I purchased my car as an auto x car. It was very stripped. It has never had carpet since I got it. I will most likely not be racing it competitively so I figured that I would put carpet back in. I have a nice set of carpet. How do I attach the carpet? Does it glue in or just lay in place?
I glued the longs but nothing else. Just me. Used Loctite Spray Adhesive. Got it at Home Depot.
http://www.loctiteproducts.com/p/14/17/a_cntct_high/overview/Loctite-High-Performance-Spray-Adhesive.htm
nail gun with 3 and a quarter inch framing nails.
I used 3M spray adhesive that is available at your FLAPs
David
i did a jeep once with the spray adhesive just the cheap stuff. it lasted a while but its been loosing its hold. On the 914 i used contact cement pretty much everywhere except the front feet area. it went well but dont expect to pull it up without damage
To be serious for a moment, I found a thread at the Pelican site which might be of help: http://forums.pelicanparts.com/porsche-911-technical-forum/577586-carpet-glue-carpet-inside-car.html
That's some nasty looking stuff in those little bottles, Dave. Looks like some under handed Yank repackaged some super glue and pawned it off on the Canucks.
It is! I just read the fine print on the label.
.....If it will just lay there?do that!(better for in&out service)
But.....do what you like!
