxn Jun 7 2013, 10:17 AM
I can here my 944 CV's clicking due to the extreem angle. The Boxster/Audi transaxle flanges sit forward of the trailing arm position. I think I need to swap to a 930 CV but they won't fit in the trailing arm.
Anyone ever built or bought a spacer/adapter to go from 911 bolt pattern to 930 bolt pattern?
Posted by: okieflyr Jun 7 2013, 11:29 AM
I'd be curious as to what angles your working at for comparison. I've been using 944 cv's and no problem thus far with 5-6k miles. I did have to make adapters for the trans flanges and to equalize the axle lengths. This did shorten the axle lengths and increase the working angles, but there are a mix or compound of angles that I'm not sure now to read accurately.
Posted by: pcar916 Jun 7 2013, 04:44 PM
The 930's are 108mm right? I ran them for years in my trailing arms bolted up to a 108mm stub axle. No problems. The 930 certainly has a bigger drive angle... eats up horsepower though at those deflections. Someone may have done some testing at some point to see how much.
Inverting a 915/930 transaxle will produce some extreme angles too. Haven't tried that yet with my 944 CV's either.
Posted by: strawman Jun 8 2013, 12:26 AM
I've got a pair of 930 CVs you can have. You gonna be in SLO anytime soon?
Posted by: kg6dxn Jun 8 2013, 12:36 AM
QUOTE(strawman @ Jun 7 2013, 11:26 PM)
Friday 6-14
Posted by: kg6dxn Jun 8 2013, 08:00 AM
I'm looking for something like this... It is an adapter made for an Audi 016 transaxle (100mm) for 930 CV's (108mm). I emailed the blogger but it got kicked back...
Posted by: Krieger Jun 8 2013, 08:15 AM
FWIW some early 911s (maybe 69?) used a 108mm cv joint that fit our rear wheel bearings. It also had four bolts and two pins, but you say they don't fit pcar says they do..
Posted by: kg6dxn Jun 8 2013, 08:29 AM
QUOTE(Krieger @ Jun 8 2013, 07:15 AM)
Maybe they fit. Just looks tight! I would still need an adapter for the tranny side. 930 CV's use 6 bolts so I guess I would have to machine the pin holes if I use the Porsche stubs.
Posted by: pcar916 Jun 8 2013, 09:17 AM
They fit. You just have to use the a 930 stub-axle. For the trans-flange use an adapter there. You can use sway-a-way axles, modified 914-6 axles, or 911 axles with a spacer to make them long enough. They're way heavy though... can'r remember exactly but at least 5 lbs per axle heavier than the 944 setup. It's true they have 4 M10 bolts and two roll-pins.
Posted by: kg6dxn Jun 8 2013, 11:17 AM
QUOTE(pcar916 @ Jun 8 2013, 08:17 AM)
Is this what I'm looking for?
http://www.ebay.com/itm/EXCELLENT-USED-ORIGINAL-PORSCHE-911S-LOBRO-AXLE-FLANGE-/370541910866?pt=Motors_Car_Truck_Parts_Accessories&hash=item564604db52&vxp=mtr
Posted by: pcar916 Jun 8 2013, 12:34 PM
That looks like the animal. The splines match early hubs. Those hubs work on any number of rotors from 914-6 to SC, with different spacing for the caliper/rotor offset.
I haven't bought any of these stub-axles in well... nearly forever, so I don't have a feel for the pricing. Some folks here may have some used ones as well, I'd place a WTB in the Buy/Sell section.
Good luck
Posted by: TurboWalt Jun 8 2013, 07:05 PM
Mike,
Check with Scott at advancedautomotion 720-443-2771. If anybody would have the adapters he would.
Posted by: strawman Jun 9 2013, 01:07 PM
QUOTE(kg6dxn @ Jun 7 2013, 11:36 PM)
Friday 6-14
I'll leave 'em in a box on the garage side of the house by the recycling bin in case I'm not around when you stop by.
Geoff
Posted by: kg6dxn Jun 9 2013, 02:23 PM
QUOTE(strawman @ Jun 9 2013, 12:07 PM)
Friday 6-14
Geoff
Thanks Geoff!!!! I will be leaving town around 1pm or 2pm. Most likely you will be at work. My Nephew graduates from Grizzly Academy on Friday! With a 4.0 GPA I might add. I'm very proud of him!
Posted by: PRS914-6 Jun 9 2013, 07:28 PM
The 108's will fit fine, I am using them in a stock arm.
They will have four 10mm bolts with two roll pins
You can buy both tranny and drive flange in this pattern and the Sway-Away axles are an excellent upgrade that simplifies installation without adapters.
If you go this route don't buy the early drive flanges but instead get the later 911 hub-centric flanges. (requires 5mm bearing spacer)
This is all assuming you are going to go 5 lug.....
Posted by: kg6dxn Jun 9 2013, 07:43 PM
QUOTE(PRS914-6 @ Jun 9 2013, 06:28 PM)
Very cool!
I am running an Audi tranny so I have to have adapters there. I already have a 5 lug with 930 calipers and brakes. Looks like I need stub axles. I found a place that sells the adapter I need. Looks like it will all come together...
Who sells a 5mm spacer?
Posted by: PRS914-6 Jun 9 2013, 10:56 PM
QUOTE(kg6dxn @ Jun 9 2013, 05:43 PM)
I think I have an extra set ($25.00) PM me if interested
