I would like to add heat and defrost to my Subaru conversion, but I'm not sure the best way to do it. Now, I'm no expert on the ventalation system of these cars, but I was hoping to have something simple like 2 discrete motors. One for the vents on the dash, and another for the defrost.
The stock heat blowers are intact on the car, but I don't believe they're hooked up at all, since the PO had a SB350 installed. That motor is going bye-bye, and I'm not sure the best way to add something to replace it. I don't need fire shooting out of the vents like my Land Rover, just enough to get the windscreen clear and take the edge off of a cool night.
I see a few aftermarket blowers that I can put in-line with the heat tubes, but how should I GET the heat? Is thee a way to do it from the water in the radiator?
Do a search under Marks914. He put an oil cooler in the fan blower box and ran coolant through it via a valve.
I'd look at a motorcycle oil cooler, mounted in front of the tubes in the engine bay and plumbed in the water system. Fabricate a shroud to connect the cooler to the round pipe and put a fan on it. One on each side probably. Wouldn't need a valve in them, IMHO. Just control the fans. And use the stock diverter valves to control direction.
I did an oil cooler in the fresh air box. I did a how to here somewhere. I use the stock fav and control the water valve with the dash controls.
For my subie swap I plan to modify my fresh air box and install an a/c evaporator and ...haven't worked out the details yet, but I think my next step is a long day of digging through small vehicle dashboards at a pick-n-pull. The ultimate goal would be functioning heat and a/c through the fresh air box controls. For heat I want to use something like http://http://m.ebay.com/itm/331082538313?nav=SEARCH&sbk=1 and direct the heated air into the fresh air box where the factory heat came in from heat exchangers.
Like mine here. Both heat and AC.
Still have to finsh this before next summer
Bob
Here's my heater thread...
http://www.914world.com/bbs2/index.php?showtopic=105071&hl=watercooled+guys+bellis
Here's marks914...
http://www.914world.com/bbs2/index.php?showtopic=70317&hl=
Considering this myself.
This is where I'm leaning. Please feel free to shoot holes in my theory.
Using a expansion tank with radiator cap as the highest point in my coolant system. With the addition of a couple more inlets and outlets or some fitting tee's you can have a small electric pump circulate water through the heater core branch and return it to the tank.
Heater core and heater core branch lines need to be kept lower than the top of this tank.
Ideally this would probably be mounted on the rear wall of the front trunk.
You could either run one leg of the engine-to-radiator coolant lines through the tank, or what would probably be cleaner would be a large tee in one of the engine-to-radiator coolant lines running to the expansion tank.
Wow, Bob, EXTREMELY sanitary! And you actually carry that broom around? Wow, that's above and beyond.
Seriously, that's excellent, are there parts details in one of your threads?
Yeah, I'm waiting for that explanation too! That looks like a hot setup.
Is this what you used Bob?
The unit you linked is one of the Vintage Air under-dash units; very different from the one in Bob's pic. The VA guys believe very strongly in recirculate-only setups, none of their units are set up to pull fresh air.
I think we all want to know what he's done there. 8)
Ah OK. I was trolling all his old threads...we'll just wait then!
I'm looking at this, thinking it may work well.
http://www.summitracing.com/parts/vta-506101?seid=srese1&gclid=CNi57s-JuLsCFYlDMgodzAYASA
I have seen the under dash ones. Renagade, Pelican and what not sell them but its a whole kit compressor and all. I would be happy with something like that if I could use the compressor from the subaru enigine.
Bob's setup is really cool. Would love to find out what it is exactly, but also how he figured out what would work there.
On another note, someone with CAD experience and a 3D printer could probably design something similar, once the proper heater core and fan were identified.
So, challenging one of the basic assumptions, it occurred to me that one could surround your Subie exhaust with some stainless sheetmetal, add the heater valve box thing from the 914 heat exchangers, and blow exhaust-heated air through your stock heater system.
Goofy idea? Sure, but it saves running coolant hoses to and fro...
I saved all of the SVX hvac system hoping to use it and the wiring harness. Even the dash vents and dash top and stuff just to understand how it worked before....would take a lot of work to integrate into the 914 but will try to figure it out someday. I'd hide the control panel somewhere so you can't see it...under the center console I have to build or the drivers side arm rest....
It's just this part....
I have a unit that came in a Rotary conversion. I think it's similar to the fresh air vent Mark is making. Except it had oil & water filtering through it. It also used the stock fan. Kind of fugly but very functional. Also pretty easy routing as it sits in the engine bay. So short lines going to your motor.
Just an opinion on drawing fresh air from the engine compartment on a conversion car. Unlike the stock 914, where fresh air is drawn from the top side of the motor/engine tin through the engine grill (fresh, un-contaminated source with constant flow), drawing air from the engine compartment on a conversion car (non-Porsche) and blowing it into the cabin is potentially dangerous. I'd be mostly concerned with CO, aside from oil fumes, or fuel vapor.
Andys
The svx evaporator and fan assemblies are too big to fit under a 914 dash.
I have the under dash unit from Renegade.
I'm wondering if it loses some heat running the lines under the car, as it is not real hot. I did wrap the lines with some insulation from Menards to help out.
Re: the stock SVX unit: They are BIG that's for sure. It's a big cube in stock form and could definitely not sit under the dash comfortably without modifications. My dash will be empty in the middle since I took all the manual heater and fresh air stuff out so there may be room for it (or some other system) to reside partially up inside the dash. I'm so far from doing this though...really just speculating with no actual knowledge at all .
I hear you. I saved all the hvac stuff from my svx, that's how I know. What would be ideal is a unit that could fit in the existing fresh air blower area. That way all the original vents and defroster vents could be used.
I've used McMark's system for 7+ years now and have found it to be very effective.
I also installed a "T" on one side of it to aid in bleeding the air out of the cooling system.
Modern heat without the burnt oil aroma...
I ordered this one today. I'll let you all know what happens when it shows up and I try to fit it in there.
http://www.summitracing.com/parts/sum-991102-1/overview/
the other benefit to AC is that it dehumidifies in the wet months
